V6 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21
  1. hvac
  2. 94 engine swap
  3. check engine light
  4. what is normal oil pressure for 3800 v6
  5. The best oil
  6. Help, need help with redline
  7. CIA--SLP vs. Whisper lid??
  8. grommet
  9. "Security" light? what for?
  10. pushing limits on mileage
  11. 98 3.8 Stalling problem
  12. Engine misfire/trans stutter/o2 sensor problem?!?!?
  13. coolant temperature sending unit
  14. Blown HG, cracked head/block???
  15. Intake question
  16. Anyone ever gone from a 3.4 to a 3.8?
  17. security light on
  18. the beatst is back..... and better then ever
  19. Looking for info on turbocharging a 3.8L series II
  20. Looking for a camaro
  21. Oil Pressure gauge quit working
  22. Need a new transmission
  23. poping while turning?
  24. Blown Headgasket. New Engine? Which One?
  25. rocker arms
  26. Interior Fuel Odor!!
  27. Oil spout leakage?
  28. intake 3.8
  29. putting a 5.3 vortec in my 00 camaro
  30. twin screw supercharger
  31. the owners manual
  32. valve covers
  33. 4-6 hours for 3.4L head gaskets, no way!
  34. Magnaflow catback review
  35. 1997 v6 Camaro 5-speed
  36. auto -> 6 speed
  37. tranny mount
  38. 3.8 V-6 engine pics
  39. V6 Turbo question?
  40. maf and O2 sensors. issues
  41. Summit Racing
  42. Rear End swap troubles....HELP
  43. 55 more hp?
  44. v6 power solution
  45. camaro rs
  46. Where to get uncommon parts??
  47. Hypertech Power Programmer
  48. Detailed instructions for bleeding 95 camaro clutch!
  49. Water in engine?
  50. V6 Tubos
  51. TT 3800 F-body
  52. chrome intake tube
  53. Beehive springs?!
  54. tranny ???
  55. not much knowedge of engines.....
  56. !cat questions
  57. P0336
  58. Auto Trans?????
  59. Is a 1995 3.4l Speed Density ?
  60. camaro 2000 problem code p0300
  61. lol step up and get a V8 some real power!!!!
  62. Smoking need help new here!
  63. SOrry to all the people i offended
  64. car missing please help cant find the problem
  65. 3800 series II dependability
  66. New member saying what up
  67. Carb'd Small Block
  68. EGR valve
  69. Can someone help me diagnose this code?
  70. once again
  71. Throttlebody Spacer
  72. LIM Gasket
  73. Throttle problem?
  74. trouble code camshaft bank 1 sensor
  75. 02 sensor
  76. sad sad sad
  77. advice needed
  78. tranny flush...
  79. evac sys wnt pass smog
  80. Multiple Misfire?
  81. Weep hole location on 3.4L V6 waterpump
  82. Someone knows
  83. In need of sum major info.
  84. oil pressure problem
  85. How can you tell it's a blown h/gasket?
  86. Alternator swap difficulty?
  87. transmission problems
  88. '97 3.8 misfire problem - help
  89. Oil pressure question?
  90. Do 98+ have headgasket problems?
  91. Overheating?
  92. Compressor
  93. broken egr bolt
  94. rack and pinion question
  95. Break Light/Signal Electrical Problems
  96. Lifter swap!
  97. V6 Engine Diagnostic Trouble Codes Lists.
  98. Car is going nuts...
  99. fog lamps?
  100. Fan problem
  101. 3.8 firing order help
  102. bought car with siezed 3.4, which route to go?
  103. stupid question, but it's for a jeep
  104. take a guess
  105. AC probs :(
  106. Alarm trouble...Help
  107. 97 camaro Headlights? WTF?
  108. need help 3.4 will not say running
  109. what would cause this
  110. dtc codes
  111. Valve Covers
  112. SES and stumble
  113. Tapping lifters....blown headgasket??
  114. Schrader valve
  115. 3.1 Overheating
  116. p1406 and p0102 error codes
  117. what trans to use on 96 v6 camaro
  118. Compare and contrast. HELP PLEASE
  119. from a v6 to a v8....
  120. Need some brains for my v6 3.4's issues...
  121. Hidden rpo sticker
  122. 3.4 leaking antifreeze out the exhaust
  123. Mods Onto 3800 V6.
  124. Pulled my motor
  125. change oil soon light
  126. car sputters at highway speeds
  127. My 1997 Camaro V6 3.8
  128. a/c compressor
  129. Please advise on problems with 95 Camaro
  130. possible tranny problems
  131. V6 ??? i thought this was z28
  132. throttle position sensor
  133. a/c problems
  134. 1999 V6 Studdering and throwing codes
  135. Help. The 3.4 is overheating.
  136. Sputtering when stomping on the gas?
  137. Why the 2 piece drive shaft ?
  138. Cooling Fans Won't Kick On!
  139. kind of an odd question
  140. Questions
  141. 94 3.4L idle problem
  142. another missfire issue
  143. crankshaft position sensor
  144. Cooling Problem
  145. 3.4V6 1995 4th Gen not starting properly
  146. 3.1 questions???
  147. gauges going crazy
  148. 95 3.8L cooling question
  149. why go V8
  150. 1999 Camaro V-6 to V-8 Engine Swap
  151. 3.4 coolant temp sensor and gauge question
  152. 3.8 Cam Specs
  153. Supercharger on 3.8
  154. How to change spark wires?
  155. How reliable are the 1995 3.4 v6 camaros?
  156. 99 3.8, rought idle, oil in tb
  157. Power Steering Quits
  158. 3.8L supercharger
  159. 1997 v6 CAI question
  160. i need help with my 96 rs
  161. 96 rs vs 07 mustang v6
  162. Scrapping noise
  163. air fuel ratio gauge
  164. Oxygen sensor performance question
  165. Vendor evaluation questions
  166. popping sound
  167. have to do some work on a 98 V6 car, questions on plugs/wires
  168. 96 3.8 to 94 3.4 swap
  169. Questions on what to buy. Or not.
  170. Need help with 3.4L engine knock
  171. my 95 3.4 VS 95 3.8 stang
  172. Gasket Problems
  173. Hypertech problems issues
  174. Oil Pressure Sending Unit???
  175. bogging at full throttle
  176. wtf?
  177. Romping when I start the engine in the morning
  178. flowmaster 40 series on a 96 3.8
  179. P1441 problem
  180. Non-Mechanic Translation Needed for Upgrade Guide
  181. Likely source of oil leak
  182. Squeals AFTER turning on AC?
  183. What would a V6 do with a T/D Exhaust Setup?
  184. 96 3.8 dies after a few hours of driving
  185. are they worth it
  186. V6 conversion in a Nash
  187. v6 problems in friends car..
  188. Its Time
  189. 99 Camaro random misfire code
  190. suspension question
  191. is there any cams for the 3.4s
  192. Practical, Cheap, Do it Yourself
  193. Need Help with a fan...
  194. Backfire, misfire, jump, skip......
  195. A/C works again finally
  196. 98 v6 engine replacement
  197. A/C not working
  198. is there any technical service bulletins for 95 3.4s
  199. 93 3.4 cold air intake
  200. How Much HP does a 95 V6 3.8L Have?
  201. Plugs not firing at high rpms?
  202. Unusually high oil pressure...
  203. Throttle Position Sensor
  204. Is this V6 Worth Buying? Can it be supercharged/turbocharged?
  205. 3.4L ported throttle body, K&N FIPK, 18" Vette wheels for sale!
  206. check engine light
  207. New To The Fourms few questions
  208. Stumped
  209. Loud Wooshing Sound From Engine Bay Above 3500 RPM's
  210. Brake Recommendation??
  211. is this cam kit any good
  212. Disk brakes on V-6's?
  213. rear defrost problem
  214. oil pressure gague going crazy
  215. 3.8L Dipstick question
  216. 99 Service Engene Soon Light
  217. 94 and 95 3.4L
  218. 99 3.8 stalling and weirdness
  219. what are the power gains with this mods
  220. 1995 3.4 and I need to change the thermostat
  221. 1994 v6 3.4L 50mph service engine soon light
  222. 231ci. V6
  223. Simple question about 95 V6 exhaust...
  224. 94 camaro v6 water pump replacement
  225. 2000 3.8 V-6 Oil pan?
  226. stupid misfire
  227. 98 Firebird 3.8L p0301 rough idle
  228. Who wants some TT, Garrett T25's FS
  229. rear main seal
  230. 3.4 no fuel pressure.
  231. v6 5speed for sale
  232. "reduced power light" keeps coming on
  233. looking at buying a V6 F-bod, what to look for
  234. 98 3.8L Fuel pressure
  235. Water leak
  236. 3.8 fuel pump
  237. Need some engine swap info
  238. 1994 V6 overheating...
  239. 3.4 Oil Pan
  240. Timing cover gasket set... where to these others go?
  241. 1998 camaro Stalled no start
  242. Installing dampener... how deep on the crank should I go?
  243. Can The Suspension Out Of A 95 Z28 Wk In A 86 V6 Camaro?
  244. Need a bolt size
  245. owners manual
  246. start up
  247. bogging when stepping on gas
  248. Any of you guys looking into swap in a LT1 - Look in here
  249. help!!!!
  250. Differential decode ???
