Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. sp2 and datamaster users
  2. More LTCC question
  3. Enabling Traction Control on non trac control cars
  4. Can I delete this?
  5. Is it possible..? advanced PCM hackers inside
  6. obd2 lt1edit
  7. Help, which Hypertech to buy?
  8. Code 11 any help confused
  9. Attention: madz28 and all others welcome
  10. Finally, a LT1/LS1 Dyno Tuner in Northern California
  11. Fitting vortec pcm into lt1 opti elimination
  12. what knock sensor to use
  13. Tuning Computer in DOS (TTS Datamaster)
  14. flashing a computer
  15. WOTelectronics trouble/ contact info?
  16. tune help needed
  17. Need Someone to tune pcm
  18. OBD-II connector pin-out; and SES light pcm pin.
  19. Heeeelp... Gauges no signal
  20. 88 iroc gauge problem
  21. F.A.S.T. and other aftermarket computers
  22. Reprogram LT1 Computer
  23. tune problem
  24. Deleting EGR in LT1 Edit
  25. FAST & delteq
  26. "incorrect message sent"...
  27. home made cable problems?
  28. Lt1 tunning in Oklahoma
  29. hppIII On My Auto Ls1 . Yep Iam retarded .
  30. Syclone programming?
  31. PCM questions for LTCC
  32. using 95 obd2 style connector on obd2 car
  33. Help posting/reading freescan log (FRED or another guru)
  34. LT1 Edit
  35. WOT timing on a blown stock LT1
  36. Aftermarket EMS
  37. Transmission Needs Programming
  38. new to DataMaster question
  39. Looking for a tuner in southeast florida
  40. What is needed to use HPP cable?
  41. Tuncercat
  42. help LT1 edit 6 speed program needed
  43. Is my motor running rich or lean??
  44. Tunercat:car feels weird after I reprogrammed for gears
  45. new motor programming needed
  46. Anyone have any 99-01 LS1 tunes or 5.3, 6.0??
  47. Security System
  48. 383 datamaster run falls on its face
  49. Need a programmed Lt1 or bin for 373 gears A4
  50. New Parts, want to buy a tuner prog, suggestions
  51. USB-Serial Converter w/ datamaster
  52. Autotap or tunercat
  53. Need a "flagging" tool/option
  54. Failed emmissions. Need tuning advice.
  55. Fuel tables in TunerCats
  56. Need Corvette M6 File
  57. Did I damage my ECU?
  58. BS3 manual
  59. USB-Serial Converter or PCMCIA in DOS Mode
  60. could the OBDII response, be faked?
  61. Best/easiest way to tune my car?
  62. Where is this extra timing coming from???
  63. OBD scanner 1 or 2 ?
  64. wanting to get Madz28 email tuning, which akm cable?
  65. Help with check engine codes
  66. Tuning Mailing list
  67. Engine knock?
  68. leaning out at high rpm
  69. New transmission...What needs tuned?
  70. new power lock actuator or new BCM?
  71. Need help with getting my pcm programmed
  72. ECM going bad
  73. 94 LT1 issues
  74. Sample BIN
  75. need help check engine light is on code p0400
  76. those with 32# inj. need tuning info please
  77. Brake light is stuck on??
  78. Would this laptop work well with tunercat/LT1edit?
  79. Redhat scantool?
  80. Help-quick!
  81. BigStuff Gen3
  82. Datamaster Help translate
  83. Reprogram for cam
  84. Datamaster log file
  85. Vats System..i think
  86. best data loger
  87. Cable failure in cold weather?
  88. Computer Location on 01 Z-28???
  89. Beginning tuner help
  90. Car sucks, can't find Madwolf
  91. anyone know if this is a good product for tuning or not?
  92. FreeScan Flagging Tool COMPLETED inside
  93. PCM Tuning 95 Z28
  94. datona sensors wideband
  95. How Do I Reprogram My Stock Keyless Entry?
  96. hptuners ever gunna maket lt1 obd2 version?
  97. PO Code
  98. *NEW* Mail order LS1 tuning by HPE
  99. Is it true that the factory computer is only good for 7,000 rpm
  100. Will someone take a look at a log for me? .uni Datamaster?
  101. 2 computers better than one?
  102. How do i tell if my car has been programmed?
  103. reprogrammed pcm
  104. A4 Tranny setting help
  105. help! no fire from coil
  106. diagnostic ports
  107. Leaning out at idle with 72# injectors ?
  108. SES: Code 420 Caused by bad gas?
  109. DTC P1153 problem... (long story!)
  110. I need a pinout diagram for a port on the computer.
  111. Anyone have the latest $EE def from tunercat?
  112. Repinning a harness
  113. Datamaster Injector Duty Cycle
  114. I want to tune, but what laptop?
  115. Want to examine a .uni file?
  116. OBD2 LT1 edit question
  117. Need info on Tuning LT1
  118. Manual for TunerCat?
  119. Injector sizing
  120. Shift firmness question??
  121. Want to learn to tune
  122. what diagnostic/scanner tool to get
  123. SES Codes After Header Installed
  124. Using skip shift light as a shift light?
  125. Emulators
  126. Third Gen Computer Tuning
  127. need bin files. for my site. please read
  128. Hook computer directly into data/diagnostics port?
  129. delphi/lucas inj offset vs volts (where can i get it)
  130. EGR problem, Need 2bar MAP for SC application?
  131. reseting the ECU codes
  132. ODB1 or 2 Plug
  133. Very different O2 readings.
  134. LT1 ScanMaster.
  135. car was converted obd1, need help
  136. E-mail tuning
  137. RT tuning a 93 pcm, then flashing a flash prom
  138. OMG....got 20* of knock retard
  139. Chip Question
  140. Do LS1 cars have a "black box"
  141. How can I dump my chip info onto my laptop?
  142. 383 Tune running very rich....
  143. 383 in finally but....
  144. obd 2 to obd1
  145. quick ls1 ecm question
  146. TPS minimum voltage
  147. Scanmaster vs Datamaster display units
  148. New cam and car won't stay running
  149. obd1 question
  150. 94 trans am what other than lt1 edit to tune?
  151. PCM question.
  152. Tunning My LS1...
  153. Having A problem running LT1 edit on my computer.
  154. I need of tunning for my 383
  155. taking care of business....one SES light at a time
  156. Safc Ii
  157. tunercat shift point questions need help
  158. Need someone to look at this datalog and tell me why my car runs like CRAP! PLEASE!
  159. Building an impedance converter
  160. More on the dtc P0300 multiple cylinder misfire
  161. PCM Tranny Change
  162. OBD2 PCM edit options
  163. Need some info (HELP)
  164. tunercat forum
  165. LT1 to LT4 mods
  166. Learn Mode
  167. looking for tuning in dallas area
  168. OBDII Scanning Solution Needed
  169. OBDII to OBDI conversion, what about emissions scan?
  170. only knock sensor pulls timing??
  171. What's the Best diagnostics software?
  172. Help with new chip!
  173. Free scanning w/ computer
  174. (un)Usual communication problem?
  175. Tuning
  176. tuning for a 2 bar map? Ion?
  177. Auto and Manual OBD 1 PCMs identical?
  178. LT4 timing charts
  179. DTC def?
  180. GM Tech II and HP Programer
  181. Tuning VE tables
  182. Custom Tuned...will it be lost if car loses battery power?
  183. Is this a change to make for a 58mm throttle body?
  184. Please check out my datalogs and see what you think.
  185. custom tune
  186. Sensors...sensors...sensors!!!
  187. USB to RS232 adapters for my AKM cable????
  188. How to tune out CAGS with LT1 edit?
  189. how to compare files
  190. Sd ?
  191. need advice on OBDX computers
  192. Tuning Methods
  193. 93 Car, change to 94 Computer?? any info?
  194. Holley 42lbs injectors
  195. just had car madz28 tuned..
  196. air/fuel reading from Autotap
  197. Issues with AKM cables ...
  198. trip meter not functioning
  199. Tazzo VPC VS G-Tech.
  200. CarChip Scan Tool...is it worth it?
  201. line pressure tables for vacuum modulator
  202. does anyone know how the spedometer works? *Prize for help*
  203. hooking up shift light...
  204. just got in my pcm!!!
  205. Could this be OBDI high stall issue?
  206. kickdown downshift table
  207. every single knock retard table zeroed out, still pulling timing??!
  208. "Closed Loop Idle Vehicle Enable Speed"
  209. Realtime MAF translator
  210. power programmer question
  211. Looking for some '730 help
  212. ATTN Shoebox...I need your help!!!!!
  213. Dyno tuning?
  214. 1994 PCM Info
  215. What 02 mV for 14.7?
  216. Key Fob programming
  217. Any one tuning LS2 yet?
  218. quick TTS datamaster question
  219. PCM tuning?
  220. Question about programming
  221. A/c delete w/ odb2 needs tunE? +misc questions.
  222. Tuning for !EGR! and !AIR!
  223. A/F tuning with tunercat question please...
  224. Change VIN's on edit files?
  225. big cam LEW heads long tubes obd1 conversion smokes white and smells rich?
  226. Please Help, Reflash, which PCMCIA?
  227. Bad Miliage & Autotap ???
  228. OBD I Scanners
  229. Predator 2
  230. I'm in need of a BDLD bin
  231. Do computers default when power is lost?
  232. OBDII LT1 PCM's and emissions... I need an authoritative answer on this
  233. cords
  234. scanner readings on ignition timing
  235. Any cure for false knock due to piston slap?
  236. Cell 18??
  237. Adding 30lb injectors
  238. Datamaster install help
  239. MAF sensor code
  240. Any dyno tuners in socal/Los Angeles area?
  241. Tunercat error - INCORRECT MESSAGE SENT
  242. Carputing
  243. All Kinds of Tuning Woes
  244. Heads/tuning
  245. just ordered tuner cat. any advice?
  246. Not Going to Closed Loop
  247. Data Cable
  248. Can someone help me interpret this log
  249. HC's, Open Loop and My Car HELP PLEASE
  250. only 1 o2 sensor with fast?
