N2O Tech
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Window switch for a 2000 LS1
  2. Can a K&N FIPK work with NOS?
  3. cc503"xe224/230 112lsa".....anybody run it with nitrous yet?
  4. nitrous kit wiring help
  5. Want to run a seperate gas tank for N20??
  6. My car isnt running right any help?
  7. Ok, help the noob out please
  8. Spark pulg question
  9. stock intake elbow, or tri flow??
  10. Quick ? about wiring selinoids...please help!!!!
  11. nos placement
  12. solenoid resistance
  13. How did you wire your bottle heater?
  14. micro switch ?
  15. Help!!
  16. Disabling FPSS…
  17. solenoid ?
  18. nx relay question?????????
  19. How much power adder can forged parts handle?
  20. wiring question
  21. biggest shot on stock bottom lt1
  22. nos on single turbo
  23. Best Timing Retard Box??
  24. Leaking Solenoid??
  25. Anyone running the Nitrous Works Wet Plate system?
  26. Modified MSD Window Switches now available!
  27. Suggest a Nitrous cam for 300 shot
  28. Wide open throttle switch install
  29. NOS + stock LS1 motor
  30. ??need special engine assembly procedure for N20??
  31. leaking fuel solenoid...help!!!
  32. anybody cover their nitrous lines??
  33. NOS tutorial/help?
  34. How is the NW's LT1 system
  35. Timing Retard on Scanmaster??
  36. ZEX Lt1 kit....anyone running it?
  37. Just curious, what size shot would you recommend?
  38. Installing NX wet system this weekend...any tips?
  39. Fuel Pressure Safety Switch (Hobbs Sensor) Install on an LT1?
  40. How long is too long for bottle heater?
  41. Nitrous
  42. Nitrous Oxide 101
  43. Where to buy Compucar N20 kits??
  44. Any pics of bottle mounted on hump?
  45. How do you tell the diff between a 125 jet and other jets?
  46. need help with 100 shot NX wet shot jets
  47. NX jet question
  48. Help with Zex kit
  49. Fuel and NOS Pressure gauges?
  50. direct port setup
  51. Nx wet kit (20920-00) what all do I need???
  52. convertor,cam and gear setup for nitrous
  53. how much N20 on a stock LT1?
  54. What jetting and fuel pressure for a a completly dry shot for a LT1.
  55. is it the right one for me?
  56. NX Kit LT1
  57. NX price increase and upcoming new products!
  58. Does nitrous have an effect on manifold absolute pressure?
  59. Strange(maybe)N2O Problem
  60. NX dual stage... MSD digital 6+, 2 RPM window....????
  61. What cam are you nitrous guys using?
  62. do i need a strong bottom end or top end for large nitrous??
  63. NOS 5177 System Instructions
  64. Stall converter and nitrous
  65. What about TR5 ??
  66. Looking for a NX kit with all the options
  67. Anyone using the Wilson efi kit?
  68. Nitrous Surges on Full Bottle, Help
  69. What is the smallest nitrous shot I can get?
  70. Best additions to NX kit?
  71. ZEX for LS1 SS
  72. Ran N20 for the first time....does this sound right. Experts please help!!
  73. High mileage LT1's on the spray
  74. setting window switch below 3K rpm??
  75. TNT vs NX
  76. 15 lb tank bracket dimensions
  77. why do my rpms take a split second to fall after using juice??
  78. Will a generic GM EFI kit work?
  79. FPSS? Who is surging/Who is not?
  80. Plate vs ummm other????
  81. Spay on stock plugs???? good.... bad???
  82. ported heads/stock cam/fully forged bottom end??
  83. My winter prject
  84. Can I use a generic GM EFI kit?
  85. First Time Nos
  86. Need part numbers for NX products
  87. window rpms
  88. N20 and porting the heads??
  89. Dangerous to mount wet kit in donkey dong?
  90. No liquid Nitrous from purge?????
  91. NOS curious
  92. fuel requirements
  93. need help with intank fuel pump...scared to install
  94. Spray with cutout open or closed?
  95. nos cam?
  96. LT1...How often do you change plugs...
  97. is comucars lt1 kit a wet or dry kit?
  98. Second stage with horn button???
  99. Anybody running 175 shot on there NX EFI Wet Kit?
  100. Could I change my shark nozzle to a plate system?
  101. Biggest Shot You Guys Think Is Safe For TR6 Plugs??
  102. 100 shot worth worry about timing retard...
  103. leaking NW fuel solenoid... what to do?
  104. Most amount of N20 u can spray on an LT1
  105. What type of mix to get optimal octane for srpay??
  106. 224/236 users in here
  107. Best cam to use for my setup on N20?
  108. Can someone give me the jet chart for the NX wet kit?
  109. Accel Ignition Timing Computer...
  110. what NOS should Me get??
  111. Nitrous setup for a lt1
  112. what rpm and speed trapping at?
  113. Where Did You Mount The Solenoids?
  114. car feels a tad faster after n2o use??
  115. Need some Direct port xperts
  116. LS1 Injectors?
  117. Nitrous and 10:1 compression
  118. Whos got the quickest LT1 n20 car
  119. How often do you guye change your
  120. MSD Digital 6
  121. hypertech power programming and n2o
  122. ring gap?
  123. Who's been shooting the longest???
  124. For Fun- Lets see some bad a$$ N20 set ups
  125. New times with xtream 224/230&N20
  126. Zex Jet Help PLZ
  127. need to trade FIPK filters
  128. Micro Switch For Second Stage With M6??
  129. dry sex sucks how is dry zex
  130. NX Wet Kit with vortech elbow
  131. New track times
  132. opinions on spark plug probs on spray
  133. Need spark plug part #'s for 2-3 steps colder
  134. Whats your opinion on this system?
  135. Ring gap on LT1's??? Can it handle a 150hp shot?
  136. 383 Compression ?s
  137. Which is easier on engine, NOS or supercharger?
  138. Knocking
  139. Alternative to Progressive Controller?
  140. Where can iget these replacement parts??
  141. Camshaft Selection
  142. stock tune+cam+n20
  143. Bottle mounting/ solenoid mounting
  144. What else??
  145. fuel/ignition requirements?
  146. 250 dry shot
  147. Popular 355 Buildup choices??
  148. Can you disassemble a Compucar TB plate?
  149. KTamez
  150. non-f-bod question: ZZ4 and Nitrous?
  151. Zex Problem
  152. Bottle heater pressure switch question.
  153. nx 100 shot expected et gain?
  154. N20 Popping up high
  155. Dry or Wet???
  156. WHat's safe for an LS1
  157. When should I spray?
  158. NOS bottle heater wiring... Help please..
  159. Launching with nitrous..... How many do it?
  160. stock 3.8 with nitrous
  161. Too old?
  162. What fuel to run?? Please..Need answer today
  163. Detonation factors?
  164. Please post your 383 N20 videos here
  165. 5176 dry kit jet question...
  166. 3 gallons on 100 octane gas will be ok with 150 shot??
  167. Who here has chromed ot their bottle, or knows how
  168. Need nitrous lines/intercooler mount/solenoid...Where to get?
  169. PICS, need PICS, install, and bottle mounting between rear seats
  170. A/F question while spraying my car....
  171. help my nitrous 75hp shot feels like 30hp
  172. just finished my comucar install
  173. What brand??
  174. Pulling fiming question...
  175. 306cam vs 224/236 cam for n20
  176. Need research information
  177. Please help with MSD8982 install..
  178. Dyno Result: 99 vette w/ 150shot
  179. What do i need
  180. I played it safe. What should I increase to?
  181. Having problems with Mallory 685
  182. Pic of black intake w/ nos fogger?
  183. Lt4 hot cam kit and nitrous...any good??
  184. 2 question please help.
  185. Edelbrock nitrous kits??
  186. 150 shot = 10.3@129
  187. Dyno'd on the juice today, evaluate please...
  188. going to track this weekend and i will be spraying?
  189. Why no purge??
  190. Damn nitrous help!!
  191. TNT 150 shot
  192. Gemini Quad???
  193. Small dry kit or small wet kit
  194. Lean spike on my dry kit... Any input..
  195. purge locations?
  196. Off the shelf Octane bossters
  197. Nitrous throw maf vs elbow vs tb plate?
  198. nitrous works jet sizes
  199. NX solenoid max flow?
  200. N2O for Bracket racing??
  201. Opinions on bringing in the squeeze... 150...9
  202. How long does the bottle last?
  203. NEW DRY KIT 50-400hp
  204. Nitrous Works Kit ATTN: Speedtechnologies
  205. spraying while on a 2 step rev limiter ?
  206. cc306 with Gas???
  207. differances in nozzles
  208. LT4 Knock module with Nitrous
  209. Hooking up wet kit ??????'s
  210. Co2 with N20
  211. Is N2O socially acceptable?
  212. quick question on N20...
  213. Nitrous Install Pics
  214. thinking about N20
  215. Spark plugg gap?
  216. stock lt-1 goes 11.52 for $1300
  217. Where does the grey wire go? (MSD8982)
  218. Stock 1995 Z & Nitrous
  219. difference between dry and wet kit
  220. nitrous uping jets what do u think?
  221. Where should a 150 HP NX kit put me?
  222. Nos Refill Station
  223. hesitation
  224. n20 problems, need help
  225. heads and cam plus nitrous questions
  226. need 175 nx jets
  227. what is more dangerous to...
  228. Basic Beginner N2O kit?
  229. n2o newbie question inside
  230. Anybody know where I can get a 3an to 3an fitting
  231. retarding timing with 100-125 shot?
  232. need help getting fuel
  233. Tried a Shark nozzle and 175 jets today...
  234. plugs and N20
  235. N20 and plugs
  236. platinum plugs and 100 shot wet kit
  237. NOS 5176 on a LS1?
  238. 150 pills on NOS kit are???
  239. Am i crazy or is this ok
  240. Whats wrong with my bottle?
  241. Dry 150 Shot..
  242. Jimmy Jams Activation switch
  243. N20 Tech
  244. Compucar kit...want to run 75 shot...what jets?
  245. Is there a NX combo for 125hp shot?
  246. Nitrous Buildup... for 200 shot?
  247. ZEX LT1 kit.. Opinions?
  248. Bottle location
  249. n20 problem???
  250. why are platinum plugs bad for N20
