Classic Engine Tech
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. 60ft times,second gen cars..what times and what setups..??
  2. lot of HP with monoleaf springs?
  3. Window seals
  4. Int. manifiold prob
  5. exhaust leaks
  6. Anyone have a holley carb interchange book? (or know the double pumpers well?)
  7. All you fellas with the 17's on your 69's..
  8. Quest for a Rear for my 2NDgen TA
  9. 69 Z28 302 question
  10. Anyone using gear drives
  11. blowby question
  12. Engine Build Help
  13. Recomending timing on my 327 with the new cam
  14. Timing question on my auto car..??
  15. 1/4 time and shift rpm questions..??
  16. Split Bumpers
  17. have 049 heads fallen from grace?
  18. Building a 307
  19. Air bags on a 1967 camaro.
  20. From points to HEI conversion
  21. Th350 and shifting problems?
  22. Put in new speedo cable speedo still acting weird!!??
  23. 79 to 81 taillight seal questions..??
  24. How much more power with bigger carb??
  25. Pacecar question
  26. Anyone use lead additive in unleaded gas?
  27. My Friend Has A Question
  28. 10.8:1 cr too much for pump gas?
  29. Please Help!
  30. Valve train geometry question
  31. disc brakes on a 67 camaro
  32. ? about shackle
  33. Spindles?
  34. PlastiGauge?? aargh!!
  35. I know it's not camaro related...
  36. 69 1/4 mile times?
  37. kickdown cable for a TH350
  38. 69 dash help
  39. Front end rebuild
  40. 67 - 69 frame
  41. Trying to get new engine running - backfires through carb
  42. Lt1 In My 69?
  43. 350 heads
  44. Arrgh! Clutch/Super T-10 Probs
  45. Dart CNC 227 and felpro 1205 gasket?
  46. Clips that hold in headliner needed
  47. opinions about Strange engineering
  48. F/S MUNCIE aluminum flywheel
  49. 1981 Camaro Z28 FOR SALE
  50. Edelbrock EFI kit users come
  51. My Engine (look!!) Help Me Out!!
  52. Whats my Compression Ratio?
  53. Will this hurt my engine?
  54. Going to Dyno: Is There a Standard Process?
  55. What intake manifold for 12's ?
  56. will 275's fit in a 2nd gen?
  57. Speed Demon help!!!!!!!!!
  58. What Heads/Intake to use?
  59. What to do first?
  60. Old style Trannys
  61. Which would you rather have?
  62. MASSIVE Overheating Problems
  63. Compression Ratio and cam questions
  64. Edelbrock Air Gap or Weiand?
  65. I think im running to rich.. help
  66. Demon Carb tuning help!!!
  67. what intake and headers??
  68. net vs gross hp
  69. ? on heat riser install- 68 RS
  70. 81 camaro hood scoop
  71. what would my car be worth?
  72. F/S SB 400, 6 speed, Muncie 4 speed
  73. Wheels and Tires on 1978 Z
  74. which manifold?
  75. 79-81 gauges
  76. 2nd gen drop
  77. firing order on a 1999 350
  78. Holley Street Avenger question(s)
  79. Distributor install
  80. Possible to stuff 295's on a 67?
  81. Will performer RPM airgap fit?
  82. 69 Camaro Fenders
  83. hood question?
  84. leaf springs=>what brand is a good choice ?
  85. Timing Tab?
  86. tranny swap question
  87. junkyard intake manifold and headers
  88. T-56 in 69' Camaro
  89. backfire with headers
  90. LT1 in a 2nd Gen?
  91. Vin info on a 69 GTO
  92. help with building a 327
  93. No Spark!!
  94. Edelbrock carb questions
  95. Will Procharger P1-SC fit under 2nd. Gen Hood?
  96. centerforce clutch ?
  97. what do you think about this plan?
  98. pan gasket blowout
  99. Need more power! HELP
  100. 1969 Camaro ZZ502 or 2003 Corvette Z06
  101. Full Framed 2nd Gen?
  102. pinion shims
  103. Beating an LS1
  104. 425 HP, 355 CID, Short Block
  105. Can someone explain Heads to me. I got 2 dumb questions
  106. Fuel pressure inconsistancy...
  107. shock choices
  108. Any 1 have pics of 17's on a 2nd gen?
  109. biggest tire size for 2nd gen
  110. 4 Speed Tranny Identification
  111. -67 steering wheel help
  112. 1980 Z28 Part # question!! Help!
  113. 67 chevelle???
  114. new motor wont turn over
  115. Weld Racing Pro-stars broke
  116. Decisions?
  117. recommendations?
  118. where can I get a door alignment tool?
  119. )-Ringed Block
  120. these heads any good?
  121. rear gear ratios 81z
  122. Norwood Strike Question?
  123. 383 stroker?
  124. Advice on buying a 67 Camaro RS
  125. Wheel Alignment?
  126. 350 crank in 327
  127. 77 Firebird 400ci question?
  128. straight 6 exhaust
  129. HELL YEAH! Got my girl running again!!!
  130. Power steering conversion
  131. hesitation problem almost fixed, ???'s
  132. Its A Boy!
  133. harmonic ballancer ques.
  134. "camel hump" heads?
  135. HELP Please Front end nightmare!!
  136. Holley Help
  137. Just wont to say thanks for the replies
  138. 400 sb, and th350 question
  139. Help with '72 396/402 engine I'm building....
  140. cam question guy's????????????
  141. POP Question
  142. Clone or Original?
  143. Good Price? Good Car?
  144. Where to start?
  145. best ignition timing type for sbc?
  146. had a little manifold mix up
  147. Want to know everyones opinion on these Camaros
  148. New Jets to Match Climate?
  149. Gangsta Lean
  150. HELP with 67 RS headlights
  151. what's it worth?
  152. what kind of theft protection do you use?
  153. LT1 / 67 Camaro
  154. Gauge Problem
  155. New Motor Delema
  156. Engine problems
  157. transmission lines
  158. recommendation wanted
  159. My headlights stopped functioning the other day..
  160. 67-69 Ss
  161. T56 ~ 700r4
  162. i'm looking for a 69 camaro rearend??
  163. Wheels and Tires for 2nd Gen
  164. Must Sell 1978 Camaro Z28 Original
  165. How to open the darn hood!?!?
  166. what year transam had the strongest engine
  167. Whats some good 1st mods to do to a 79 TA 6.6L?
  168. Exhaust Crackle, Why?
  169. Bought the 67 Camaro i showed you before
  170. acid dipping
  171. I'm a Noob!!!! Sorta....
  172. Tight engine fit for the LT1 in the 69'
  173. Doors?
  174. drum to disk
  175. IT's DONE!!!!!!! 9" Installed
  176. temp question
  177. Need spark plug gap
  178. carb ?
  179. Gen 5 Camaro concept
  180. water pump
  181. Seat Covers....
  182. Brakes????
  183. Trouble with '68 Dodge...hopefully you guys can figure it out...
  184. 95 LT1 in 2nd Gen, which headers?
  185. Brake Light on Dash is on...help
  186. well...
  187. Heads worth anything?
  188. 1971 firebird w/ 400 engine, TH400 trans FS
  189. aftermarket heaters and a/c
  190. Would you pay $1500 for......
  191. Please help identify rear end on 69Camaro
  192. what the "XX7" code
  193. Rear end question
  194. Lakewood uni traction bars
  195. Old Chevy 302 motor
  196. Size of AC Vents?
  197. '67 Camaro Radiator Upgrade?
  198. help i need summits code for 10% off today!
  199. For the Experienced Engine Builders
  200. Has anyone here dyed some of their plastic pieces on their old car?
  201. Looking For A Scatter Shield.
  202. need opinions on possible purchase
  203. 4th gen stuff in a first gen...
  204. what trans is in a 79 z28 automatic
  205. cant shift gears. please help
  206. 700r4 Ratcheting shifter?
  207. jack points for a 68
  208. 383 with low miles forsale
  209. Computers on a 1981?
  210. About Trans-Am rear end
  211. paper behind back seat
  212. couple engine swap questions
  213. gm water pump pulley part #
  214. 454 in a 69...
  215. Turbo 6 or BB?
  216. Suspension Upgrade...?
  217. new photos
  218. How do i shimm a distributor?
  219. where can i get guages for a 68?
  220. I cant unlock my door!!
  221. 4th gen seats
  222. seatbelts in a 1st gen.
  223. bigger wheels causing speedometer probs
  224. Best place to buy short blocks?
  225. BBC build up
  226. 4th gen seats in 2nd gen
  227. lots of small block basics ?'s
  228. Motor Is Done!!
  229. Help with stutter!
  230. Stall Converter?
  231. Changing a Clutch ???help!!
  232. New Member needs advise
  233. 1st Generation Forum
  234. low MPG on '78 350
  235. Are SS Clones an acceptable restoration approach?
  236. Anyone ever install an AC system?
  237. 77 camaro...question
  238. First Gen Pros in here please
  239. 350 steel crank on ebay
  240. 67, 68 Body
  241. help with crank,rods,pistons!
  242. Headliner install - 67 Camaro
  243. '68 Firebird wheels
  244. My new car - maybe.....
  245. driveshaft ?
  246. New Forum
  247. What rear should i get?
  248. Rear window molding removal - '68 bird
  249. Carb too small?
  250. price 79 z28
