Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. The case of the "Knocks"
  2. Airbag light is on... why? and how do i fix it?
  3. datamaster
  4. Tuning, Nitrous, and Race Gas...
  5. freescan log
  6. LT4 binary file....can i borrow one to look at?
  7. Tranny changes get good results.
  8. EE and EE_B def differences....i need some help please
  9. base stock tune for FAST?
  10. Started Tuning :)
  11. Tuning for 87 octane
  12. PCMforless tuning...
  13. recommendation?
  14. PCM SES light.
  15. how quick can values change?
  16. need a scanner for 94
  17. Need comparison file
  18. URGENT: tunercat owners read
  19. LT4 Tunning.
  20. info
  21. Need USB adapter for AKM cable.
  22. Free Gateway, IBM or Toshiba Laptop !
  23. Free Sony, IBM or Gateway Desktop Computer !
  24. pedal position decreases power
  25. How to turn off SES light?
  26. need stock bin file please!!
  27. Nitrous Tune vs Regular tune??
  28. bad PCM?
  29. Driver By Wire, new LS2 Electronic TB
  30. 93 conversion. No fuel. HELP!!!!!!!!!
  31. Burst Knock
  32. Question about Accel DFI Gen VI...
  33. skipshift light turn into shiftpoint light
  34. using a 94 cable to log a 95
  35. Tuning Question
  36. installed F.A.S.T. no start!!
  37. AutoTap - no parameters!
  38. Sanman?
  39. check engine light???
  40. TTS Datamaster Trans Question...
  41. GM ESI available online
  42. just how different is tunercat than lt1 edit? need to know best bang quick!
  43. Fooling the PCM to get the EGR monitor ready
  44. lt4 knock modulator???
  45. Wiring in a new Tachometer
  46. logging/scanning a 93?
  47. Weird WOT thing occuring.
  48. Speedo's out, replaced the VSS, PCM knows speed, Speedo doesn't...
  49. Cell 18 for WOT........
  50. No Speedo, Replaced the VSS, What should I check???
  51. datamaster
  52. Please check out blown Z .lt1 file
  53. anyone ever hear of this dude?
  54. o2 sims
  55. surge, data logs, tune file..need assistance
  56. Possible to mess up PCM by aborting a read?
  57. fuel tunning
  58. Computer Tuning Issues
  59. Lean code on banks 1 & 2.
  60. cant get connection on a 94 with datamaster
  61. tuning for idle with a/c on?
  62. AirBag/ABS INOP HELP (long)
  63. Air pump 2 electric h2o pump ckt
  64. software to tune
  65. A little help please
  66. Dyno day with PCMForLess - big increase
  67. need a Ed right file
  68. Cheapest, easiest, best way to reprogram for gears
  69. Normal, Hot and Cold mode in TC
  70. BLM Locker. Where to download?
  71. Pulling timing for Nitrous, what table?
  72. 93 speed sensor
  73. Hypertech Custome Chip Question
  74. MAF-translator be used to cure cam-surge?
  75. Looking for a Comparable Tune
  76. can i pass smog with cc305??
  77. quad driver
  78. Stock 94 Z28 Auto tunercat bin
  79. lt1 tune w/ cc306 & 1.6:1 rr
  80. Programming Retard for Nitrous/or msd?
  81. Hard to Start for Awhile, Now SES and DTC's
  82. Anyone bored? Take a look at my PCM .bin and DM log.
  83. hotcam .bin vs. zz4 .bin
  84. Cheao tuning laptop on ebay
  85. Can't get PCMCIA card to work with Datamaster???
  86. disabling vats didn't work, how do i do it.
  87. Cable Compatibility (AKM or Moates with Turbolink)
  88. MAF Calibration Tables
  89. Removing Cats?
  90. VSS used for engine operating parameters?
  91. Changing degree extension
  92. where to buy tunnercat?
  93. Running a little rich
  94. Want to invest in a scanner
  95. In Datamaster how can you tell if your rich/lean? roughly
  96. PCM Reset, BLM=120?
  97. Base tune for cruise
  98. problems with current program..lean
  99. PCM for less owners
  100. Tuning Methods
  101. Link error
  102. Looking for a base LT-Edit program for a SC LT1.
  103. OBD1, Code 48 MAF Circuit Problem
  104. speedo/turn signal
  105. anywere to download
  106. mystery injectors
  107. ls1 and lt1 maf interchangeability and part numbers?
  108. Where to download tunes from....
  109. OBD1 to OBD@
  110. Timing, Which to Believe?
  111. ses light for code 43 esc failure? obd1. what does this mean?
  112. Power-washed engine- BLMs to 160 both sides
  113. this ever happen to any of your hypertech guys?
  114. OBDII: Code 100 and 1657
  115. Wierd data ideas for me running out of them!!
  116. Just scanned car don't know what to make of data
  117. Local to NJ for LT1 tuning
  118. pcm bad?
  119. Please help with the programming for my TC!!
  120. Jumper cables to mate Xray 12 pin cable to 16 pin connector
  121. Question about Powerporgrommer 3 with 4L60E
  122. Going to buy a 97z28 soon.
  123. need a tune
  124. Light throttle closed loop tuning tips needed
  125. Alarm trouble
  126. What's wrong with my speedo???
  127. 108/160
  128. Deleting Tranny
  129. 94 Z28/A4, stock... can someone recommend me a tuner?
  130. No connectivity from data port
  131. Using cells 17 & 18 SO MUCH, and what's going on with the CCP ????
  132. Bump timing up to 50+ ????
  133. Is Autotap worth the $$$?
  134. just ordered tunercat ! want to learn to tune on own any ideas ??
  135. new 381ci LT1 ecm concerns.
  136. Data logging software....which one is better?
  137. MSD6al+datamaster=trouble
  138. 1993 Chip Programming
  139. anyone want to look at datamaster file?
  140. fixing pcm
  141. best place for a dyno tune???
  142. Hypertech Programmer with a 4.10 gear
  143. LS2 LS1 LS6 Dyno tuning now available
  144. Malf 44 & 64
  145. Whats this "freescan" you use?
  146. PE IDLE- LT1 Edit
  147. Can someone take a look at this freescan files files for me?
  148. Wanting to purchase tunercat for obd-1 and 2 few questions
  149. Painless Engine Management System
  150. Injector constant for 42#
  151. slotting tps on BBK 58mm T.B.?
  152. Converting PCM from M6-A4
  153. EFILive 5.26.8
  154. Whacky trouble code
  155. Have Ses Codes For 1991 Camaro, How Do I Know What They Mean
  156. how to test voltage?
  157. False knock problem.
  158. Is USB available for obd1 lt1 edit?
  159. Take a look at my closed loop values
  160. Can't read the PCM
  161. Low Coolent Light ON???
  162. will i lose my tune if?
  163. Need to extend wire harness that goes over passenger fender. Will This...
  164. Lost my PCMforless bootable floppy, need help ASAP.
  165. i need the basics
  166. Electrical gremlins.....need help ASAP
  167. Data Logs
  168. what to do with timing...
  169. LS1 Injector In Lt1??!?!?
  170. Tunercat demo version question
  171. "Invalid Response from PCM" TunerCATS 2.08
  172. Change Oil Light
  173. fuel tables
  174. Tip in throttle is always lean
  175. tunercat...easy to use?
  176. Stumble off idle
  177. Datalogging software comparisons
  178. which is left O2 sensor in Freescan?
  179. scanner ?
  180. P1441 EVAP code... help
  181. Fried my pcm, where do i send it to get rechipped?
  182. LT1 Edit fuel tables
  183. my 297rwhp cammed car now has been logged. please help.
  184. deleting egr with tunercat
  185. Autotap users inside pls
  186. engine managment
  187. Tranny Not Down shifting and TCC - Need Some Help
  188. How to make tranny shift faster...
  189. Code 1133....
  190. How do you keep OBDII PCM in open loop?
  191. Autotap (BDII LT1) lists two sets of LTrims for bank 1 and 2, whats the difference?
  192. anyone have any experiece with madz28
  193. Question about Fuel Gage needle
  194. Need Help...tach problem.
  195. Malf 48: maf system fail ??
  196. need EFILive logging tool! HELP!
  197. Stand Alone EFI systems
  198. Autotap or Datamaster for OBDII
  199. Where can I get VE Master
  200. Using Scanner on OBD1 conversion
  201. Possible to run 42 lbs with OBDII?
  202. Hypertech (hypercrap) programmer problems
  203. 97 keyfob w/ 94 TA???
  204. Piggy Back Harness?
  205. newbie here...need some help
  206. Where to start (added 52bbk, 30lb svo's)
  207. Weird stuff on scanmaster ,car or scanmaster what you think?
  208. SES light still on!!!
  209. Keyless Entry Programming?
  210. Programming out hesitation on tip-in? (big injectors)
  211. CAM - Carolina Auto Masters - Jeff Creech
  212. Timing questions
  213. Black smoke on dyno...
  214. Where can I buy LT1 Edit??
  215. SES light and codes
  216. finally ordered the tune
  217. used TunerCat OBDll, now car will not start... flashing SES light???
  218. How do you obd1 guys check your ses lights?
  219. ob1 ses lights
  220. Still getting knock at 5krpm...
  221. Tried everything but wont shift at WOT!!!
  222. 20 gps MAf at idle?
  223. ODD DTC Errors
  224. scan problem
  225. hypertech question
  226. Diagnostic Programs
  227. Question about SLP Camaros
  228. yes, i did a search, and no i didnt find a response.
  229. hard to start when warm
  230. Anyone have PCM flash capabilities??
  231. Can someone verify injector serial numbers?
  232. Base program for LE2 head and cam package
  233. 94 LT1 computer woes
  234. OBD2 PCM with Stand alone??
  235. Any way to tune for gears without HyperCrap?
  236. strange blinker problem
  237. I hate paying the dealer $90 for a scan
  238. Second PCM fried by TUNERCAT!!!!
  239. Car won't start... pcm???
  240. Adjusting MAF
  241. Lots of tuning problems :(
  242. anything else besides lt1-edit?
  243. Ion?
  244. PE idle....
  245. LE2/GM847 bin file?
  246. 94Z28 SES light ?
  247. I am having problems with Tunercat OBDII
  248. obd I question
  249. I have a laptop and the right cable...
  250. Anyone Here Make A Speedo Recalibration Box?
