- Where to put fogger nozzle w/ Vortec intake elbow?
- Bad spot for solenoids?
- Anybody used the "main line" system from NX?
- Does nitrous go bad?
- New add on !!!!
- No dyno tune.
- Pics of switch panels
- anyone have the nitrous works plate kit for lt1
- spraying without tuning?
- MSD harness For Mallory 685..couple other ??
- Nitrous Bottle Brackets
- Check out my mods> safe to Dyno?
- Nitrous Works Tunnel Mount
- How to Hook up nitrous?
- How to wire it all together??
- Re: LS1 auto and nitrous???? HELP!!
- I know i'm going to get flamed for this...
- looking for a wet kit,need suggestions...
- throttle body plate
- Can I run 100 shot wet on 94 Octane w/out stock timing retard?
- April Nitrous Specials.
- nitrous works lt1 plate
- Testing my N20 system before hitting the street??
- plate vs nozzle
- I worked all day for nothing....
- New Mechanical Remote Bottle Opener
- Wet system for Stealth Ram intake...
- Blow down tube?
- Nitrous newb. 75 shot HELP!!
- PROBLEM: Digital Dual Window Switch with TPS sensor
- What else do I need?
- Re-fill?
- Is all nitrous the same?
- Should I get rid of my NOS plate for a Nozzle?
- nitrous
- Mallory: Small orange wire
- I hit the button for the first time yesterday (also have some tuning q's)
- nitrous nozzle testing
- Ignition Box Question
- Anyone using nito dave's dedicated fuel system for nitrous????
- Plugs, wires, and ignition for N2O.
- Nitrous and Methane?
- Timing question
- What jets do I need???
- Jet sizes and tuning
- N2O tapped TB plate (LS1)
- Help with bottle mounting
- Nitrous on a Stock LT1?
- All Installed
- Viper Install
- NX Gemini Twin EFI system lt!
- Nitrous Express LS1/LT1 Mass Air System
- Nossle placement ?
- Best Progressive Controller
- Ok need some input.
- toggle switch
- Blow downtube
- Whats the best plugs for a SBC Carb motor??
- How to mount the bottle???
- 12+ switched power
- which is the better pump for 650hp?
- Spraying before MAF but on my 01 Mustang GT???
- What jet sizes are these??
- rpm - tach wierd issue 7 k bounce!?@
- Small shot?
- spray on a innercooler?
- Bottle pressure???
- your thoughts on how to run my Fuel Line and Blow-down tube??
- Harlan window help
- Likelihood of engine fire due to wet kit?
- When to use seperate fuel system?
- Is this a good price? N20 bottle...
- Purge valve question.
- How much abuse does 100hp dry show take on a stock motor?
- window switch vs. "nitrous button"
- Anyone using the 860 v-spray purge block?
- somewhat new to nitrous
- Thinking about getting N20
- problems
- 95 Z28 Auto
- NX bottle opener woes
- Standalone fuel system. High or low pressure?
- Just bought a TPI Nitrous Works kit..any ideas
- i am putting my nos back on after a rebuild of my engine and.....?
- 365rwhp heads and cam + 150 shot?
- value
- NOS fuel psi saftey switch
- i want to add a 2nd stage to my nitrous ?
- Appropriate size fuse for NX bottle heater
- foger nozzal aim
- nitrous on a v6
- nitrous dont work
- air temp and nitrous
- Injectors???
- Plug Gap for a 100 shot?
- spark knock under spray
- timing for 250 shot?
- Part #'s on zex jets
- lean a/f
- Fuel system upgrade for boltons plus 150 shot
- Gapped Rings for Nitrous but Direct Port or Single Nozzle.
- Spring Nitrous Kit Specials!!!
- Compucar wet kit with NOS fogger nozzle and .047 and .053 jets- what hp shot is this?
- Best Nitrous Kit for my Car
- injector size for dry shot and 396 CI
- Nitrous wiring problems
- Need NX wiring diagram
- 96 LT1 nitrous questions
- Fuelrail fitting on my L98?
- Dual Stage vs Progressive Controller
- Can my car handle 100 shot?
- how to activate the 2nd stage
- Exper. w/dynotune kits? N20 Q's??
- holley says fogger wont flow over a 150 shot!!
- window switch
- fpss ?'s
- what size jets?
- what shot?
- tapping into plastic fuel line
- track times with 305 tbi&n20
- What RPM activation with 3200 stall?
- All those with NOS 5176 kit inside please
- Help with window switch
- NX solenoid rebuild ?
- nitrous questions on ls1
- n2o gauge position
- 28lb ls1 injectors on a bolton lt1 with dry kit
- Wiring the NX Bottle heater.
- Question about NX MAF kit
- Nitrous Or Not 108,000 Miles?
- still getting "detonation"
- Too Much Pressure?
- Fuel Cell Installed
- et time on 01 z28 with 100 shot?
- Mad Z28 tune-how much timing to pull?
- Nitrous Tuning Questions
- LTCC and MSD Digital Window Switch wiring?
- 75 shot tune or not to tune
- Converting from a Plate system to nozzle and other ?s
- N/A tune with 100 shot?
- Do I need a tune for a dry shot?
- new car with nitr4ous question
- Nitrous Newb...Being tempted!
- what kind of autometer guages should i get?
- where to mount digital msd ignition box?
- 396ci LT1, D1SC, 58mm NOS TBI, F.A.S.T. and NOS ......
- Whats The Best Kit For Me?
- What do you guys think of the cold fusion kits?
- Stock LS1.. Got all the NX stuff, Need Advice!
- Making my own kit
- HSW bottle opener??
- Plz Help
- Making Your Own Nitrous Lines?
- Window Switch Wiring Problems
- How many heads/cam stock bottom end guys are spraying
- Newb nitrous question
- n20?s need advice
- Well... Im down.. Dry Kit.. Which one?
- What jets for lt1 NOS Dry 150hp w/ 48ps1fp???
- difference between ford and chevy universal nx kits
- Looking for N2O newbie reading material
- Fogger set up
- For those with LT1 nozzle setups...
- NX jet sizes
- lean on a 75 shot
- NX WOT Switch?
- Nitrious controller
- MSD 3 stage retard
- stock ls1 nitrous questions
- Nitrogen Push...?
- Stand alone set up
- Plugs? what kind
- What size shot do you need to start pulling timing with?
- Dirt Don't Hurt?
- is there a longer lasting 1 step colder plug?
- which kit
- How to wire purge and bottle heater?
- whats not enough fuel pressure for n2o
- Mallory 685 w/ Nitrous Works kit
- Nozzle placement with a Moroso CAI?
- track advice
- Will TR55's cause detonation?
- Problems after nitrous install
- wiring for bottle heater and opener
- which octane to use?
- how can you icrease bottle temp?
- nitrous facts
- cheap retard box?
- A/F Ratio for a nitrous car
- Racetronix Pump
- When using 200hp Single shot
- NX safety nut tap size...
- Good set of pistons for a N20 car...
- Any tips before going to NOS???
- 150 shot
- Quick Zex Question
- 200 Shot TNT System on 95Z28 Camaro Stock
- all about nitous
- opinion
- Safe shot?
- Does anyone on here sell these jets?
- spraying BIG for a season
- Well... This is the place where I learn before spraying....
- nozzle placement lt1 direct port
- Just a teaser pic of my mess, err progress
- Need some advice on dual stage 150/150HP?
- Did search..please post 'noid mounting solutions
- zex
- nitrous problems
- i am clueless, need some help
- not running right
- timing retard
- 675 HP/685 TQ HSW Brute Force Dyno Results
- trying to get into 12's
- nitrous piston
- 100or150 shot
- What are you guys running 1/4 on 100 shot?
- Anyone tried the direct port nozzle systems?
- bad idea to run n2o with no knock sensor?
- does it realy matter if you heat your bottle
- fast 90mm intake w/ blow off relief?
- TPI nitrous setup...which one is favored?
- Intermittent NOS shut-off during run
- pro/con of dry/wet systems on stock LT1
- Use C16, add timing
- strange problem with nitrous... please help.
- which nitrous set up is recommended for the set i'm running
- Jets in Intake Elbow
- New dyno #'s
- Would the NX 20915 EFI setup work with my LT1?
- Nitrous Works???
- nitrous gurus... pull timing for 100 wet on stock LT1?
- Some pics of my NX dual nozzle install.
- Lookin to get the nitrous system functional after a yr, need some help
- jets? help some1
- NOS 05151 wet kit on lt1
- Buddy and I are building an LT1 wet system... plate or nozzle?
- Full Line of Nitrous Express and NOS Products!
- Which type is more prone to sneeze/backfire?
- where to run the nitrous line?
- Thanks HSW
- Mallory users
- Nitrous for your R/C car???
- LT4 direct port fogger jetting
- any problems with low PSI and spraying?
- modules/pills.....what's the difference?
- mallory.....timing
- finding jets for the lt1 throttle body nos plate
- Whats involved in a single to dual stage conversion?
