Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Programmer Purchase Help
  2. Chip for 93 LT1
  3. Optimal Timing advance on an LT1?
  4. Speed Density?
  5. Chip Burning software and hardware for 93 and older?
  6. Anyone use Diablo?
  7. PCM4less -vs- Madwolf tuning
  8. Auterra OBDII scanner
  9. Easiest way to get stock program?
  10. got a few data logs...can someone tell me what it means
  11. LT1 edit to laptop communication - problem solved
  12. VE Tables???
  13. OB2 programming
  14. IAT vs Map timing
  15. logged some data, short term fuel counts?
  16. cell-specific low BLMs
  17. R&R Thermo reprogram pcm?
  18. BLM boundries for a cc306
  19. what interface is everyone using?
  20. need reprogramed?
  21. Need help-Car won't go closed loop
  22. lt1_edit programming
  23. OBD1 Conversion Question
  24. hypertech question
  25. what is a good program
  26. Simple programming/exhaust question?
  27. P-code help please!!!
  28. 700R4 VSS signal into M6 PCM Possible
  29. Tuning a 1993 PCM
  30. formulas? spreadsheets? where to begin?
  31. best program to read codes on OBDI?
  32. GEN 7 DFI Questions
  33. Advice on data results
  34. emissions and LT
  35. need a good file
  36. What are the signs of a VSS failure in a '90 700R4
  37. 95 reprogram
  38. Datamaster people
  39. faq thread?
  40. what to do? newbie to computer tune
  41. VE Master!
  42. Low/High Impedance Injectors
  43. That company on ebay, anybody?
  44. Where's Andrew???
  45. Aftermarket Computer Questions
  46. 94 wiring harness vs. 97 (LT1)
  47. security/VATS/pass key.. problems
  48. Is it possible to edit my vehicle using a cable that worked for my thirdgen?
  49. LT1edit Version 2.2 is out now
  50. code 33 map sensor high
  51. low RPM cam surge
  52. programing problem or mecanical
  53. Hypertech Programmer Question
  54. Hypertech and Jet together??
  55. K&N & Speed Density LT-1
  56. Cable Differences
  57. Shift Points HELP
  58. IAC motor just need time to learn?
  59. Problems Pulling Codes
  60. Tunercat 1.98
  61. Those with datamaster look at this !!!!
  62. Anyone know how to use tuner cat?
  63. Looking for more...
  64. codes wont go away
  65. speed pro computer for sale
  66. 383...Need a tune...
  67. Need help converting OBD1 PCM for OBD2 conversion
  68. LT1edit
  69. please help answer my noob questions.
  70. Going to DFI
  71. Need advice on datamaster run and fuel injectors
  72. Passed Smog!!
  73. Can't pull any timing!!!!
  74. best prom tuning for TPI cars?
  75. programmer@pcmforless.com
  76. LTrim question...
  77. SES light is on Again!
  78. Who fixes pcms and what caused this?
  79. Best bang for the buck scanner?? whats your favorite?
  80. lt1edit lean
  81. USB to ALDL cables?
  82. lt1 edit vrs tuner cat
  83. How to tell if PCM is M6 or A4
  84. TTS datamaster pcm sync problems
  85. speedo adjustment after intalling gears
  86. paging Madwolf
  87. PCM from an Impy?
  88. Problems adjusting VSS calibration param's in the 95 LT1 PCM
  89. Best place to get ALDL cable?
  90. LT1 edit or Tunercat
  91. anyhthing similar to tuner cat for mustangs?
  92. New edit software for LS1
  93. Tuner Cat Programing
  94. Stock LT1 computer "on the fly" programming
  95. I need help with a obd2 code
  96. Gear change and speedo recalibration
  97. Where can I buy 28F512 chips?
  98. Best place for a PCM edit ?
  99. Need some help with Tuner Cat
  100. Tunercat, for OBDI only? Please help!
  101. few general questions on tuning
  102. Lt1 Edit Help
  103. Computer requirements for Tunercat?
  104. Speed Density to OB1 MAF Setup
  105. What's with Accel?
  106. I am changing my stall..Do I need another reprogram.
  107. PCM fried???
  108. Finally got the money for a tune, but ran into a prob.
  109. Tuner Cat Questions
  110. Connecting My Laptop to my PCM
  111. Injector problem cus of programming?
  112. base tune
  113. Need as much info as possible on Tunercat and tuning- opinion, links etc.
  114. Madwolf Help!
  115. .bin file for a 95 6spd LT1
  116. Laptop question
  117. tts datamaster problem
  118. "error: incorrect message sent" while flashing a .bin
  119. Question(s) and Problem(s)
  120. Just got my MaStach.com interface and software
  121. Getting pricing straight on tunercat
  122. inj calc
  123. what could be causing a P0128 code?
  124. FAST question
  125. simple question for those with Accel DFI
  126. ecu program
  127. 30lbs inj to 36lbs inj
  128. new to tuning
  129. Any recommended reading for new LT1 Edit user?
  130. Tuning Guru's give me your thoughts!!! (Long)
  131. In dire need of stock '95 LT1 M6 program
  132. Governor Switch Removal
  133. tips for running obd-2.com diagnostic software
  134. OBD-II vs. Aftermarket System
  135. bad obd1 conversion
  136. Gauge Problems
  137. Need TunerCat help badly please....
  138. cc306 prob
  139. LS1 edit ? ANYONE ?
  140. Newbie to computer tunning, what do I all need?
  141. Can I gain with tunning, LT's and RRs?
  142. LS1 tuning help ...PLEASE
  143. Easy one, tell me what the DTC: "MAT Low" Means?
  144. Anyone Care to Look @ my Log? :)
  145. Disgusted.. engine backfires, shakes stumbles..then runs perfect.. HELP!
  146. Question about MADZ28
  147. MAFT How to?
  148. OBDII and 7500rpms?
  149. hypertech programmer
  150. ECM Ground
  151. Handheld Wide band A/F ratio meter from SEMA?
  152. 6 speed and 8#SC Bin Please...
  153. Tuning with OBD1
  154. PCM tunning for the 96-97 V6;s
  155. tunercat howto?
  156. 1994 trans am..CAn i tune this car with hypertech?
  157. Strange fan settings?
  158. short term and long term fuel trim
  159. .A-Tap Wire, any other software i can use with it
  160. What can I do to prevent frying PCM
  161. newb programming question - speedo
  162. dtc 83
  163. How do I remove CAGS using tunercat?
  164. Desperately need help with Lt1 tune...
  165. Logged a drive with Datamaster
  166. OBDII code=P0420
  167. I read my pcm and now it will not start/ tunercat
  168. Dumb question...TunerCAT related.
  169. Obdii P1641 & 1642
  170. different fuel trim from each bank
  171. Removing the computer
  172. C.a.t.s. ?
  173. Engine misfire code and LT1 edit??
  174. z28 pcm and v6 pcm....? same?
  175. Bench harness compatable w/ LS1 Edit??
  176. which unit should I buy for my Camaro LT1?
  177. OBDII LT1 Edit question...
  178. data logging for 93
  179. Whats the pest PCM tuner out there?just installed new weels.
  180. Unhook MSD when uploading a tune?
  181. Cooling fans stay on after program upload
  182. need a/f help PLEASE
  183. How to set Fuel Pressure?
  184. have 96LT1, using 94PCM.. now what?
  185. Guys, take a look at this thread please.
  186. 24 to 30lb svo injector change with Tunercat...What changes??
  187. Tuning with gas
  188. Need someones help
  189. Windows 2000 and no DOS? Tunercat related
  190. Dtc: Po412, Po418
  191. need help decide on a tune program!
  192. 96 Z28 A4 to M6 swap PCM question
  193. tuning a bolt on car
  194. could someone analyze this freescan log?
  195. Q's about my A-Tap Log
  196. Do I need to get my shift points reprogrammed with a high stall?
  197. Anyone ever made a .bin for gas milage?
  198. Lt1 edit to tuner cat (bin) converter
  199. Any Have a Stock 6m .bin file or better yet...
  200. Performance mode shif on a ´96 z28
  201. Idiot Light......
  202. speed density mode
  203. 94z tunercat shiftpoints????
  204. set up ildle speed
  205. AFR tuning
  206. TunerCAT tuning for beginners?
  207. tuning a bolt on only Lt1
  208. Ve table
  209. GM 2 bar MAP sensor #
  210. FAST LT1 harness?
  211. simple freescan questions
  212. swapped MAF sensors, strange...
  213. Winflash ok to use now?
  214. Stock 93 M6 .bin file Desperately Needed!!!
  215. ? on Auto X-ray scanner results.
  216. Tuner cat tables
  217. timing retard question
  218. instrument cluster swaps
  219. Simple Question: What are Accel Fuel Injectors rated at?
  220. '95 OBDII problem
  221. Fast track performance harness?
  222. LT1 Software & Cables
  223. fan on thresholds in tunercat
  224. how "LEAN" can yo go
  225. Tune Pro's inside
  226. does tuner cat log data & scan
  227. What is the best scan tool/data loger
  228. OBD-II and emission cheating
  229. going above 14.7 AFR
  230. Wide band o2 sensor kits
  231. 95 z28 programming
  232. first start after heads & cam
  233. computer compatabilites
  234. Diacom blues, won't connect...
  235. When to get an aftermarket ems?
  236. Accel DFI tuning
  237. Eliminating EVAP on '97 T/A with OBD! to OBD@ conversion..>>
  238. No cat, No tuning?
  239. pcm read???
  240. TunerCat tuning for WOT?
  241. anyone know how to reprogram an eprom?
  242. tunercat to desensitize KM??
  243. Fan Hystersis
  244. Salvage 2002 LS1 won't start
  245. Advancing the timing table
  246. Anyone running a wide band af sensor, where do you mount it?
  247. emissions tuning
  248. LT1 edit data logging errors
  249. someone help me w\ these abbreviations
  250. Can anyone check out my Freescan scans?
