- well its in and spraying......
- edelbrock
- Going pig rich when spraying
- TB or TB boot for nitrous jet?
- nitrous and fuel gauges?
- Spraying too much?
- what head gasket for my lt1 383 with nitrous
- NX intake, NXL DP system, 85mm TB
- What tubing for direct port?
- flo-through manifold is leaking....
- dual foggers in a intake elbow,
- how much nitrous is too much....
- Nitrous and Mallory 685 wiring diagram
- Mail Order Tune
- LE2 LT1 with 75-125 shot. Do I have to change plugs?
- T-fittings from Nitrous Outlet
- FP gauge on stand alone?
- If it burns gas
- Where to get bottle filled in Southeastern NY?
- Window switch?
- How do you tell when bottle needs re-certed?
- Nitrous or turbo
- Breaking up at high rpms
- Nitrous, FJO controller, and Mallory 685 wiring diagram
- Nitrous and timing on LT1
- nitros on a TPI MAF w/ a custom chip that advanced my timming
- Nitrous works EFI systems!
- Jetting on a NOS Plate w/ auxillary fuel pump/cell...
- LT1 Plate System Group Purchase!!!
- Fuel Leakage Problem
- nitrous lt1s come in please
- gear/tire combo
- Newbi need help !!
- 300 shot bottle pressure question
- 100 shot, what size jets???
- ZEX Boost pump
- Nossle or plate LT1
- 2nd stage
- 860 heated brackets questions
- direct port advantage?
- Effects of colder plug on motor when not sprayin?
- Boost meets Juice
- question on spraying out of the hole
- Best cam for 396
- any lt1 8.00 or below 1/8th mile out there
- 250 shot will it hold
- Plugs too cold
- Fitment problems
- Density Altitude and Nitrous Cars
- 175 jets?
- Block good for a big shot?
- Directport Time 2007!!!
- where to hid the purge
- Let me see your solenoid mounts!
- Cold Fusion Users
- Thread sizes?!
- zex questions
- Nitrous / Fuel Injectors
- Need help, what jets should I use?
- Kit shutting off in 3rd gear
- Nitrous Outlet
- Still not working after Walbro fuel pump! Please help!
- LT1 Solenoid Brackets
- NOS sneeky pete?
- Nitrous used as a flamethrower
- mallory wiring HELP
- 1/8" npt distribution block
- nitrous on stock LT1
- Custom switch panels!!!!
- 4AN 90 deg fitting
- Drivetrain Limitations
- 75 shot on a 133k LT1?
- LS1 Timing Retard for Nitrous
- Window options and shift points?
- The Cute Little Solenoid Story!!!
- Nitrous and Cam?
- zex 82011 dry kit for lt1
- 90mm Throttle Body N2O Plate
- Nitrous/Fuel jet sizes
- lt1 +100shot car falls on its face,
- Intercooler sprayer questions
- Nitro Daves 4th Gen Tunnel Mount in a 3rd Gen
- Anyone got good instructions for wiring a purge kit?
- 140,000 miles and nitrous?
- Where to route purge
- Mounted my solenoids!
- Just filled bottle, but only 600 psi on the gauge
- April Nitrous Specials!!!!
- Who grinds a Nasty LT1 gas cam?
- Wiring a Mallory 685 Box
- relay question
- Look at this schematic please
- how do you wire a bottle heater ?
- 8.19 in the 1/8th plus a 150 or 200 shot
- TNT TPS switch wiring help
- Twin nozzles in elbow?
- What do you think about my window switch setting?
- Spring Specials!
- Walbro 255 pump: Is it big enough?
- Switch panel for 1982-1984 Camaro and Firebird
- Finding nitrous
- why on at 3000 rpm
- N2O for the Truck
- Bottle leak help
- Looking for a pic of an LT1 direct port fogger setup
- Biggest shot through a fogger
- dry to wet
- anyone ever blow an lt1 with nitrous?
- Spraying NOS
- Back cylinders going lean?
- 100-150 shot on stock motor?
- Where do you mount your 10lbs bottle? Pics?
- tr6 ?s
- Who wants a 100 dollar gift certificate to Hooters?
- where to tap fuel
- cant feel the nitrous
- Pics of your wet NOS setup plz!!!
- Pics of Nitro Dave's LT1 noid mount
- stock, cc306 cammed LT1.
- NOS wiring help!!!
- Can I get some help on wiring my nitrous?
- two stage purging?
- So do you think I should get a tune ?
- wiring a heater to a switch with single relay
- Anyone from Pittsburgh? Where do you refill?
- Spark plug for nitrous
- Where did you mount your zex box?
- nitrous kit help
- LS1 nitrous nozzle
- jets?
- For You LT1 Guys..
- backfire with fuel on?
- Shot size
- Zex Dry Users Please Help!
- Direct Port on stock LT4
- Nitrous filter assembly
- Lt1 timing with 150 shot
- help with burst disc install
- Nitrous Guage Pre-Plan
- LT1 Install Pics
- Been researching nitrous, few questions.
- Nitrous cams, a brief tutorial
- How much HP will it take? Haven't found my answer with search
- Looking for a safe LS2 Wet shot, preferably hidden *already searched*
- Finished installing Nitro Daves solenoid bracket
- Purge Routing Pics
- Any way to move nitrous from a large bottle to a smaller bottle?
- ...........fpss
- fuel line question...1994 lt1.
- Which Blowdown fitting do I need?
- Nozzle ripped intake boot
- what do locked up injectors sound like?
- Not shifting on the spray?
- Look At My Parts. What Is Good And How Do I Use Them!?
- Direct port and Fuel Rail Covers
- A/F target on 150 shot??
- few tech questions now that my new cam is in
- Nitrous composition
- Got Milk
- June Nitrous Specials!!!!
- Nitrous question!!!!
- Settle an arguement
- How to conver zex dry to wet?
- Where can i find this set up
- Question
- Nitrous and Ignition set-up
- Nitrous Outlet Widebands
- NOS Throttle body 20360nos?
- Dry nitrous kit (maf style)
- Which plugs to use for nitrous?
- How many of you spraying out of hole w/high stall ???
- nitrous
- How to keep the torque numbers up or flat?
- 125 shot???
- Safety First!
- Dual nozzle 200 shot
- You pick the WINNER
- Can I remove the label on the nitrous bottle?
- Spark Plugs Question
- Would the real Autolite 103 please stand up...
- Want an NX Banner
- Hooking up BMN WS in conjunction w/ Mallory 685?
- ok to spray 125 wet shot with this cam and stock tune
- NEW PRODUCTS, Black Series Display Controllers.
- bad zex Solenoid
- And The Winner Is..................
- Battery Relocation & Nos Setup
- Plumbing the fuel side..
- The 2 Day Sale!!!!!!
- Bad fuel solenoid???
- Best system....need a rec.
- Recieved my kit, couple questions
- Best Timing Retard Module
- July Specials from HSW
- Nitrous?
- Solenoid, gauge and window switch pictures
- The 2 Day Nitrous Sale!!!
- 125-150 on TR5's ok?
- Mounting MSD digi-window switch
- Wiring the MSD digi-window switch.
- LT1 falling on its face...
- rpm switch
- Airbrush Special
- Yank converters and nitrous use
- Nitrous ring gap
- N2o effect on stall
- N20 and fuel pressure Gauge
- Intake Manifold recommendation
- VID 355 lt1 gm847 with Nitro Dave Plate and NX Noids.
- would nitrous be resonable on my car?
- Can I use the ZEX fuel injection kit on an LS1
- fuel rail fitting
- retarding ignition timing Q
- Anyone know what color?
- How much Nitrous?
- post your underhood pics plz
- so what exactly will i need?
- gas line for nitrous Diagram
- crank case ventilation
- What else helps nitrous
- dyno results
- Spark plug choices
- Not spraying thru the shiftes and ET?
- What options are out there for ash tray switch panels?
- How many 1/4 mile passes.
- My bottle Pic
- So how'd you guys wire up your 685?
- Need Some Tech Info.
- MPH gain with a 150 shot?
- when is it OK 4 Nitrous on a new motor?
- Wiring up two step/line lock with nitrous?
- Zex dry install question
- Options for retarding timing with nitrous
- Zex dry question
- Stock bottom end?
- August Nitrous Special!!dont Miss Out!!
- Timing help
- Dished pistons and nitrous ?
- 250 shot on a 355nforged bottom end
- Wiring a Mallory 685 to a Zex dry kit
- Nitrous System Wiring
- What else do I need for this Nitrous Kit?
- zex nitrous mangement system unit?
- locations for hiding...
- Nitro Dave wet system pics
- Got A New Kit What Do You Guys Think
- Low MPH w/ mods and 100-shot
- Sportsman fogger/Jacob's electronics box
- LT1 Nitrous Question
- Dyno shop for my nitrous camaro need A/F reading
