- Backspacing on 18" wheel???
- Rebuilding 76 SB 400: need help.
- t-56 in 67 Camaro
- Popping backfire in Carb
- 383 Mopar/383 Chevy Shootout - Your guys thoughts?
- Hard to start, then blows white smoke out carb and backfires badly when started. HELP
- I have converted from 1995 Z28 to the real muscle
- best headers for a big block 396?
- Neutral Safety Switch Hookup?
- Can someone explain to me exactly how a 383 and a 377 work
- 69 Bird Value Please
- internal or external regulator?
- Can I run '87-up comp lifters on a 400 SBC? Need help ASAP
- biggest cam choice
- Oil groove in camshaft?
- Electrical problems........Need Help Please
- Edelbrock Performer RPM heads and a 400 sbc
- Nova sites????
- Torque Converter going bad?
- Advice on a 355....
- Time to look for a cam, basically stock Pontiac 400........
- Steering box
- Will a LT1 crank go in a 400 Pontiac?
- T-56 shifter knob
- Fuel Pressure??
- Help!..., My rear windows are kind of stuck
- 69 Z-28 instruments
- FS 302 pistons
- Is this a good cam for my car??
- 454 crate motor low power
- 230 cc heads on a 358, too big?
- Oil Pan ?
- need info on putting 70 to 73 nose on 74 to 78 birds
- engine compartment colors??
- ceramic-coated headers
- 305 Heads means 305 engine right?
- Shortblock, Where to get one?
- How do you get the window crank handle off so you can remove the whole door panel??
- Rims/Tires
- Trany and rearend... good price?
- Whats the biggest Crank that a 400 sbc can take?
- I FIGURED IT OUT, YOU WONT BELIEVE THIS....
- 79 camaro, seats
- Anyone have a T56 in a second gen???
- 2000 rpm stall?????help please
- Door Panels
- Weight Differance Between an 81 Hardtop and T-top Z?
- 3 inch exhaust on an 80 Z28?
- how much
- engine running hot
- Need interior for 79/Z28
- 700R4 Swap
- High/Fast Rev SB
- Is my Z REALLY a Z?
- What headers will fit?
- 1969 leaf springs
- What material is your diff composed of?
- header length...
- SBC Pro Action cylinder heads? any good?
- Question about mufflers
- lowering leaf springs
- How can I tell if I have a 8.2 or 8.5 rearend?
- First Gen Rims & Tires
- Canadian stock exhaust manifolds
- Value of a '67 SS Convertible?
- more starter problems
- Header Primaries
- exhaust piping
- Enigne Blueprinting
- Winter Driving
- ZZ4 ho crate and cam....
- Another Hot Engine
- anyone use the G2 twisted wedge heads?
- HELP!!! trying to tune my edelbrock carb in on the car
- Mika Salo's personal ride
- RESTORER
- Will new rearend fit old Camaro?
- Rearend info
- Real SS or no?
- Question about Rear Ends
- Fuel line kink?
- ANY Thoughts?? on an 81 Z suspension
- New seats?
- Can't figure out a lighting problem
- Engine Identification Help
- 79 Z/28 Seats
- Swap Meet
- how do you build a vette/porsche eater?
- Spark plugs and wires
- Your 350 water temp?
- New car what to do with this one
- Its finally running
- Need to gain 1/2 second, all on motor! How?!
- Power out of a 283?
- brakes
- Cooling Issues
- Cam choice...
- more rear end questions?
- Usable components from 89 Firebird Formula?
- What posi and gears should i get?
- 68 Parts
- whats in my car!
- 91 TPI 350 TRANSPLANTED INTO A FIRST GENERATION
- Rearend Help.
- Axle
- Tranny going into neutral at X rpm's
- going to look at a 69 tomorrow...
- '68 camaro SS
- Too much power for rearend?
- Question about muscle cars in general.
- B&M 144 SBC under 69Z28 hood?
- winshield wipers
- Vin Number
- 4th gen seats in a 1st gen?
- Not charging?
- Need Suggestions
- Shocks
- Is a 1969 X-66 code always a SS?
- HELP!!!!! #5 plug wire fried and ran car on 7 cylinders for over an hour :(
- 1974 camaro For Sale Or parts
- Where can I find a 1980 front clip and hood for a Z28?
- Your challenge, should you choose to accept it
- Wheel question
- differences between 23 degree and 18 degree engines
- emblems
- Yenko Turbo Z
- 50/50-Pictures-LAST UPDATE!
- Good headers for 350 SBC?
- Hardcore starting problems
- BBC CSI water pump + LWP pulleys?
- new mountain dew commercial
- Cog Belt Pulleys?
- LT1 Brackets Go bold or Beautiful?
- 68 Pontiac 400 Shortblock for sale
- OK, guys. Here's my questions.
- long-tube headers - heated O2 sensor?
- air cleaner height?
- cylinder heads opinion
- picked up some Dynomax Race Magnums
- 1971 camaro pitman arm
- How to wire alternator with Painless wiring kit?
- a few questions
- Where to decode bog block serial number?
- intake swap to low rise...power loss?
- need a black INTERIOR
- Need pictures of your 1970 Camaro!!
- Help With Foot Brake?
- 73' Camaro
- 1979 Firebird Engine Help PLEASE
- car wont start
- Speedometer
- 12-Bolt Troubles
- need new oil filter bracket for 403, where?
- btw, how high can you rev a 403 w/ stock pistons,rods+crank?
- Just got new motor running today for the FIRST TIME!!!
- Help!! Car is not running right??
- AFR 227's for SBC 408?
- ur thoughts on a powertrax no-slip trac system??
- HELP!!
- found a 68 convt camaro for sale, should i buy?
- Rear Gear Advice? 3.90 or 4.10?
- what to do?
- 77 Trans Am performance mods?
- Project ended.....80 T/A.....owners inside....
- sump/vaccum
- 350 heads.....stock.. i guess
- Need help with suspension on 74 camaro LT
- Help with dyno?
- Can a victor jr manifold be ported safely to fit a 1206 gasket?
- Clicking noise from motor....
- Battery not charging, must be a short somewhere?
- Several Parts for sale........80 T/A
- How much boost could I run?
- 10.5" clutch plate on big block >>
- What r ur MPG's for ur 60's-70 V-8?
- Buy my TCI TH400 rebuild kit *NEW*
- first generation exhaust system for sale....
- FS: 1968 Numbers Matching Camaro RS in MI
- 327 build up
- question for old school poncho guys
- 1/4 Est. for a 73 T/A?
- 72 455 Trans-Am running 12.0's bone stock?
- differential cover bolt torque specs?
- a Good 383 kit?
- 70's 350's
- Need pricing for 350 forging?
- Poncho engine help needed
- Is my BBC a freak?
- T-5 in 72 Camaro?
- Turbo 350
- slicks
- Why the overheating on my '79?
- 2 BBC flywheels for sale (both new)>>
- Crane Gold Roller rockers for sale>>
- Is this 78 camaro worth 850?
- SBC 350 and TH350 for sale!!!
- Disc Brakes
- Need a recipe for a 455.
- water pump suggestions...
- Where to buy engine block?
- Insurance costs for older camaros
- Vapor lock
- need help pontiac 400
- Is this '68 SS396 a good deal? Help ASAP!!!!!
- What happened to the Camaro Research website?
- How many hp?
- stock aluminum intakes... r they n e good
- REAR END WENT OUT IN MY CAMARO!
- rear shock relocation and 17X9.5 wheels on a 67 ?'s
- Will a bigblock fit a 78?
- Push Rods
- Firewall painting...
- 2 original '79 Z hoods 4 sale...
- double hump intake port size?????
- mild perf cam for a stock 454
- cruise control
- LPW Rearend Support Cover for 8.2 or 8.5 Rearend and Cragar Superlites for sale!
- Head castings
- tire size for 67 bird
- 1977 chevy 350
- Qjet Choke on Vortec Manifold?
- '78 Trans AM?
- vortec heads
- ET STREETS FOR SALE
- Information Board
- fuel delivery question
- wire short for tail light /parking lights
- cutouts / exhaust dumps / open headers
- TCI Street Fighter TH350 FOR SALE
- classic t/a dis.
- I have a 73 camaro engine where is my voltage regulator?
- rocker arms
- Cylinder pressure
- LT -75 rear
- HELP!!!-Vibration at 4000 rpm an higher
- First Generation Camaros
- what times to expect?
- Can I supercharge my 69 Camaro?
- Anyone that knows anything about the yenko Turbo Z's please read
- Project car Finally Makes It to the Track!!
- Oil leaking out of intake bolts....
- help!!!
- FS: 1967 Camaro RS/SS GM 502ci + Holley Supercharger + NX
- Easy way to test rings with heads off?
- T56 In 69 Camaro
- Engines and parts....
- Subframe connectors?
