Classic Engine Tech
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12
  1. 2nd Gen Fuel Cell
  2. 202 heads do any have [] []
  3. '67 Carb Float..
  4. Kit for Chevy lovers >>
  5. Help me choose the right carb size!!
  6. Big cube SBC, need head advice...
  7. Need dyno for XS274/282
  8. 70 t/a hood questions
  9. Torque converter
  10. Headers and clearance issues
  11. Ford rear ends
  12. 4th gen rear end in a 1st gen?
  13. coil springs
  14. Tool Box
  15. v6 ------to-------V8 conversion
  16. 69 camaro help
  17. 5spd in a 2nd gen ?
  18. 79 camaro question
  19. Car has been sitting for about a year and a half...what to do to get it started?
  20. 94' LT-1 Steering pump mates to old steering box
  21. my chevelle engine plans
  22. 77 z28 front end swap to 79 berlinetta
  23. Paint question
  24. 69 camaro parts worth anything?
  25. split bumper conversions
  26. What is a 454 shortblock worth?
  27. Moroso Trick Front Coil Springs
  28. Front end alignment
  29. stock fuel tank and mini tub?
  30. New project car
  31. which tranny?
  32. rim size?
  33. Frame coating
  34. 68 12 bolt
  35. Good info for selecting wheel sizes
  36. Headlight Gremlins - any thoughts?
  37. Disk brakes?
  38. PST products
  39. Rack & Pinion
  40. Replacing Nose/Passenger Fender on '79 Z28
  41. someone on here asked some carb questions
  42. New engine install......
  43. 1980 Z-28 Restoration
  44. Thinking about going to Vortec heads, questions...
  45. Got some loose wires - what are they?
  46. Clutch for my 302
  47. Carb linkage prob, no W O T - Help!
  48. What do you think of this Engine Combo?
  49. D-port heads and non D-port headers
  50. Headers
  51. subframe connecters-advice?
  52. Group Purchase on T56 kits over at pro-touring.com!!!
  53. New 1st gen bodies ?
  54. 15x10 too wide stock?
  55. 1969 Camaro Frame Rails
  56. Simulation Software
  57. Anybody got a 1st gen drum brake setup for sale?
  58. Your thoughts on this car:
  59. classic car staus and milage on collectible
  60. Compression Check
  61. 81 gauge cluster swap - out with idiot lights, in with gauges
  62. 12 bolt rear end dimensions?
  63. 10 bolt?
  64. Dont laugh.. too hard
  65. More Wheel Questions...
  66. 6sp tranny swap
  67. serial # on a 400 ci block
  68. 73 type LT emblem
  69. 74' 468, What's it worth.
  70. how hard is it to run 6 speed with pre-86' block?????
  71. 67 SS and 67 RS Pictures
  72. chevy 305
  73. Heater core
  74. It has happened to somebody?
  75. Start w/ Engine or Rear-End?
  76. Z28 Rs Production Numbers?
  77. Is this a true SS
  78. Trusted Vendors
  79. Difference between M21 and M22
  80. Auto to Manual tranny swap...
  81. Anyone know how to take apart a deluxe seat belt buckle?
  82. lt-1 turbo 350 need info
  83. High Tech Gauges for my 69'
  84. Pontiac TC cover gasket
  85. 400sb 2 bolt or 4 bolt??
  86. Locked Trunk
  87. 406 Pricing
  88. How to tell if you have EEC?
  89. Chambered Exhaust?
  90. Manual or Power steering
  91. 69 S/s Amx Running 9's On Tbi All Engine....
  92. B&M Pro vs Hurst Quarter stick shifters?
  93. wanted: rear to fit my 69 bird
  94. l88 kit
  95. thinking about selling 71 rs
  96. Moroso Drag Springs
  97. Car Suggestions
  98. Need big front brakes for a 2nd Gen Camaro
  99. Need Door Jamb Pillars
  100. Hooker long tube coated headers for 1st gen for sale!
  101. Any one need some gears for a 12 bolt
  102. 350 bored .060 is..?
  103. 70 1/2 RS Split bumper all original 1 owner...
  104. legit vin plate replacement
  105. Testing EGR Valve?
  106. shifter
  107. Firewall Question
  108. Ol School chevy help
  109. Fuel Injection on a Second Gen
  110. Steering Wheel Pic's on 67-69
  111. Pulley Setup on a 350
  112. How do you know???
  113. electrical problem
  114. offset spring hangers
  115. Motor Decisions
  116. m/t heads?
  117. ss 350 68....help
  118. need advice
  119. Gasket help
  120. Powder Coating Front End
  121. Need Help
  122. A/C Firewall Stuff, removal
  123. Distr TVS
  124. W00t
  125. Nice Headlights!!!
  126. Rally Wheels
  127. Replacing upper fuel fill neck....
  128. Fuel Tank Paint??????
  129. Exhaust Suggestions
  130. pre 87 heads with LT1 headers
  131. Front width's
  132. Trouble with leaky 2ndary on holley 750
  133. Dyno of 67-69 Z/28
  134. Clutch Linkage for 79 Z28?
  135. Thoughts on car and a few General Q's
  136. Thinking Of Building A 1970 SS 396
  137. aproximiatly how much....
  138. Debate - "Upgraded" or "Original - Numbers Matching"
  139. Chevy 400 and Pontiac 400
  140. engine build and pics of car
  141. mechanical roller cam in pre 87 block
  142. We need to get a little representation from the early camaros!
  143. Mickey Mouse Heads?
  144. How much power can I get out of my O49 heads.
  145. 78 Dash Question
  146. 1980 z28
  147. Carburetor Questions. Plz Help.
  148. 383 stroker kit
  149. Need help
  150. '88 Drive Train into '79 Body
  151. Seats
  152. Pistons are too stiff on the rods?
  153. What's this worth?
  154. 65 Chevelle Build-Up
  155. Lt-1 into a 70 Camaro?
  156. body question
  157. For all you carb people...MPG??
  158. 6 Speed Tranny Swap
  159. 81Z w/ac heater core removal
  160. Weld Prostar wheels
  161. Last few things before starting.....
  162. How to change a/c clutch
  163. 4th gen wheels/tires (ZR1's) on a 67 Firebird
  164. Vortec truck motor
  165. Buddy just bought a 77 camaro, what power does it have?
  166. What stall converter is right for me?
  167. Deluxe interior, rear seat measurement question.
  168. Rear Leaf Springs
  169. Whats needed to retrofit LS1 into 70 Chevelle
  170. Broke the pinion shaft retaining bolt in carrier! HELP!
  171. Engine rebuild suggestions.
  172. Free Lugs for a 2nd Gen
  173. 1970 L78.... Trim Tag L78 and no Z27... Help
  174. motor recommendations??
  175. Replacing rear window seal?
  176. Check out my 69
  177. C5 Rims on a 2nd Gen
  178. EFI swapping guide available
  179. Thoughts on this car (Round 3)
  180. Help Me With My Set-Up
  181. My Camaro
  182. After paint...........
  183. 2nd gen weight?
  184. 1972 camaro
  185. Couple of second gen camaro questions
  186. 72 formula clone 455 4 speed
  187. Carb Question
  188. 69 camaro suspension questions?
  189. Rarity of 75 Camro type LT
  190. New Camaro owner..... maybe
  191. rear of camaro
  192. 78 Trans Am car bra search. Help!
  193. Body repair cost
  194. engine size
  195. which 10 bolt?
  196. Wheels spacing 1969
  197. Does anyone know if 4th gen rims/tires will fit a 2nd gen?
  198. black seats with.. ? color carpet?
  199. 70 PONTIAC A-body, whats a good exhaust manifold?
  200. Engine swap
  201. replacement ac parts for 72 firebird
  202. 327 Rebuild w/ new cam
  203. shifter placement
  204. GM A body Board
  205. Where can I take my MSD distributor?
  206. Door won't open
  207. Pontiac 69
  208. header question
  209. 4th gen wheels on Classic
  210. Jetting On A Street Avenger.
  211. broke a bearing race in my 8.5" 10 bolt.. advice needed..
  212. Looking for green 69 camaro with white stripes... anyone have any info on colors?
  213. 69 Tic-Toc-Tach
  214. Timing help please.
  215. Engine & Trans Questions on a 78 Camaro Z28
  216. trick flow sbc heads. what plugs should i use?
  217. 202 heads???
  218. Wiring Problems???
  219. Anyone else burn oil?
  220. 69 camaro z28 rebuild
  221. Clean Car
  222. If you have any ATS products on your car- CONTACT ME!
  223. Any of you guys trailer your 1st gen?
  224. Source for new control arm
  225. steering column swap
  226. How hard is it to get a T56 into a 2nd gen
  227. 69 restoration
  228. 4G Rear End to 2G
  229. which big block heads are better "049"or"781"
  230. 67-81
  231. Complete 78 Interior in 80 Camaro?
  232. 1979 z28 value
  233. Rear Quarter Removal
  234. How to tune a carb?
  235. 81Z28 4sale
  236. What is the proper coolant and water mix?
  237. So I got bored and started my car today
  238. Leaf Spring Shackle
  239. dipstick not reading correctly
  240. Z28 Cluster on Non-Z28
  241. My 1st post
  242. different trans
  243. Been having a vibration problem.......
  244. Rear subframe rusted to pieces (78 camaro)
  245. Sonuva...!!!
  246. new brakes
  247. Can anyone check VIN for 70 Camaro?
  248. Brake Lights suddenly dont work...
  249. 355 falls over at 4K RPM. Advice???
  250. 86' corvette heads on 79 z28?
