V6 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21
  1. What are the differences between a v6 and a v8 engine?
  2. Exhaust Noise
  3. Dash lights......
  4. Issues w/ Stock Flywheel
  5. HELP!!! For The Love Of GOD!!
  6. transformation
  7. e brake problems
  8. How to change a fuel filter?
  9. Chip for 94 Camaro???
  10. sad
  11. begining research on LS6 swap
  12. Upgrading V6 - The Most Asked Question In This Forum
  13. hypertek power programmer 3
  14. Car misfiring?
  15. What are the symptoms of a bad coil on a 3.8L V6?
  16. emmissions
  17. SS Exhaust on a V6?
  18. Rough Starts and Falls on its face
  19. need headlight help fast
  20. Where is the EGR valve?
  21. New front brake pads and rotors are making a mess of my wheels!
  22. My new (and first F-body)
  23. thrust bearing on my 2.8L
  24. Please help ASAP!
  25. Wanted: 93-95 Cam/bird 3.4L V6
  26. Aftermarket coils for 3.8L V6?
  27. Hitting 90K Miles
  28. What the hell is wrong with my car?
  29. stock fuel pressure on the 3.4
  30. New best, 12.1 at 107 w/ 1.5 60 foot!
  31. not an f-body but have a question
  32. Where to buy a tail light assembly?
  33. got some times with the firebird!!
  34. What the gas milage on a v6
  35. my sixer for sale!!!!
  36. Anyone have a good write up for a take off SLP diff in stall on a rear disc brake car
  37. time set
  38. code p0102 MAF sensor low input
  39. Codes 42,33
  40. I need tips on timing
  41. Weird question, help if you can.
  42. Best exhaust for a 3.4????
  43. Newbie!
  44. Anyone have a pic of their RS badges?
  45. Fuel problems?
  46. Gears and Nitrous ?'s
  47. engine swap
  48. supercharger times
  49. V6 to V8 Swap?
  50. Can you increase idle speed?
  51. 18 inch rims
  52. more airflow maybe?
  53. glasspack
  54. Belt came off going down the road
  55. puttin kinda clapping sound
  56. heads/cam
  57. 99 Firebird Owners Question
  58. People with automatics in here please
  59. firebird 2.8-3.1 maf
  60. 3800 series help?
  61. what cam for my 2.8l?
  62. firebird is runnin real rough after sprayin!!!
  63. worn timing set?
  64. will lt1 and ls1 injectors fit in a 3.4??
  65. Oil Change
  66. Brakes / Rotors
  67. Low Oil Pressure after Camswap!! Need Help!!
  68. 93 v6 firebird front roters.
  69. V6 to V8 swap!HELP!
  70. what rockers for the 3.4
  71. Chips
  72. Calipers Paintn'
  73. any ideas on my problem?
  74. 3.4l, slightly different application
  75. Just signed on
  76. a few basic mods
  77. V6 - LS1 interchangeable accessories ?
  78. 97 3.8l
  79. Is a computer necessary to change spark plugs?
  80. best camshaft for 3.8
  81. my bird just started to tick!!
  82. 3.4 PCM reprogramming option?
  83. rear end swap
  84. 99' 3.8 wont start?
  85. V6 MPI ---> 2bbl/4bbl carburetor??
  86. Overheatin
  87. vacuum hose routing?
  88. any takers
  89. window motor
  90. UhOh SES Light
  91. EGR problems
  92. Which line lock for a 96?
  93. Bad Acceleration
  94. Trans mount
  95. how do i set the clock
  96. Replaced EGR/cleaned tube...still getting SES
  97. what to do with $1000?
  98. 00 3.8 hesitation/shift problems
  99. belt tensioner
  100. 3.4 short Shifter???
  101. Lots Of Stuff For Sale!!
  102. Best plugs n wires for 95 3.4l?
  103. How much will a cat run me at the dealership??
  104. Oil Pressure
  105. Looking to buy
  106. 1990 Firebird....engine cranks, but wont start! HELP!
  107. Waterpump
  108. 1997 V6 Speedo/Fan Problems
  109. What do I need for my swap.
  110. hypertech?
  111. IAT sensor on 95 camaro
  112. Full Tank...of WATER!!!!
  113. no "pull" at high RPMs
  114. 117cfm, unacceptable
  115. Questions about 3.4
  116. Headlight and Fuel Cleaner
  117. Quieting Loudmouth
  118. ATF vs. Seafoam
  119. cleaning with b-12
  120. Weird noise
  121. Magnaflow & Z28 I-pipe
  122. Comp Cam for sale 3.8 V6
  123. Electrical problems, car alarm related..
  124. Could my Check Engine Light related to exhaust?
  125. ??'s about a V6..
  126. RPMs jumping back and forth...???
  127. how many horses?
  128. 98 Whisper Lid idea???
  129. Get new exhaust tips? gut cat?
  130. Drooling....
  131. coolant boiling out cap?
  132. Power gains from this?
  133. 150MPH Speedometer
  134. Please Help
  135. Question on distributer
  136. Where is my water going?
  137. Gaskets for 98 V6
  138. Where to get tranny rebuild guide?
  139. help me out here...
  140. I think I added too much oil
  141. v-6 headers?
  142. vacume prob???
  143. Check Gauges
  144. v6 speed
  145. formula v6
  146. my car is running stronger than ever!
  147. Check Engine Light?
  148. Need exhaust noise Fixed
  149. I need a block...
  150. Choppy Acceleration
  151. noticed oil pressure little high
  152. cat converter
  153. Does anyone have a 97 PCM?
  154. replacing alternator
  155. computer swap
  156. What all do i need?
  157. 3.1L coolant leak..
  158. something is really wrong with my car>
  159. 3.8L Supercharger to 3.4 Engine
  160. Replace 98 Maf with 99+?
  161. Need help PLEASE
  162. Slow Window Motors
  163. Tightning Interior
  164. Octane DOES make a difference!!!
  165. rebuild/more power question
  166. RPM jumps and rough starts tip!
  167. Belt Problem
  168. better injectors?
  169. did a compression check - got questions
  170. 02 LS1 Auto tranny into 96 V6?
  171. Brake Wire
  172. Exhaust W/ No Cat
  173. How many horses can a
  174. Manufacture Control Module, Transmisson
  175. will this work?
  176. tiago's turbo
  177. 3.4 - tapping noise at idle/low rpm
  178. Any spare front springs?
  179. Edelbrock Cam Kit
  180. K&N Filters
  181. diode/ resistor
  182. y is my firebird slower
  183. can I make a engin trans fer?
  184. Losing Power...
  185. 3.4l valvetrain questions....
  186. Grinding and knocking sounds loud and often
  187. anyone relocated their iat like this?
  188. Help asap
  189. Newbie here. Great board, but have a few questions (long)
  190. rebuilding the v6
  191. I have a 98 V6 Firebid and have a few questions.
  192. Cold start hesitation
  193. Urgent Help Needed *Overheating*
  194. Built up 3.4L or 3.8L...
  195. Speedo broke need help
  196. How much can i get out of it?
  197. Please help!!
  198. HELP! Info on V6 to LS1 SWAP!! (99+)
  199. Ebay CAI Difference?
  200. Help asap !!!
  201. I got a digital camera!
  202. v6 lowering springs - eibach 1" drop
  203. offroad use only?
  204. Question about EGR
  205. Gutted cat vs. high flow cat?
  206. 204/214 or 216/228???
  207. V6 Cooling system. Specifically the radiator and fan/fans
  208. Acceleration Problem
  209. i need help to beat my step brothers...
  210. Noisy V6 engine
  211. eibach sportlines
  212. gmmg exhaust
  213. Q: Auto Trans to Manual Trans?
  214. Gears
  215. 95 firebird for sale
  216. removing dash
  217. Double Walled Y
  218. this is what im getting
  219. maybe u can help
  220. i was wondering
  221. gumball 3000
  222. Engine leaking coolant?
  223. VIN Decoders and RPO Decoders
  224. Problem with exhaust manifolds - should I get headers?
  225. Where is the lowest price for an aluminum DS?
  226. 3.1L engine harness interchangeability
  227. what's fair?
  228. bad idea?
  229. car problems
  230. SES light question
  231. Help!!!!!
  232. ses light and detonation
  233. Injectors?
  234. 4th gen fuel mileage
  235. How much possible horse?
  236. how much of a difference is it
  237. Lil' Bro got a '99 Bird--Q's inside
  238. Is it worth it
  239. this is wut im gonna do
  240. Tach not reading right
  241. Will Z28 exhaust work on a '96 Camaro?
  242. V8 transmission
  243. Can someone carfax this for me please...
  244. Disable factory alarm
  245. 3.4l a/c suxs
  246. 94 3.4L Camaro - thoughts?
  247. Roadmaster Engines Suck
  248. Anybody need any 3.4 manifolds?
  249. Exhaust Cut Out
  250. Ever heard of this prob?
