- stock V6 Camaro springs
- weird smell
- is 3.4 worhtless?
- code
- 95 3.4L Overheating... I need help!
- my friend is in need of your help!!!
- 3.8 supercharger
- Mass Air Flow Sensor
- IMPORTANT: Those with Taylor wires
- 94 V6 3.4l
- Magnaflow exhaust
- V6 BLocks
- running richer
- Check engine light...scanned
- Sound Or Video Clips
- 94 3.4l no muffler! future no-cat?
- all 3.4l performance mods?
- overheating + ac problem
- 1997 Camaro RS
- looking for a teal v6, how hard are they to find...
- Reliability with 159k miles... what to do???
- 95 3.4l V6 Raditor Flush how to ?
- Where is the Fuel Filter on my 95 3.4l Camaro
- I need a online Guide for changing all fluids in a 95 camaro 3.4l v6 ?
- A/C system
- 95' Camaro 3.4l NEED HELP PLZ ! Knocked Something off the oil filter assemely ???
- car won't start unknown problem help please!
- Good Performance Ideas?
- need help with my 94 camaro
- sparkplug changing on 3.8 firebird
- Turbo Installed
- 98 3.8 question
- V6 3.4l Overheating.....
- Where to get my car's chip programmed?!
- Hia
- NEED 3.4 to 3.8 swap info... no "get a v8" stuff
- PIMP my Ride!
- n00b ?? wheels and shocks
- walbro PSI fall off
- Terrible gas mileage (weather? whisper lid?)
- Please Help With Valves
- help SES light on Code wont clear
- is this a trusted site
- dropping a 3800 into my Isuzu
- wanna go with headers
- 3.4L misfire and poping
- Engine going out????
- Can I.......
- No Injector pulse, help!
- Stock GTP boost?
- Mass Air Flow Sensor Location
- have to replace shocks and struts
- Flowmaster 40 on a V6?
- best, rice free camaro 3.4L exhaust?
- Wiring harness
- Upgrades? Which ones?
- high idle
- 99 camaro 3800 issues
- new exhaust
- Help me with my 3800 series v6 engine!
- Just replaced my 3.4L V6 Sparkplugs and all hell broke lose
- After a week of driving "slow" to get the best MPG I got....
- New tuning forum
- Civic or Cam project?
- Injectors on a 3.4 V6
- 3.4 w/at ... parts must go!
- 416 RWHP V6 camaro!!!
- Are headers really worth it?
- 3.4L camaro won't start sometimes when hot?
- 3.4 running rich upon startup, please help...
- If your looking for a 3.8 with some mods..
- 1995 3.4L Losing Coolant rapidly
- PCM scanning software
- Tail Light Woes - Process of Elimination
- need to replace lifters?
- Belt tensioner assembly
- 3.4 cold idle/clutch problem
- Fuel Pressure Question
- 01 V6 - Have to turn key about 30 times to start
- Scared of New Sound With New Muffler...
- Rev limiter on a L32 V6...
- Brake problems after V8 swap
- Anyone got a cam'd 3.4?
- ABS INOP light
- broke the T-5 at the track
- What other car models use the same 3.1L V6 that's in the 90-92 Camaros?
- rocking bad at constant rpm speeds
- k&n for '02 grand prix gt NOT gtp
- Only getting 15.5 miles to the gallon?
- Overdrive or not
- Cold Air Intakes
- camaro vs GTI
- 97 RS 3.8L supercharger
- B & M Shifters
- Some insight into the 3.4L OHV RWD motor
- How many 02 Sensors?
- Thinking of creating my own borla plate>>>
- exhaust problem?
- How fast are camaro/bird v6's?
- Slave Cyl Brackets ????
- 3.73 Gears
- camaro/gtp
- New Intake for 3.4L
- 3.1 Help Please
- Magna flow Direct-fit
- 1987 Gn
- Weird bucking
- ODBII code p1406 when it gets cold out
- Resonators
- new turbo for v6's
- Pinion Seal
- 96 PCM question
- help on some shocks... (descision)
- 456 RWHP 509 RWTQ 3800 camaro
- Misfire at WOT, cylinder 1, done a whole lot, HELP ME!!!!!!
- small block into 1994 Camero
- Weird hissing noise up front?
- Strange Throttle Response...
- Help with Carfax? PLEASE!
- Egr Valve?
- temperature sensor tricking
- ? about taking on a RX-8
- rpm cuts off at 4000!
- camaro rs.....?
- Help a noob
- 97 3.8 Starter swap
- What are some cheap mods?
- new times
- 94 3.4 help please
- Difference Between Corvette and Camaro (V6) Intake
- crappy belt tensioner!
- Catalyc Converter
- New best
- Tune up....Needs some parts advice
- AC Delco Rapidfires....Which #?
- ? about times
- Misfire and engine stall...
- whats the difference between 96-97 3.8 and 98+
- shifting technique
- Firebird V6 Cat converter delete
- V6 3.8 supercharged VS LT1 !
- difference between 96 v-6 camaro's and 98+
- Heating Problems - '95... I need Help!
- Tuned her up........and she pings?
- Stock 3.4L Y-pipe double-walled? rattling...
- Y87 package
- f41?
- Upgrading the fuel injectors
- fuel rail fitting parts search
- something is wrong with my 2000 firebird
- headlight switch?
- Ignition Coils......Stock,MSD, or Accel?
- Help, my Camaro went nuts last night
- air doesn't blow out front vents
- Got some pretty impressive MPG!!!
- 3.1 V6 oil leaks?
- how to pull codes on 94 3.4, mouse ate thru wires!
- Weird Injector problem w/ my friends car.
- Corvette or SS?
- Pulled a tire off the ground..... N/A
- Technical Info
- question about catalytic converter on 1997 V6
- 3.4 horsepower increase
- 3.4L Intake Manifold Gaskets
- Fuel pump
- spark plug installation
- Weird sound during cold start up.
- egr removal?????
- Temp gage on 93
- Swapping a v6 to a v8
- Help me get a 1998 Camaro stand out some..
- After Market Shifter
- broken vacuum line
- Code P0175
- What temp do fans kick on?
- freeze plugs???
- headers...
- torque question
- starting problem
- cold start noise
- which type of oil would be best for my car?
- convertbile problem
- Gas Mileage
- misfire...again
- Crank car but engine is locked (hangs) until about 10th try.
- P1406 DTC code question
- GM Tech's - Injector ?
- 3.4l?
- plugs and wires?
- cooling system question
- Cam info
- asr in 3.4??????
- Wires burning? help...
- Codes and O2 reading
- v6 to v8 Lt1?
- What would happen if I removed my Cat when installing my flowmaster CAT back?
- Wiring question for any V6 owner.
- Ok, new q for you guys... Head Gaskets
- Forced Induction?
- oh damn it!!
- distrutorless 3.4
- ported heads
- Whats It Worth?
- Well I am needing info on what Chip to install...if I can even get one...
- Pacesetter exhaust headers...good? no good? please respond asap
- Smithy's Patriot mufflers
- 1994 3.4 V6 vibrates
- Anyone have some front V6 springs
- tranny swap
- Strange brakelight prob, help!
- 97 V6 trouble starting???
- Engine code.
- possible exhaust manifold leak? need help!
- new parts for a 3.8
- 3.8 pushrod
- will a firebird?
- will a computer chip make a diff?
- New plugs/wires, still have misfire
- engine swap idea
- v6 stuff on ebay cheap
- oilconsumption
- cold air intake
- Look at this pic and tell me if you see a 3800 pilot bushing.
- 95-02 3.8 coil packs
- Pls Help Me Someone!!!!
- Good first mods
- 98+ crank pulley
- O2 simulators. where to get em...
- 01 missfire
- freeze plug ?
- pulleys
- what size freese plug
- 95 3.4l to 350
- v6 to v8 swap, opinions plz
- tune up on a 97 firebird
- the best chip for a semi-modified camaro (obd2)
- Can you do this in California and get away with it?
- Water in oil maybe??? Pics inside....
- Used Injectors.. Tips?
- Old Car, New Possibilities
- 3.4l upgrades
- Just like new?
- 97 3.8L not starting?
- Big problems with crank senser(HELP)
- Venom 400??
- platinum plugs
- 3.4l 1995 with obd2 computer need best ch
- Misfire on 1995 3.4L V6 Camaro
- Short Shifter
- Ticking from driver side of 96 camaro
