- get'cho butt in here now!
- ??'s on 90 camaro RS 3.1L
- Mobil 1
- wheel hop
- FS: 1996 Firebird
- i hate chevy for making v6 camaros.
- underdrive kit
- Has anyone every done a V-6 crate engine swap?
- which
- All v-6 f-body fans, please enter
- Will a 98 3.8 v6 fit in a 96 Firebird?
- Is this the "SPARK PLUG" Problem?
- random stumble and miss
- supercharging a 3.8
- What are the easiest/cheapest parts to replace to make a '96 Camaro more lightweight?
- 3.8L with severe power loss or slow accelleration
- More power needed
- how many mods
- Problems with 98 3.8 intermittently dying ??????????
- 3.4 or 3.8 reliability question
- Catback exhaust for an 87 w/ a 3.4?
- HELP!? Many Questions!!!
- Video of me at the track
- MAFS screen
- Lightweight flywheel?
- 3.4 to 3.8
- 1994 3.4l
- 92 V6 misfire
- what do you think
- My Turbo 3.8 Camaro!!! **PICS**
- Tune Up Time, Factory or Performance???
- 3.8L V6 blowing white smoke after TB ported
- Car is having trouble starting and squeeking?
- ARRGG Lost to A GT!!!!!
- any1 know a good exhaust system for a V6???
- Dead Camaro
- Coolant Bypass for 3800 V6?
- car wont start
- Pro 5.0 with LSS problems...
- Driver Side Seat Adjuster Plastic Covering
- lost my keys HELP!!!
- 94 engine mods
- misfire questions.....
- 98 3.8L....suggestions
- 60 Degree Gen 1 Aluminum heads. YES THEY DO EXIST!!!
- What kind of gas do you put in a 4th gen V-6 Camaro?
- service engine light!!!
- P0133, P0141, P0147, P0300
- SES light
- 2.8 bogs bad!
- clicky
- rebuild kit for 3.4??
- Coolant Flush...
- 3.8 fast idle
- Import mufflers on v6 camaro?
- Anyone remember?
- Should I drop a LS1 in my V6?
- Hesitation/Miss
- first time at the track.........
- 1982 v-6 questions
- 3.1 injector size
- few questions
- need some quick help regarding struts
- did GM ever have a recall on the misfire problem?
- New Exhaust
- Wacky Gauges
- New to the sixes and I have a stumble.
- Coolant Sensor is too Low?
- Tampa, FL 93-97 Firebird / Formula / Trans AM body panels
- Buying a daily driver...
- V6 Ported heads FOR SALE
- runnin hot on my 3.4
- Anyone know where the IAC is??
- Best muffler for a v6?
- 3.4L Camaro catalytic convertor problem???
- help, im lost
- how much longer till my car breaks again?
- '94 3.4L..want Dual Outlet, but keep quiet stock sound
- thermostat
- V6 question
- Running Hott
- Shift Kit??
- What does the "2nd" button do?
- Rod Bearings job
- Engine/Track Philosphy Q's
- Need Help Fast
- Help with IAC problem?!?!?!?
- BAD Fan!!!
- hi guys can you help me out
- best 3.8 exhaust?
- 3.4 giving me problems
- Help..trouble installing TPS!!!!!!!
- trans go shift kit with vette servo
- Wheel hop
- Camshaft Selection
- Weird staring problem with my 01 Camaro
- Belt routing
- Some general questions
- 95 3.4L/At for sale in maryland
- Mustang=Dawg???
- SLP Cold Air Intake?
- 98-02 front bumper ground effects
- Bolt torque ?'s
- Need help with 3.8 detonation issue
- Which 3.4L headers?
- Clutch and shift problems
- true duals
- my ac compresser for sale
- Tick problem with my 2.8
- Starter Removal????
- Bigger throttle body for a 3.8 seriesII?
- 3.8 Series II rebuild questions?
- Emergency Brake Light Stays on
- 99 v6 vs. 94 stock gt
- Wow, INCREDIBAL loss of power!!!
- Intake Manifold...
- Water in my oil?
- Just bought a 94 camaro 3.4 litre. Need performance tips
- Is there any need?
- What Oil Filter and oil to break in with?
- Do I need o2 sensors?
- T/A Hatch F/S
- No cat conv+straight pipe=less torque?
- Possible Tranny swap
- What is the Best cold air?
- RS problems!
- weird feeling at higher rpms
- cia headers?
- Engine Kit
- Dad's AC isn't running correctly
- Please lord help me, the 85' dead, again.
- How to change water pump??
- Should I run a Dynomax bullet w/flowmaster?
- Bad vibration from front right
- engine swap help
- Change in Shifting
- Injectors not firing
- Service engline light is on, reader said auxiliary emissions, what does that mean
- Help msd dis-4
- Not starting after it sits
- Wierdest problem ever, ideas?
- What would cause a turn signal bulb to keep blowing up?
- V6 to V8 Will the 5 speed bolt up??
- leaking oil pan + changing rear drum shoes....
- A Few Questions
- Trying to find...
- Problem with my lights!
- 3.4 V6 - SBC 350 Carbed
- noob questions (v6 to turbo/twin turbo)
- Found a blower kit for 3.4L, $700
- need help, car all messed up
- I need a oil pan
- How to clean injectors?
- Working on new overlays--Multiple Color Options
- LT1 swap
- Question on overdrive
- Ignitions? MSD DIS 4, Dig 6+, 6AL.....
- 1/4 mile times
- ran over something now my cars nuts..
- Distributor and coil replacement?
- Problem fixed *sputtering stalling hesitation*
- Timing Belt or Timing Chain?
- '95 3.4 camaro dies today
- Electrical Problems
- LT1 Exhaust?
- 2.8L swap to a V8....?
- headlights wont pop up
- Turbo and charger kits?
- What Hooker catback for my 97 V6?
- fluid changes
- New 99 V6
- Fuel injector cleaners?
- Car misfires all the time.
- crooked steering wheel?????
- Electrical issue
- Exhaust problem
- blown head gasket
- Replacing Starter?
- Bolt pattern for a V6 4l60E same as LT1 T56???
- car starting problems
- Oil Pressure
- Throttle Body
- Track times and dyno for the charged 3.4
- Cooling problems.
- 02 Camaro
- Supercharger?
- V6 muffler opinions
- Track results for friends 3.8 V6
- hey guys im back again
- Need help, am lost
- Dirty Engine-Cleaning tips?
- Yet another issue....
- Gasket options
- Boost and the 3.4
- looking for help
- Torque Converter
- i think i screwed my engine with seafoam
- my 2000 y87 firebird vs 95 neon r/t sport coupe. how did i lose???
- Install Power locks, windows & Key fob?
- HP Question?
- Nissan turbo in a camaro?
- repl. headgasket kit
- will these mods put me into the 14's?
- Direct fit vs. Universal Cats
- supercharger 4 my bird
- Low Oil Pressure?
- Simple Question from a Newb
- Mileage 3800 v6?
- y does a grand national sound like an 8 and my car sounds like poop? is it the turbo?
- gauge problems
- Turbo Project
- heading to the strip
- car problems
- MAF - Code 34
- Need a fuel pump for a 3.8L Camaro
- 13's N/A!
- Intake runner design, short vs. long. w/pic!
- 3.8L Wiring Diagrams?
- cylinder head/ intake install
- worth the money?
- eCharger?????
- best catback
- Shifter knob thread size
- Length of Catco Converter?
- I just bought a 99' 3.8v6
- My car is having trouble starting
- Did 3.4 to LT1 no start.
- Loaded 1996 Camaro For Sale
- Voltage Problems
- What will the 3.8 fit into?
- Huge Bmr Sale
- Overheating! Help!
- what kind of cat to buy.. 3.4
- wont shift 1-2 unless you let off gas?
- Adjusting the clutch?
- 2003 rsx type s vs 2000 y87 firebird?
- do i need larger injectors
- throttle body p&p?
- how much
- Loss of power at mid-high rpm's
- Just got my Best MPG EVER!
- Help Please!
- best shifter/ short stick combo for 3.4 5spd???
- 95 3.4 Hard Start
- Making my own spark plug wires?
- 3.4 wont start??
- ABS Inop Light stuck on
- What can I do to add power to my Camaro?
- Opinions on Clear image automotive headers.
- TPS voltage
