Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. line pressure
  2. Everyone with Tunercat, inside please
  3. 230/236 bin/lt1 file or tuning help
  4. Is the tunercat for OBD II coming out anytime soon?
  5. Need to know what these tables are for in tuner cat
  6. Can someone make some sense outta this?
  7. 396 tunercat ?'s
  8. little help Gen 7 users
  9. why does my car only run good after i reset the computer?
  10. upload options, beside lt1edit?
  11. Found errors on DynoTune spreadsheet. Please double check your excel file.
  12. OBD-II Programming
  13. Anyone here have Gen 6 DFI???
  14. ignition problem
  15. MaStach ALDL cable - will this work for a 93 LT1?
  16. PCMforless "Dangerously lean" ?
  17. Would resetting the BLMs do anything?
  18. wiring directions for Fasttrack harness
  19. just got Tunercat, what should I do?
  20. explaining TunerCat options...
  21. Data Error
  22. maft tuning/scanner help
  23. anyone have a modified fuel table that I can try?
  24. What LT1 Edit changes after ported heads?
  25. PCM Speed
  26. uploading .bin file from A4 into M6 (Bad?!?)
  27. Supercharged 383 BIN/LT1 file
  28. uploading .bin file from A4 into M6 (Bad?!?)
  29. pcmforless, speed density success???
  30. Is pcm for less better then Hypertech??
  31. code 42
  32. LT1-Edit: Performance tuning plz help
  33. any DFI6 gurus care to help?
  34. Computer
  35. Tunercat ?
  36. Chip info
  37. Vats mod location
  38. Lt1 Pinouts
  39. Where to buy LT1 Edit and cable, what kind?
  40. opti spark / icm questions
  41. what fuse do i pull to reset my pcm?
  42. MadZ28.com or PCMForLess.com?
  43. Adapter for OBD1 cable to OBD2 system???
  44. Tuning for cc306??
  45. programmer question?
  46. Does anyone have a gm847 tune A4
  47. Flashing pcm
  48. I want to start doing my own programming, help me buy what I all need!
  49. Lock the WOT BLM's to 128 on a 93?
  50. question about tunercat
  51. Are BLM boundaries used in Open Loop ?
  52. Tunercat PCM Read Error : /
  53. Knock Sensor issues.....
  54. How good are these numbers?
  55. OBD1 conversion
  56. Tunercat for 306
  57. would programming help?
  58. Chip
  59. ls1 edit
  60. Help, I want to start programming.
  61. What does this code mean?
  62. de-tuning hypertech!?
  63. Need a new tuning tutroial
  64. OBDII EGR duty cycle
  65. Learing how to tune
  66. Cam LT1 PCM sense boost?
  67. LT1 Highway Mode
  68. Line pressure???
  69. Has anyone ever messed with these tables?
  70. FreeScan CSV files...
  71. LT1 edit, changin tire size please help
  72. Zero out Open Loop AFR tables????
  73. Where can I get a chip!
  74. 96 Obdii:egr & Air Removal........
  75. Gen6 and Gen7 DFI use the same cable?
  76. Fuel and Timing with Tunercta.
  77. Keyless entry: other CAR MODELS remotes work on my car!
  78. programming for dummies
  79. what should i get?
  80. Keyless Entry addition to non-RPO car
  81. where to get LT1 edit
  82. Just recalibrated speedometer...
  83. Need a bin file
  84. pulling a code
  85. O2 values before startup L0.514mV R0.451mV
  86. tach wiring question
  87. VATS question
  88. Big Problem!
  89. Command 950 MAPS!! help
  90. B4C Package
  91. LT4 Knock module w/ OBD1
  92. wierd esc code 43 knock sensor problem
  93. Whos running large cams with closed loop tune?
  94. JET Performance strikes again!
  95. FANS+programming
  96. Battery reset kill tune?
  97. Anyone that likes looking at datamaster files?
  98. need help bad
  99. Ported MAF question
  100. INJUNEER..Please help!scanmaster prob..
  101. V6 PCM Problem?
  102. Will SLP 85 mm maf work
  103. RPM jumps around during WOT
  104. Beginner problems with LT1 Edit
  105. How much can I expect from a dyno tune?
  106. PCM sync problem w/ Datamaster (already did Search)
  107. 1994 pcm-1996 lt1 in Toyota landcruiser
  108. Tuning problems...need advice
  109. MAP at idle and off idle
  110. TTS datamaster problem
  111. Heads and cam swap???
  112. Where can I get a cable for about 35 bucks?
  113. how do i add 1 deg of timing? - tunercat
  114. which bank is Left/Right with Scanmaster??
  115. SES after OBD1 conversion
  116. cheapest place to get ls1 edit
  117. Dan White Racing Hanress
  118. Flash chips for socketed 95 PCM
  119. bad 02's???
  120. Tuning Accel Gen 6 DFI
  121. um....help? please?
  122. ls1 tunercat
  123. Lt4 hot cam tune
  124. Lt1edit/OBD2 conversion problem-->
  125. Putting car on the dyno tomorrow.. help
  126. A couple easy questions
  127. Measuring timing with opti/LTCC
  128. Help with engine miss...
  129. LT1edit manual correct?
  130. Fans Temp
  131. chaning gear ratio question
  132. Do Lt1s have an IAT vs Map timing table?
  133. What PE values are you running?
  134. 93 & auto xray ?
  135. Data logging Help
  136. Pcmforless Tune for Hot cam
  137. 93 ses codes
  138. Adjusting fuel pressure affect air fuel ratio?
  139. MemCal & Chip extention
  140. 95 camaro airbag replacement
  141. How to tell if I have my original PCM?
  142. gm/sec airflow
  143. IAT sensor
  144. 99 Camaro Programming
  145. Am I doing something wrong?? TPS voltage
  146. VSS, TH350, and me....
  147. Scanner connection
  148. How to make TCC engage at WOT in 3rd? (TunerCat)
  149. LT1 Edit & OBD II
  150. Will MAFT + help tune this combo
  151. pcmcia to serial with tunercat
  152. ECM Scanner Options - what's hot, what's not?
  153. Need TunerCat 1.98 demo - 2.0 causing errors
  154. Having trouble with laptop cable
  155. New PCM problem
  156. Differences between Tunercat and LT1Edit?
  157. GMS MAF sensor cause lean condition?
  158. GEN7 DFI Install Questions
  159. code 43 again
  160. Any TunerCat tutorials out there?
  161. Tell me about........
  162. Idle Speed
  163. converting from MAF to speed density
  164. PCM 95 Trans AM?
  165. Will replacement digital odometer read my 97z mileage?
  166. PCM re-programmers
  167. 97 SS need OBD I conversion info
  168. ls1 edit or hp tuners??
  169. Need a stock manual bin file
  170. thermometer for tuning?
  171. Need some wiring help
  172. b-body pcm's
  173. still getting a code
  174. MAP and TIMING....what do i look for
  175. Any websites with modified bin/lt1 files? other than bfrankers site?
  176. HPP connector for '95
  177. Tuning N00B needs help with new setup
  178. need some comp help
  179. ls1 edit info please
  180. A4 TC lock up concern/problem
  181. obd-1/obd-2 cables??
  182. AKM cables
  183. KNOCK and low octane tables...again (new question)
  184. OTC genysis
  185. 93 PCM question
  186. Line Pressure...
  187. Would a reprogram help
  188. HELP! My laptop died while programming...:(
  189. HELP! My laptop died while programming...:(
  190. 1991 sd 730 ecm vs DFI?
  191. Lockup MPH when?
  192. Tunercat basics
  193. Q@A time
  194. Please HELP!! PCM Tuning Problem
  195. Please HELP!! PCM Tuning Problems
  196. Accel Gen 6 DFI Users Manual
  197. help with tunercat program!!!
  198. Atten. MAD WOLF I need help with tuner cat
  199. BLM locker
  200. dtc 77, 26, 27
  201. lingenfelter programming
  202. Speedometer incorrect
  203. EPROM type for socketing OBDI LT1 PCMs?
  204. how do you use injectors instead of MAF for changing blms
  205. Idle timing /knock retard
  206. looking for bin or LT1 file for a 94 TA
  207. MAF calibrated wrong?
  208. FAST: WhiteRacing Harness and FIRE !!!
  209. Data Cable
  210. How do you set idle in TunerCat?
  211. 383 with SVO 42#ers 8psi ... need PE table
  212. TPS low voltage
  213. BLMs at 108; HELP!!!
  214. TunerCats Definition File
  215. Hmm- TCC normal Vs performance engage/release
  216. Anyone using the PCMCIA serial card?
  217. MAF circuit malfuntion error
  218. Hptuners edit Q
  219. Datamaster/Car running like poop question
  220. what software?
  221. I need a scanner...which one?
  222. 4l60e programming
  223. What do I need to buy
  224. Carolina Auto Masters
  225. Changing Transmission, What's Needed?
  226. Best aftermarket EFI system???
  227. Need help with 700R4 conversion and the Computer
  228. Post M6 Swap Tuning Issues.
  229. o2 simulators
  230. Ion or any programer
  231. labtop scanning w/freescan
  232. Fans arent going on...i tested them
  233. Any guides that tell you what to look for when logging your car?
  234. scanned 2nd injector what?
  235. PCMforLess Question?
  236. Guys with no PCM and FAST inside
  237. Running Freescan
  238. keyless entry
  239. Shift and rev limit problem
  240. Split BLM's in ALL Cells
  241. RPM Tables ?
  242. Can't connect with tunercats
  243. anyone know where to get free tunercat?
  244. Can you change blinker speed?
  245. Going to the dyno
  246. What should be changed to shorten high idle time?
  247. ? about heated o2
  248. LT1 Editing
  249. BOosted tunning.. New idea? Possible?
  250. Quick MSD BTM and Scanning Question
