- Intial Oil Path for Early Model Chev SB
- driveshaft help please!
- My 68 coupe
- T56 6-SPeed in a First Gen?
- $$value of 72 Z28 clone
- 400 crank ? specs
- Where's the #1 cylinder on an older 350?
- Suggestions on heads?
- How do I get the window crank handle off?
- L88 and LS7 Question
- oil breather
- L65 info
- need info on zz3 engine
- How much metal in filter?
- What are some websites for buying parts?
- RamJet
- Suspension Questions
- Core Plug is Leaking - Need Tips Please
- lt1/tpi/sbc ?
- Need help on header gaskets on zz4
- Spring INstall
- turning a 76 into a 70
- NEEDED ASAP - Anyone with a nice '69 Camaro Z28!
- Stout Auto Trans
- heavy chevy
- Eagle or Scat crank and rods?5.7 or 6.0 rods?mains?
- This is my camaro
- Demon Carb question
- Intermediate cable for Emergency brakes....
- 4 barrell carb.
- Need Help Finding Parts!!
- Anyone want to trade a 67-70 for a 4th gen?
- holley stuff
- Correct Speedo Gear
- Help me pick out an intake manifold and carb set up....
- 4th Gen Seats in a 77
- Fire up the Grill
- Parting my 67 Camaro out. Anybody want a EFI turbo engine?
- My Car Sounds Vicious! Sound and Video Clip Inside
- heater
- 1970 Camaro SS Tach
- Custom hood?
- Post your street/strip small-block combo
- 700R4 in a '79 Z28?
- THINKIN ABOUT BUYIN A CAMARO for my first car! :)
- 76 needs to go on a diet post haste.
- 4th gen interior in 2nd gen
- Thinking of selling the car
- Seatbelts in 1970
- Where to buy a disk brake conversion
- compression and pistons choice?
- timing question
- Edelbrock Chapman RR heads?
- Serpentine for 1st Gen?
- Attn. Big Block Guru's
- ignition switch
- how much could i sell this motor for?
- 77 camaro question
- Help With mystery motor...
- shaken while clutchen
- 327 or 396
- selling my motor
- Stupid seat belt question......
- engine problems not running right
- rear end
- questions on swapping Olds 455 into a 403 car
- where can i get?
- Camaro!!
- how much hp does...
- ignition wires
- 1979 z28 350
- what "all original" means?
- blown67 pics
- New Member, '78 350 4speed
- Why is the LS6 engine code given to a big block and a small block?
- Overheating
- 1st Gen. Tramsmission
- Carb and Intake
- Fender gills '78
- transmission for a 67 camaro
- 327 problem
- Lakewood scatter shields
- Is it worth it?
- WTB Lower Front Valance
- How much $$$ for a 1979 T/A
- Weiand stealth or Edelbrock Performer
- trans question again
- Brakes/engine question/poll
- Getting Head.....................ers
- How will these rims look on my 1979 Z28???
- Brake question
- Brake Compatibility
- Question about "Complete Dual Exhaust kit", Jegs
- N90 aluminum wheels go for?
- Electrical
- g-machines ?
- 1980 Z28 w/ an LT1 A4??? How?
- Is this a good price?
- What carb to run?
- Opinion
- Is it my fuel pump?
- My 68 Camaro is going bye bye...
- Looking for.
- 70 z28 ss rs difference?
- Another "what's it worth" ?
- starter
- original paint & graphics
- my 1980 thinking of selling (pics)
- Gold emblems for '76 Trans Am?
- Anyone running TT IIs on a first gen?
- Just picked up another Camaro
- Engine update question
- 1971 nose on an 81 trans am
- speed demon 650cfm carb Help
- 1st gen radiator core support repo/fiberglass??
- Quick Ratio Boxes
- 1970 camaro ?
- Radiator tech question.....
- Anyone using aftermarket subframe?
- Am I lucky or what?
- HELP me finish my carb install - throttle issues....
- carburetor
- Rear truckarm suspension
- how do you get to the trunk hinge to replace it? and where can I get one at?
- Crate motor suggestions?
- 69 Camaro Emissions
- What would this run?
- CarFax or somthin similar?
- Disk Brake material questio
- no spark
- 81 z28 1/4 mile times
- Engine Bay Harness....
- X pipe vs H pipe on First Gens....
- 75 camaro look to a 78-81?????
- completely new!!
- wiring
- look but don't touch signs?????
- Looking for old muscle cars out west?
- LT1 starter
- Parting out 79 Trans Am
- anybody want to trade their 1st gen for my 4th gen?
- my 81 z
- 502 Crate Question
- First Gen Camaro Question
- Looking for info about the '70 Z28/LT1 cam
- Got a problem need advice
- Automatic? Manual?
- gear question
- Big Shout Out To Damon
- msd 6al box
- What do you think of this suspension kit?
- Restoration question
- Adding a rear sway bar question
- What are you guys doing for aftermarket stereos?
- 2nd Gen LED Tail Lights?
- What is your favorite Classic Camaro movie/TV car?
- Horn tech on 1st gen cars....
- Suspension SEtup
- What are good tire sizes for 16x7 rims?
- cahmpoin plug to AC crossover.
- Hello All
- Weld Pro Star wheel help.......>>>
- Question on Dana Camaros
- 355 engine
- What wheels would look nice on a 79 camaro?
- new guy here
- 1st gen questions
- Complete Fuel System
- NASCAR SB2 heads
- check engine light when msd is installed
- best shifter?
- Great Q & A site !
- Wheel and Tire combos
- How do i swap a 229 for a 305?
- no Z-28 for me BOOOOO!
- 3rd Gen to 2nd Gen engine swap
- ford fairlane
- Lowerinf "blocks" for read axle question.
- Camaro control arm relocation template / Suspension Help!
- AGR steering box question
- POLL - What brand and weight oil are you you guys running?
- This one is easy....Torque specs on lug nuts..
- Motor Oil
- Stock spec front coils....do they settle?
- 3rd gen rear end in 1st gen
- What was the stock 15 inch tire size?
- i need tips on building a 350. wanting 500 hp.
- inner-wheel well.
- Power valves.
- I'm looking for a 67-73 Camaro with an LT1 or LS1
- Engine Combo?
- cross threaded block
- Backspacing on 1967 Camaro ?
- looking for a '69
- maybe you guys could help with a gas tank leak ?
- I would like to say that these 1st gen...
- Bellhousing Bolt pattern
- interior swap from a 4th get to a 2nd gen
- 1973 Trans AM Taillights
- Tire size (math formula) query
- Body Work..........?
- 454 with 700-r4 gear
- a/c heater fan rem & ins
- Edelbrock Air Gap vs. Victor
- Areas of concern in late 2nd gens
- Brake Fluid
- has anyone had to replace a dashboard
- Mesurments needed for door mirror (round, first gen)
- Question about Holley Carb...
- 327 question.
- Black Panther !
- max hp and torque for a 2-Bolt?
- Sluggish when Hot??
- Camaro Shifter Mount Location
- Not a chevy, but can you help anyways?
- Carb Backfiring.
- Holley blue fuel pump question
- 400, 350, and 1978 Trans-Am Parts For Sale
- Dynomax vs Hooker Aerochambers
- Hydraulic Lifter Sequence for a Chevy 350
- help
- Supercharger
- Just bought a 1981 Z28
- Sub-Frame Conectors
- Power door locks and window kits...
- Who remembers the Cheetah ?
- Another supercharger question
- Rear Discs and C-Clip Eliminators
- Getting a 2nd gen-
- My experience with classiccarsprings.com
- Where to start
- Head casting #`s
- 72 formula info wanted
- rear window
- I am having a hard time deciding on a color
- piston identification...
- Pics of Procharged 454 in my 80 Z28
- Installing RS lights on a plain jane 69 camaro
- What is the correct color or paint scheme for....
- Price of Labor, Engine Swap?
- Tire size and 2" drop 67 Camaro
- 1st Gen for Daily Driver?
- Valve cover breather
- Rear Springs
- Shocks
- East Coast Classic Cars
- pagin dirt
- How do I STOP the HOP?? (2nd Gen)
- Is this a good deal?
- two speed tranny?
