V6 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21
  1. Oil pan gasket change
  2. Coolant leak at TC
  3. Code P0001 and P0003- Is this a bad fuel pump?
  4. Code P0001 and P0003- Is this a bad fuel pump?
  5. v6 fuel injection to 350 carburetor
  6. new and getting a car in two weeks!
  7. Toss Up....
  8. original cam specs of a 95 camaro
  9. hey guys i was having a problem
  10. heater core question
  11. hi im new w/ a question
  12. start problems
  13. 95 Firebird Hard Start Smell Gas Goes Dead At Times
  14. for those swapping motors
  15. v6 95 to 350 injected
  16. 4.3 vortec
  17. starting problems 1994 3.4L
  18. coolant lines that goes into head
  19. Newbie
  20. ls1 into 89 rs camaro
  21. Any cars other than the Camaro that have a 3.8 and 5spd
  22. An auto-start alarm
  23. New O2 Sensors Improve gas Mileage?
  24. Oil smells like gas???
  25. New Engine
  26. Stock 3.8 coil voltage?
  27. Msd Dis 4
  28. pressure plate torque specs?
  29. Starter problem or Flywheel problem
  30. is it ever safe?
  31. 3.4L idle problem
  32. 1997 3.8 heater core
  33. What does Missfire feel like in a V6?
  34. odd noises from air intake system 97 3.8
  35. 1998 Camaro - wont start
  36. p1404
  37. Is $550 a reasonable cost for EGR valve/gasket replacement on a 3.4L...
  38. p1518
  39. $70 Electric SuperCharger??? Do these work?
  40. $70 Electric SuperCharger??? Do these work?
  41. non-fbody.....gm 3.8L v6 timing chain swap
  42. 94 camero 3.4 idle *please help!!!*
  43. Have a brake light issue...
  44. battery drainage time to ask the experts for help
  45. 3.4 swap probs
  46. Help!!!
  47. MAF cleaning?
  48. Now What?!?!
  49. Stock or Performance
  50. Catalog
  51. (95 auto tranny in a 96
  52. looking at a 99 3.8, any tips?
  53. well the Camaro is in it's death bed
  54. Stalling, Idling Issues
  55. Best Exhaust???
  56. 2000 V6 3800 Camaro ?'s before purchase
  57. 1996 3.8L Miss
  58. finally fixed the problem
  59. Differences in fuel pumps
  60. coolant problem
  61. drivers window stopped working on 97 V6
  62. 98 Burning Smell
  63. cylinder map for 98'
  64. need a direct fit 99+ fuel pump
  65. Project: Camaro
  66. distributor to coil packs
  67. Can i take off my ecu on 92?
  68. Want the car BUT Code P0420 and rough idle!
  69. Quick connects for coolant reusable?
  70. what are the 1/4 mile times for a stock 3.4
  71. the 3800 f body with a GTP supercharger??
  72. Turbo Kit for 3.8
  73. My car dies when i turn...
  74. 2.8l V6 question
  75. Gotta 2.8l question for ya
  76. I respect the 3.8
  77. 94 Camaro v6
  78. pcm tuning
  79. Anyone swapped the 3.4 into another platform?
  80. throttel body
  81. Quick 3.4 question
  82. shudder/shake in gear 98 3.8
  83. I GOT MY refund back
  84. 3.1 Operating temp?
  85. installing gauges
  86. I'm sellin my Car, The post is in the for sale section
  87. ABS Module question?
  88. how do i now if my firebird has TCS
  89. Help Rough Idle
  90. EGR Valve question
  91. spark plugs
  92. Y Dos Every 1 Say That V6 3.4
  93. if you recently changed plugs/wires-misfire warning
  94. Changing 96 to a 97
  95. Alternator noise on 2001 3.8
  96. I have a 1999 Chevrolet Camaro 3.8l. I want to make it faster?
  97. Damned rpm spike is back
  98. Help Help Help Anybody
  99. throttle body
  100. 3.8l turbocharger???
  101. V6 to LS1
  102. Evap purge error
  103. Need Help Finding The Problem With My 99 Camaro
  104. rear end
  105. Turbocharger for a 1999 camaro 3800?
  106. Will this do anything performance wise for my 3800 camaro?
  107. Check engine code p0440
  108. check engine light again
  109. V6 or V8?
  110. 3.8 internal or external balance engine
  111. Panhard Rod??
  112. Multiple cylinder misfire Question..
  113. Low oil pressure
  114. 3.1 Bucking Violently
  115. Harmonic Balancer question
  116. Headlight Casing Bolt Problem
  117. Thermostats?
  118. ls1 driveshaft?
  119. Rear wheel bearing -- can I remove the axle myself?
  120. 1999 Chevy Camaro 3.8l mods?
  121. re-using intake manifold gaskets 3.8
  122. Crankshaft timing gear question
  123. 99 V6 w/70k miles, trans flush or fluid change?
  124. just picked up my new car
  125. Problems after hosing my engine off!
  126. I have a 1999 Chevrolet Camaro 3.8l thermostat question?
  127. Is bad U-Joint causing my humming/howling? [PICS]
  128. Ring and pinion set installation questions
  129. Firebird 3.4L problem! Help!
  130. Reprogram computer for a different year trans
  131. rear main seal
  132. *Compression Results*
  133. speed chip for 96 3.8 camaro
  134. pos didn't pass smog
  135. evap purge valve solenoid
  136. Oil In The Radiator?
  137. ready to drive it off a cliff
  138. 1993 camaromwith a 3.4 any problems??
  139. 97 camaro pcm re tuning
  140. Looking to buy 99 firebird with rod knock. Have several questions.
  141. 1997 Camaro connundrum
  142. my car has been over heating lately
  143. starting problems anyone i mean anyone
  144. Somethnig really Wrong HELP PLEASE
  145. 91 FIrebird w/3.1 V6 problems
  146. a/c unit
  147. Exhaust manifold gaskets reusable on '99 3.8?
  148. pulleys
  149. 2001 LS1 V6 engine to 99-02 Corvette LS1 V8
  150. 99 camaro 3.8l blown head gasket
  151. free rear lowering springs
  152. piston slap? rod? knocking sound please help(video inside)
  153. 3.8 bearings
  154. Cam Swap, What do you guys have in your car that works?
  155. 99 3.8 swap to 96 LT1...possible?
  156. Is the 3.8L in the Camaro the same as the 3.8L in the Grand Prix?
  157. cheap horsepower
  158. 96 3800V6 with 120k weird Oil Pressure... Goes to 0 At idle sometimes...
  159. birthday/car not starting
  160. complete lt1 6speed swap outta a 97 z28 forsale
  161. replacing water pump
  162. 3800 + AEM stand alone, anyone else?
  163. Help with a 2001 v6 3.8 with a rough idle.
  164. I think I have an exhaust leak... and a ticking injector...
  165. Am I SOL?
  166. your gauges
  167. car wont start.. can someone help.. heading out
  168. fuel filter/spark plug wires
  169. ticking upon startup, goes away <15 seconds
  170. has there been a computer problem with 97's-2000's??
  171. Freeze plug spraying coolant ?
  172. 3800 spark plug help
  173. Oxygen Sensors
  174. problems running compression test
  175. Alarm disables electrical system?
  176. the correct tool
  177. code p0358
  178. the used car saga continues...
  179. i know its not a chevy
  180. For those of you who've done LSX Swaps...
  181. Coolant leaking from behind motor...
  182. Has anyone tried hacking the 94 3.4 PCM?
  183. Car died, now wont start.
  184. intake plenum / fuel rail removal
  185. Water pump oops. Help!
  186. #11 fuse keeps blowing
  187. differential oil
  188. 98 3.8L Performance help
  189. code reader problems
  190. Idle problems 2 questions in one.
  191. Blown tranny from a shifter change?
  192. oil pressure drops
  193. accelerator cables?
  194. Just got a free Camaro
  195. tranny removal
  196. My custom stainless steel setup? Let me know what you think and if it will work.
  197. 99 3.8 ASR module tripping and engine stalls
  198. Shock Sensor? Car Alarm?
  199. RPM Stutter on acceleration
  200. 3800 motors from what cars will work in 98 bird?
  201. car will crankbut wont start
  202. Radiator leak?
  203. hydraulic roller and flat tapped lifters
  204. Different fans/radiators?
  205. 99 V6 Code Issue - Cooling Sensor?
  206. Ignition Coils
  207. 3800 rebuild
  208. light throttle surging
  209. compression
  210. Coils keep going bad
  211. 3.4 makes a racket through the CAI above 2500 RPM
  212. The upcoming 200k mile time to tune help
  213. does anyone have
  214. throttle body
  215. starts runs 15 min and dies 1991 3.1
  216. Fix'n friends camaro, lil help?
  217. 3800 Pictures
  218. 3.4L Rebuilt/Reman Engine
  219. Which slave cylinders are interchangable with 3.4L
  220. A/C Compressor question
  221. v8 fuel pump in a v6
  222. Exhaust Manifold Comparison
  223. weird electrical problem possibly
  224. low oil pressure problem
  225. 98 Firebird, hard starting
  226. Here we go again after 7 months
  227. Fuel pressure 36-37 PSI on 3.4
  228. Tuning for a 1996 V6?
  229. '97 3.8 Hard Start
  230. Harmonic Balancer help
  231. 1996 lt1 Harmonic Balancer help
  232. crankshaft pulley removal
  233. Sputtering issues
  234. 93 Camaro Transmission Issue
  235. P0420 Code that keeps coming back
  236. Cars been misbehaving lateley
  237. Loud ticking noise?
  238. Camaro keeps dieing
  239. Question about V6 performance
  240. Camaro running/starting problems????
  241. Anyone ever clean their own fuel injectors?
  242. 2000 3.8L V6 wont start
  243. 96 rs camaro
  244. Rad drain 1993 3.4
  245. driveshaft....car is broken down right now
  246. 98 Camaro 3.8 P1153 code problems, please help!
  247. need help turboing my 3.8
  248. Fixed starting problem!! Woohoo!!
  249. Transverse muffler vs universal??
  250. all bad = not good
