V6 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21
  1. Will Pacesetter's make me lose low-end?
  2. 3rd Gen V6
  3. Borla
  4. desent headers for a 3.8firebird
  5. Who has the highest mileage V6 fbod here?
  6. egr vaule problem
  7. Msd
  8. K&N FIPK 3.4 or 5.7?
  9. 3.4l suggestion on add ons
  10. lever under drivers seat?
  11. flowmaster
  12. Stump the Chump (Experts)
  13. 01 Camaro V6 with a stock Camaro SS exhaust
  14. I overtightened my waterpump on my 98 3800 do I have to start over?
  15. spark plugs
  16. Oil Pressure Gauge
  17. temperature gauge
  18. what is the Y87 performance package?
  19. auto to manual swap.......
  20. Engine is making a loud clicking sound...help!
  21. Coolant temp sensor connector wiring?
  22. mods list
  23. cheap better sounding exhaust
  24. rattling noise
  25. Intake Manafold
  26. true duals
  27. 3.4 to 3.8 swap
  28. piecing together a summit 3" exhaust-help with cat (muffler replacement?)
  29. ported/polished TB on today!! (pics inside!)
  30. Antifreeze
  31. burn outs
  32. Camaro 3.8 Headers
  33. Chip For 3.8?
  34. Quick reassurance question
  35. 3.8 toast Waterpump ?
  36. Oil pan Gasket
  37. a/c system problems
  38. one of the nicest v6 camaros out there.
  39. heat meter
  40. 3.8L to 5.7
  41. strang noise
  42. LT1 TB on 3.8?
  43. performance chip
  44. 2 Quick Questions
  45. 3.8 with Dynomax
  46. Starting issues...
  47. o2 sensors on a 97 camaro...SES light
  48. can i use a 96 v6 cooling fan on my 3.4 95
  49. engine idle help me
  50. 3.4V6 underdrive pulley
  51. 91 Firebird, Replaced Starter Now Runs BAD, Help
  52. thermostat
  53. can someone with knowledge work with me on a 5.3 lsx swap
  54. Would a 155 speedo work on a 2001 v6 camaro
  55. f41 ???
  56. turbo kitty or no?
  57. 5k and cant find a shop!
  58. headlights grinding
  59. V6 2.6L(89 RS) to V6 3.0L(90 RS) Engine swap
  60. can i use the intake off this car on my 3.4
  61. Camaro 3.8 work in a FWD GM car?
  62. 98 3.8 complete intake,tranny,heads,block cheap
  63. Does anyone run COMP roller tip rockers on 3.4 V6?
  64. wheel speed sensor
  65. Normal Launch causes drivetrain flex?
  66. Radiator Question
  67. 98' For sale in NJ, LOW MILES, VERY clean!
  68. are the fwd intakes (upper and lower) different that my 3.4
  69. quick question
  70. Engine misses when weather is hot & humid!
  71. Shortblock Upgrade
  72. What the heck?? *photos*
  73. 99 firebird 3.8 tranny hard shift from 1st to 2nd
  74. Yet Again Another Problem!!!!
  75. Possible EGR problem
  76. 3.4 V6 Misfiring
  77. 94 3.4 problems
  78. how do i make by engine faster for cheap?
  79. Need to replace CAT 02 Firebird
  80. do u guys have these starting issues please read every1
  81. 96camaro
  82. Code P0420 - help!!
  83. 91 Camaro 3.1 to 3800 swap??
  84. Performance Chip????
  85. How much would headers and a high flow cat give me????
  86. Anyone who has tuned their pcm. HELP ME
  87. Car Bogging in 2nd Gear?
  88. BAD cooling problem in 94 camaro
  89. 3.8 misfire
  90. does powerbraking a manual burn up the clutch???
  91. does powerbraking a manual burn up the clutch???
  92. does powerbraking a manual burn up the clutch???
  93. 3800 interchange-ability
  94. VATS system wont let car start...
  95. 1997 v6 supercharger or turbo??
  96. digital horsepower tuner
  97. 96 cCamaro For Sale
  98. V6 Chev Vortec Restrictor Plate Engine
  99. New V6 3.8 Motor In So Cal area?
  100. Ignition Type - late 90's V6
  101. v6 to v8 engine swap
  102. 2 questions
  103. what can i do to get my 1997 v6 to perform better for cheap??
  104. Washed Engine - No Start
  105. NOS2006 appreciate your help bud
  106. Help! 96 3.8 V-6 engine "Locked down"
  107. 3.4 CAI on ebay
  108. video problem with"v6"camaro video
  109. 95 V6 vs Z28
  110. Gaskets, Dex-Cool, Leaks & Warranty
  111. V6 Auto Trans
  112. Exhaust headers
  113. 3.4 with security problem
  114. Fuel Line Disconect
  115. Compustar Pager
  116. My Cars on E bay for one more day!
  117. Factory Service Manual
  118. A/C Compressor
  119. How do I?
  120. anyone know?
  121. Engine is loading up....
  122. Spark Plug Question
  123. Throttle pegged this morning, VERY HIGH IDLE :P
  124. 3.8 V6 off road
  125. NEED help !! engine hellllp!
  126. exhaust question
  127. lower oil pressure
  128. camshaft sensor? for 3.1
  129. New Cat, now getting code 420
  130. RPM is too high, help
  131. Coil Pack & dielectric grease
  132. misfire and no code?
  133. Bad trac times
  134. Random Stall Out and Won't Start!! HELP!!
  135. Remove Black Hood Liner??
  136. new clutch
  137. Full throttle V6 southern clash
  138. Anyone have pacesetter headers and a catback exaust??
  139. clutch problem, please help!!
  140. Lost to a supercharged grand prix with some stuff done to it
  141. Need to know what bellhousings will fit a 94 3.4
  142. coolant leak at rear of motor
  143. Will 3rd gen d/s work on 96 RS
  144. k-member
  145. my 1997 v6 is pretty fast
  146. converter and trans 3.4l
  147. My 1997 v6 5-speed strip video 1/8 mile
  148. starting prob
  149. See if you guys can figure this one out..
  150. Stock A4 3.4 V6
  151. Starting/transponder Problems?!?!?!?!
  152. the pictures out of my magazine (new 2009 camaro) v6 lol
  153. Guide to Installing rear disk brake conversion
  154. lifters?????
  155. trans....sux?
  156. 2.8 to 3.8 S\C swap
  157. new exhaust pics!
  158. Dtc E504, E545, 7700, 7900 & 8100
  159. question...
  160. Belt tensioner out of alignment :(
  161. heater core
  162. Coolant pipe on a 3.4
  163. Please Help ASAP
  164. SES Light...
  165. I'm new here...Can someone help me out?
  166. Camaro Suspension Help
  167. Camaro with Bose System
  168. Won't Start
  169. guide to removing wing
  170. bearings going? 3.8 with 90xxx miles (sound clip)
  171. Service Engine Soon
  172. Need help wiring LT1 '94 dash harness to '96 v6
  173. Whats the best exhaust
  174. power windows
  175. Fuel Pump?
  176. hard starting 3.8
  177. does anyone have pics or diagrahams for this
  178. How would i make my 01 v6 go atleast 170
  179. Car Running Like Chit
  180. Help 98 -2000 Springs- Same Or Different
  181. heater problems an radiator gets hot
  182. odd noise
  183. 3.4L OHV parts
  184. 3.8 rattling like a rod knock
  185. reprogram ECM for gear swap
  186. 2001 Grand Prix starts hard when hot PLEASE HELP!
  187. Cold Air Kit
  188. ecu & ecm
  189. OH GOD ...HELP ME! Another code
  190. old gas!!
  191. FTV6 Southern Clash: ***event***
  192. My V6 to LT1 swap (PICS!)
  193. how to make v6 3.8 fsater
  194. How to spend $1000 on a V6 3.4
  195. MSD wiring
  196. check engine light question
  197. Belt tensioner removal '96 3.8?
  198. 3.4 exhaust
  199. Is the 3.8 v6 governor limited?
  200. Tuning my 3.8 with my laptop?
  201. Starts but dies
  202. experts help im stumped?
  203. 1989 V6
  204. Is this a good deal????
  205. i know this is off topic but......
  206. programmer for 96' 3.8
  207. After Lt1 Swap Did Any One Change The Stearing Colum
  208. SEAFOAM cured pinging!!! VIDEO!!
  209. catylatic converter
  210. I need your guys opinion?
  211. I need some information please...
  212. Ignition Control Module
  213. V6 rear end and driveshaft question...
  214. Is there a way to reprogram the V6 PCM for 3.73 gears
  215. Quiet Muffler/Exhaust Recommendations for a V6?
  216. Ls1 Swap
  217. 94 Camaro Fuel Injectors
  218. Strane gas mileage consumption and performance.
  219. LT1 Swap
  220. clear headlights
  221. Rebuild in the future
  222. High Idle and Wierd Hanging RPM
  223. Pictures of 3800 bellhousing/5sp bellhousing
  224. Since I can't post on camarov6.com yet.. trans question
  225. v6 mustang clutch question!!!
  226. 3800 series injector size?
  227. misfires on cylinder 6
  228. MAF part number for 2000 v6
  229. ls6 or ls2 engine swap
  230. V6/LS1 Conversion
  231. 95 3.4 Won't start
  232. LS1 Lid on 3.8 Firebird
  233. 1997 3.8 5-speed handling
  234. "check Gauge"
  235. 1
  236. 95 Camaro 3.4 HELP
  237. anyone out there ever install a big block in a 93-97 camaro
  238. V6 heater problem
  239. 4.11 rear?
  240. Car is Breaking up top
  241. 3.4L V6 Misfire at Idle
  242. 3.4L engine rattles? help
  243. fuel line trouble....HELP PLEASE
  244. Oil Pressure
  245. how do you add a photo to a thread???
  246. Pacesetter Y-pipe rattling
  247. Valve Cover Gasket Installation?
  248. fuel related problem
  249. Help!!
  250. help with o2 sims
