Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Help getting cable to work
  2. Scan tools
  3. Base tune/start up tune For FI eng
  4. SES light flashing
  5. what a/f ratio ??????
  6. Currently Avalible OBD1 tuners
  7. Building a PC in the glove box?
  8. Early LT1 high stall shift problems
  9. need help w door locks
  10. LS1 edit question?
  11. 2 Questions --> 1. TunerCat 2. General Tuning
  12. Adjusting MAF tables.
  13. props to pcmforless
  14. Tuning for 4l60e-to-700r4 conversion?
  15. Usb/serial port adapter for laptop datamaster
  16. Free Scaning Software
  17. obd1 to obd2
  18. diy cable
  19. experts in tuning please, can someone take a look. I WILL PAY FOR SERVICES
  20. Datamaster file with a cc306 cam?
  21. tuning prblems with my 97 ws6
  22. Important LT1Edit Info!!
  23. LT1 Edit install HELP
  24. computer Q
  25. Closed Loop Timer in OBD2
  26. OBD2 to OBD1
  27. Change Connector - Help
  28. New to self tuning. Tunercat or LT1 Edit?
  29. aldl converter
  30. LT1 Edit,383 tune Help!
  31. What years were OBD1 or OBD2, what years were MAF, MAP, both?
  32. Freescan Help
  33. Help with reading Datamaster
  34. Spark Retard
  35. Spark advance fluctuation at idle solution
  36. spark advance?
  37. Car running rich after new injectors
  38. Codes question
  39. fuel problem while crusing
  40. what is VEmaster and can someone explain BLMs?
  41. my obd II
  42. Basic bolt-on OBD2 LT1 log file...
  43. How do you set a LT1 for open loop, in OBDI and OBDII?
  44. Issue with Impalae idlign low rpm timing commanding
  45. OBD1 tuning program options
  46. need stock 96/97 tune
  47. Problem with windows xp and flashing computer
  48. Does anybody have a list of ideal sensor readings for an lt1?
  49. my obd II
  50. H/C 400RWHP LT1 dyno or mail in tuning???
  51. computer bad???
  52. Gen 7 dfi questions?
  53. hypertech programming question
  54. Problems w/block learn at idle
  55. Didn't know this would work
  56. Has anyone tried PCMSCAN?
  57. Removing Jet Chip
  58. Newbie to Tuning
  59. Cheapest place to get a cable for a 97 Z
  60. 96 OBD2 parameters - what will keep it from starting
  61. clearing codes
  62. Changing AF in Open Loop?
  63. Got a PROMinator
  64. car runs real rich at WOT...
  65. Turning off Air Pump and EGR???
  66. Cam Surge and Closed Loop
  67. data logging OBDII ???
  68. Understanding PE mode
  69. OBD1 ALDL protocol questions...programmers, help!
  70. Question about Jeff Creech
  71. anyone have a tuned bin file?
  72. autotap
  73. Tuning Supercharger
  74. Speedo Correction w/ TH400
  75. Tunercat help
  76. What to look for in an Inexpensive Laptop for Tuning?
  77. Do I have to change or reprogram my stock computer after I put a 383 crankshaft in?
  78. free scan ?
  79. Put in computer and got a code...guys come in and let me know!?!
  80. Fast files to share?
  81. What needs changed?
  82. Anybody want to check out my tune?
  83. MAF tables
  84. anybody know about code p0300
  85. updated tunercat
  86. Will Freescan work on a 95 Lt1?
  87. LT1 edit update.
  88. need help with edit???
  89. how in depth can an ecm be programmed?
  90. freescan csv file, all zeros?
  91. need quick help with shift light install????
  92. Can anyone help with a S-10 lt1 conversion
  93. 02 sensors question
  94. What timing adv is everyone running?
  95. Difference between high cool and low cool
  96. big cam and vacuum ?
  97. What are the throtle follower tables?
  98. How important is....
  99. ordering tunercat definition file
  100. Best Wideband Sensor?
  101. Something new in Summit
  102. Question regarding Injector..
  103. tunercat EE vs. EEB
  104. Tuning OBD2 cars with emission testing.
  105. How to lean out my tables in my PCM???
  106. Short term max
  107. Engine starts, then stalls
  108. Diagnostics connector pinouts
  109. Need guidance
  110. n00b question on a 95 3.4
  111. Aem Wb
  112. Best Tuning software/ cable for 94 LT1
  113. computer mounts
  114. Megasquirt opinions
  115. Usb Comport Adaptor
  116. Code 57 pulled from BCM
  117. Speedo calibration
  118. OBD1 conversion
  119. Best tuner in Colorado/New Mexico/Utah/Arizona
  120. need a 94 z28 bin file
  121. 11.45 volts ok for MAF to work properly?
  122. Tunercat Help
  123. diagnostic troubleshoot codes
  124. First Time DataMaster user...Need Help!!!
  125. MadZ28 Rocks
  126. malf 97 and haywire speedo
  127. Tcs Switch
  128. which data scanner to use?
  129. Computer Swap
  130. Running a TH400 in a 96 ODB II Z28.
  131. Tunercat $EE file
  132. tuner car ?
  133. need help deciding on tuning
  134. Will this scanner work on a '94?
  135. Any Hp Tuner's in Texas?
  136. How dependable is VE master?
  137. Malf 24 Datamaster Code
  138. Tuning to make stock LT1 pass sniffer w/ no cat
  139. Datamaster or other scanner..
  140. My Doors Wont Lock Or Unlock!!! LS1
  141. ABS tied to the PCM?
  142. Help me decide/Laptop to 95 z28. want to edit pcm/view/erase codes/and view obd ii 2
  143. Very interesting OBDII emissions test results
  144. Freescan help!!!
  145. Datamaster Rpms Variances(T.C. Adjustments)
  146. No knock count but still pulling timing???
  147. Convert LT1 to wideband o2?
  148. Tuning ? For beginner
  149. Ion, tell me something
  150. What can i tell from Datamaster.
  151. extending oxygen sensor wires
  152. Idle adjustment??
  153. GM TECH 2..question
  154. GM Tech 2 Question...
  155. 02 sensor can cause knock retard....
  156. quick C.A.T.S tuner help
  157. Need DTC Def. Help
  158. dfi dyno problems
  159. Tunning a Nearly Stock GMC Denali
  160. seral to usb
  161. my long term fuel trim jumps (normal)?
  162. Welding on car... PCM precautions?
  163. Need a starting point for revised BLM boundaries
  164. imposible diagnostic *MAF glitch*
  165. PCM reset before every start? why?
  166. OBDI Conversion and High Idle
  167. Help with Freescan!!!
  168. Freescan Help!!
  169. Help with tuning
  170. fast ecu
  171. P0400 EGR & P1361 Codes on OBD2 LT1
  172. First day of dyno tuning yesterday; yikes...long
  173. Strange Idle Surge
  174. BLMs at 160 all the time?
  175. Throwing codes - MALF 26,27,29
  176. PCM programming - suggested settings?
  177. what size injectors?
  178. How to save stock programing, updating to MADZ28 tune.
  179. Are there ANY companies that actually sell cables ?
  180. A way to disable KR at WOT?
  181. Palm Pilot Data Logger?
  182. Need help with code po1629
  183. Very cheap PCM cable
  184. LT1 Tuning Q.
  185. AF question?
  186. Tuning a vette.
  187. Torque converter solinoid signal
  188. AEM wideband...?
  189. Checked out my cable ... is this right ?
  190. Datalogging Problem
  191. SES code
  192. Fuel pump signal out of PCM
  193. scan tool(obd2)
  194. does anyone have a stock bin from a 93 Z28
  195. Need help getting Datamaster to work on my laptop with PCMCIA card!
  196. hypertech power scan program
  197. PCMforless vs. MADZ28?
  198. quick hypertech question
  199. Please help w/a code
  200. Idle problems
  201. hot cam to cc305 do I get flashed
  202. LT1 with No Spark or Injector Pulse
  203. Freescan for Electrical Faults
  204. OBDII vs OBDI in a OBDII car good or bad
  205. Laptop for tuning/Good deal or not?
  206. props to madz tuning
  207. hypertech or custom chip??
  208. Program or not to program
  209. '96 M6 .LT1 file needed
  210. 95 lt1 m6 file needed
  211. MAF max freq fail
  212. Loading Gen 7 on a Gen 6 Accel system?
  213. 2001 V6 Camaro tuning...
  214. Open Loop Question/ Bog off idle (Wideband)
  215. O2 Sim. installed but S.E.S. light still comes on???
  216. scanmaster ?
  217. code-bank 1 sensor 2
  218. free scan
  219. 95 3.4 jet chip question
  220. OBDII question
  221. Programmers/Tuners--- inside please
  222. Questions about rear O2s
  223. AKM cable guys/gals....
  224. people with good tunes
  225. LT1 A4 to M6 PCM Ques
  226. Problem downloading trial version of Datamaster
  227. Help please?
  228. Wires required for ALDL connection
  229. Question about lowering injector flow rate
  230. Larger T/B Where to start tuning.
  231. Splicing into PCM harness
  232. Target AFR on the Dyno
  233. Injector Fault?
  234. Diagnose problem. 1/2-3/4 throttle car "misses"
  235. Lean spike before WOT
  236. Need help with Service vehcile light!!!
  237. Programming for cc305 w/ lt1 edit
  238. easy tunercat questions
  239. Programming out ABS
  240. file needed 95 z28 t56 with 3.73s
  241. interpreting ecm data
  242. diagnostic tool info
  243. Tuning for driveability using Datamaster and TC
  244. Cold starup require more fuel?
  245. Tuning to eleminate predetination
  246. LT1 Timing options
  247. electrical problem
  248. is there anybody with the answer?
  249. looking for tuner in 4 courners region.. Co/Ut/Nm/Maybe AZ
  250. problem with idle surging in an 89 iroc datamaster-32
