Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. help me out with upping the line pressure...
  2. injector and tuning question?
  3. Will TunerCat work with the L99?
  4. How to download Datamaster, site is not working?
  5. got ls1 edit programmer installed today and still doesn't have 2nd downshift at wot
  6. Just Installed my Scanmaster and have a couple questions...
  7. T56 Swap into 93...VSS Problems...
  8. Tuner Cat - Need Stock 95Z Auto Bin
  9. Anyone have a good stock head hot cam file??
  10. LT1_edit 2.2
  11. datalogging issues
  12. where can I buy LT1 edit and the proper cable for OBD1?
  13. accel 300 and 375+ unit ,Good???
  14. LS1 scanmaster......need info
  15. Maf translator and gms conficts..???
  16. autotap 2.05 questions and problems.
  17. Ques. about main spark advance vs. rpm vs.map
  18. VE Tables And Air Fuel Ratio?
  19. Question about tunercat(re: tranny line pressure)
  20. LT1_Edit help for Air Fuel Ratio Tuning...
  21. Tuning help for newly installed 383 OBD1
  22. Is there LT1 edit for 93's
  23. Heads up Display anyone?
  24. Knock count going bizerk
  25. DFI and Delteq?
  26. Quad module driver.
  27. 1995 Z28 Camaro
  28. Just got MadZ tune, but.....
  29. Tuner, Or Rt Tuner (tunercat) For My 95'ta?
  30. Ditching VSS signal ... consequences?
  31. Scanning OBD-2 pcm IN A OBD-1 car???
  32. Need help with datmaster
  33. 383 stroker help
  34. Knock Retard Everywhere!!!!!
  35. Need pressure Accel 30#'ers are rated at
  36. Delteq's ECU
  37. Tunercat help on transmission functions
  38. Tuner help
  39. WOW - this thing is rich
  40. Help! Data errors!
  41. ok, i have
  42. Where to get the male connector for my akm cable?
  43. 383 STROKER<SPARK ADVANCE AT IDLE>?
  44. Locked Programming?
  45. Anyone have a copy of LT1 edit?
  46. Vats
  47. Does anyone have a-->>
  48. Can someone look @ a freescan log?
  49. Quick Kpa question please...
  50. team zr1 tuning vs madwolf, anyone ever had tuning by team zr1?
  51. Sudden Surge in Power... PCM problem?
  52. o2's appear low on one side
  53. help, blown something!?
  54. cheap laptop serial port addon
  55. PCMCIA to USB Adapter
  56. Help needed- LT-1 engine swap into v-6 95 Camaro
  57. Scanned PCM quick?
  58. Price of Ignition and Computer in '84 Camaro RS?
  59. Possible O2 sensor problem...Gurus inside!!
  60. 93 camaro supercharger program
  61. car tuning ? please
  62. false knock?
  63. Editers/Tuners
  64. Minimum value in inches that will set a MAP code
  65. Injector offsets for Siemens 57lb injectors?
  66. computer question
  67. deprate! need help with my Mallory box!
  68. Need a tune
  69. i broke it
  70. Idle spark advance?
  71. Formula for changing injector constant when changing fuel pressure
  72. security light??? (VATS)
  73. Help..ERROR Messages Reading 95 Z28 OBDII
  74. Speed Limiter Elimination?
  75. PCM, Sensors,.....
  76. Datamaster issue
  77. Removal of VATS
  78. Replacement PCM needs my VIN in it to use edit
  79. Cable Question
  80. Cold misfire/hot and cold performance?
  81. Injector #8 stays open.........................
  82. wideband readings at idle with a big cam with lots of overlap
  83. My Cpu Burned Out
  84. obd 2 cable
  85. 2.8L computers? Same as TPI???
  86. What do I need for TunerCat programming?
  87. Stock 1993 Bin for manual (m6)
  88. Few supercharger tuning questions please...
  89. So what can I expect from a dyno tune?
  90. VSS Myth Fact or Fiction?
  91. Removing pcm batt power?
  92. Changing tunercat table listings
  93. Fuel guage problem
  94. ? on Tuning for Accel Injectors
  95. Module Test
  96. How much good does the Power Programmer do?
  97. High BLMs, low fuel mileage, what gives?
  98. SES code 1642
  99. MAF Readings Peaked
  100. Scan Software?
  101. Scan Software and cables?
  102. Have a ? about Fast and my new Throttle Body
  103. Can I just get any old shiftlight or tach for my '95 LT1?
  104. mad z tuning for almost stock car?
  105. MAF Tables for Cold Air
  106. The dreaded Knock after Shifting....
  107. Can anyone look at my datamaster file...
  108. how do you lock the blms to cell 15
  109. 94 LT1 PCM Diagram - HELP
  110. Cant seem to get open loop idle to work.
  111. ? about A/f ratios and power
  112. p1870 code?
  113. Changing injector size
  114. wont shift at wot. lt1 edit guys in please
  115. Cannot connect to PCM with lt1edit...Fuel pump not priming.
  116. new gears, after tune, still hitting limiter on 1 -2 shift
  117. need LS1 edit help asap...gotta set my injector tables back closer to stock!
  118. I'm wanting to get
  119. EXPERTS in here, I have a SERIOUSLY strange Air/Fuel Ratio issue. Need ideas !
  120. predator tuning
  121. Left and Right pulse widths are different, yet BLM's and INT's are locked to 128??
  122. Will aftermarket tune fail emissions?
  123. Can post o2 exhaust leaks cause faulty o2 readings
  124. Is there a detailed website explaining how to use LT1 Edit?
  125. Looking for 8# blower tune w/42# inj.
  126. Data logging for a '96 OBDII
  127. Turning off Traction Control
  128. Modifying ASR on the LT1
  129. Different ways to get IAC count
  130. No juice..but batteries good??
  131. WOuld anyone mind checking out my scan logs?
  132. I need help with my lap top to PCM conection
  133. Anylize my WOT run log.
  134. Anyone have an FAQ for programming?
  135. PE seems to be affecting open loop idle....
  136. help with timming ????
  137. Will Tuning for Nitrous effect N/A dyno numbers?
  138. hp tuners anyone familiar with this?
  139. LT1, not reading key, no communication with computer
  140. Did I have my first tuning "oh sh#$"
  141. Service Engine Soon light - garage can't access database
  142. Who can program a chip for a 93 LT1 Firebird?
  143. Wot electronics OBD I cable?
  144. Question about waste spark ignition
  145. How to change Max MAF fail point
  146. Non-SES stored codes on OBD1 cars?
  147. HELP! O2s all over the place
  148. datamaster....what is CCP DC
  149. EFILive
  150. '95 OBD II Connector to OBD I conversion
  151. Need LT1edit file for xe 224/230 cam.
  152. OBD II editing software
  153. 383 datamaster file 12.4 pass something wrong????
  154. LTs w/out the use of STs
  155. Jet Stage 2 PCM, Worth Buying??
  156. Code 36
  157. Can you fry a PCM will reading it?
  158. LS1 Edit
  159. Scanmaster Spark Timing Results & Question...
  160. Computer not communicating with trans??
  161. Where to get software?
  162. LT1 Edit Comm Error
  163. Getting a ODBI PCM to work on a OBDII car?
  164. Another Thumbs Up for MadZ28.com Tuning
  165. engine off...knock counter still going
  166. Tunercat for ODB2 - Wassup?
  167. Tunercat Help
  168. pcmforless tune
  169. 4L60E in Limp mode?
  170. TunerCat question?
  171. What laptop???
  172. need info
  173. Need some help converting .lt1 file to .bin file?
  174. Computer tuning for LS1
  175. Anybody know how to reset Hypertech PPIII
  176. anyone use dynotex in san antonio
  177. Examined a Hypertech chip from a 93Z, results within.
  178. PCMCIA card problem with LT1 Edit
  179. Readings on scanning tool question?
  180. A little help with Tuner Cat?
  181. Scanner for 93 LT1 cars.
  182. Problem with OBDI port not communicating, V6-V8 swap
  183. Coding 95 Z28(OBDI with J1962 (OBDII) connector
  184. I have a million and one questions, Hp tuners...
  185. Extended Crank Period
  186. FAST and OBDII users inside
  187. stall wall
  188. Datamaster won't work but freescan does
  189. xe230 236 base tune needed
  190. Do you need integrators for block learns?
  191. can i upload a tune from another car to mine?
  192. why is my AFR constantly going to 9.6 on WOT?
  193. Possible Bad PCM
  194. A4 trans limp mode
  195. If Serial port doesnt work...try PCMCIA???
  196. Need dos upload program
  197. HPP questions
  198. Please Help Code 13 02 Open Circuit
  199. Using Laptop To See Engine Info
  200. Bosch 30#?
  201. Does locking integrators at 128 = open loop?
  202. High Stall Problem
  203. In Car Computer
  204. Just got my hands on laptop... where do i start?
  205. Idle issue
  206. auto comp in manual car
  207. Tach Signal???
  208. How do I fix rich open loop idle?
  209. Code 36 and 42 problems
  210. Turning off knock sensor....
  211. Tuning quesions
  212. Programming install question.
  213. 383/Turbo tuning
  214. Please Help!! Wiped out PCM!!!
  215. Help identifying wiring harness
  216. tunning question
  217. ABS INOP...getting annoyed now...
  218. Tuning for cc306 & 385 LT1
  219. HPtuners/EFI live all info needed
  220. CKP Sensor unplugged - Ok to pass emissions?
  221. Just starting out with tunercar have a few ?'s
  222. Communication Error
  223. Idle PE mode guys inside
  224. Taking out battery mess up computer??
  225. ABS inop
  226. changing to obd1
  227. Can I add a switch to turn Traction Control on/off?
  228. ODB1 - Code 26 Help!
  229. biggest injectors on stock pcm
  230. 94 vs 95 cpu
  231. neeed a program
  232. Looking for a 306/stock heads tune!
  233. autotap: 1 question
  234. Is there a crash course I can take to learn Tunercat?
  235. Stock OBDII M6 tune needed for conversion
  236. CODES 34 & 44 PLEASE HELP
  237. TPI computer programmer
  238. Dyno Tuner in Toronto area!
  239. News Flash!! TUNERCAT OBD2 TUNER AVAILABLE NOW!!
  240. Aftermarket TB Drill Mod, Who's done it???
  241. 2bar+ support for DA cars.
  242. Bad LT4 knock module?
  243. BLM Locker Issues on a 93 SD car
  244. computer help
  245. CKP - Reading a Negative 15???
  246. Thrown codes: P0135 & P0137; after LT install
  247. obd 1 to obd2 conversion
  248. can i see datamaster log in excel?
  249. 93 z28 383, is it worth the money too...
  250. taking out fuel
