Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Quick ??
  2. Help reading Freescan file
  3. OBDI Conversion
  4. Flashing "Change Oil" light
  5. CD Player - need help
  6. Looking for FAST file- blown 383
  7. ABS Scan Codes/Scanner
  8. Spark, but no fuel or RPM after FAST install
  9. wiring
  10. Desperate, posting everywhere. Why the low MPH?
  11. RPM drop going into gear (a4)
  12. looking for VE table from a large cam speed density tune
  13. Tec3 Computer
  14. Can a bad tune cause this problem?
  15. Security light/ Pass key problem
  16. programmed pcm learning curve
  17. ????????
  18. Cruise mode shift points?
  19. Odd 02 readings
  20. Please help with car shutting off!
  21. Settings / Table For MAF
  22. uploading tune problems...
  23. Knock retard
  24. 2 codes need help!!!
  25. I've Got a Half Dozen DTC Codes
  26. Help with PE tables, does PCM ignore past a sertain point?
  27. Looking For Tunercat 95 Z28 M6 Bin File
  28. Tunning prgram
  29. Freescan not working??
  30. 93 bin file for 221-227 m6 car
  31. anyone know a good place to get epros for cheap?
  32. Tuner comparison
  33. Strange tuning problems
  34. getting the cable to work with laptop
  35. What kind of tuning should I do, Predator, ls1edit, vht?
  36. tunercat or lt1 edit
  37. areas to get a tune
  38. GM847, need base file
  39. Hypertech Programming
  40. Ion @ MadZ28....where is he???
  41. Tuning closed loop idle
  42. what is going on with my car's computer or cable
  43. Mustang event coming up - i'm the only f-bod. Need a .226/.236 tune help
  44. I'm At My Wit's End; Need Serious Help
  45. !AIR! and !EGR! without tune?
  46. how to read Codes (w/out scanner)
  47. Pros & Cons
  48. Drop in Kpa?
  49. body harness
  50. which self tuning route to go???
  51. Anybody have an tested .LT1 or .bin file for a car like mine?
  52. ?.:PCM BAT fuse removal:.¿
  53. need help with tunercat please!!!
  54. need help with tunercat please!!!
  55. Anyone have a REALLY good Bin or LT1 file for Hot Cam??
  56. Anyone have a copy of LT1 edit that I can see?
  57. How to load OBD2 LT1 Edit file?
  58. Dyno&LT1edit near bakersfield ca????
  59. Does changing the cyliner size from 350 to 383 in LT1_edit change any data?
  60. Pcm
  61. Does spark retard go down when correcting from 350 to 383?
  62. Help, was told PCM ground is off
  63. B&M Shift Plus
  64. Speedo recal LT1 A4 -93 questions
  65. Open Loop PE tuning?
  66. SES Light - P0335 & P0336
  67. 97 PCM Pinout help needed
  68. Hypertech ?
  69. very low idle at anything more than 180degrees
  70. tuning for stroker motor?
  71. switching to OBDI & tunercat?
  72. What hooks to a laptop???
  73. 1995 Z28 bad opti-spark / distribution system
  74. Need Help with VATS Please
  75. would +/- 2* timing change AFR much?
  76. PCM went BYE BYE.
  77. Possible to go from analog to digital cluster?
  78. Tablet PC for Tuning?
  79. OBD2 - 1 swap without soldering PCM, and swapping KS?
  80. ECM Connectors Needed
  81. park/in gear idle change
  82. New laptop keeps failing aldl test
  83. I am about to bundle all this ls1 edit stuff to a rock and sink it in the river!!!!
  84. Tuning for Stall?
  85. UPgrade a 93 to 94-95 ODB1 Computer?
  86. TunerCat Help ... can't copy to 2nd PC!
  87. another tunercat question
  88. Pcm tunning for Fuel press?
  89. Anyone ever gotten help from the LT1edit mailing list?
  90. Wanted PCM Tuner That pays attention
  91. Help with a a4 shifting problem
  92. problem with lt1 edit
  93. Anyone ever ran into a laptop that just wouldn't work?
  94. injector offsets for stock LS1 injectors (28#)?
  95. computer upgrade
  96. Reman. PCM
  97. 02 sensor ?????
  98. I have a PCMForLess GM847 tune, can I use it temp with my cam?
  99. speedo recalibrate
  100. I hate computers
  101. Could you guys take a look at my Data stream PLEAESE!!!
  102. Hypertech worth it?
  103. Urgent Help Needed
  104. Forcing open loop operation in TunerCAT
  105. any PCM problems???
  106. what is the turnaround time for madz28?
  107. Extreme fuel trims
  108. Datalogging
  109. CC306 Bin file
  110. new to edit
  111. Need help before tomorrow!
  112. Emissions ? with obd II - obd I conversion
  113. Intake popping under rapid throttle accel
  114. Edit for new cam...
  115. have i fried my pcm
  116. ? on F.A.S.T. system
  117. o2 sims... how do they work?
  118. Help With Choosing Tune
  119. 2 codes..HELP
  120. Tunercat problems
  121. pocket PC tunar programs?
  122. Hypertech or Superchips programmer
  123. Car weaker after dealer program........
  124. Security Light?
  125. Bought Diablo Predator Tuner - Need help
  126. Need a stock 94 bin (M6)
  127. Can someone tell what this checksum means.
  128. Temp problem - Tuner
  129. Anyone ever have a problem viewing the tables in tunercat?
  130. Recommendations on programming for 10psi 383
  131. Tunercat Tutoring
  132. Add timing, or pull timing...
  133. car acting crazy, scanned info here..
  134. Newbie to the edits. Just got a laptop...
  135. wondering about ECM Part #.
  136. Timing vs. Altitude
  137. Can I put a A4 computer on a m6 car...
  138. For those thinking of using MADZ28.com
  139. Typical IAC count Cammed Z28
  140. Security Light while at WOT...
  141. Any FAST or GEN 7 users out here?
  142. Wife's car lost .3 by adding Hot Cam over little Lunati cam... ????
  143. Scanned my car with FreeScan. Need help to decipher the spreadsheets
  144. replys
  145. Maf Q....
  146. Codes programmed out
  147. Injector Constant of Acell 32#
  148. LT1 Edit File
  149. WOT 2-3 shift is not after HPP+ install...??
  150. cool feature
  151. Hypertech Tuning questions
  152. Madwolfe....where are you???
  153. Rough Startup '88 IROC
  154. PCM Identification
  155. Freescan question
  156. Run A/C without PCM?
  157. MAP high
  158. Just ordered my MADZ28 tune!!
  159. unpluged the battery?
  160. Mastach Cable not working!?!?
  161. Well.. I need new airbags.. what else do I have to do?
  162. Alarm or somthing
  163. PCM pinout diagram help!
  164. Dyno Tune Special
  165. Dyno tuning an LT1? NY?
  166. Anyone have the latest $EE Def from Tunercat?
  167. Can't get the trans tuned right...
  168. SES Light AGAIN, Banks 1&2 Rich, Please Help
  169. Code 1626: Anti-theft system--Fuel enable circuit. What does this mean?
  170. OBD I ECM Scanning / Logging using a PDA - do they exist?
  171. Bad dyno numbers, need to scan?
  172. can someone take a look at my FASTfile?
  173. Lean Code, BLM's at 160
  174. open loop issue, need some insite
  175. Computer tuned for Bosch 36#, will Lucas 36# require a retune?
  176. Need LS1 Programming!!!!
  177. Lean!!!
  178. Reducing Transmition shift pressure? Bad?
  179. Wide band reading about 1 point off
  180. 98 3800 Series II Programmer???
  181. Cheapest scanner
  182. Can I look at your trans table?
  183. Please help with these codes!!!
  184. transswap
  185. anyone know this???
  186. Just sent an email directly to GM
  187. need aldl cable help
  188. o2 problem ses at about 100 miles
  189. got my 373 gears installed today and i have a question about using the hypertech
  190. Computer won't chat with car
  191. LT1 Edit-IAC follower
  192. knock sensor ?'s
  193. anyone get a stupid dell to work with usb->serial
  194. I got another Datamaster logfile for review...
  195. Scanned car the other day. . . Have a few questions
  196. PCM's
  197. SLP takeoff injectors
  198. ABS code C1236 - system voltage low
  199. need advice on monitoring/tuning software
  200. tables missing in the new EE$ def file. and what is this for
  201. Final word on open loop operation
  202. couple tuning questions...
  203. Any Good?
  204. Anybody have a STOCK 96 M6 .LT1 file?
  205. what does this code mean
  206. Any FAST tuners here?
  207. How can I completely remove VATS???
  208. SES light after header install
  209. Can't scan the PCM.?
  210. scanning problem
  211. AKM cable problem.
  212. Going from 52mm TB to a stock 48???
  213. what options do i have to tune a 96 LT1 obd2?
  214. 96...396
  215. stick with OBDII or switch over to OBDI
  216. is computer bad
  217. Stock LT1 MAF table?
  218. Tripometer resetting randomly
  219. TunerCATS for OBD2 soon!
  220. New TC tables
  221. Programmer
  222. scan master do I need it?
  223. pcm won't scan
  224. Hopefully my final VATS question. :)
  225. Mail Order vs Dyno Tune
  226. Carputings LS1Scan beta...
  227. FreeScan Question
  228. Turn Off Security Light Via TunerCat
  229. emissions problems 94 Z28
  230. Can I manipulate the kickdown threshold to get rid of kickdown tables??
  231. turbo, SC, or nitrous activated spark retard in the PCM
  232. Using Skip Shift Light As A Shift Light
  233. start up program for 93 camaro blower
  234. Normal Mode, Performance Mode, Manual Mode shift settings in LT1 Edit
  235. erratic rpm
  236. 94 computer into a 93 Fbody
  237. need a tune for a cc305 cam
  238. help with tune when cold
  239. Non-topic kind of post
  240. What do I need, computer wise...
  241. LT1 Edit Files Sites
  242. MAF and possible opti problems??
  243. hypertech settings
  244. Suggestions for tuning for boost
  245. no matter what we do, car does 9.7 AFR
  246. Computer in Roadmaster/Caprice same as Z28?
  247. 93 Keyless Entry
  248. 4L60E Shift consistancy tuning
  249. Accel DFI
  250. have a question about bringing my car to get a tune for my A4 trans
