V6 Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. idle revs?
  2. What tire pressure should I run?
  3. info on lowering
  4. Nitrous
  5. Air Tempeture Sensor Mod...?
  6. Think I can install this thing by myself? (exhaust related)
  7. Brakes question
  8. broke some new records
  9. crappy fuel guage...
  10. lowering
  11. 3.4 info?
  12. Brakes real grabby when cold
  13. Help With My Ws6 Rims!!!!!!
  14. D or OD?
  15. Question about delayed interior lighting
  16. Question about stock paint scheme
  17. Stock IAT sensor problem
  18. i want a head count....
  19. Calibrating tach when switching to 155mph speedo?
  20. it's baaaack!!!
  21. Poll: for all y'all that got a whisper Lid on your V6!!
  22. Question about the 3.4 vs 3.8
  23. 94 3.4 falls on its face at about 70 mph
  24. Had a realllly good time tonight with the Camaro.....yes the Camaro & NOT the truck
  25. Winter Driving
  26. putting a new rear end in
  27. CAI + Lid Installed
  28. What gears do I have?
  29. RS Body Kit
  30. trying to tighten the valvetrain
  31. Ignition Coil Replacement
  32. Size of 2.8 injectors
  33. Security problem...
  34. Silencer removal ?
  35. still searching for that 3.8 exhaust
  36. spark plug change
  37. clogged cat?
  38. Bay Area F-Bidy Gathering- Jan-4th
  39. 1992 3.1L, can someone take some pics>>
  40. A new V6er
  41. Sprayed the 125 shot, new best et
  42. ses codes
  43. car is fixed....(long)
  44. Jet Stage 2 Module
  45. DAMNIT! SES light misfire screwed EGR took car to track & BLEW IT UP, DESTROYED IT!
  46. swapping engine info???
  47. 3.4L Headers
  48. Do igintion upgrades make a difference?
  49. simple question
  50. Just a ?
  51. K&N Air Filter
  52. 96 V6 to an LT1 questions
  53. A sad sad day
  54. finally got some pictures on cardomain
  55. power steering pump
  56. 1/4 times?
  57. Converter
  58. Paging 12secV6
  59. 3.8l ignition ????
  60. Bigest Pain so Far
  61. ***Will a T56 short stick fit a 95 M5 stock shifter??***
  62. hard shifting?
  63. My stupid speed limiter with 410 gears!!!
  64. 3.4L 1/8 mile times? & MY NEW ET!
  65. Hi Everyone...
  66. need some help please!
  67. Just Finished Headlight Conversion
  68. selling car
  69. what the heck is this thing?
  70. legal or not???????
  71. CAM???????'s
  72. Brown water came out of my exhaust??????????
  73. How many Emmisions legal Cam's out there for 98 3.8l?
  74. reading SES codes on '98
  75. roller rocker set?
  76. New Pics Up
  77. weight
  78. Help: think i broke camaro playing in snow..
  79. FS: TransGo Shift Kit
  80. Fs: 98-02 Ss Hood
  81. B&M shift +
  82. 3.4 Turbo
  83. 94 running like ass - need help
  84. Manual Fan Switch
  85. TransGo Shift Kit
  86. guage cluster help!!!
  87. disk brake conversion
  88. engine conversion
  89. engine conversion
  90. Replacing Rear Main Seal on 3.4
  91. SLP takeoff Z28 shocks.
  92. crate engines
  93. couple of mod questions
  94. Vortec truck engine swap
  95. V6 camaro
  96. what rims???
  97. exhaust
  98. The CamaroZ28.com calendar and V6 Camaros...
  99. What gears are in a 95 spd firebird?????
  100. Oil Light, Please Help!
  101. What part is this?
  102. cooling problems
  103. My 3.1L V6 gets 11MPG!
  104. SES Light flashing and car runs like crap!
  105. Which tires are better????
  106. Posessed V-6
  107. just some questions...
  108. stock camaro
  109. Got a third gen V6? Want headers?
  110. desktop dragstrip
  111. 3.4ltr turbo guys/gals step inside
  112. i've got a weird one for you
  113. complete super charger kit for 3.4L f-body for sale...
  114. general questions...
  115. How much rear wheel power will I gain If....
  116. Z28 throttle body
  117. Exhaust Pipes
  118. What exactly does a air pump do
  119. Need Help
  120. shift knob
  121. V6 gears
  122. port and Polish
  123. more pics inside
  124. Clutch just died, need advice.
  125. How Would A Cut-out Sound On A V6??
  126. cheap s/c for rustangs but not us
  127. Camaro Hoodscoop/Front Facia Concept
  128. Throttle Body and MAF
  129. Will 3.42 gear ring and pinion from a 00 SS fit on 99 V6?
  130. A/C light/LED all of a sudden out
  131. EGR value for a 91 3.1L V6
  132. voltmeter all the way up
  133. 2003 Mustang GT
  134. Runnin 15.9 need to run 15.6
  135. Fuel Injector Cold Start Valve
  136. I started building my V6 headers!!!!!!!!!
  137. Front Brake Rotor Q?Q?Q?'s
  138. Tire,brake,rim diffrences between V6 and V8?
  139. Oil Pressure starts high, then drops?
  140. need some opinions
  141. Driveshaft
  142. Just did V6 HP test
  143. New Exhaust
  144. Ideas for Buddy
  145. 98 C5 rotors on a v6?
  146. Cold Start Injecter"FYI"
  147. Can a 3.4L firebird be put into the 14's N/A with bolt ons?
  148. 3.4L guys need help oil problem with my car...
  149. leaf blower? is it possible???
  150. FTRA cold air intake and 160 thermo
  151. edlebrock
  152. The Smog Nazi's strike again!
  153. gears?
  154. what brake pads?
  155. Engine upgrade help...
  156. Eh... I think my car is dead.
  157. track time
  158. I blew the turbo on the PSD...but look at its replacement..MUWHAHAH
  159. Changing Spark Plug wires
  160. Pacesetter headers
  161. misfires
  162. Cat question
  163. Would this Exhaust work?
  164. B&B sound/video clips
  165. SLP CAI Gargley Noises?
  166. Question about first mods to do
  167. gear swap
  168. make a v6 sound like a v8??
  169. exhaust from a z or ss???
  170. dynomax, and how to stop rasp, when rev?
  171. Scu2000 For 96-99 Auto 3.8 Camaros And Firebirds
  172. Cheap SC for 3800 II ?
  173. jet chip stage 1 or 2
  174. Some videos of my car in action...
  175. what gears sould i get?
  176. where to get CAI
  177. mods for 84 2.8 V6 camaro
  178. Please Read Asap Need To Get My Car Together And Need Your Help Asap
  179. what will void my warrenty?
  180. misfire under load
  181. anyone using synthetic oil?
  182. 93 3.4 to 3.8 Upgrade
  183. How many miles on your V6?
  184. got a SC...need advice
  185. Misfires at Idle and Hard to Start
  186. difference in springs
  187. Strange exhaust thought...
  188. supercharged?
  189. 1/8th Time Slips
  190. Possible to rebuild FPR on a 3.4?
  191. Factory Alarm
  192. What are the stock shift points w/ 3.42's?
  193. Car is away for winter question about gas tank
  194. 1992 3.4 Twin-Dual Cam 5-speed in a 3rd gen proposition...
  195. Spark plug order? on 3.4
  196. Help!!! Big Time Electrical Problems!!!!
  197. Help with tires sizes?
  198. removing air silencer on 2002
  199. SERIOUS company looking for feedback to produce the ultimate F-body turbo kits!
  200. 3.4 with 215 horse?
  201. yet another problem
  202. Blinker On Frits Need Help
  203. Oil Leak
  204. Is there a noticable difference in a Y87 Camaro over a normal V6?
  205. 3" catback = not enough back pressure?
  206. Interesting day at the track today.........
  207. Twin turbo custome setup......is it possible?
  208. beating a dead horse
  209. gear code question
  210. 1LE tranny mount
  211. v6 gauge...
  212. Factory Alarm Help!!!
  213. Spark plug wires
  214. v6 White face gauges
  215. Dealer problems
  216. Bad Thermostat?
  217. Speed Limiter Removal
  218. Porting stuff
  219. Exhaust ?'ss for my 2001 V6
  220. estimated 1/4
  221. please help
  222. What Rear End Gear Ratio would this have?
  223. SS Hood for sale
  224. TransGo Shift Kit for Sale
  225. engine swap
  226. V6 swap to a LS6
  227. Vibration at idle
  228. What 1/4 mile times can i expect from my Y87 V6?
  229. Cheap SLP intake for Salve (V6)
  230. Intake Noise
  231. what is my car good for now? HP wise?
  232. ss takeoff exhaust?
  233. noise and vibration from 1st gear
  234. Did My Friend Ruin My Tb Spacer Everyone Inside
  235. some pics, hehe...
  236. Car loses power @ WOT
  237. Spark Plug Maintanence
  238. Jet Stage 2 Power Module
  239. Part Locations
  240. Guage Overlays
  241. exhaust....ok, ok, last time
  242. PASS-KEY II giving me problems!!
  243. Question about V6 Exhaust.
  244. Car Wont Start
  245. american thunder
  246. changing tranny fluid
  247. Am I missing anything??!?!
  248. What else can I do?
  249. 2 CATS on a CAMARO?
  250. Best Exhaust for the Buck
