V6 Tech
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21
  1. 92 bird 3.1 engine stall 5k rpm's
  2. where is my EVR filter
  3. 94 camaro t-top conversion COMPLETE PICS
  4. axles
  5. Idle High
  6. Power Steering rack length?
  7. I'm Selling my powerdyne supercharger kit for the 3.8L
  8. Can I use 3.4 K-member in a 3.8
  9. where online to get tires?
  10. Throttle body spacer
  11. Bad Water Pump
  12. pcv valve
  13. Custom Turbo
  14. 800-700rpms normal???
  15. Can I......
  16. B&M shifter
  17. antifreeze
  18. Help! Camaro running awful.
  19. 96 3.8 for sale!!!! cheap
  20. 94 stock LCA part number / 98 Z28
  21. whats my cars Weight>???
  22. what could be the problem?
  23. RPM's
  24. sound clip
  25. "Low Engine Power" light wtf?
  26. What do you think my car is worth???
  27. Mustang v6 vs. F-bod v6
  28. 3.4 overheating!
  29. ls1 muffler
  30. Looking For T-tops!
  31. Air Flow
  32. Rear Brake Drums..
  33. Hit by Deer
  34. just a few quick ?'s
  35. Loudmouth exhaust
  36. V6 tuning
  37. 97 camaro: wacky gauge behavior!
  38. high idle...
  39. Hanging Tranny Valve??
  40. 228/228 Lunati question
  41. Has anyone put the blower off a GTP on a 3.8l Firebird?
  42. Free Ram air mod for a v6 > can it be done ?
  43. Why is my muffler rattling?
  44. pro 5.0 shifter
  45. Battery volts drop to 8
  46. Why is it...
  47. Throttle Body for V6 3.8 1996 Camaro
  48. question about plug wires
  49. camaro noob with a few ?'s
  50. Intake QuestIOn
  51. Fipk
  52. port and polish head q's
  53. 2.8 to 3.1 swap
  54. Tell me what you think (pics)
  55. First 4th Gen V6 in the 11's!!!
  56. ***`!NEW V6 Message Board!`***
  57. spark plugs
  58. Broke my 3.4L
  59. I need Alt. Bracket pics! help!
  60. Keyless Entry
  61. V6 Formula
  62. V6 Exhaust Options
  63. Brake question
  64. 3.4 to 3.8.. possible?
  65. CHIP for a 3.4l 94
  66. Misfire Code But Car Doesnt Run Like A Miss Fire Please Hep
  67. 3.8 compression psi?
  68. shocks
  69. Misfiring at normal speed
  70. A fuel injection problem?
  71. Think the maro is burning oil...or somthing at least.....
  72. Water in tank?
  73. rear-end squeeling...any ideas? i think brakes
  74. Big Tech?
  75. shocks
  76. Lowering spring Questions?!?!
  77. Cut out questions...did search already
  78. third gen vortech
  79. what auto tranny will fit my 3.4L???
  80. LT1 cat-back
  81. multiple misfire
  82. Need Help Fast!! Please!
  83. Thump!!
  84. 3.4L Stock gap
  85. Trans Am Gauges
  86. Well
  87. motors and computers
  88. Interested in getting a 98-2000 firebird for a 2nd car...
  89. Cruise Control
  90. question about slp take-off shocks
  91. Changing Oxygen Sensors in a 99 3.8?
  92. 3.4 Acting up!
  93. Is Synthetic Oil OK in the winter time?
  94. Windows....
  95. will brake cleaner eat o-rings/gaskets?
  96. Ack help, car wont start
  97. Starter Recommendations
  98. decals
  99. supercharger on 3.8L?
  100. strange problem
  101. Can I see some pictures of your firebirds?
  102. Can't even get off my road..
  103. 4.3 Vortec High Idle Problem ??
  104. Carfax help needed
  105. Harmonic Balancer Position (3.4L)
  106. Stock 97-98 V6 exhaust setups
  107. will 25th anniv. intake , air plenum fit my 95 3.4l
  108. ASB Light on DASH
  109. so what will high oil pressure do to a 3.4L?
  110. storing the v6 for winter
  111. Engine build up?
  112. Will someone please help me instead of just looking at it!
  113. What size tire OEM?
  114. What gear came in a '95 V6 5-Speed?
  115. ready..set...go?
  116. v6 major problem..wtf?
  117. tb bypass
  118. 3.1 and 2.8 smog legal headers
  119. 3.8 Tpi???
  120. P-Code help
  121. V6 Tranny??
  122. mod to get my 6 for christmas
  123. help
  124. 93 Forumla - Rear turn signals dont work
  125. temp sending unit/pcu sender
  126. N E one here own the camaro I saw on 202 near raymond dodge?
  127. Vacuum Leak?
  128. question about take-off shocks
  129. Mid 14s for $0 in a 2000 v6
  130. 94, 3.4 head torque
  131. turbo kit
  132. Mod list, from japan
  133. 3.4 Engine Shakes
  134. Grand Prix GTP
  135. Muffler
  136. Mufflers
  137. Mufflers
  138. What type of muffler should i get!?
  139. What type of muffler should i get!?!?
  140. service intervals of v6 camshaft
  141. Pictures of the V6
  142. Custom guages..
  143. IAT question....
  144. How many of you have Nitrous on your 3.8s?
  145. Question about V6 rearends...
  146. Ahhh!!!! Oil Leak!!!!
  147. engine rebuild
  148. Better top end.
  149. momentary miss after sitting
  150. 02 sim
  151. Timing belt!!!!
  152. New rear?
  153. Oil Change light
  154. everyone who has air fuel gauge
  155. Headlights/Foglights
  156. How will Headers effect sound?
  157. Why our V6's don't have top end.
  158. Emissions...
  159. Jerking brakes
  160. Tuning PCM
  161. V6 vs. V6
  162. Clear Image Automotive headers
  163. Z28 hand me down parts(to V6)
  164. bought hypertech chip
  165. Coil pack order requested - how they sit on the ICM
  166. What would cause a car to completely loose all electical power?
  167. Horn doesn't work
  168. Has anyone used this before
  169. k&n on a 2.2 cavalier
  170. Difference between 98 V6 front shock and 00 Z28 front shock?
  171. Where to get trans Parts?
  172. clutch slipping slightly, due to cold weather?
  173. No MAP sensor easy to turbo?
  174. will ford 5spd same as my t-5 5spd
  175. No start problem??
  176. Paint Codes...
  177. Don't know crap about suspension...help please!!
  178. Swap 350 into '95 3.4L Firebird
  179. question about the v6's
  180. Thinking about getting a V6 Camaro
  181. do you have a 3.8? check this out
  182. Rough Idle/Stalling Help!!
  183. 00 V6 gearing
  184. Headlight replacment
  185. turn signal bulbs
  186. Resonators?
  187. Ac
  188. would this be stupid?
  189. Who has !EGR on a 3.4?
  190. FREE 3.4 + 5-speed
  191. supercharger
  192. need some power
  193. SpeedAutomotive.com
  194. New best in the $0 modded 3.8L
  195. jet stage 2 pcm vs Venom 400
  196. purple wire mystery...
  197. 90 V6 3.1L Q's (head gaskets)
  198. lowering springs question
  199. took my car to the shop...
  200. A good buy?
  201. 3.4L to 3.8L
  202. How hard is it to fix lifters on a 99 V6?
  203. Oiling Holley/K&N filter?
  204. ses light
  205. 2 questions
  206. Speedo is way off! Is it the Tranny?
  207. Help!!!!!! '99 V6 Belt!
  208. v6ers!
  209. Tensioner removal? '99 V6
  210. Where is the Controlboard???
  211. Zerk Fittings.
  212. Income Tax Return and a Gear ?
  213. cant go past 85, flashing ses
  214. Lsd?
  215. Tranny blowing fluid! PLEASE HELP!!!
  216. Rear-end lubrication level question.
  217. turbo or blower
  218. 52mm to 75mm tb (updated with pic)
  219. What HP is a 95 V6 rated at?
  220. Changing clutch
  221. Please Please Help
  222. Ses
  223. need help with 3.4L trans
  224. Help Quick
  225. Car Problems (non-camaro)Jeep. 4 friend
  226. Help w/ this Oil Report from 95 3.4
  227. Has anyone put a trans am spoiler on a firebird?
  228. paging kevin 2.8
  229. Wiper Motor Help
  230. Brake Problem Help????
  231. How much slower will a new firebird be than my old 94 trans am?
  232. fuel pump replacement
  233. clutch pedal return spring replacement?
  234. Moded fuel rail pic
  235. Interesting Idea for TB
  236. Fuel Injector upgrade 17lb > 22lb?
  237. Need help
  238. Catalytic Converters for 3.8 v6
  239. 3.8l Camaro
  240. Speedo is chasing Tach!?
  241. 3.8L header gaskets
  242. Swaping V6's
  243. Why wont it start?
  244. Spark Plug Boot #3
  245. Gauges
  246. 3.4 internals
  247. My car has no memory!
  248. engine difference
  249. ac clutch
  250. Finally Got a Camaro
