- 68 Camaro rolling chassis
- Approx HP from my 305? please give me your best approximation
- Vortec Heads on 68 327
- Rear Disc for my 68 10 bolt rearend
- Steering quiestion
- I have a serious question
- connecting rods
- ANY aftermarket/new/rebuilt 4 speeds for BOP engines??? T-10???
- Would a .060 455 with High Domes and a nice cam be a decent starting set up?
- 67 option question
- Stock 305 head numbers: what can you tell me
- Scrap Old plans, new monster!!!
- Vette
- can't time 67 camaro 350
- anyone here using a vac. reserve cannister?
- Please explain the difference between solid and hydraulic lifters.
- Engine Block ID
- Wanted:Pic of a 1st Gen w/ exhaust ....
- stock heads/dome pistons
- 2nd gen suspension recc.
- stereo placement
- 327cui vs 350cui
- Baby steps.
- 327cui
- Does anyone know Greg McGann?? (http://www.holisticpage.com/camaro)
- how to change pontiac ignition switch
- Question = What is the difference between Total timing and initial timing?
- Need Help Choosing new intake
- My first camaro question
- Strength of the corporate 10 bolt rear
- What is the maxium amount of lift you can run with 6X pontiac heads.
- Quick question regarding Holley Carbs
- battery dead
- biggest tires on a 15x8 corvette rallye wheel?
- springs
- CPP disc brake conversion kit?
- Wow...
- Holley Blue Electric fuel pump...
- mufler question
- Muncie M21, M22, or Super T10 for my 69 Camaro
- Distributors - MSD - Says it will only work with their complete ign. system?
- Holley carb identification
- smog pumps
- Roots supercharger on 454
- leaf springs
- help id a block #
- Which gears to run?
- taking out radio
- Control Arm Bushings
- What should I expect?
- Wheelhop, traction bars, and crappy springs
- One Wire Alternator Install
- lowering a 1980 Z28
- Ideas on next motor ....
- LT-1 Into a 87 Buick Regal? How Hard?
- Exhaust Question
- 400 Head Gasket ID, need HELP ASAP!!!! PLEASE!
- What is the weight of a stock 67 Camaro?
- engines
- Replacing Quadrajet Carb on 69
- At the strip again
- rich holley!
- 69 camaro turn lights
- need some wheel help
- LS6 compatibility
- Flexplate teeth?
- Carburetors
- question on th400
- Anyone with older Convertables in here!!
- which year of 400 small blocks are better?
- BB ram jet
- Ind. Suspension in a 1st Gen?
- 400 Small Block
- putting 68 traction bars on '68 camaro
- Powerglide
- 400ci and 350ci
- RS Headlight conversion
- need some timing advice
- fattest wheels that can fit
- Rearend swap
- Backspacing on a 69 Camaro.
- What size is this carb?
- Will 4th Gen Rims fit on a 2nd Gen?
- Anyone wanna trade cars?
- T56 Clutch master stroke?
- Looking for a first gen
- heads?
- hotchkis suspension
- Force fuel injection?
- hood bird
- Automatic to standard.
- 383 buildup
- deluxe door panels, used or new?
- My 1980
- searching for 1970 to 1973 firebird or trans am
- Still problems
- What is best to treat a roof with after removing V-top ?
- T56 in 2nd gen w/ poncho 455?
- my '79Z
- What am i Doing Wrong? (Holley Tuning ?)
- Will a 295/60/15 fit under a 1969 rear qtr assy
- Anyone have any soundclips of a 302?
- base $ for a 78 corvette??
- FS: 2nd Gen gauge package
- Can Someone Please Explain This to Me?
- How does an Amp gauge work???
- Need to get a rear-end
- NOOO, Look at what I missed!!!!
- Chilton book
- t-56 flywheel
- Anyone running a carbed gen 2 LT1?
- Must Sell 1978 Z28
- new site
- LT1/T56 into first gen sites?
- How can you tell......
- HP/Torque output estimation
- Im looking at buying a 67-69 camaro anything to look out for?
- oil temp guage and brakes
- Waken up a 350
- Some stuff from early 70's camaro for sale
- What brand of headers to buy
- Aluminum Driveshafts? Can't find em for my car....
- need roll cage pictures
- What times to expect?
- Wanna go faster w/79 383 ci camaro
- Question about 1967 Pontiac Firebird
- how safe are we?
- Does anyone have info on Smokey Yunick and esp. his 67 SCCA Camaro?
- 327 1/4 time
- carburators again
- Can you decode this rear axle code?
- My 69 Rear Quarters are sticking!!!
- 77 Trans am heater box
- Have a 72 Pontiac 400 and TH 400 what can I do to get most hp possible?
- Powerglide to 4 speed standard.
- small black
- Performance improvements with a AL driveshaft?
- White Lithium Grease
- Trade/Sale: 68 Camaro front end
- Vibration in driveshaft/rear end...
- Difficult restart when warm
- Wheel and Tire fittment questions
- Rear suspension (leaf springs)
- Another starting problem...
- breaking in engine
- Polygraphite bushings
- Car is running rich at idle!
- What motor is in my car?!?
- suspension
- Dynoed the car today!
- Biggest rims for a 1968 Camaro?
- Super T10...What type of fluid?
- Does anyone make an electric water pump for a 68 Firebird?
- Holley 870cfm "Street Avenger" For Sale.....thread in "For Sale" forum.
- broken valve springs
- 68 Camaro Selt Belt Setup
- 4 speed transmission experts?Help
- Serpentine belt question for
- SBC Message Board
- Porting Performer RPM heads
- SBC exhaust manifolds W/2.5" outlet
- Is it true you about putting a screen in between your intake and carb?
- Car doesn't crank well
- Please help me with my tech questions!
- Please tell me if i'm on the right track!
- Brakes
- Car not running right?!?
- Air conditioning in a 1971 firebird
- Brakes
- Driver/Pass Windows... No Hardware
- Damon and other 406 peeps
- 383 buildup Cam choice
- ignition switch help
- fitting 17x11 in the back
- 1st gen disc swap
- 350 bottom end -- Main bearings
- 1967 camaro sub frame help
- wheel sizes??
- check this out
- howmany peaple here have 1st gen ?
- 4 Bar suspension
- Welcome 2 The 2nd Generation
- th400 problems
- 454 Build Up
- jet question
- Dimensions of 68 camaro
- 72 Camaro
- front clip for 68
- Gas tank filler hose?
- Recommendations for books on shortblock assembly?
- 350 cam, questoins
- 68 RS fenders and lights....
- 4th gen rear brakes onto 67 and up???
- head question
- lowering rear of 67 camaro???????
- Quick Q-Jet question
- I need some help!
- Man, long time no post.
- Kinesis wheels on a 71 bird
- I got new pics!!!!
- Is anybody useing the edelbrock sbc street tunnel ram???
- ign.?
- need info on 79 camaro
- 383, cam selection needed
- Isky better than Comp?
- 68 windshield... how much? need help ASAP
- sound like a sticking thermostat ?
- MustangII suspension question?
- Low Mount Alternator brackets
- New to the "old farts" help me out
- 1981 tranny's
- 68 trans am camaro! what is the body worth
- Smog laws in CA for a 75?
- Tilt Column?
- 68 Gas Tank
- Ss Proof?
- timing question
- i wanna spray, what plugs
- 79 Z28 less motor/trans $1500 lots of new(er) parts
- CD Player In my 78?
- Must sell 1978 Camaro Z28
- 67 Camaro Value
- Newbie
- Value of a 79 Z28
- 71 Z
- Must Sell '78' Z28 - Redford, MI
- Swapping old to new gurus...
- Universal Radiator Brackets
- 393 or 406 which one should I build?
- pic of my car
- Carb choice - Did I screw up?
- need help, about ls1 swap. important
- 1979 T/a
- signs of an intake leak
- X.xx = Xx C.i.?
- Big Block chevy & other stuff for sale
- Gen 1 Projects
- hey... im new...
- 142 & 177
- hood clearance
- The Ls1 Lives!!!!!!!!
- torque converter for sale
- Will these wheels fit??
- Brakes
- exhaust question= borla
- 17in on 78TA
- converting from leaded to unleaded???
- I need some help.
- Paging scooters97ss
- 67 camaro for sale
