Classic Engine Tech
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12
  1. where to start with mods?
  2. read the thread"(where to start with mods)" and answer it
  3. just bought maro with 1971 chevy 350
  4. Would this work, a 79 with a 454
  5. i need perf. exhuast 4 81 350 maro
  6. Performance Stats for '69ZL1, anybody know??
  7. It needs to be faster.
  8. unleaded fuel
  9. HEI Rebuild Problem
  10. 5.7 vortec in 1981 Camaro?
  11. fuel fountain?
  12. rear info needed! please help!
  13. 305 and 350 intake??
  14. what is my engine doing?
  15. Michigan girl needs help with 81 Camaro Z28
  16. Appraise my car, please
  17. Appraise my car too!
  18. Best Gen 1 SBC 23* Race Head?
  19. powerglide to 700r4
  20. Ford 427?
  21. Read my plugs, please
  22. The new mouse
  23. trans swap
  24. 496 Stroker
  25. 454 BBC: stock heads on this combo?
  26. Points ignition specs
  27. 396sb vs. 406sb
  28. what times will I run
  29. whats a good company for crate engines?
  30. Anybody out there?!?
  31. Someone tell me the difference between these 2 Hedman headers.
  32. new spring old head set up
  33. Not Starting
  34. help
  35. Looking for an engine-rebuild FAQ
  36. engine help quick please
  37. rear end
  38. "Brand new" 1975 Camaro LT
  39. CHEAP engine
  40. flywheel tech
  41. Anyone know how to adjust a TH350 linkage?
  42. Too much play in the steering wheel
  43. Good methods of improving mp/g
  44. fan pulley wobbles....
  45. Trans Am 79 1oth Anniversary
  46. Valvetrain Questions
  47. 2000 rpm idle (even after warmup)
  48. Old Dodge Magnum Engine
  49. What Other Classic/Muscle Car Boards Do You Visit?
  50. Block Casting Numbers
  51. Oil Pressure
  52. Car Broken Down, Any Suggestions!?
  53. About to buy a 78 TA with a 403
  54. 20W50 oil
  55. Search for a 2nd gen... is this worth it?
  56. Reading NGKs
  57. Z28 302 engine question
  58. Re-doing the suspension
  59. Got ripped off I think
  60. Cam Break IN?
  61. how much HP can a carbed 305 make?
  62. question about sheet metal
  63. need help tranny problem
  64. Front Spring Problems
  65. Clunk from rear upon launch
  66. Correct pushrod length?
  67. '73 camaro neutral safety switch
  68. Request for info...
  69. Why so slow?
  70. New car 79 Z28, know nothing about carburated engines. Bad tune?
  71. '79 Z28 350 won't tune right exhaust pops !!!!!
  72. DZ 302 Questions ?
  73. hooker gheyed me...
  74. Please Help! I hope I didn't ruin a set of AFR heads :(
  75. Just bought a 1971...need some suggestions
  76. SBC Head Swap Coming - questions
  77. removing transmission
  78. Got my 74 Firebird
  79. How to tell a 350 block from a 400?
  80. Teach me about cam specs....
  81. ls1 in a 69?
  82. should I use a PCV valve brether? or the regulars?
  83. Aftermarket driveshaft?
  84. whats kinda 4spd manual trans
  85. very rough estimate on HP...
  86. Just got a 69 camaro, any suggestions on finding a TKO
  87. 350 in 81 Zed
  88. 302 crank
  89. exhaust
  90. Widest rims for a 78 camaro?
  91. Alternator help....
  92. What would you put under my hood?
  93. Compression Test - what is "good"?
  94. WHO Has Fast burn heads? RWHP #'s
  95. Jegs high flow 220 alum heads
  96. Any HP gains from using COOL CAN ?
  97. Need help with rebuild info
  98. ls1 swap in to a 67 camaro
  99. aluminum pulley's wanted for sbc small water pump
  100. Interior question (couldnt find specific forum)
  101. 67-69 camaro owners ever used a 93-97 ..........??
  102. 327 rebuild question
  103. Pontiac 301 V8 Question....
  104. DS question
  105. NEED help WITH '74 z28 "Type LT" interior
  106. Will this transmission work?
  107. putting an lt1 in a 68
  108. massive blow by
  109. 427's still around?
  110. i got a nasty squeek in the back and...
  111. 302 cam question (69 camaro)
  112. Rack and pinion
  113. turbo engine?
  114. electrical problem
  115. 68 Z28 fuel question
  116. I can't turn my car off!
  117. Cam help
  118. 1969 RS headlight problem
  119. t56 into 1970-81 camaro
  120. H/C Pkg:
  121. 81 Z28
  122. '97 Silverado 454 in my '67?
  123. 1977 Trans Am
  124. Is a 69 10 bolt and a 81 10 bolt the same?
  125. starting problems
  126. Engine Dies under hard breaking
  127. Fuel line questions
  128. ?best stock sb heads and intake
  129. Transmission Mount
  130. has anyone here ever flowed the old chevy
  131. First Generation Salvage Yard
  132. Identifying My Pistons
  133. what my interior and hood is worth?
  134. 69-74 z28 valve covers
  135. Rebuild Opinions & Suggestions? Cams, Pistons.
  136. some of my 68 camaro stuff im starting to sell more to come
  137. pontiac 455 vs buick 455??
  138. small block problems
  139. Anyone use Tri State cyl head Pro Topline knock offs?
  140. Can a cast crank take 450hp?
  141. suggestions for my Small Block
  142. 454 chevy block question
  143. How heavy is it?
  144. stock motor specs on 79 z-28
  145. Need an extra 1/16" clearance on valve covers
  146. 69 camaro
  147. you guys build my motor
  148. motor wont start
  149. Quick Ratio Steering Boxes
  150. New sts kit on 67 camaro??
  151. Best place to start.
  152. 69 Camaro With 93 Z28 Drivetrain
  153. is vin# 136370K135032 a 70SS Chevelle?
  154. Is this engine a 396 / 375hp?
  155. Feedback carb question (problems)
  156. Second (& third, & fourth) opinions please...
  157. crate engines
  158. CAM question
  159. Opinion of this car?
  160. Where can you get 3inch stainless exhausts?
  161. Old engine big problem (please help)
  162. cam question
  163. Pypes ?
  164. Oil system flush for a 327.
  165. What brand makes the best header for BB chevy?
  166. where can a guy find a radiator for a 57 chev?
  167. Whats your favorite Carb?? Holley, Edelbrock, etc???
  168. The 383's coming along. Got my rotating assembly last night.
  169. carb selection help
  170. Pics of the 383!
  171. stroker questions
  172. 79 Z28 starter need help
  173. Oil for my engine...
  174. Exhaust suggestions
  175. Need help with starter!
  176. Anyone had a smoke problem with a zz4?
  177. whats a 69 with a 307 worth?
  178. carb trouble
  179. What could cause a motor to just sieze?
  180. 454 Bbc
  181. Piston to valve clearance problems
  182. water pump
  183. lifter difference
  184. 1980 camaro
  185. valve covers
  186. Engine timing
  187. spark plugs
  188. 383 stroker motor
  189. 454 0r 383 will it fit?
  190. motor mounts for BBC in 79 Z
  191. Pics of my 383 stroker progress!
  192. What type of engine...
  193. Spark Plug Wire Placement
  194. 250 to 350
  195. How to make more HP out of a ZZ430??
  196. Timing Problem
  197. T56 in a 71 Camaro what will i need to make this work?
  198. 73 camaro with 700r4 what do i need to make this work?
  199. Kickdown cable to the carb!
  200. 327 Fuelie SBC
  201. Old School cams?
  202. Race Motor Timing
  203. Budget Motor Build
  204. pulley shims
  205. First time out with new Predator carburetor
  206. Lt1 intake on 1980 format engine
  207. 487X - Truth or Hype
  208. water pump pulley shims
  209. From Automatic to Standart
  210. Need factory crank specs for 67 302 small journal crank
  211. Anybody running the Holley Systemax package?
  212. Is this ebay Dart 434ci too good to be true??
  213. Valve Spring Tech
  214. Would a Camaro driveshaft be the same as a Nova?
  215. How to tell between aluminum and iron water pump?
  216. 1974 350 engine questions
  217. Oxygen Manifold
  218. '68 RS Brakes
  219. hood clearance with high rise
  220. Need help 69 camaro auto to m20 conversion
  221. Building a 406 need some info..
  222. 1965 Corvette 327
  223. sbc into 71 olds cutlass supreme
  224. Is this 750 going to be too much carb?
  225. upgraded rear brakes for 79 z28
  226. supercharger and hood clearance ? ? ?
  227. Tachometer location
  228. choke keeps flooding the car....
  229. Question on converting to serpentine
  230. Can you turn a 327 Block into a 383
  231. '68 Valve Lash
  232. Got a cam question
  233. 1971 gasket thickness
  234. I hate header gaskets!!!!
  235. BBC in a 81 Camaro
  236. Which water pump do I have?
  237. Big Block zz502 for '69 Camaro? Should I DO IT?
  238. Odd knocking/ticking sound
  239. 1st Gen Camaro forum???
  240. holley carb identification
  241. 327 power
  242. small block numbers
  243. What size carb
  244. Motor Mounts
  245. How do I remove the ignition switch?
  246. Can you replace the hub on a water pump?
  247. LS or ZZ383
  248. camshaft question. Please help
  249. bought a used intake
  250. 455 pontiac in a camaro?
