- Maf Discharge?
- Help me choose a bottom end
- N20 Switchs and MAF questions
- Need help finding the right setup for me
- Anyone running the ZEX N20 Kits
- How much would be safe on the 355
- Where are you guys putting your dry nozzles?
- whats the jetting for a NX 100 shot??
- Adjustable fuel pressure regulator?
- ignition set up
- jeting
- NX Shark VS NOS Fogger
- Anybody ever done this?
- Which knob is the fuel test port on a LS1? Also...
- I Love N20 !!!
- Trick Flow Elbow/Nozzle
- LT4 hot cam and TNT...anyone?
- how do u guys hook!!
- 125-150 shot on stock cast crank. Y or N?
- 306 in; can I bump up w/s off time
- Which Nitrous Express (NX) kit for my 2002 SS?
- First run
- Best GEAR for N20?
- What do you use to pull timing?
- Need headgasket recommendation for 355 TNT setup
- Zex and Hot Cam?
- What kinda LT1 motor and N20 Setup will make 900-1000rwhp?
- How bad would this be???
- Harlan RPM window switch for sale
- Timing Retard
- Am I ready for NOS?
- Fake94ss-vs-911 turbo
- Most miles with 100 shot?
- 15# Bottle in Spare Tire Well???
- Edelbrock Nitrous Kit
- NOS... need info please
- Was going to get nitrous, having second thoughts.
- Should i keep my NOS kit??
- What wet kit? and is this everything I need?
- guy selling nx wet for 325
- Selling NOS 5177 Polished KIT
- anyone have a NX solenoid fail??
- pics of my nitrous setup, ideas to make it cleaner???
- pistons
- TR6 equivalent?
- Nitrous and other car parts
- Whats your ideas on this cam?
- Installing A NX Wet Kit...
- will this bottle and opener combo work?
- lil help here please
- NOS KIT...plugs and pills???
- if i put zex 75-100 shot on my bone stock 94 Z
- nx install ???
- LS1 times with NOS #5177 Dry kit?
- NX MAF Setup
- Nitrous exhaust and bearings questions
- Recommendations needed
- How bad is it to run a regular Yank stall with N20?
- nitrous windows ????
- Running a ProCharger on a 1991 TA (what benefit wih NOS?)
- n20 and cat converter
- Spraying lots of nitrous- Need help, advice and predictions
- NOS gain?
- spark plug ??????
- nx kit used for 325
- how much no2 should i use
- Best oil for nitrous application?
- Is AutoTap good enough to watch A/F while spraying?
- N2O Diminishing return?
- N2O: Next?
- Long tubes or N20?
- Fuel pump needed for 100 dry shot?
- Nos
- tranny???
- Putting a N2O kit in a 96SS
- Better safe than sorry
- Whats missing in my kit?
- Mallory Hyfire VI harness?
- 100 shot hurting M6 tranny?
- perge kit
- Where can I get a N20 shutoff valve?
- Details on what wires go from MSD rpm switch to TACK & Computer
- MSD switch vs Harlan window switch
- Attn: Dave Pic's YOU REQUESTED Fogger setup for 500 shot
- Pardon the ignorance, but why do I need a retard feature on a switch?
- Mounting 2 bottles
- manual activation?!
- jet sizes for 5176 kit
- Nitrous
- Nitrous Guru's.Finer points of a Solid Roller for Spray
- best cam for my ride???
- does plug life lesson with nos
- Fire Extinguisher Bottles
- what kinda of spark plugs can i use
- Best Compression Ratio for N20 Motors
- nitrous?????
- Opinions on Nitrous Systems
- Where To get Shark Nozzle?
- Nos
- 6sp nos guys in here!!!
- best place to install shark nozzle on the elbow !?
- NX Gemini Twin MAF Kit for lt1
- Need pics of guages mounted in cup holder
- NOS Progressive controller Q?
- Nitrous - propane and NOS 58MM TB
- Vortech elbow and nx
- booster or not !!
- New to Nitrous got some ?s so I dont kill my LT1
- wet kit question
- clogged solenoids
- N2o Info
- Someone clue me in on guages please
- how do i know what hp the nozzles are
- NOS dry flow kit? 5115
- digital 6 and knock sensor ?s
- Anyone Here Personally Using a Wet Kit W/ The SDI??
- where do the jets going ont the nx hark nozzle?
- video of my 150 shot pass
- 3.73 or 4.10??
- Nos Throttle Body?
- where to i hook up the fuel line
- Pictures of 10 pound bottle mounting in spare tire well?
- What to do?
- nitrous pressure guage??
- Non projecter tip plugs
- msd window help
- Window switch ?s
- NX kits
- Where can I get a mount platform for a 10lb bottle?
- How much Nitrous
- How do you install a wet NX kit
- jet sizes for the LS1 5177 NOS kit
- Nitrous Works
- couple Q's, Nitrous 101
- Quick Question....gap for TR55's with N20?
- what do you guys know about this ?..looks cool!
- i got my nitrous going
- Schrader valve question
- Whos got a Harlan Window switch
- Nitrous Bottle
- NX or NOS
- N20 and Propane?
- what do u think the gains will be???
- First 5176 175hp shot test ????'s
- Is this a good nitrous controller?
- TPI NOS kit on an LT1?
- Hotcam and N20
- i ran the 75shot can i run the 100??
- How much do you think I should charge to do this nitrous install
- When is the best time to spray???
- How do I wire up the MSD rpm switch & FPSS?
- What do you Know About...
- need help... having problems mounting N20 Gauge in gauge pod
- Bottle Warmer is given me problems. Any one experience with these?
- Various Fuel Concerns/Ideas
- Various Fuel Questions/Concerns
- 5176 Dry shot track results
- nitrous works jets
- nitrous works spray bar plate
- CC305 cam with nitrous
- OK, bottom line, what do I need to run a 100 shot wet on a 93 LT1?
- LT1 Tach wire
- can I spray with impala head gasket?
- Fpss ?
- large shot, need cam?
- LT1 Spray Plate
- Need pics of mounted solenoids and WOT switch
- Who sells spare tire bottle mounts?
- spratin with only 750 psi
- How much will a stock ls1 take?
- What else do I need for a nitrous install??
- LT1 Nitrous ET's
- cc306 and nitrous
- NOS timer control.....
- Can bottle warmer tap into defrost for power?
- Will a NOS remote bottle opener and purge system work on a Compucar system???
- Help finishing custom wet kit
- Pics of your nitrous setups?
- What safety items do you recommend...
- seperate fuel cell
- Nitrous Freeze!!! WTF!
- backfire
- Where do you think a 150 shot will put me
- Who makes a nitrous pressure guage that goes high enough?
- What size injectors should I get?
- My direct Port LT1 Intake On Ebay--NO RESERVE--
- couple of quick ?'s
- NOS parts with a NX kit...
- gauge w/wet kit
- Heads/Cam/Spray what rpm to spray to
- quick question
- Carbureted to LT1
- ? for A4 guys
- hidden nitrous setup
- Finally sprayed it - one question?
- Can someone measure the resistance across an MSD pill?
- 2 questions?
- nitrous question??
- Lowest HP shot on an LT1?
- under carb spray bar Question
- Just bought TNT, how much will it help my 1/4 mile
- Does Nitrous need PCM programming?
- Just bought used Kit got ???'s
- upgraded fuel pump on nx kit?
- How many shots?
- Stupid nitrous question...
- best way to inject nitrous??
- Dual bottle ?? with a single stage
- the 100nx shot
- timing?????????
- Where/How to mount shark nozzle
- Engine damage if you run out of n20 while spaying?
- what igniton
- Can I use a Mallory Hyfire VI on an LS1?
- how is the scc 224/236 536/555 114 for a daily driver
- whats best brand for lt1 maro?
- window pills
- Using A Nitrous Noid As A Fuel Noid?
- what nozzle to use for each shot?
- FPSS how reliable are they?
- Any predictions what the Love Boat will run on the hose?
- Fpss Settings
- Nitrous Plate, Do i need to modify throttle, cruze and TV cable?
- Shark vs Piranha vs NOS Fogger Nozzles
- if i dont have a window switch
- would a Ls1 nos kit work on my 94 Lt-1?
- pistons+N2O
- Ok, ready for my sneak attack, what am I missing?
- ZEX nitrious kit question?
- is soem thing wrong???
- What have in specif LT1 NOS or NX kits that doesn't have at the universal kits ?
- How to maintain pressure w/ 15 lb bottle
- nx 175 jetting.
- DIY Direct Port Q?
- what injectors do i need
- Nos writeup please or help
- would my engine last 1 more year?
- Nitrous and Longetivity
- spraying an 85 TPI
- Simple question, please don't laugh.
- wiring bottle heater
- will a nos dry kit for a 98 maro work on a 94?
- 150hp Wet shot on 130k Shortblock
- Using 1 step colder plugs without using nitrous yet?
- Nitrous Crossroads.
- Dual State Nitrous??
- Vortech elbow with nozzles?
- window switch?
- 100 shot: What will it do?
- dry kit instalation help???
