- Exhaust & Intake
- car alarm tech?
- Brakes
- Superchip or JET Chip
- v6 camaro vs v6 mustang 2000
- 1 Piece Driveshaft
- List for V6 to V8 swap, am I forgettign anything?
- Tach
- Adding Zexel to non-posi rear
- GM's 2.8- How reliable?
- V6 vs V8 springs Interchangeable???
- Wire Ohmage (?)
- where did the link go for the v6 timeslips
- Rear End Swap
- 3.8l rebuild
- 2.8L problems
- When do 3.4's die?
- Just got 80 series on 3.4
- what kind of internal work can be done to a 3.8
- took car back to track
- Exhaust leak in manifold
- 3.4L Problems...EGR, Charging System...
- V6 free mod question
- Ran My Car
- Dynoed the bird on the bottle
- Can't figure out what this noise is coming from
- I've got Trouble...that starts with T and rhymes with...
- I can't get the intake manifold off
- sup
- New 1/8 times...
- Question about an odd setup
- SLP Cold Air or SS Hood
- i have some ?? that have no been answered
- pics of my car comments ???
- how much is a radiator
- Good formula for a stiff suspension?
- who make rebuild kits for thr 3.4?
- im confused
- i have $80 credit at rksport
- z28 sway bars
- New times with the little v6
- V6 Parts: Gauging interest....
- It's only a V6
- What year did 3.8 come out?
- Why V6?
- Stock 3.8 Times? 5spd or A4?
- Wrecked my car...
- wow sumttin is wrong
- hey guys, Im new, got a few questions
- Will these tires work on a 93 Firebird?
- stalls
- Installing pipe in place of Catalytic Convertor...Need Answers ASAP...
- SS Sway Bars
- Cai?
- How do i remove alternator? HELP
- Burnouts
- Need to know quick...
- Help with high/low beam lights
- rear end ?
- 3.4 probelms
- A scooter wants to race me
- Does anyone make an aftermarket cam for the 3.8L
- Beta Tester Spot for Batman's S/C
- When to replace clutch? Fog light replacement?
- cam question
- Whisper LId?
- ECU Programming
- Head Work???
- Supercharged 3.8
- CAI or Free Ram Air Mod?
- Rear End Gears
- Whisper Lid or CAI?or Both?
- Belt Squeek at gear shift
- W68 appearance package
- Not your ordinary V6
- cold weather startup
- t top conversion manual
- What mods should I do to my 3.1
- Glow lights
- car jerking and not goin past 45 all of a sudden
- brake problems?
- Vibrating worse each day!
- Where's it at?
- Will this shifter go on my car?
- 160 Thermostat
- shaky tranny
- oem clutch replacement recommendations
- Who has rear axle noise?
- Basic Mods ALL in major help
- cams??
- a sad day...
- I know this is the wrong section BUT!! I need to sell this ASAP!!
- heater
- I Need To Know Where I Can Buy The Ultimate Clutch!
- What size cam they put in the V6 60's?
- manual fan switch worth it?
- pullys from rksport
- roll bar
- Slaughtered
- new to the board
- Changing Valve cover gaskets
- Center console door
- good suspension???
- ?? about V6 3rd generation
- 3.73 Gears
- LT1 in a 98 V6
- Tune-up
- 3.1L pistons
- Where in the heck are the bleed screws??
- Took the 3.4 to the 1/8 mile again...
- me at the thunder racing shootout
- car is stuttering/stalling..
- How to remove the fuel rail?
- Must turbo charge
- 3.8L Engine Misfires
- SES upon highway deceleration...
- steering wheel radio controls
- suspension problems?
- Emergency Brake
- GN powered 1995 Camaro!!!
- Borla muffilers?
- turbos
- LS1 Rearend is in! But I need help with brake related problems...
- FS: (99-02) Whisper Lid
- what to look for when purchasing a camaro
- spark plugs?
- Removing heat shield?
- LS1 master cylinder???
- Door Locks
- Flickering Lights
- Help the Newbie!
- SES code question
- Pulling my v6
- Rough Idle in a 3400
- highflow cats
- 700r4 from a 6 cyl. into an 8cyl.
- 1994 Mustang V6-vs- MY 1993 V6 camaro?
- Car got a check up; there are some issues
- 93 V6 tries to die after its warmed up.. whats wrong?
- New 3.4L
- 3800 runs a 14.3 is that good???
- 11" clutch disk? flywheel change?
- hars to start..
- rough start?
- Driveshafts
- Best price on SLP CAI kit?
- Car Started Overheating
- carb to mutiport swap
- 3800 Question
- Throttle Body Bypass...
- OK to put straight pipe in place of CC?
- 2.8 power?
- wondering on how practical this is?
- Mustang
- been thinkin bout it
- Ram Air Airbox
- Flowmaster...
- LOUD Cunking Noise
- Help with bent suspension
- brake pads
- 3.4 engine Q's, truck, FWD and camaro.
- Changing gears..
- Help
- Hi
- Still getting bad milage
- LT1 TB on 3.4, can it be done?
- Suspension???
- turn signals
- t tops arived!
- v6 mod hsp question...
- Borla Exhaust (cut-back) PLEASE HELP!
- Get to take camaro over seas!
- SC kit for 98 3.8 camaro
- It wants to lay-down just after it downshifts...
- Gonna be needing tires soon...
- V6 casting and ID #'s
- v6 vs v8
- Whats wrong with my car ???????
- 3.4 to 3.8 swap
- Fog Light Fuse Keeps Blowing
- Parting out my car - mods must go to pay for the LS1
- Car Starts Then Turns Off
- Back Pressure?
- sub frame conetors?
- Changing wires and plugs
- How hard is a V8 swap on a 95 3.4L?
- Where to buy a Superchip??
- My Car
- accelleration problem
- If you know any thing about 3.1's see this.
- Hose from the radiator???
- Basic v6 upgrades....????
- Whats This Plug???
- center console
- best sounding & lookin exhaust for 3.8
- V6 1/4 mile times?
- IAT Sensor
- what all can you do to modify a 96 v6 bird.
- replacing the engine, is it worth it?
- Mean N/A V6.
- best cat-back system for the buck-performance
- Quaddrivers?
- Rearend question
- civics.... haha
- Car wont start...
- Exhaust Question
- recently started running rough and strong exhaust smell
- SLP CAI Filters
- getting ready for rebuild and have some ques.
- ****Flowmaster 17356 Catback Install w/ guide and review****
- Engine sencors
- Ran the turbo bird........
- Turbo for a 3.4 V6?
- 4L60(700R4) won't shift!
- any opinons of what mods I should do next on my 3.4L? I am at a blank...
- 2.8 Transmission-fluid change question
- V-6 Guys, I need some parts!!!!!!
- putting away for winter any tips?
- Auto to Manual Conversion? Has it been done? How much?
- Time for 60K tune-up....at 65K miles
- Video of my 3.4 M5 runnning 0-75
- If it can make 7500lbs move 13's....imagine it in this...
- H.O.?
- Starting to run bad
- Boosted 3.1, fuel?
- My buddy's V6 run
- What do I do next???
- TO: Rollin in a Camaro
- 1992 3.1l >>
- Air Induction
- CAI vs Modded Stock Induction
- what should i do first?
- Bay Area Camaro Z or V6 gathering???
- 3.4L Hybrid up and running, sound files within...
- How much power?
- Springs and Lowering
- Question for Magnus
- cam selection
- Short belt w/o A/C
- Problems w/ M5
- Attn:ALLintheRED
- is it just me...
- Good Mods
- got problem... need some 3.4l EGR, and removal of sanpped bolt techniques..
- V6 Brakes/Suspension Vs. V8
- HVAC overlays
- My Insurance went down!!!!
- torque arm
- Eek! Fake dual pipe exhaust?
- 3 Maintainence Questions
