- hesitation and misfire on 94 3.4L
- tires
- track times
- Oil pan on a sixer
- Best intake for a V6
- muffler
- 3.8 Header Bolts
- Picking up a 1994 with a 3.4... are they good? Have questions
- 97 3.8 liter v6 idling problems
- Sway bar size
- Flowmaster!
- Underbody Rust
- Buying an MSD DIS 4 - questions
- Alternator for a 3.4 help!!
- Camaros?
- Multiple Misfire help
- Shed some pounds off that maro!
- missfire only in overdrive
- What size gas tank?
- WTF is going on?
- Selling your camaro?
- Mileage worth it?
- questions about v6-LS1 conversion
- Nevermind Previous Thread I Posted
- Keyless entry programming
- I put in a bigger radiator.
- fuel ,wont start.
- 3800 rebuild
- Removing EGR on a 3.4
- False Misfire Code?
- Pics of rusty drivetrain & VIDEO of engine, weird skip.need advice!
- manual trans issues 96 3800
- B&M Ripper Question
- 3.4L What are symptoms of bad Crank Position Sensor?
- power steering pump
- ls1 swap no start
- ??Car has loss of power on both bottom and top end, it hesitates, vibrates, shudders.
- engine will not turn over
- 3.4 to 3.8 questions
- PCM Programming for 3.8L
- What's the prob??? My gas guage goes up and down irratically.
- needs upgrading
- Automatic to Manual
- 12-13mpg in 3.4L
- A little help please..
- 95 camaro 3.4 V6 Cold Air Intake
- 1997 Camaro RS 3.8L V6 mods... what can I do?
- which are teh best sites?
- msd dis 4 help...
- Underdrive pulley...
- 1998 Cai
- 3.1 sucks
- new
- 3400 to 3800 swap?
- Does LS1 driveshaft fit 2000 v6?
- can I swap the 3800 series 2 out of my 97 camaro for 3800 series 3 supercharged
- How many miles on your V6?
- 3.8L trouble code
- Overheating! Please Help Me (I've been going crazy with this)
- 3800 series 2 HP ??
- Trans filter for 2000 A4
- '95 3.4l Stock Tranny
- Cold start problem...
- just ran a 12.0360 @ 112 in my V6
- master cylinder lines
- Exhaust Question
- How to adjust rockers on a 3.1? Need help!
- Rod Diameter? 3.1
- Black stuff
- ACDelco plugs
- 3.4 Rebuild
- all kinds of problems...
- 2001 3.8 performance musts. what to do?
- HELP! 95 Camaro 3.4 L V6 EGR & gas loss problem
- Cam / Valvetrain
- help 3.4 running bad
- brakestands with a V6?
- TOTALED! How much?
- urgent car problems
- 350 carb in 95 camaro
- Difference between 96 3.8 and a 98 3.8???
- 1989 camaro injectors problem
- holley fuel pressure regulator
- HELP- Blown Engine
- Upgrading V6
- K&n vs. SLP
- 99 3800 ticking????
- Dash board conversion??
- 1999 3.8L governor limited?
- Turbo Exhaust Manifolds
- 97 camaro v6 running problems
- 1998 3.8 blown camaro... need information about swapping in another 3.8
- Some Coolent questions
- overheating question
- venom 400 chip for 3.4l
- Few 3.8 camaro questions
- Ticking injectors
- Headers?
- Fuel filter 2000 3.8L v6
- 3400 questions
- 94 camaro 3.4 to 4.3 swap
- throttle body
- What are the best bolt ons and Results
- BEST Ignition wires?
- Does the 3.4 require pcm tuning after ........
- 4.3 v6 vs v8
- funny question for you guys
- 94 V6 water pump replacement
- 95 camaro...removing EGR?
- U-joint Replacement
- 2 problems:
- Engine light
- Cheap/Good Code reader?
- Need help, no experence with electronic motors
- any v6's with gears and posi upgrade??
- HELP Problems whit Camaro 97
- Wires Arcing?
- muffer mounting location and other exhaust questions
- What can a 3.8L be swaped with?
- Heads?
- Strange noise from dash board
- places to fix f-bodys in San diego or Chula Vista
- 1988 2.8 multiport
- Question??
- Putting in Headers...
- 3800SC prime oil pump
- Help! Car won't start!
- modded v6 worth v8 ?
- V6 Driveshaft busted...again(?)
- Another Question
- 2.8 mfi to 5.7 tpi conversion
- Weird Problem with my V-6 (won't start sometimes)
- Why cant my 1998 V6 Burn out????
- 1998 V6 camaro wont do a burn out....
- Cometic or Fel-Pro head gaskets?
- Searched, found, gotta ask anyway.
- Want to convert
- What should I do
- Mileage
- Fuse help
- converting an auto to a manual
- 1997 v6 auto at drag strip
- 97 v6 auto gears
- quick gasket help.
- 3.4L headers
- Installed Cam/Headers
- I have three problems.. please help
- alarm on 97 firebird wont stop going off!!!
- Misfiring?
- P&P stock Heads
- SS Hood on V6
- Rear disc swap!! finally!!
- Fan Switch
- remove the cat conv. from a 98 3800?
- 3.4 engine help
- Cam/Headers/Tune/Rear-End/Swaybar all Done!
- blown gasket heads! possible water in engine! need help!!!
- is this car normal?
- 3.4L '94 camaro
- BOSCH +4 Platinum: Yea, or nay?
- K&N Oil Filter: Low pressure???
- ***flaming Fuse Box!!!***
- Slave Cylinder Question
- Need More Power!!
- 4.3l Vortec
- Supercharging a 3800
- 3.4 stock exhaust information
- 3.4 Power Steering Bolts
- will this work?
- Difference between 1998 and 1996?
- Engine questions
- Engine whining
- How do i get this piece out?
- edelbrock cams????
- 100,000
- Going Z!!! Care To Help???
- Do Carseats fit???
- Oil and Water
- Ignition problem
- Check Engine Light
- 25mpg LS1...Is it possible?
- suddenly won't start
- 98+ driveshafts
- engine hesitation
- increase lift on stock rockers?
- electronic spark control module???
- remote oil filter on 3800SC
- NEW 5 SPEED V6 Camaro
- 3800performance.com question
- 2000 V6 camaro...aftermarket underdrive pulley
- Need Help Asap!!!
- a few questions...
- My new car pictures 5 Speed!
- More pics of my new 1997 5-speed v6
- superchargers and blow off valves
- SLP Cold Air Intake
- showing off the ride!!!
- GMMG exhaust?
- anyone have a hood?
- SES light....
- cold air kits? better gas mileage? or worse?
- quick question for exhaust
- hood scoops (DIY)
- Need Help
- Oil Life Monitor....
- Head bolts: TTY?
- Wrist pin problem
- weird feeling while driving..wtf?
- Exhaust Manifold Heat Shields...
- Rear gears?
- low-side A/C hook up
- Throttle Position Sensor
- 3.4L parts and zex nos kit for sale
- 184rwhp/212rwtq...
- Magnaflow exhaust questions
- Any Suggestions?
- Has anyone tried?
- 3.4L v6 HELP
- 3.4L v6 HELP
- What type of oil?
- 3.4L mileage to the tank.
- What is my problem??? Help!
- Jet Performance Chip Questions
- Msfiring? No Codes!!
- FS: 1996 Camaro 3.8l
- one day left for v6 parts on ebay
- if anyone knows of a....
- V6 supercharger compatability
- Aftermarket Y-pipe?
- what else would i need
- rocker arm adjustment on 3.4 L
- New here, have a question or two...
- 2001 camaro v6, 5pd 60k $400.00
- anthor missfiring problem
- just saying hello
- Need Help Radiator Hose
- Starter Motor/ Alarm Help
- Cams??
- Went to the strip
- Good Pass
- I hate v6's...............serious
- Will a catback help me that much?
- why do these cars come with 2" stock exhaust?
- Building a fast 98+ V6?
- new here, have a simple question
- Exhaust options needed asap!
- 94 camaro cuts off after a while
- Blackouts on black camaro?
- Is a 98's Wisper lid and K&N worth anything?
- Changing center consoles
