Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Help- Need Pcm Connector Terminals
  2. Shifting with Tunercat
  3. Quick SBLM variation at WOT
  4. MAF Translator question
  5. P0420 Code....any help?
  6. Tuning for a new intake
  7. tunercat tables ?
  8. Anyone willing to have look
  9. BLM cell boundaries
  10. tuner cat vs tuner cat rt
  11. split block learn multipliers
  12. 93 Dtc 28
  13. right bank running lean
  14. open loop tune, about to test
  15. Code 51 ECm Prom Error
  16. need tuning but PCMFORLESS website is down?
  17. Odd tunercat problem
  18. 233/239 on 113 lsa tuning
  19. dtc code
  20. Need help with codes.
  21. Will pcm throw wrong codes if it goes bad
  22. 88 IROC ECM question
  23. What is the most popular way to tune a 396 LT1???
  24. Simple OBD2-OBD1 swap question.
  25. 97 OBD2 pin out, and a few other ?s
  26. question about DFCO when tunning
  27. IAC counts
  28. TunerCat users... Read this if you have issues...
  29. Tuning options
  30. Specific question on KR
  31. tuning after cam install?
  32. Coast-down lean roughness
  33. Turbo LT1 file
  34. 1st Time Scanning...What to Look For?
  35. AKM Cable
  36. Timing / Knock retard
  37. Pcm
  38. Major tuning around a new MAF?
  39. LT1 OBDII Seed/Key Algorithm?
  40. LT1 Edit OBD2 Question
  41. Idle tuning troubles...
  42. madwolf rocks
  43. datamaster files
  44. LT1 Edit No0b
  45. Lt1 edit or tuner cat users inside
  46. Freescan troubles
  47. Tuning out a MAF sensor with tuner cats
  48. Datamaster problems
  49. What Cables For Tuning
  50. performance maf
  51. LT1_Edit - and linux
  52. need help identifying harness... supposed to be 94LT1
  53. Hypertech power programmer
  54. Anyone with a 230/236 tune I can see
  55. Anyone have a stock '97 .LT1 file?
  56. Upload PCMforless tune?
  57. Can someone reflash my PCM?
  58. Madwolf, Question for you.
  59. low rpm stutter
  60. Settings for handheld programmers
  61. LT1 Tuning Help Needed!!!!
  62. 93 Speed Density ECM disassembly?
  63. LT1Edit won't work for me
  64. tuner cat ?
  65. Will this work for idle
  66. FAST pcm piggyback?
  67. Should my car
  68. Ok guys, big question please.
  69. DELTEQ anyone use it yey ?
  70. Quad Driver Modules
  71. Hypertech Thermomaster....
  72. Predator .. Not applicable to 98 LS1's?
  73. leaning out according to tuner cat
  74. Lt1 Edit
  75. Question???
  76. Anyone used a PROMPAQ?
  77. who can burn me a chip
  78. tunercat --- How to? Desciptions of functions?
  79. need help
  80. VE tables...controversal...i know
  81. Tuning for part throttle
  82. Need Help Bad...Which size injectors to run?
  83. WOT BLM confusion...
  84. Which Mail Order Tune to go with?
  85. Freescan Readings - Big Vaccum Leak only Sometimes?
  86. A/C compressor not coming on?
  87. TUNER CAT question
  88. Need FAST help fast
  89. Extremely low vaccum after cam change!
  90. Yellow "REF 3x" wire from crank sensor
  91. how do i tell if my cable is working
  92. Radar Detectors, City Vs Highway use.
  93. True that OBDI cars make more power than OBD2?
  94. USB port for cable
  95. What Software Choices?
  96. Got A Question for Madwolf "Ion"
  97. Autotap - Enhanced or Generic?
  98. Wide band O2
  99. 95 obdI with obdII style connector
  100. VATS System Problem? Car Wont Start
  101. Hypertech or or Jet PCM?
  102. Winaldl file..please read it for me!
  103. OBD1 swap info
  104. First things to do for a performance tune?
  105. pcm programming?
  106. Which side is right bank?
  107. Can a OBDII be reflashed to become a OBDI?
  108. scanner data
  109. help with bin file
  110. lookin for some programming help...
  111. diablosport predator?
  112. software
  113. corvette gauge swap
  114. speed density or maf
  115. AFR after startup
  116. air and egr
  117. Computer tuned with bad TB,fixed now car runs rich.Questions.....
  118. couple questions
  119. Trouble code help
  120. Car tuning issues
  121. Lt1 computer tuning, cant get ahold of Ion(madz28)
  122. Will A/C not working give me a code?
  123. Removing VATS
  124. ?s on making a OBD1 scan tool connect to my OBD2 connector (95Z)
  125. PCM edit help for +sized tired and rear o2's
  126. so confussed, someone please help!
  127. tranny not shifting after FAST install stuck in third
  128. Can someone tell me what size these injectors are??
  129. LS1 edit
  130. Scanner readings???? Help
  131. pcm idle
  132. wiring fog lights
  133. Service Engine Soon Light
  134. All I need to start using LT1 Edit??
  135. Diagnostic Software for ODBI conversion
  136. dfi units
  137. logged a few runs, have a few Q's
  138. how do you read free scan logs?
  139. Car runs fine, but cannot read PCM
  140. Very poor low end after new cam
  141. Tuning for power with bolt on's?
  142. 01 Camaro SS - ECM pin assignment
  143. can you use tunercat to change closed loop fueling?
  144. can't get IAC counts down
  145. Dyno Run: How much Knock Retard will effect performance???
  146. Correcting Speedometer with TunerCat?
  147. what is a wideband? what benifit?
  148. Need some help reading my Datamaster log...
  149. SES Light Disable
  150. Rate your Tune
  151. Hypertech ?
  152. LT1 engine swiths off??!!
  153. KR when shifting
  154. Anyone on Here USE that Dynotune Spreadsheet?
  155. Calcs-- Nitrous and Inj's
  156. need some type of programmer or chip..changed gears
  157. Who can fix my computer
  158. Palm Piliot Programming?
  159. Tech Edge WBO2 log/display Q's
  160. tuning/diagnostic program
  161. Programmer Help
  162. Programmer Help
  163. Jet Power Module
  164. idle problems
  165. Performance Mode Switch for LT1?
  166. tunercat or LT1 edit
  167. wont idle when cold
  168. need help finding cable
  169. emissions problem
  170. PLEASE HELP!! Keep getting code 16 yet not SES and runs FINE
  171. Need a tune
  172. will Hooker LT's and SLP Loudmouth give you knock retard
  173. Engine DTC MALF 27: EGR Electrical Fault
  174. After installe heads, car runs slow. Feels weak, throwing codes..
  175. DTC Code 36 popped up..
  176. Can reason for poor gas mileage be seen from a Datamaster log of car idling?
  177. Question on VATS
  178. Question on Belkin/Com Port Recognition
  179. Burst knock question
  180. who has the best rep for mail order tuning?
  181. ACCEL DFI Vs F.A.S.T.
  182. Knock Retard on 93
  183. best programmer?
  184. programing for a4 to t56 conversion
  185. CAM Tune w/ tunercat
  186. software
  187. Who sales LT1 edit
  188. How to tune w/t350 to 4l60e
  189. Which EPROM '93 Z-28?
  190. Programming tools for '95 3.4L?
  191. running rich, help please
  192. White Racing - FAST PnP harness
  193. White Racing FAST harness
  194. 3.23 auto lt1 shift tables
  195. MAF Tabe question
  196. bad bog
  197. car idles like a**
  198. hypertech question
  199. Look at my 233/239 timing.
  200. reprogramming is it worth it
  201. Laptop powered from the Auto
  202. What is BLM and is this number bad?
  203. Reprogramming MASS air versus MAP
  204. Have a couple Comp Questions, (needing a basic 306 Tune)
  205. speed density ecm?
  206. OBD1 cable from a local store?
  207. M6 Obd1 Vss
  208. Help w/AutoXRay PLEASE!!!
  209. cats problems. HELP!
  210. Will Datamaster work with Windows XP??
  211. Freescan & W2k SP4
  212. Newbie scan/dianostics questions.
  213. Question about Computer Diagnostics
  214. Hitting the rev limiter WTF??? LT1 editor
  215. computer scanning?
  216. PCMcomm and vemaster
  217. disabling 3-2 shift solenoid for a dyno run?
  218. Need .bin file for stock cam, LTs and CAI
  219. GMS MAF and Programing questions
  220. Is there a better Programmer the Hypertech
  221. kPa?
  222. Can someone review my datamaster log?
  223. $DA2 or $DA3 .ecu files available?
  224. Superior Cable ALDL Cable Connection Question?
  225. Datalogged car, -- few observations. Help!
  226. Do I need a special usb-serial port converter?
  227. 10k resistor for pins a&b?
  228. OBDII to OBDI conversion?
  229. Does edit clear codes also?
  230. need A4 shift table for 4.10 gears
  231. Will VE Master work with modified BLM boundaries?
  232. Why can't I access the calibration help in Tunercat?
  233. Accel DFI VII.. questions...
  234. Just bought a laptop now I need software
  235. OBDII / OBDI Laptop cable Conversion
  236. maf code question
  237. 94/95 Tunercat burn proms?
  238. Looking for Stock 93 M6 Bin File
  239. EDist users inside--->
  240. Getting Code 11
  241. PCMcomm revisited
  242. Speed signal on 87 truck with LT1 & mech. speedo
  243. Retrieving codes after OBD2-OBD1 swap?
  244. OBD2 Scanning Software
  245. hypertech?
  246. Big Thanks to Ion(MadZ28)
  247. Timing Advance
  248. Getting started
  249. Creating Macros for Freescan!
  250. I Need some advice on mail order tune...
