Classic Engine Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12
  1. 4th -> 2nd gen swaps
  2. Best mufflers on an olds 403 in my 79 TA
  3. Can I use this t-56 with this much torque?
  4. An Action Shot of the Z at the Track
  5. So how do you like my new toy?
  6. Gunson Gastester
  7. what does my 80 Camaro weigh????
  8. intakes with egr
  9. I'm desperate for a camaro
  10. Looking into a 1st gen
  11. Subframe Connectors on my 80
  12. Rollcage
  13. parts for the body of a 1981 z-28
  14. Those of you that want to do a T56 swap into your first gen! I got something you need
  15. T56 Swap...Yoke
  16. For sale
  17. New lighter FLwheel
  18. 2bolt main rpm limit?
  19. Sump or Cell?
  20. T56 bellhousing?
  21. sbc 400 heads
  22. need a 9 inch "pumpkin, 28 spline,posi,about 3.5 gears
  23. Q-Jet intake help
  24. body parts?
  25. Is there anyone using a fuel cell that has got there stock fuel gauge to work?
  26. oil pump driveshaft
  27. intake and carb?
  28. anyone around maryland?
  29. 2nd Gen Roll Call: British Columbia
  30. 1st gen Update
  31. Ticking sound from engine.
  32. Did anyone see the article in the new CHP?
  33. Coan Torque Converter
  34. 1981 z28 air induction
  35. LS1 questions
  36. Shoulder Straps in a Conv?
  37. Mini tub
  38. Rendering of the baddest 1st gen EVER.
  39. stroker motor???
  40. Project F-117 Stealth Details
  41. '56 Chevy w/ 265 motor
  42. cam info
  43. advice please?
  44. 74 vette with a 72 Z28 block question
  45. A/C Qeustion on a '72
  46. 71 Firebird have questions.
  47. 1978 gold bird TA lots and lots of parts 4 sale
  48. Rpm Air-Gap= no power until 3000rpm??
  49. Roll Cage
  50. shock extenders?
  51. Pics of the cracked rocker arm
  52. 400 sbc deck height
  53. Have I been drinking too much or what?
  54. Recommended Clutch For 69 Z
  55. Hey guys...
  56. t-56 Trans on SBC 350, please read!!!!
  57. Sway bar on a 1st gen ?
  58. fuel injected 69 camaro
  59. flywheel hp to rearwheel hp
  60. Original 67' Camaro distributor specs
  61. When was the first camaro made?
  62. What should I expect for $10,000
  63. Anyone Know Where I can Get Power Steering Bracket For My 81 Z?
  64. Flat-tapped or Roller for 67
  65. Is there any steel spring wedges out there?
  66. G-Machine 1st Gens
  67. Shorties vs. long tubes
  68. Pro Topline - Iron Lightning heads
  69. what will it run in the 1/4?
  70. 1973 Camaro ---> ALMOST ROAD WORTHY!!!
  71. Looking for a 454 block/complete engine and vinal top question.
  72. how do these parts sound?
  73. I have a question about my '68 Dodge....maybe you guys can help
  74. ball joints ... HELP !!!!
  75. Can I Get a Good second gen T/A for under $3000?
  76. Exhaust
  77. rear end ratio
  78. Why does the 1970, 1971, and 1972 camaro's weigh less then the 1973 and up
  79. Best way to sell a 71' firebird??
  80. Biggest 1st Gen Tires?
  81. weight
  82. Temporary pics of 50/50- Completed!!!
  83. looking for 69 guage cluster for aft mkt guages
  84. Prep work before pulling my 327?
  85. 327 shifting at 7K?
  86. 2nd Gen Mini Tubbing?
  87. Classic 1/4, pics, sounds...POST!
  88. Clutch Recommendation
  89. holley help
  90. Paging all 1st gen Z28 owners!! exhaust question
  91. AHH... Dieseling help!!
  92. 79 Z is dead,looking to rebuild (budget)
  93. Not starting after 4 months
  94. 400 a big block, or small block?
  95. pinion angle
  96. 2nd Gen vs 3rd Gen seats
  97. Very odd gear ratio question
  98. stock exhaust manifolds vs. headers
  99. Best Distributor???
  100. Cam Experts
  101. Best Street/race Carb??
  102. 350 casting year
  103. What happened to nastyz28.com?
  104. Help with my lights...
  105. Gear change = quicker ET???
  106. lower springs went higher !!???
  107. What intake???
  108. Terminator/Afterburner mufflers...
  109. Electric Fuel Pump?
  110. need link - who was it that was doing an LS1 swap into a green first gen?
  111. '78-'81 Suff Sills?
  112. big block or small block??
  113. Looking for 68 roof or parts car!!!!
  114. Questions about a 1974 Camaro
  115. running straight pipes...
  116. 4.10 rear end
  117. Doesn't look like I am going to be able to keep the 69 after all...
  118. Mallory unilite replacing HEI
  119. 2nd gen 12 bolt
  120. Building a 302
  121. Front Shock Lower Mount Nuts
  122. Hurst Competition Plus mechanism...
  123. wiring harness install quetion
  124. 1980 Project Car, what do ya'll think??
  125. Same Cam, different engines?
  126. Engine Stalled
  127. Down on power...
  128. Please Help!!! Disc Brake Conversion
  129. Centerlines
  130. Car sags to the right..
  131. Rear Susp ??
  132. Rack and Pinion
  133. Headers on a 1975 Camaro
  134. muffler stuff
  135. 81 camaro 502 BBC swap?
  136. What wheels do you have?
  137. What causes fuel pump to leak oil?
  138. Front End Swap Possible on this car? Help!
  139. Running to hot.. cant bring it down.
  140. Z28 Auto Vs Gear
  141. Decisions....
  142. HID's
  143. Got A Tranny Question
  144. rear end
  145. Rally II wheels and chrome exhaust tips for sale
  146. Restoring 67 Camaro
  147. BBC head casting
  148. 68 firebird clutch fork
  149. camaros
  150. Hey guys, I need a refresher
  151. "self-aligning" roller rockers on World Heads
  152. I just joined the club! A few Q's for you...
  153. Synth or Natural Gear Oil?
  154. Terrible gas milage outa my 67
  155. 67-68 Z28 Water Pump Question
  156. inner fender wells
  157. 68 Camaro brakes swap
  158. 69 Z28 JL8 resoration pictures
  159. ? about leaf springs for a 68 camaro
  160. New pics
  161. Correct Headliner for 77 SE
  162. Need a new Carb???
  163. tubbing halfback system.
  164. Finally thinking of building a 2nd gen Help me out here
  165. 68 Gas Tank... How the Heck?!
  166. 1969 z28???
  167. Seats
  168. got a 94Z and a 69 sitting side by side...
  169. 67 Camaro rear window resto
  170. TH350 temp gauge sending unit, where?
  171. 00 Trans am Rims on a 79 Camaro?
  172. ? about body bushings
  173. help- need a water pump bypass hose EBLOW
  174. cowl tag
  175. Building a stroker hopefully
  176. I am about to Purchase an "original" 69SS
  177. new leaf-springs for the drags
  178. Keep 97Z28 or Restore 67RS/SS?
  179. Hi!
  180. Shift Kit and Rear-end Install
  181. f/s 70-73 parts
  182. HELP!!! dropping a lt1 in a 67 camaro
  183. color codes?
  184. Starting Problem
  185. Need opinions on carburetors
  186. Speed Demon 750cfm Carb vacuum sec. Question
  187. How Much...?
  188. restoring a 69'er
  189. Is the EFI MULTIPORT KIT worth the money?
  190. If you put 350 heads on a 400 do you have to drill the extra holes in the 400 heads?
  191. First gen questions for a soon to be owner
  192. Trying to find out if its an SS or not
  193. Big Block Chevy heads and valves FS
  194. Recomend a STRONG tranny?
  195. I need a trany dipstick & tube for a 68 Camaro w/a TH400! Help!
  196. 572 crate motor?
  197. Cal-Tracs for sale
  198. Rancho GT3 leafsprings for sale
  199. Gulstrand & Herb Adams suspension parts fs
  200. Transmission or Differential? Need Advice..
  201. Seeking info on M6 install in '70 Z28
  202. Connecting Rods Most Important Part?
  203. What's up?!
  204. clutch linkage
  205. questions on 81 z28
  206. Holy cow ... painting is expensive !!!
  207. f/s tuned port inj. kit, accel dfi
  208. New.. lots of questions for you guys..!!!
  209. Can anyone scan me a fuse box picture for my 80 ta with power eveyrthing..
  210. 2nd gen parts for sale
  211. do i need a torque converter or just not producing enough vacuum
  212. 78-79 driveshaft length?
  213. Looking for mkt value on a Grade a '67 Firebird
  214. shocks to get for street /racing..??
  215. south side lift bars..or ce trac bars..??
  216. What springs for front end of big block second gen..??
  217. Should I got with 2.5 inch dual exhaust or is my 2 and 1/4 good enough..
  218. Indash gauge pictures on second gen tas..
  219. Cant get heater fan to work since last owner took off air system.
  220. My Speedo is All Messed Up.
  221. New converter got me 12's
  222. Fuel Pump Problems
  223. coilovers on a 68????
  224. tpi setup for sale, cheap!!!
  225. DAMN EXHAUST LEAKS! suggestions???
  226. disc brake conversion
  227. Looking for people that have swapped a SBC into a 4th Gen
  228. Vortec swap
  229. Need to know color of the underside of original hood 68 RS
  230. th-350 or 700-r4 ??
  231. What's your 350-400 CID carb size?
  232. 2nd gen fbody parts for sale
  233. Ok guys running the summit or ce adjustables on the street.??
  234. wanted: 2nd gen driveshaft!
  235. T56 install pics from 68 Camaro
  236. Is the rear end ratio marked somewhere on outside of case or something.??
  237. What makes for quiet gears.??
  238. Composite leaf springs good or bad experiences..
  239. San Antonio Texas folks...
  240. How much power gain from 1.6 rockers
  241. Car won't start?
  242. How much horsepower big block and 6.71/8.71
  243. Is this a fair price?
  244. Installing 3 point seat belts in my '69
  245. What to clean 80 ta dash with..
  246. Still can't decide which shocks to get..anyone running the ce or summit racing ??
  247. question about rear suspension on camaro
  248. '88 Camaro Rims and Tires
  249. 69 camaro SS
  250. Weldwheel weight questions and opinions..??
