- 3.8L Camaro Underdrive Pulley?
- What kind of springs should I get?
- Ideas on how to make my 2001 Camaro V6 faster?
- Can a short stick shifter be installed in my 2001 Camaro V6?
- spit sputter die
- Another Horsepower question
- Camaro 3.4L valve covers?????
- '94 camaro 3.4L valve gaps?
- Are all Catco Cats high flow?
- Do I need a Camber Kit if I lower my Camaro?
- Air Conditioning Belt
- Borla Exhaust Tip
- Is a 1.75 drop too much?
- shes fixed!
- 99' Camaro
- Trying to keep my 3.4 cool
- Can a V8 Eibach Springs fit a V6?
- How long should I drop my Camaro?
- 95 3.4 Owners Report ! Need to identify the DLC connector
- stock internals, bolt on only 3800
- take off cat..good bad?
- 3.8 liter out of 96 riviera??!!!
- Catalytic Converters for 3.8 v6
- Help!! Heater hose leaking!!!
- Will it work?
- Camaro back from Winter Storage = Problems!
- Which is lighter?
- 3.8 EGR Parts
- some V6s Qs
- 60 degree heads
- 3.8 Won't Start!
- losing too much water!!
- Borla or slp loudmouth
- lt1 tb on a 3.4
- Are Camaro V6 front signal lights different then Z28 and SS?
- does anyone in here need a 2000 model 3.8???
- Seems like my car bogs when i gun it....HELP PLEASE!!!
- This a Good Induction System?
- Me again...forgot to add something....BOG PROBLEM???
- LT1 vs. LS1
- need help
- Catback or muffler???
- What engine oil are you using?
- 94 3.4L camaro vs. 92 prelude
- wanting electric windows...
- Should I Get Headers?
- What Is The That Rattle Sound?
- Catalytic Converter?
- Where to buy Carsound cat 23494??
- Smoking/Oil Leak Problems
- internal coolant leak?
- What size is my catalytic cat converter?
- What Kind Of Tires?
- TB Bypass?
- K and N Typhoon intake
- V6 3.8L Plug Change HOW TO?
- what will they think of next?!?!
- Another Camaro in the stable
- Weird Noises - Any Help
- Water in oil....
- SLP Exhaust
- Heard V6 brackets will work on a Small Block 400, True???
- power windows
- gotta dumb one for ya........
- Long tube header questions.
- Oklahoma V6'ers!
- Intake manifold question
- Springs, shocks, sway bars, etc
- help....3.4 camaro overheating..w/in
- Ever Dyno?
- Need some help
- Are these mid-tubes or short-tubes?
- 98 z28 camaro exhaust on 94 3.4L camaro?
- Where to Find 3.8 Underdrive Pulleys?
- 95 3.4L water pump install...tips and tricks needed ....w/in
- 3.8 Rocker Adjustment
- my y87 firebird lost to a 1990 lincoln mark vII lsc coupe
- Weird blower type wining noise.
- Can I install a Cut-Out if I already have an exhaust?
- Oil additives
- I have a few questions so im gonna just make one post!
- Gutting my cat
- Question about the v6 transmissions
- Free 3800 V6 engine
- high rpm
- Overheating Issues with my 3.8L
- Where is a good place to put a cut-out?
- Is this normal for a Y87???
- ? 3800 Changes/Improvements 98-02 ?
- 3.8 Performance MAF's or TB's
- HP Progressive Tuner?
- strange coolant leak
- 3.4 Wants New Exaust
- 94 Camaro 3.4L VS 1990 Honda CRX SI
- how much oil in a 3.4l v6 ???
- How Can You Spot A V6 From A Z28?
- 97 pcm
- HOW DO YOU LAUNCH A 3.4 l CAMARO?
- fuel filter problem
- pulling codes
- Engine Swaps
- these lil ricer kids
- which wires
- Temp gauge not working
- Owners Manual
- 3.4 jet chip questions
- Gear ratio?
- updated list???
- Feel like my mileage has gone to pot lately
- Upgrading to Super Stock 4,000 converter, my ProYank 3200 is available
- SLP wisper lid
- Was I sent the wrong shifter?!?
- Loud Clicking Sound...
- Thermostat
- 6 Speed
- HELP! Feels like i'm gonna stall!
- need brighter lights!!!!
- instrument swap ???
- Typical oil pressure 3.4
- who would like a sweet swap site
- 3.4 v6 and tranny for sale,low miles.
- Waht Knid Of Free Moods
- Bracket Behind Cat?
- Need O2 Sensors!!!
- GM V6 vs Ford V6
- How low is too low?
- o2 sims
- catco confusion
- dont know what to get
- OBD-I v6 Camaro Software
- Which High Flow Cat is better?
- Rear End Swap (LS1 to V6)
- Help me please
- Borla
- Chambered muffler or bullet muffler?
- Is this a good buy?
- 94 v6 camaro
- fuel pressure regulator please help!!!!!
- Transmission Swappage (due to slippage)
- Ls1 Throttle Body V6 Camaro
- 1992 3.1L overheating need help.
- Fan Motor replacement? help
- Spark Plug Help
- Dont know what to do with this car
- overheating HELP
- WS6 Exhaust on a v6?
- Installing Shift Light
- Exhaust sounds like rice... help?
- Alternator question
- Can i replace my two piece drivesaft with a one piece.
- Intense cam for my V6 Camaro
- 3.4 to 3.8 swap?
- 3.8 headers
- rev limiter
- 2000 3.8 shift light install
- quick question about k/n intake...
- Shifting Problem
- cams
- No fuel pressure please help.
- Cheaper replacment for stock fuel pump
- Need Help
- Steering Wheel
- Randomly doesn't start
- does a broken catylitic converter slow you down
- Aftermarket Crankshaft??
- 1993 v6
- Mysterious Coolant Leak...
- Hi everyone
- (POLL) Push botton start
- I want faster window motors
- 3in Exhaust on a 3.4...it worked!
- Help!
- 3.4l muffler removal?
- Post your cardomain here
- misfire/plug question
- 1994 Firebird 3.4, Some Questions
- which wires are better
- OMG i'm changing my spark plugs
- 3.1 V6, Bolt Ons
- Gas Mileage Now what it should be..Suggestions?!
- 1 spark plug is giving me some trouble
- 2000 Camaro mods
- 93-97 conversion to 98+
- what gas mileage do you get
- temp sensors
- Replacing Gaskets in 3.4 (relieving fuel pressure)
- 02 sims for the 1 wire 3.4
- Hypertech/160
- Idling Problem
- Looking for a button.
- 6 or 8?
- look what I got yesterday
- Valve Covers
- Problem DTC code
- Taylor Wires question
- Egr
- Spark Plug Wire Gurus in here
- Turbo kit for sale (all 3.8l engines, new kit)
- Is this a misfire?
- Ok Please HELP!!!!!!!!! time sensitive
- Magnaflow or Flowmaster?
- no o2 sensor bad?
- Oil Pressure Problem.
- what grade of gas?
- need help with door
- Where to buy CAT?
- Plug and wire question
- What would these power increases be?
- 1992 camaro 3.1 still overheating.... wtf?
- RK Sport air temp module
- starter problems
- SLP intake fitment
- Driveshaft Problem
- turbo
- 3.4 Thermostat Restrictions?
- Mild cam in 3.4?
- No Compression???
- Spark plug change
- Demodding car due to accident ! ! !
- rebuilding a v6
- fuel filter
- A/C Evaporator '97 3.8L
- what should i do?
- Cat back pipes
- 1994 3.4 camaro vs 1994 3.8 mustang
- Trouble Codes
- Whats up w/ Shift Kits?
- Yet another spark plug question :D
- Will a 95 t-5 tranny fit in a 98 and up fbody?
- Help!!!!!
- Cam
- upgrades for my first Camaro
- buying a 94 v6 maybe
- 3.8l Turbo!
- My camaro is overheating at highway only.
- What next?
- air intake
- headers again
- Weird Voltage Surge problem....Help
- 92 camaro RS
- just got hit, now some wierd problems
- Speakin' of EGR valves...
- New Camaro Owner
- What's it worth?
- Flowmaster 80 series over a 40
- dual exhaust on v6
- gauges arent working
- gay ass wires $hit balls ufck!
- revs climb by 300rpms when i tap the gas
- turbinator
