- Where do I get.....
- will mac laptop work with LT-1 edit or others?
- 3rd gen OBD-I
- VATS not correctly disabled? Help!
- EFI live, who is using for monitoring on 93s
- can someone look at this .csv file from my car??
- Strange problem with Backfiring.
- Need Help Fast!!!!!!!
- Any MAP over 60KPa is causing knock, but why?
- Burst Knock and Knock
- possible? MAf to SD
- Spark retard at Idle
- Dtc 18 ??
- How much timing is too much (with no KR)
- DFI gen 6
- oversize tires
- GM MEFI IV ecm info
- Datamaster + AKM cable + usb adapter = no data!? HELP
- where can i find tunercat & the cable for laptop? any1 know?
- Can someone in IL run Datamaster on my 93 for me?
- 93 Camaro LT1 Flash Test
- TunerCat shift point problems
- Car wont turn over when I turn the key. Vats to blame?
- Can a program like Autotap tell me what my A/F ratio is?
- Want to get in to Programming
- Eedbrock Pro Flo 3500
- Once again, Datamaster/ car tuners come in here PLEASE!
- Help? just fried PCM
- 4L60E adjustment questions
- OBD1 conv, still have problems
- What is the BEST?
- Help me set my shift points in TunerCat
- Have a pcm tuning question?
- Flash PCM with engine out?
- Tuning idle with CC306
- cam install...now bad idle...whats wrong? Long...
- Will a re-programmer do anything for an M6?
- How does Autotap figure AFR off the PCM
- First Gen Camaro...C5 Vette Guages
- using lm1 to simulate the nbo2?
- OBD conversion tranny fix?
- What's Better LT1 Edit Or Madz28?
- just got gears, have a ?
- Datamaster ?
- Cable connection for OBD1
- How to lock BLM
- flash program for pcm
- How to adjust part throttle and WOT fuel on TC??
- Camshaft position Sensor
- Will someone please look at my freescan file?
- Why does Datamaster NOT work, but Freescan DOES??
- I need a stock 94 A4 bin file
- HPP3 Part #345752. What will it work with?
- Accel Gen 7+ DFI and LTCC
- What line pressure you running (A4)?
- LT4 Knock Module (OBD2 to OBD1)?
- question about tuning?
- bad grilfriend......
- Car is still running rich
- Tuning on stock car worth the money?
- hypertech question
- cables for running freescan on 93
- W/B under $500 ???
- tuner pro software
- BLEMS are 128, still running rich!!!
- problem with idle! --injuneer?
- Worn exhaust valves cause false rich?
- 93 OBD-I to 96 OBD-II Conversion?
- Location
- who does re-programming
- Speedo off
- Ls1 Edit Tuning
- OBD1 or OBD2 ?
- need a .lt1 or .bin file for 221/227 cam.
- Question regarding scanmaster.
- How does madz28.com or pcmforless.com work
- need help with problems
- Needing BIN file
- Idle won't come down while coasting??
- Diagnostic Cable Problems
- Folks with USB Laptops with no serial port, did the Belkin F5U103 solve your problems
- Where To Find Tuning/Monitoring Software?
- New computer system
- instructions for installing Gen VI dfi
- what the hell? Ignition issues
- can't get this code
- LS1 inputs
- LT1 Edit
- Need 100% Stock 94-95 BIN
- Need your opinion
- install cats
- Looking to get Programmed. What needs to be done?
- Adjusting the Fuel Balance (off idle)
- how to "log" a run w/freescan
- Air Fuel Ratio at WOT
- IAC Park Position Vs. Coolant Temperature
- Data Logging OBDII
- cable not working? Help
- info on what info to get help.
- Question regarding LT counts in Datamaster
- Tunercat - quick ? about speedo cal and 4.10s
- Speed sensor
- Is there a way to tune out the front O2's?
- Programming my 96 SS's PCM
- Does anyone know the voltage range the MAF puts out?
- PE tables compared
- May have fried PCM...
- Code 48 an 84
- problem with air/fuel metering?
- Arrrggggg need scan tool
- Innovate LM-1 and Accel Gen 7 DFI
- Power Programmer III/M6
- Adjusting non-WOT AFR in Tunercat?
- tuning w/minor mods
- Knock Sensor Question
- Autotap
- Failed E-Test Need Help
- Is this right?
- Need help with Code 36( HI-res failure)
- How the Hell do i read this Freescan data
- full time open loop mode
- Can you diagnose a bad O2 sensor with DataMaster?
- new to laptop and tuneing
- LT1 Edit
- Spark advance help!!!!
- Low Idle Problems
- Predator tuning help. What temp to set cooling fans with 160 degree T-stat?
- Read my Specs..your input please
- Is there a DFI that will...?
- Autotap lt-1/LS-1?
- air/fuel ratio on datamaster
- TPI 165 $32 and $32b compatability
- Whats involved in changing an A4 program to M6
- Got alot of in-depth q's about tuning
- Tuner or RT Tuner
- Scanmaster questions and an odd one..
- Adapting Cable for editing LT1 PCMs...
- Need some information on OBD2 emissions readiness stuff
- what else needed with tuner cat?
- monitor 2000 as a gift
- jet chip uninstall
- Dyno tune/Hyper tech
- they make lt1 edits right
- Different tire/wheel size--easiest way to adjust speedo?
- Need help with 94 camaro wiring
- tuners?
- Predator help please
- Looking for a stock or mod Bin for 93 M6
- LT1 tuning advice
- Freescan log...need help and opinions on it
- Who custom tunes PCM's???(LS1)
- Firmer shifts programmed(PCM)??
- Code 16 low resolution failure
- Cooling Fans
- How do you identify what year a PCM is?
- Removing the computer
- Strange LT-1 O2 sensor readings
- Can someone look at my freescan file please?
- Radio Codes!!!!!!!!lil Help Here
- File to use for OBD1 conversion???
- TA's got problems
- Wierd!!!!!!!!!
- Differences b/w '94 and '96/7 Z28 wiring harness
- M6 file
- code 48
- NEEDED: xe230/236 bin
- how to get PCM out of speed density mode
- So I have a Tech 2.......
- Anyone have a stock 95 A4 bin file?
- My 95' LT1 has OBDII...WTF???
- Please look at my Freescan Files
- HELP! holeshot problems!
- :( which scanner
- Wideband
- APEXi SAFC II, failed intall. Need help
- Looking for a 226/236 cam tune. Anyone?
- so cal tunning
- 1994 obd1 powerdyne
- My car is possessed, codes gallore..
- Anybody using efilive v4 here?
- right blinker
- Sticker on pcm says not comp. with lt1 edit etc... WHY?
- 400-4000 rpm Spark Advance..Whats the best way?
- weird tach read out
- Just bought a DFI 7 ECU
- Split O2 readings on top end?
- Cable for hypertech?
- PCM Fried
- Where to start programming with Headers
- 94-95 OBDI w/6speed
- Best chip or reprogram for 1995 Z28
- Does this thing do any good???
- EFI101 Class
- PCM compatability
- Tuner Injector Flow Rate Setting
- MAF Tuning
- datamaster readout
- Off idle hesitation 97 LT1?
- how to set rev limiter with tunercat (LT1)
- .bin files wanted
- What is Ideal TPS Voltage at Idle
- Connection of Software
- tc in ms-dos mode
- abs, airbag gages light up
- wtb autotap and lt1 edit
- Reading O2 Voltage with Multimeter
- i am droppin the complete drive train into i think an 63 impala...questions bout comp
- Recomendations for a engine tuner?
- O2 not switching problem after header install
- turbo and emissions monitors kinda interesting
- Problem getting Freescan to initialize
- Keyless entry transmitter, VATS etc.
- Laptop not able to connect to PCM
- Coolant Fan Malfunction????
- VE tables tuning, please explain
- Fixing exhaust leak made split BLMs much worse!
- Looking for CC306 Tune
- I have a quick question.
- Wait for Tunercat or buy LT-1Edit for OBD-2?
- Programming Keyless romte for '98 ls1
- false knock retard? Take a look 4 me please!
- Help using Freescan
- I am thinking about getting one of these programs i need help
- Car feels faster with A/C on
- OBD II Readiness Help
- shift points?
- tunercat
- FreeScan Question.
- Changing AFR during normal driving with Tunercat???
- Idle showing very lean on both sides (Need Help)
- Why do i keep on blowing my vehcile speed sensor?
- Error Codes PO171 & PO174
- MALF 16: Lo-Res Fail
- LT1Edit mailing list....
- Accel LT1 units
- O2 simulator question
- Options for ODB2 Programming
- 1994 vs 1995 Connector?
- pcmforless
- Freescan and Datamaster issues
- 4l60e to th400 conversion
- CEL Reads 01 On Startup & Full WarmUp???
- PCM Crashed need quick answer?
- Injuneer, Ion, others.. ???
- tunercat- remove false knock- what tables
- Cheapest place to get a cable for LT1edit, or...
- P0133, P0141, P0147
- heads and cam LT1 cars....
- service engine light question
- OBD2 CC306 GM847, GTP6 big cam guys with tunes inside
