V6 Tech
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. oil gage problems? 96 v6
  2. How much should I sell for?
  3. clutch replacement
  4. V6 to Z28 buildup
  5. My mom is getting a camaro. PLZ read
  6. Larger throttle body 3.4
  7. How good are 4th gen V6's?
  8. $300 Tranny Mount
  9. 4th gen V6 top speed
  10. P codes
  11. P Codes Help!!!!!
  12. LS1 NOS kit with lid into a v6?
  13. How much can be safely sprayed on a v6?
  14. a few questions
  15. new motor
  16. Larger injectors
  17. 2000 Hpp3
  18. CamaroV6.com a total disgrace... read within
  19. Camaro making a squeeking sound
  20. V6 3.4l N20
  21. In my defense.....
  22. Does anybody know what the word "Camaro" means?
  23. B&M Shift kit for V6!
  24. TB bypass and 160 stat.
  25. Eaton M90/112 Blower project
  26. Bad plugs and wires, now have questions
  27. Removing speed limiter
  28. What do you THINK I could run
  29. 98+ 3.8 V6 q's
  30. 93-95 3.4 V6 specs
  31. 3.8 into high 13's low 14's??
  32. High pitch squeal ?
  33. PLEASE READ!! RK Sport Header Lawsuit
  34. How fast do you turn your 3.4?
  35. kumhos
  36. Well the day has finally arrived!!!
  37. rough starts
  38. SLP CAI vs K&N FIPK
  39. Ca Clunk
  40. Camaro decals
  41. 3.1 Plug Wires
  42. motor will not rev past 3900/4000 rpm's
  43. I went to autozone
  44. What year did the V6's start coming standard w/ AC?
  45. Clutch Pedal Makes a Clicking Noise
  46. thermostat help....
  47. whine whine whine
  48. Where can I find a TB & Mass air sensor for my 3.8L?
  49. new v-6 f-bod
  50. Need new computer, have some questions.
  51. Won't let me shift into Park!!!
  52. MagnaFlow catback exaust for 02 V6???
  53. ABS Inop light??
  54. hypothetically..
  55. What gears come in 02 3.8 Coupe w/ posi??
  56. Shift Cable!?
  57. reverse gear HELP PLEASE
  58. What is wrong?
  59. posi? LSD?
  60. 3.73 or 3.42
  61. Wierd electrical problems
  62. looking for some parts
  63. 3.8L Turbo Update
  64. squealing brakes
  65. Y-Pipe = Power Loss?
  66. 4l60e slipping out of gear.
  67. Sea Foam!!
  68. How much power can a stock 3.4 bottem end take?
  69. IS this an LSD?
  70. fog lights
  71. Front wheels lockup when braking
  72. how much hp?
  73. flywhell, pulleys etc...
  74. Catalyic converter
  75. Cheapest Dual exhaust?
  76. Comparison of Cat-Back Exhaust Systems
  77. Help Diagnosing Car Troubles Please!
  78. Cat
  79. What is the Camaro lug offset 5x????? (nt)
  80. To all 3.8L guys.
  81. Is this a good deal?
  82. Torque specs for 3.8L V6 water pump?
  83. trannys
  84. Jet Chip
  85. What type of rearend is in my car?
  86. 2.8L muffler
  87. 3.8L Exhaust setup
  88. Coil questions
  89. K&N air filter
  90. 95 camaro 3.4 noises
  91. What will a cam and lifter do for me?
  92. v6 free mods
  93. GTP supercharger
  94. crazy oil gauge
  95. engine dies
  96. Help!!! Just Lost To A Jeep Cherokee
  97. 120mph gauge scan
  98. Installing Power Windows?
  99. B&m Transpak????
  100. turbo v-6
  101. oil gauge problem
  102. what about this intake setup?
  103. HELP!!! Broke a stud on my rear "drum" brakes!!!
  104. Somebody with a V6...Help!!
  105. Will a bigger i-pipe make my exhaust louder?
  106. Stock tailpiping for dual duals?
  107. Another metting in CA
  108. RAT Stage 2 TB/MAF
  109. 3.1 to 3.4
  110. 2.8L specs
  111. UPDATE: RK Sport Header Lawsuit
  112. starting hesitation?
  113. How do I change the fuel filter
  114. "Security" light won't go off!!!!!
  115. v6 trembling...need help
  116. Starting probs after runnin for awhile
  117. Option Code Questions
  118. No Power...what Do I Do?
  119. TB Bypass for 3.4?
  120. i need help with a 3.4 help fast
  121. help with power
  122. heater/engine temp problem
  123. How much is a 2002 Y87 V6 Camaro worth?
  124. Need help fast with mom's car
  125. Is it possible to have ram air and cold air induction
  126. getting fed up of my f bod!
  127. #5 misfire on 98 3.8??
  128. Corvette Air Lid??
  129. 94 V8 FIPK for 95 3.8
  130. Good Deal?
  131. 93-95 camaro now or 96 camaro and wait
  132. dyno results
  133. A4 sliping? Need help A.S.A.P.
  134. scoop for cai under the car?
  135. Which is quieter?
  136. Will this catch on fire?
  137. Will an LT1 fit into my 94 firebird I'm replacing a 3.4 V6?
  138. Help with cylinder heads
  139. help asap
  140. 3.8 vs 3.8
  141. changing v6 spark plugs....passenger side
  142. Muffler Size?
  143. Where to get Accel Coils?
  144. who has the highest mileage 3.8?
  145. SES light
  146. someone explain this!
  147. pictures of moda r6 wheels anyone?
  148. Best 3.8 Engine Mods?
  149. 3.4l vs 3.8l
  150. Ram Air Mod vs SLP intake
  151. best bang for under $500
  152. wanted, 3.8
  153. engine conversion
  154. Question about stock diff. gear and upgrade
  155. 1996 3.8 Starting Problem
  156. performance chip
  157. Dad Broke My Parking Brake
  158. My sound system cracked my dash!!!
  159. 95 3.4 Code reader?
  160. How much should exhaust installation cost?
  161. Not sure what to do.....
  162. VISA tires (a.k.a. Falken tires)
  163. **Urgent help please**
  164. Need Confirmation of 2000+ V6 auto's.. experts inside
  165. Gear question
  166. 96' V6 Revving Problem....!?
  167. Why get a lid?
  168. Transmission RPO codes
  169. intercooler
  170. CAI for 99 V6
  171. vortech supercharger
  172. 3.8 engine mods
  173. Cam for 96 3.8 liter?
  174. Best induction setup?
  175. Best Exhaust setup?
  176. i think i have a problem
  177. CAI on ebay?
  178. Shift Points
  179. best clutch to get?
  180. Best catalytic converters?
  181. V6 or V8 For First F-Bod
  182. 5speed gear ratios.
  183. Surge w/SES light
  184. Help!! I hsve starting and idle problems
  185. Please Help!!
  186. please help! thanks
  187. Flowmaster exhaust system for 3.4l
  188. Fog lamp bulbs
  189. Acceleration problem in heavy rain..?
  190. Exhaust question for a friend
  191. Backfire through intake!!
  192. Chips
  193. Pulleys
  194. 3.4 Pacesetter headers
  195. serpentine belt
  196. WTF idle air HELP
  197. SLP shift knob
  198. slight hesistation under initial load, pls help :)
  199. JET pulleys stress me out! Need part#
  200. eibach sportlines on a V6??
  201. Best sounding exhaust for a v6?
  202. cam?
  203. Pacesetter headers
  204. Cuting out problem at 3500 rpm
  205. Autometer Gauge Install
  206. How to get stripped Screw off?
  207. Oil change and gas gauge
  208. What headers for 02 V6 Camaro?
  209. 96 chips/reprogrammers for 3.8
  210. 3.4 liter heads...
  211. Cat on exhaust smoking! HELP
  212. HELP!! Important Fan ????????~!~!~!
  213. Will this make a ricey sound??
  214. recommended mods
  215. Keyless entry problem
  216. manual fan switch
  217. Best Ways To Add Some Quick Horse Power
  218. Hazard lights coming on and both wheels....
  219. Nitrous Kit
  220. GTP body control module Problem
  221. anyone ever have a timing belt/chain go?
  222. cam install?
  223. extreme loss of power...thinking tranny
  224. V8 exhaust on a V6
  225. Wher to buy? -After Market Parts
  226. oil change
  227. power mirror conversion
  228. squealing front brakes....need help
  229. exhaust smoke and back fire
  230. Help...acceleration issues...
  231. A/C not cold & hissing sound in vents from A/C?
  232. 96 camaro CAI
  233. Anyone looking for a new motor?
  234. crazy steering wheel!!
  235. drop a gtp into a 3.8???
  236. Advise on buying a camaro
  237. oil filter
  238. anyone running msd wires?
  239. amber turn signals
  240. How to remove passenger side lift bracket
  241. SLP 1.8 Roller Rocker Package
  242. MSD Digital 6 Ignition
  243. need help with crazy problems!!!
  244. What do I have to do for a V8 conversion?
  245. 95 Firebird in Parts
  246. Nx Wet Kit 20920....help Fast!!!
  247. check engine light
  248. Tranny Swap
  249. rant: follow up to previous post...
  250. Congrats to Max!!!!!
