- Questions. If y'all Don't mind.
- Alunmium or Iron heads w/ 150 shot?
- ZEX Nitrous Kit Stealth Installation Info and Pics
- Mounting bottle in Spare tire wheel well..
- how do you install a MSD window switch??
- how do you install a bottle heater??
- thinkin my next mod might be n20....
- Mods: can we make this a post it???
- vid of me sprayin a high 12 sec bird
- venom vs. NX
- N20 Pics
- almost spraying time!
- What's the best wet N2O kit....
- anyone running sneaky pete?
- Need some advice.. Heads/cam car with nitrous, stock bottom end
- total advance
- ZEX Kit is in!
- bottle warmer?`
- Free remote bottle opener with any nitrous kit purchase!
- anyone wished they'd gone supercharger/give reasons why or not
- shutting off the bottle!!?
- Question on NX remote bottle opener
- cam choice
- Dimentions of NX accessory switch panel.
- HELP... Lower ET with bigger jet???
- purge work yesterday, but not today
- Does this kit off of ebay have everything i need?
- how to launch on slicks with juice??
- do you guys have pictures of your switches??
- How to mount a WOT switch on my LT1?
- You guys wanna see wwhat I got today!
- bottle heater questions.....
- the nitrous works whoas
- Looking for a bracket that holds two tanks
- Plenum Spray Bar by Nitrous Works
- Hobbs Switch?
- safest way to do nitrous
- New Nitrous best,more to come.
- No2 Head gaskets??
- Do police really look down on N2O?
- Can nitrous line be used for fuel?
- wiring help w/ mallory window switch!
- Colder Plugs / Fuel Pump
- Do I need to upgrade my clutch before installing a nitrous kit?
- Bought a used compucar kit...have some questions.
- How much does a Nitrous install usually cost??
- How many keep their N2O tanks visible? Poll
- damn this bottle leak
- 'Ghetto' Nitrous Install...?
- seriously, can you feel the diff. with 75 wet shots??
- is there anyway i check my solenoids??
- to Hawk, Timberwolf and everyone that replied to my threads
- Solenoid current draw?
- Need help on zex LT-1 install
- adjust pcm program for nitrous?
- nitrous info on my 98 z
- Some basic questions: Stock LT1 and N20.........
- What is the best setting for my mods???
- which one better NX kit or TNT kit??
- Is there 2 versions of the NX remote bottle opener???
- what type of oil for nitrous use??
- nitrous on a stock LT1
- Thought some of you may be interested...
- getting ready
- Nitrous Filter
- Digital nitrous pressure gauge coming soon
- Question about fuel pumps?
- nos install price???is this right
- need wiring help asap
- what should I get my stall set at with a 150 shot?
- o.k. to spray through shifts??
- The new Nitrous Express NXL system
- shifting threw 75 shot
- Bottle pressure
- nitrous on 01 ss a few ?s
- Damn Compucar changed their design!
- Custom Bottle Brackets.....
- $40...wasted
- This is just sick
- Can yall check my setup please
- how do i know how much nitrous i still have left??
- What??? im confused
- my 1st bottle did not last very long (i'm pissed)
- My new Nitrous Install what do you think Pics Included
- How to mount NX switches in ashtray?
- Dual stage carbed set up
- NOS remote bottle opener wiring. Help please...
- Mounting Bottle in spare tire....
- Anyone mount their bottle between the rear seats?
- How many gallons of fuel are used?
- NX bottle warmer question
- NXL kit? any scoop on this?
- nitrous backfire
- Nitrous question
- Death blow to N2O?
- does pcmfrless do good work for nitrous cams
- where to get jets for NX kit?
- do i require some tuning for 75 nx wet shots??
- Switch panel in ashtray help
- NItrous question help
- Anyone running the new ZEX "wet" kit....
- Zex kit fuel pump question
- cam suggestions for 85 TPI and 150 kit
- MSD Timing Box?
- how much total?
- to spray or not to spray
- Question about nitrous kit working on a 3rd gen?
- Locked out timing with nitrous
- Nitrous People - FS: Start/Retard Control - PN 8982
- 150 NX kit on 383
- bottle heater
- n2o will most likely to cause damage to.....
- What ET to expect with NOS...
- Nitrous Express
- whats the most minimum clutch I can use with N20
- For those looking to get into nitrous cheaply...
- NX question
- Fuel Pump and Injectors
- Any difference between...
- how hard is n2o on the stock rearend
- Newbie Question
- lost 50 hp on spray..WTF HELP
- Dry kit on 95 LT1??
- Progressive nitrous controllers
- Would I benefit from tricking the IAT when spraying?
- Can someone help me wire up a dual stage system?
- Mph?
- Stupid gen X kit...
- Mustang 4.6 NOS kit on a LT1?
- autolite 103 or 104??
- advantages of race gas on the juice?
- Jacobs Nitrous Mastermind install help
- Is purge valve necessary with nx wet kit??
- is window switch necessary for Msd 6al??
- leaving bottle in car?
- NGK TR6 and your gas mileage?
- pics of under hood setups?
- FP safty switch
- What head gaskets are you guys using?
- WOT switch question.
- What is pull timing???
- N20 Kit NEED HELP
- A few random Wiring questions.
- jet sizes for nx kit
- Small fuel cell in engine compartment
- Got to spray for the first time at the track today
- How hard is it to install a nitrous kit??
- Is this normal or does it indicate a leak?
- N20 cam choice for a 383?
- costs for a 100 shot
- what does the ZEX kit do for fuel?
- Nitrous cam/NA cam
- intake for a small shot
- purdge
- Which ignition components needed to retard?
- how much can u spray with a built motor
- need help selecting a couple of parts
- WOT switch doesn't fit BBK TB.
- Knock at same RPM point even w/ retard
- Nitrous questions.
- fuel setup good enough for the N2O?
- NItrous motor running N/A. No POWER!!
- What am I missing?
- race gas as replacement for timing retard?
- tuning
- Special converter needs for N20?
- best nitrous kit for a LT1
- compucar nitrous system
- NX Kit: Regular or direct port.
- how much timing retard for 300 shot
- whats the most someone has sprayed on lt1
- Best kit with blower
- what saftey items do you have?
- Nitrous Express NXL system delayed until the end of August
- N2O TB Plate-type systems... interference issues?
- How to drive a M6 w/ 2 stages
- Wiring in timing retard
- questions about direct port
- window swtich
- anyone have an extra nx 20 jet and an msd 5700 pill laying around?
- how dumb would it be to put a 100shot on an 90k mile lt1?
- NOS 5115 vs. 5176
- Which is better, NX or Zex?
- Budget build up to handle a big shot of N2O
- ForSale: 2LB NOS brand nitrous bottle
- Purity of NOS?
- Remote bottle opener switch wiring...
- What is the best nitrous kit for an lt1??
- how much shot is 91 octane gas good for??
- average gains seen at the tire with NX & TNT
- where to spray at in the 1/4 mile?
- N2o plumbing help! quick!
- Lets talk jet sizes...
- Compucar wet kit
- MSD Window Switch
- compucar ?
- the new nx maximizer
- Need Help Quick pt. 2!
- Need pics and info on fuel cell
- Have N2O prices skyrocketed lately?!!
- mass air flow sensor
- 12:1 compression +N2O
- Who runs the NX "white" filter?
- n2o questions for a beginner
- Fuel pressure question
- Anybody know of a short header style plug, that's the same as TR-6's?
- A4 and Nitrous ?
- Direct Port ?s
- Nitrous Noid sticking open? HELP
- nx express kit wiring questions
- took plate out
- questions about autolite 104
- What plugs for Zex
- to much fuel???
- TB Plates - Spray Bar or Nozzles - Which is preferred?
- Engage system and there is a delay for a split second...WHY? ANy suggestions?
- Will a 15# tank fit in the spare tire well?
- Safe shot for a LS-6?
- Stock Z28 M6 looking for suggestions
- where can I move my noids to without buying new lines?
- Checking/cleaning fuel solenoid
- A few quick questions
- Purging nitrous into the intake?
- Where to find these 2 items
- n2o nozzle and injector question
- Please educate me on the electrical part
- Times with Nitrous?
- Any guys have specs on a Nitrous cam thatll pass emissions?
- NOS 5176 dry kit regulator shim question...
- how much race gas and what octane !?
- LT4 set-up with N2O quetions??
- People that have used Compucar bag of Nitrous?
- Need link to N20 button is stereo controls
- mild 454....is N2O wise?
- A Big problem with my NX Kit, PLEASE HELP.
- Nitrous puge kit
- direct port question
- Wet and Dry Kits
- couple of ???'s on a free dry kit
- Ls1 nitrous guru's inside please
- plastic instead of hard lines
- Stock fuel pump and nitrous
- Electrical Connections
- 95* Thermostats for NOS bottle heater...get in
- what plugs for nx 150 and iron heads?
- LT1 wet kit work on LS1?
- Teach me about N2O.
- N20 on a third gen?
- Think I am pushing my boundrys
