- Gas Tank Question
- Did LT1 - What to do about fuel pump?
- rearend gear question
- Fan Switch in place of Knock Sensor
- Bleeding the Slave Cylinder
- coolant temp question? help
- Anyone that can help with a 97' Grand Prix GT
- Exhaust videos 3.8L w/loudmouth and 3.4L w/rumbler
- what are the stock gears???
- Strange jerking in cruise...
- Urgent help needed for CPS
- Someone please help a friend w/98 V6 motor prob
- 3.4 L Water pump question
- okay now I must be blind..
- NO throttle at all, Just idles
- What will i make with these..
- data logging
- turbo?
- 5.0 TPI 305 into 94 camaro
- clutch install
- Good v6 sites?
- Random Stall
- Transmission Problem?!?
- new some help troubleshooting (massive misfire)
- Attention V6 to V8 swap guys
- Rattling Noise, goes away when you push cluth in, HELP
- Engine Swap (partial)
- which rear controle arms
- Gas mileage HELP!!!!!!!!!!!
- 3.4L turbo kit for sale .....
- Texas Speed V6 Tuning SPECIAL!!!
- Port and polish question
- 3.4 water pump
- Spark plugs have a thinn white coating on them......whats that mean?
- wtb!! wiring harness
- 3800 supercharged
- Engine Problems...Need Help, Backfiring + no power out of nowhere
- what gears?
- v6 horse numbers
- making christmas list!
- How much does it cost to convert a v6 to a v8?
- Supercharging suggestions
- First camaro
- ignition module and testing
- removing scratches...what can i say, im a perfectionist
- Flickering SES
- Mulsafied white oil??
- How much Nitrous..
- my NA 3.8 camaro
- 97 v6 same as 98 v6?
- Fuel leak, wont start
- Help with 2000 Camaro 3800
- steering wheel shakes left and right, car goes to the right
- 94 firebird 3.4 1/4 time and mpg
- V6 to LT1 swap, can I reuse V6 k member????
- Stumble under slight load
- 1995 camaro
- 2000 V6 specs
- Eaton m90 Supercharger
- Fuel pressure test?
- pass key system
- New Engine
- Wierd squeeky sound?
- My 3.4 shakes when put in Drive
- powerdyne supercharger
- need help timing 4.3 CPI!!!
- Cant even find front passenger side spark plug
- car wont run right?
- Noob question
- mpg
- Considering switch to Valvoline Durablend, is it ok?
- will it be the same as it was?
- 3.4 cold start, really rough idle and rich..cat?
- ECU programmer
- fuel pump/wiring problem
- Clutch Install
- Anybody try the superchip or hypertech programmers on their car, how did they work
- Intake manifold
- what kind of gas mileage are you 3.8 guys getting
- Low Oil Pressure???
- wheres the fuel filter on our cars
- major clutch problem
- Power problem
- okay, that was weird...
- 1991 RS 3.1 Runs "Rich"
- Shift knob!!
- Great V6 tires?
- Fuel Pump Needed V6 Camaro
- How do i remove fuel lines from intake????
- need help to find a part
- 3.8 Turbo
- Flowmaster 40 Vs. No Muffler
- 3.4 liter auto tranny fit
- what kind of gears do i have?
- Third gen programmer?
- I feel like I have some kind of intermitant miss during crusing
- what do u guys think is the faster v6?
- Power Problem Is Back!!
- For those who want 05 Mustang V6 times>
- Car sputters
- no guage lights
- 3.8L MAF Forsale-Brand New
- 3.4L engine replacement problem
- Front main seal leak
- What is this that's leaking oil?
- Call out to the 3.4L owners
- Service Bulletin
- What can I get for $500?
- Chevy V6 Needs Help- non camaro.
- Questions: MSD Ignition For 3800II
- Can rust from your radiator build up in your engine??
- Please help identify this part
- Cylinder Heads
- why is my abs light on?
- Problem with 1999 SES light
- 1998 Camaro V6?s
- how to perk up a 2.8L
- HEADERS for a 3.4L
- superchargers...do they work???
- Pics of my engine.. Is it toast?
- Is it worth modding my v6?
- Plug wires
- 1996 posi??
- y87 Camaro Muffler
- Heater Core?
- wont start...
- 1994 v6 to carb 383
- Is my coolent right?
- performance chips
- Complete 3.4 DriveTrain, wireing Harness, AC,Radiator,10-bolt 4sale WNY
- anybody tried that Metco Valve Cover Breathers
- 4.3 Vortec Mods
- 3400 to 3800 swap
- 1994 v6 to carb
- few questions on TT'ing a 96 rs
- Smoldered a wire on the manifold!!!
- 1996 camaro 3800 rebuild or z-28 motor??
- New Old Dead 86 Camaro 2.8L
- How much for head gasket change? (Labor only)
- 1995 3.4L 28k miles.. need help POSSABLE BUYER
- if i swap engines, do i have to change my exhaust?
- High Mileage 1996 V6 Auto, Options?
- 2 questions from a new owner
- Need a new throttle body...
- Engine Light is on
- My camaro is not going past 3000 R.P.M...HELP PLEASE!
- Engine whining sound
- Smoldered Yet Another Wire!
- 94 v6 3.4 firebirs egr ?s
- My camaro is not going past 3000 R.P.M...HELP PLEASE! UPDATE!!!
- seeking 4.3 litre v6 knowledgables.
- Took My Catalic Converter Out
- checking ingition module
- Possibly selling this
- Y87 Package?
- Flomaster Exhaust: Install Article From P.H.R.
- Few Questions on Gears
- auto is so much slower then 5 speed
- Fog Lights
- Broken crank???
- my v6 runs rough
- Cars Whines When I Turn
- Exhaust problems / Car
- Foul Smell from Exhaust?
- Transmission Suggestions...?
- rear emblem?
- ecu problems
- Not able to burnout? 3.8L Auto
- Service Engine Soon light.
- 95 Camaro 3.4L Idling Problem
- 99 3.8 fuel pump problem
- brink's unfortunate events.
- need 3.8L belt diagram!
- Is It To Late?
- free 3800 ram air?
- hard starting
- Anyone Have MSN?
- 2002 v6 3800 leaking?
- Is This True?
- New kid with over heating problem
- Hey Im New
- Swapping a F-body 3.4 V6 into a Jeep Cherokee
- GT2 cam for 3800.
- Coolant leak - Help!
- Don't sell your camaro
- PICS - Coolant Leak - Help
- Whats up?
- My Y87 is sick - I'm clueless
- 943.4l Oil pressure at zero Help!!!!!!!!!!!!
- Someone please explain this error code for me?
- scratched windshield
- 94 3.4l Burnout?
- limited slip v6?
- Tires and rims
- converting my 94 3.4L to a 5.7L need help...
- removing the stock grille?
- newbee
- Home Tunning?
- Engine question.
- 95 3.4 cranks, but won't start
- chips
- 3.8 questions?
- oil leak or head gasket blown???
- Will these wheels work?
- cracked box by the horn
- 4.3 V6 Bellhousing Pattern?
- JET PCM Chip Stage 2 startup?
- help 95 camaro HVAC problem..hear hissing behind AC controls..w/in
- New Exhaust for 3800 Series II
- Shift Kits?
- What do you think of this car?
- Hella FF75 Help Please
- Auburn differential help
- what not to do to your camaro
- Exhaust Sounds .. clips!
- V-8's RULE
- D 0r Od
- who makes underdrive pulleys for a 3.4l
- DRIVESHAFT!!! My 98 Camaro
- 3.42 gears
- headlights
- Decided to biuld the V6 with a Stroker...
- Turbo v6 Camaro?
- HELP 56mm need spacer!
- foggy headlights
- HELP V6 to A V8 K member problems HELP???
- Rough Idle (3.4L)
- 4SA Transmission Question
- 1994 LT1 into a 1995 V6 Camaro
- Alternator???
- Remove Entire Exhaust?
- Changing Valve cover gaskets
- Having big problems
- direct fit high flow cat converters??
- SES troubles...
- Headers Question
- Cam and Roller Rockers
- Sometimes when I turn the key on my car loses all power and clicks.
- Stock 97 camaro. What should i do!?
- Cant loosen this bolt
- Can LT1 exhaust work on a V6 Camaro??
- Think I have a power steering fluid leak
- help w/ coil selection please!!!
- Performance Chips
- American Racing Torq-Thrust II 17 x 9.5
- LS1 brakes?
- Pros and Cons of EGR Block off
- stock 1/4 mile times and 0-60
- m5 vs y87
- A question about dual exhaust sound.
