- A couple of Q's
- Stupid Headlights Question.
- quick ?
- Question re: '01 Camaro
- Exhaust Cutouts
- SPEC Clutches and thoughts about:
- Biggest bag for the buck addon
- How can I tell???
- Cutout on a 3.8l?
- Whisper lid questions
- JET modules
- Rs
- 2000 Camaro keeps popping front left turn signal bulbs..
- removed cat
- Need Help from 3.4 V6 Owner's :(
- idle fluctuation when first starting up
- Want '01 Z28 wheels & tires?
- loss of power in low rpms??
- What's a good oil leak stopper additive?
- 3.8 max torque numbers
- help please
- v6 2 ls1 swap
- help needed with intake sensor mod
- Radiator is leaking
- what is this thing?
- finally some decent numbers from teh beast....
- need help please
- Wires from a 93 T/A in a 97 Camaro
- LS6 swap?
- Exhaust systems???
- A/C help
- Best Exhaust for 3.4
- New Member, New(used) Car, New Question!
- CAT removal? Cut-outs?
- 336 rwhp and 397rwtq video inside
- RR help ASAP
- widest tires on 18 inch rims
- No Fire Help!
- new here with a problem....
- 1/8 to 1/4 times
- Will someone please help me out, i need pics of a 96 3.8 engine to see vaccuum lines
- Adjusting the clutch
- Clutch question
- what i'm looking for
- A/C Vents not working
- faster v6 camaro
- roller rockers
- How can I fix my speedo/odo?
- Die Die Die Camaro
- rear end gears for turbo 3.4L
- Some goofy electrical/ECM problems...
- maybee a rebuild?
- such thing as a formula v6???
- hav'n trouble...
- People with 255/50-16's come on in...
- Question on what years have what Gauge Clusters and ABS.
- New Pics.
- Uneven brake pad wear
- Mpg
- Need help, Engine pics
- v6 with twin turbo???
- Intake Air Temperature Sensor
- quick questions from a new owner
- V6 Dual Exhaust
- Do I need GM additive?
- MSD- some answers needed
- will this fit?
- Magnaflow exhaust
- blower off of a gtp on a 2000 rs?
- ABS/brake problems
- new camaro owner needs help
- Does anyone else have a rattling noise?
- Buddy Help
- torque specs for 95' water pump.
- POST 1/8 and 1/4 times here
- everyone with a 96 3.8 please reply
- Flowmaster 40 Series?
- anyone need an extra 3.4 (engine only)...take a look
- Noise with slight miss
- 97 V6 Tranny probs. Please help!
- 1997 Camaro 3.8 V6
- Turbos on a 3.4?????
- I need some help with my AC
- LOUD Squeaking from belts....won't go away!!
- Hypertech Programmer?
- grand national motor in a 96 f body
- Volant Intake
- door swap? 94 doors to a 99
- Plentum spacer
- auto gears in manual
- Turbo 3.4l...
- Valve Cover Question
- Rear main seal?
- Service Engine Light Question?
- brakes and rotors question
- SLP 1.8 rocker arm GP
- upgrade your v-6
- Need help picking a muffler
- Flowmasters on a V6?
- cold air, lid. 96 camaro??
- 2.8/3.1 Rejoice
- Clutch question
- cheapest way for posi
- Quick ?? for you 2000 Automatic guys
- Dude at work's gotta V6...
- V8 Shocks
- 3.4 V6 Throttle position sensor
- looking for numbers. . .
- new 3.4 owner with questions...
- Urgent Help
- Engine Swapping Question - V6 vs. V8
- 3 questions
- electrical problem after rain
- Where can I get 3.4L timing gears?
- Rearend noise
- Which Tires?
- need help/advise on selling my V6
- oil level
- supercharger
- need help finding supercharger or turbo
- 3.4L upgrade suggestions! Help!
- Magnaflow...quick question
- Some Car Troubles
- springs
- intake
- can i chip my 98 V6?
- Exhaust question...yes another one
- seatbelt guides
- more cheap modifications?
- LS1 Swap in 95 3.4L FireBird... Input??
- Way to check if I have Airbags?
- parts car found...any issues to look for
- Radiator fluid leak (help please)
- "camaro"
- Everyone who has dealt with Tiago, inside please!
- 3.4 water pump different from 2.8,3.1?
- When I ran carfax my car came up as an RS..confused?
- Is this for real?
- 91 R/S 3.1 Eletrical problumes
- Synthetic vs REg Oil
- replacement automatic shift knob
- tail lights
- Dimensions of Bolt for Brake Caliper
- do not buy from ammperformance.com
- Is there a power wall with 2.8 intakes?
- STOCK 98-02 1/4 times
- engine swap
- how does a cutout sound on a 3.8?
- Locations
- 38 lb.hr. injectors to small?
- 3.8L to LT1 swap
- Just installed LT1 one piece.
- clutch pedal squeaks
- Late night and we are empty
- Nitrous
- Engine Swap Thread. V6 to...?
- Major Power Adders
- New Sticky Threads Posted
- Engine Stutters when accelerating
- does anyone know?
- rear seat latch problems
- Buick 3.8 Supercharger
- What Intake, Headers, Exhaust, etc...?
- polished heads
- Oil Pressure
- False OR Valid claims?
- slp cai noise
- HELP please
- V6 Insurance rates...is this bad?
- paging Tiago
- V6 to LS1
- Girlfriend's buying '97 V6...grinds in reverse????
- V6 front coil springs and shocks
- y87 package?
- fuel economy
- turtle wax... safe?
- need detailing advice! please help
- Anyone bought or sold a v-6 f-body lately?
- Home made CAI for 3800. Any of you made one?
- Gee Thanks Rich
- hesitation and pop when cold
- Car light question
- What is the FAW and RAW weight
- Monte Carlo Z34, what to do??
- 01 Z28 exhaust on a 97 RS?
- Question about 1989 Camaro RS Fuel or Spark
- Uncoated pacesetter headers
- Running badly -- rich?
- goveners
- under the hood blower
- Strut Tower Brace Question
- Magna Flow
- hope this is where to post this.. brake problem
- security dash light
- What octane should I use?
- 3.4l Rebuild
- gain?'s
- tempted to get some bolt on SFC
- what is a tac code?
- feul injectors
- how much boost can a stock v6 take?
- 2.5" B&B triflo exhaust (v6)
- reprogrammer for a 96
- URGENT! Please help!!!
- gain question inside please
- RS owners...
- Water Pump Install HELP!
- top speed?
- Hello v6 World, whats new?
- B&M shifter install
- programer for a 98?
- When will my 3.4L Die?
- The power/intake chips
- Water pump and timing belt?
- 3.8L turbo kit
- www.eriespeed.com
- fuel pressure
- New Forum
- wantabee
- engine swap troubles!
- 3.8L is misfiring (I think that it is not plug/wire related)
- fastest v6
- installing a new driver seat
- Should I use used A/C evaporator core?
- Broken Engine? Need Help Please
- Define: "drifting"
- short shifters
- need more v6ers
- AC Help- quick question
- Car for sale...and cleaning out the garage
- Crazy noise from rear diff.
- Valve Lash - please help
- Porting the 2.8 heads
- v6-v8 swap, do i need a diffrent gas tank?
- Since I haven't posted in awhile, FMIC pics
- Heater problem
- Question about 18" tire size??
- supercharger question
- Sub Frame Connector Question
- whats the ride gonna be like?
- Exhaust question
- Faster & Faster
- AC clutch
- got my best milage EVER
- 3.4l expectations w/rebuild
- What do you think
- exhaust
- Removing a V6 engine.
- Paint Code
- taking stuff off the engine
