- Parts/Vendors
- flowmaster product # help
- Is this normal? Shifting;auto
- cat back size
- What are gapped spark plugs?
- hey Mustangeater
- 02 V8 exhaust on 96 V6?
- uh oh, car probs
- Transmission
- Is my Firebird a good deal?
- hello...first post
- scanmaster for the 3.4?
- help!! car shakes bad when braking!! w/in
- traction control on v6...after 98 did posi go standard or just y87 w/in
- wut mods????need help
- rims
- SS Hood 4 sale 98-02 camaro
- Wow 1.8 Ratio Roller Rockers for 3.8
- mixed feelings on EDELBROCK catback
- V6 Tech
- Strut Tower Brace???s
- ram air or CAI
- Everyone With 96 3. Y87 3.42 From Factory Pleae Help
- Time and Shipping info
- need help hatch wont stay open
- i need some info on my '96 (squeking and rattleing)
- please help
- Exhaust Installation Question.
- What should I expect to pay...
- Security System Recalls?
- exhaust question
- My First Camaro
- v6 performance
- Best things to get if Rebuild?
- window problem
- Where to find parts???
- God Bless America
- What do your 3.8s run in the 1/4?
- rims question
- Problems with my Auto shifter
- what's the fastest camaro V6 out there...streetable i mean
- Mounted turbo pics within
- HEY Someone Please Help?
- 96 corvette 4L60E work in 95 3.4L camaro
- Car running lean
- Ported TB
- Wheel Question
- Why is everyone always picking on me?
- whisper lid with paper filter?
- Camarov6.com still down??
- I pipe exhaust question???
- Turn Signal Problem
- RKSport rear section exhaust installlation question
- i know tech board but this is funny
- power steering belt
- Turbo for my V6 or Sport Bike??
- A new system from Flowmaster from Horsepower TV.
- Factory Spark Plugs?
- My V6 vs TA
- Need some info on Throttle body sizes...
- 5 speed or 6 speed?
- suspension sway bars?
- Dynomax 17429 Catback system
- My 5 speed kicks out of first.
- The great misfire mystery
- my new plans
- Need Opinions- Plans for V6 and LS1 Bird
- Cat backs
- GM crate V6 motor?
- Add performance parts to my V6????
- abs inop light won't go away????
- do you know your car?
- Question: Adding Manual Fan Switch?
- Air Bag light
- test for sig
- v6 lt1 swap
- Resonator?
- gas mileage
- Idle Problems...
- 4.3 Timing Question
- lsd install possible?
- new heads
- difference in octane
- Is this normal????
- bosch platinum +4 ?
- Cutout on a 3.4L
- exhaust question
- Tranny Linkage Bolt Help
- couple of questions??
- SLP V6 1.8 rocker arm package
- car won't start please help
- Picking the right tires??
- Headers, Midpipe, Catback
- Where to get PCM?
- Where to buy Flowmaster catback #17356
- want headers for 3.4
- V6 3.8L Parts
- Tires / Wheels...I already have them, need advice
- Horsepower?
- Got a questions for ya V6 guys....
- Hi-flow cat
- what to do?
- new flowmaster
- 3.8 K&N FIPK nice kit built today...
- pacesetters for 194 :o
- i love b&b
- 3.08's to 3.42 gears; 2/3 Series Carrier question
- cam for SC??
- Help, V6 cutting out @ 4000rpm
- Gear Ratio on Stock Camaro, Question!
- What kind of gears to get?
- timing gasket
- Resonator or electronic cutout
- ABS and low traction light
- Center force Dual Friction Clutch?
- LSD / 3.73's
- LT1 K&N & V6 K&N the same?
- Hard starting. Why??
- which series flowmaster?
- Removal of plastic front grill insert on 2000 cam
- starting and accelertating probs with 99 3.8
- totaled car
- I need stock 5-speed ger ratios, and stock 3.4L cam specs...
- Oem Firebird codes?
- Sub Box + Rear End Weight
- v6 computer chips????
- whisper lid
- newbie
- lids
- V6 Conversion
- Need some help on a part #
- Leak near water pump. HELP pls!
- blown head gasket? long>>
- 95 camaro
- cheapest?
- Will Z28 tips go on my Y87 Muffler?
- Rollers 1.8
- What Times/Speeds do you V6's get
- Exhaust Question
- swap idea 4 u guys
- Torque Converter...Please Help
- how to install rear shocks....
- 3.42 vs. 3.73 in an A4
- 245/60/16 on Salad Shooters
- Changing serpentine belt
- Homemade Ram air system
- Bleeding Brake System for Bird with Traction Control
- Transmission mount
- stock v6 springs
- Need help w/ Headers/true dual/pipe size
- clear front plate cover
- Installing 3.8L catback kit
- bad vibration need help
- springs, what to get for 02 v6
- high idleing
- Engine Swap Help
- 3.4 L Pacesetter headers....
- 97 3.8L Performance Chip??
- Whats Better??
- what shifter should i get
- What's a torque converter and does it help?
- dual exhaust
- Will LS1 Drop Springs be same height in a V6?
- Need new cat. converter
- 350 crate motor
- SLP "Loudmouth" on a 98 3.8
- Need to do a part cross reference
- T-Top Conversion
- fog lights
- which exhaust should i get
- high idle...again
- What gears do i have??
- What size should i buy???
- Help with seafoam please.
- pro kit/ bilstein install help
- okay guys...helped me out in past...see what u can do with this one
- Door Swap
- 3.4 to LS1 Swap
- Best place to buy V6 cams
- gears
- putting chrome tips on exhaust
- What engine should I get?
- 3.8 Borla Exhaust w/Comp Cam Sounds?
- Gears Please Help Me!!
- beefy 3.4 cam???
- top speed govenor
- Alternator is poop; What's a good alternator brand?
- Going to the Track this weekend..lets Guess what i will run:)
- 96 Firebird leaking coolant
- custom GMMG?
- Where do I find a dynomax catback????
- 3.73s in v6
- steel wheels
- Service Engine Soon
- few q's on trashed tranny/clutch...
- 1995 3.4l V6 A4
- Drop shipped? what does that mean?
- Post your 0-60 times!
- trans question for future
- Window Motors
- Moving to MO....Anyone live out that way?
- What kind of Oil Pressure do ya'll have?
- Easy or Hard to install Shift kit??
- Z28 Throttle Body on 3.4
- Z28 Rearend on V6?
- 3.4L intake?
- Obdii??
- Went to the track last night
- Mass air Flow, Ram air hood?
- camaro pics
- egr?
- Power max 3.4
- What plenum is the best?
- A dumb question what a 93-97 bolt pattern
- help needed with thermostat/rough idle
- englishtown dragstrip
- cam gears and supercharger Q's
- Brake Rotors
- My Car vs. Honda Prelude
- 98 v6 to lt4
- 93 V6 ... what is this plug on the driver side head?
- 3.8L Intake Manifold Bolt Torque Sequence
- SES diagnostics help
- Anyone lookin' for a 95 3.4L M5 HPP?
- what do you guys think?
- finaly somewhat better pics
- Clutch install
- Intake
- 95 Camaro 3.4L and the SES light...
- Cabin Air Filters?
- AC tune up?
- EGR block off mod?
- dual exhaust????
- Edited my cardomain today
- weight diff?
- TB Plate for NOS
- Beat Me
- 1FastV6...good news
- intake question....
- Catback Exhaust
- V6 have more Hp than Z28 ha ha
- Cam + 1.8 Roller Rockers
- rear end+tranny
- Flowtech muffler on a 3.8
- inlet outlet
- 2.25 in to 2.5?
- only 48000 miles and this...
- New pics
- Torque specs
