- nitrous problems with 95z
- What are you running on your 305/350?
- Looking for NOS y-fitting
- Bottle mount for Spare tire?
- how long does your bottle last you?
- Who's crazy on the GoGo Juice?
- n2o
- What is this NX part?
- 93 Z Computer ?'s
- Anybody running VENOM kit?
- shipping a Nitrous bottle
- N20 On s/c LS1
- Fuel upgrades?
- Underhood pics of LT1 Nitrous installs?
- How to mount the bottle behind the drivers seat?
- N2O = eating up ur engine??
- Problem: No Gain in N2O
- LT1 TNT Plate Kit....
- CompuCar Nitrous?
- spray=head gasket
- What Guages are Recommended with N20??
- what shot should i run??
- Best N20 setup?
- Edelbrock EFI kit.....what ya think?
- NX 150 shot 1/4 mile results
- 200-300 shot on a carb.. plate or fogger
- Another dope fiend
- Whats the biggest shot on LT1?
- What Is The Best Brand??
- Best Nitrous Kit???
- ZEX kit any good?
- Venom Q...
- How much to spray!
- How many peeps here have the LT1 Scanmaster and/or MAF Translator??
- Where's the best/cheapest place to get a N20 Pressure gauge for a pod?? Anyone?
- Oxygen sencor nitous cut out kit?
- How to install a MSD window switch?
- Help quick. Motor won't rev past 2500 rpm under load.
- Question About Wiring NX Bottle Warmer.
- How many Amps?
- I need NOS info..PLEASE HELP!
- Venom 1000 or Venom 2000???
- What is the max h.p. on stock fuel pump?
- Anyone running a mechancial N20 guages or ANY mech gauges??
- With spary, 3.08's got to go.
- Nitrous question
- NOS vs. Nitrous express
- whats up with my system
- any tips on install of nx remote bottle opener
- How not to spray in 1st.
- Horsepower Range Of A Venom 1000 Kit???
- Looking for N2O system... anybody selling one !!!
- 125 shot? w/NX LT1 kit
- Anyone have a extra NX shark nozzle?
- Surging over 5000rpm with good O2's and PSI???
- Need NOS sticker
- Any LT1's running this yet ??
- Need opinion from N20 users.
- Newbie bottle warmer questions..
- nitrous works kit
- How neccasary is a Nitrous Filter.
- Question on NX TPS WOT switch
- How Many people use the LT1 Scanmaster And/Or the MAFT?? Opinoins? Please Help!
- Venom or Nex???
- Nitrous bottle heater element
- Building NA stroker and might spray...
- basic N.O.S. kit for $350... should I take it?
- Large shot of juice-
- Inleine fuel pump quest
- High Mileage LT1's Spraying NOS?
- need a center console gauge pod
- Who sells a 2 5/8 Single pod and a Regsized Single Pod?
- Tnt Conversion Kit???
- Adding a TNT Kit. I need some advice on how much to spray
- Guys spraying 150 wet shot w/ stock fuel pump inside...
- Foe Anybody Wondering What N2O Kit To Go With.........
- Anyone using MSD digital 6?
- Long n20 lines hurt power?
- wet or dry?
- why does n20 like a larger lobe separation angle?
- How much N2O is safe for 454
- HELP: install of nx bottle opener
- 75 shot on friends 2001 v-6 question
- Finally got my install pics...
- LT1 Kit on LS1 ??? (NX Base kit)
- Help!
- WB Lambda
- Performance gains of Long Tubes on nitrous powered car...
- Nitrous Works plate kit for LT1 what are the pro's & con's of this??
- how to use n20
- what should i do before I spray 125 wet shot?
- What would a 100 HP shot do with me in the 1/4?
- expectations
- Question on shot length?
- Spraying 100 shot on a bolt on/cammed LT1
- anyone have AOL IM and wanna help w/nx??
- tpi nitrous
- head gaskets
- Anyone know the Place or website that sells digital Gauges??
- Who's Running a MECH n20 Pressure gauge in their pod?How dangerous is it?See My Idea
- Question about perging w/out perge system!
- Running out of N2O while spraying
- anyone need a lt1 zex kit?
- NX MAF Kit on Z06 MAF?
- 2 stage nitrous setup with NOS 58mm TB
- NOS pro two stage kit vs. fogger
- i need a pic of a WOT switch, pissin me off
- Small shot on stock motor
- What is the best kit for 75-100 shot?
- LT1 dry shot in PE mode
- install questions on an ls1?
- Would this fuel pump setup work? NOS related
- NX MAF Kit???
- How much should i spray?????
- Which fuel pump to get?
- Nitous Mini
- 150 shotter's, how much MPH are you gaining after the 1/8?
- TNT 150 wet kit precautions
- NE1 Running with the NOS In-line Fuel Pump? Or NE1 Have Heard bout it??
- window switch, 3k-5400??
- Nitrous Oxide
- All LT1s!!! Who's The Fastest Stock With A 100Shot?
- cant decide, wet or dry???
- How much nitrous can my motor handle?
- How much sooner do you change your oil?
- LS1 Nitrous Activation Switch
- 175 jets for NOS nozzle?
- Need answer to running a big shot
- plate or fogger system?
- Taking off fuel line
- TNT- F1 or F2?
- TNT Nitrous users in here please...
- msd window switch(A4?'s)
- Wet And Dry Kit Combined???
- Shark Nozzle Placement?
- LS1 and can't use a RPM/Window switch?
- N.O.S. dry kit
- How much could I spray?
- schrader valve replacement ?
- Estimated 1/4 mile?
- bumped up timing = no n20?
- NX wet kit?
- How safe is nitrous
- Nitrous on 130000mile LT1 good or bad
- Attention N2O Tech Mod.
- Timing..
- 75 shot = low 12.x's???
- Forged pistons w/stock crank,rods, how much will it handle????
- ZEX KIT! what does everyone think about it?
- I wanna get Nitrous but I am stock.
- Stuck on a cam choice...
- Avoiding the dangers of N2O
- Merry X-Mas all
- Fuel pump for 150 shot?
- Bug Spray
- Spraying into the MAF - worried about freezing it?
- two ?s
- best nitrous kit???????
- How can I tell the difference between the n2o and fuel solenoids?
- Breaking down my NOS Pro shot fogger
- Nitrous Works !
- 5176 Instructions
- 11:1 COmpression and 75 shot
- Direct Port Pro Race NOS kit with Annular Nozzles Pic's
- need kit for stocker LT1
- Reset PCM after K&N and descreen - WOT + Nitrous= low power???
- kinda new & could use a hand
- LT-4 knock module W/N20?
- need help with NOS fuel pump install
- nx kit and fuel pump
- 4bbl Adapter plates with nos?
- Power loss with plugs and timing...
- Dry shot and OL tunes
- Post pics of your system purging...
- Fuel pressure while spraying....
- How to tap into fuel line
- E.T. Approx???
- making nitrous easier on the engine
- Cheap Misc. Nos Parts
- What type of plugs to run
- Direct port advantages? Progressive control?
- Alright, Who is runnin' the Zex setup??
- help with 67 camaro and n20
- Need Pics of Fogger on LT1 intake
- few pics of the setup......
- high hp+spray+m6 Q's
- Compucar Nitrous
- Pics of where your gauges are mounted
- How many different gauges can be bought for n2o?
- 3.8 nitros?
- Complete Compucar Wet Kit 4sale!!
- What ignition is everybody running with their Nitrous set-up?
- Questions
- 100 shot, showing 4 degrees retard
- 4177 is the TR6 part # right?
- N20 question
- Anyone Using Nitrous Works? (also ET question)
- Track Times LS1's on Dry 100 shot
- What's the best dry NOS system?
- Dual stage questions
- NX opener on NOS bottle?
- Hot Cam/ NOS combo
- Anyone using a NX SX2 dual stage nozzle?
- Can I just empty my cats for a n20 install?
- About to install a NX wet kit. Any pointers greatly appreciated.
- Jacobs Nitrous Mastermind help needed...
- Dose anybody have a picture of how the WOT switch is mounted?
- New,Confused, pls Help!
- dual purge conversion???
- Just wondering: Anybody here live in CA and spray?
- Puddle of fuel
- New TB to MAF elbow
- What kit should I get?
- What cam are you running?
- Blow down tube question
- 135000 miles and I want to spray a 100hp shot...This OK???
- Nitrous Advice
- Anyone know how to ge ahold of Harlan?
- TNT power ring won't fit on
- reducing sparkplug gap?
- Spraying with stock Ignition?
- Propane???
- Wet kit LT1 guys inside...
- What it takes to run NOS...
- Stand alone fuel system, for nitrous? Or intank?
- nos ??
- What are your comments on the NX kits?
- Total Seal rings for N2O usage
- nitrous ??
- how to wire a MSD window switch?
- N2O and BOOST
- juice on a diesel?
- MSD window switch?
- Can I run N20 with stock internals?
- what plugs?
- Dual stage set-up question??
- how much tq does a 150 or 200 shot add?
- White smoke, smells like coolant, rattling: anyone wanna take a stab?
- N20 without headers and stock fuel injectors?
- Nos
- NX system and NOS TB plate
- Question about Nitrous
- Nx Maf Kit
- Should I use my ported MAF ends with my wet kit?
- Anyone have installation instructions or owners manual for a NOS system
- LT4 Knock Module
- jetted nx fogger wrong, 52 nitrous and 52 fuel
- N20 question(direct port Vs regular)
- Pros and cons needed for wet& dry.
- Nitrous Package
