Classic Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12
  1. Torque Converter Reccomendation
  2. Restoring 1979 Trans Am
  3. Total timing advance?
  4. What is the width on a 2nd gen rear end?
  5. What is this???? located on firewall behind the distributor
  6. best factory head and intake
  7. starter question
  8. 327 rods?
  9. help with 350 timing
  10. 6 hours left. Thoughts?
  11. Can anyone Identify these heads?
  12. Starter setup
  13. require a tune?
  14. help! need some more low end torque out of 302
  15. Best mods for a 67 RS
  16. help lots of stumble
  17. burning Up Ignition Modules!
  18. motor mount bolts
  19. Video Of The 81 Z At The Track
  20. Bowtie heads...How good?
  21. Vinal Tops
  22. Electric Cut-Outs
  23. Lifting a lowered ride
  24. higher rpm issues
  25. 383 harmonic balancer help.
  26. Timing Trouble
  27. tremec TKO
  28. Semi-Restoration
  29. Where do you guys get your interior parts?
  30. ZZ4 vs. Yearone Powercrate 350 vs...?
  31. '77 Camaro RS LT vs '98 V6 Y87
  32. What do you guys think of this color
  33. What carb to get
  34. interior to a 67 firebird
  35. 1971 Camaro electric fan radiator
  36. Dash Harness
  37. 67 firebird, disc brake conver?
  38. 2.02 vs. 1.94 intake valves
  39. Identify this transmission
  40. found a '75 camaro LT. how much is it worth?
  41. anyone know
  42. Seat Removal
  43. fuel line size?
  44. help with misfiring
  45. 81 camaro rear bumper?
  46. Who modifiys carbs?
  47. Help find 67-69 Camaro
  48. 327 Engine
  49. F/S 67-69 Lower air dam NEW!
  50. 1st Gen Headers - What brand fits best?
  51. roller rocker q
  52. 350 into 95 fourth gen
  53. Power Window Problems
  54. Head suggestions (runner volume & valve sizes) for 327.
  55. Lifters
  56. 1969 camaro ss
  57. a few 355 question
  58. Parachute Mount
  59. old school 355 in 93 camaro, Please Help!
  60. Rebuild or buy new
  61. Strange engine temperature issue...
  62. Headers and gear box question.
  63. How to set static timing on a ECM-controller distributor?
  64. A/C Removal
  65. Dyno'd my 73 Z/28
  66. V6 conversion to V*
  67. Front End Swap On A 1975 Camaro
  68. WTF?! what motor mounts for a 69RS with a 454Big block?
  69. ls1 swap or not
  70. Video of my Nova winning the local burnout contest
  71. 1st Time out!!!!! well kinda.....
  72. What type of engine
  73. Big block
  74. Big block
  75. Casting numbers
  76. Help with my 267
  77. Carb Question...
  78. Cam blowing exhaust out the carb
  79. electric fan CFM needs???
  80. Comp Cams "Nostalgia Plus" N+L79H OR N+30-30H cams?
  81. 3rd gen rear end
  82. Raced my 73 Z/28 last night
  83. Nylon Radiator hose covers
  84. Hypothetical Engine build...
  85. Seized chevy 327
  86. dad's '77 RS. looking for aftermarket valve covers/air cleaner for father's day gift
  87. Gear drive or roller timing chain?
  88. second gen driveshaft?
  89. hei coil
  90. Just thinking out loud about 305 upgrades
  91. Car is BOUNCY after new leaf springs and shocks
  92. Colors???
  93. New To The Boards
  94. shifter cable bracket???
  95. Security System
  96. which set of cam and heads for my engine
  97. Pushrod length?
  98. Carby 327 67?
  99. Headers - 67with A/C
  100. Milodon Bad Part Experience
  101. New SB & BB Heads
  102. Gen I block
  103. Engine not running
  104. engine wont start hot....
  105. Please Help, fuel pressure problesm
  106. roller cam in a non roller 400sbc?
  107. L31 in 85 elcamino and headers.
  108. Oil pump for a sbc 400
  109. Port and Polish
  110. New to the 2nd Gen family
  111. Intermittent Starting Problem
  112. Headers?
  113. Compression question
  114. new engine
  115. 350 Firing order Am I just tired can't remember
  116. NX "Hitman" nitrous kit for sale
  117. how do i make my engine faster for cheap?
  118. 1969 Z28 Block Casting # question
  119. what gears should i put in the rear? 327/m-21
  120. Going into uncharted waters.
  121. engine miss
  122. Posi
  123. Need help about 69 camaro
  124. high hp street muffler?
  125. Will a 78-79 camaro run good with a 383
  126. 80 Camaro exhaust questions
  127. do i need smaller jets? boggs down low.
  128. dyno tune
  129. stock valve size
  130. Engine Whistles at Idle
  131. Decoding Engines - Source?
  132. Good deal to help your flat tappet cam live.
  133. 78 Camaro 350
  134. Adjusting the Timing
  135. just joined
  136. Quadrajet fuel drips
  137. Question
  138. Gear Drive Machining---
  139. 1967 z28 question ??
  140. Carb help
  141. paint question
  142. 327 value
  143. fuel injection fuel system help
  144. 327 vs 350
  145. 3.08 chevy10bolt to 3.90 moser lost 3teths?
  146. 327 , can it use guideplates? ---
  147. another 327 question.
  148. Crank strength question
  149. 350 question
  150. retro fit tpi
  151. "71" 350 into "96" vehicle
  152. Lookin at some new wheels for my 80 Camaro
  153. Need a reliable machine shop in New Jersey
  154. Dash Pad???
  155. BUILD UP what to do on a budget
  156. Brake Cylinders
  157. too smal of a carb?
  158. lunati cam help
  159. how do you make a 377?
  160. 68 Factory Instruction Manual
  161. 1974 Trans Am won't start...
  162. exhaust
  163. 1981 z28
  164. Grill for 81 camaro
  165. best oem rebuild kit
  166. LT1 piston number
  167. Early 2nd Gen in Bay Area?
  168. need help with setting initial timing
  169. Help Please
  170. Suggestions for 305 SB?
  171. Firebird 326ci motor
  172. 1981 Z28
  173. Cowl Induction
  174. smokes
  175. New Big Block Guy
  176. 427 Rat?
  177. blown engine, what can be salvaged?
  178. help finding a part?
  179. ZZ4 upgrade to 1.6RR Dyno Numbers!!!
  180. What motor is this?
  181. What Cam to use?
  182. How to Build a 302 out of a 350 or 327 Block
  183. Late 2nd gen TA as a daily driver?
  184. looking for dual exhaust for 81z28
  185. 10th Ann. Trans Am
  186. Good heads/crank for a blown 67 327? ---
  187. Need help with my motor
  188. Mysterious Valve Tap
  189. Valve Train for High RPM
  190. Need advice on head situation
  191. procharger
  192. fuel in oil
  193. Intake Manifold Gaskets?
  194. proform 750 carb
  195. truck engine and car engine?
  196. Will lt1 heads work on a 72 Malibu 350 block?
  197. Weiand 142 on Pontiac 400
  198. which intake manifold to buy - sbc
  199. Do i really need heat?
  200. oil pressure...
  201. Shifter issue
  202. What model serpentine pulleys to conver 69 camaro?
  203. Built In Coil/Distrib. or Pro-Billet & MSD Blaster 2 Coil??
  204. 383 build recommendations
  205. help w/ a 396 (grinding noise)
  206. 1981 Camaro need help picking engine parts
  207. New motor this summer, time estimates??
  208. wish me luck
  209. 1981 z28 emissions help
  210. blower questions
  211. 79 Firebird Dyno Pull
  212. need carb help with idle mixture
  213. help!!
  214. Need help!
  215. Dual 3" exhaust too much??
  216. help! piston question
  217. Stock block limits?
  218. Fuel Pump on 69
  219. 350 build
  220. Just having fun, theoretical engine build.
  221. 2nd Generation Towing Capacity - Help
  222. SBC Drawings or CAD Files
  223. BBC race motor - newest version rocks!
  224. LT 1 timing tab?
  225. Car steers itself?????
  226. new connecting rod nut?
  227. Gasket question
  228. Old GM part numbers!
  229. convert to V belt or cowl hood? (V6 to SBC swap problems)
  230. I don't know what to do.
  231. new engine
  232. thinking of upgrading
  233. Rough idle when cold
  234. Timing Tab??
  235. power steering adjustment nut leak
  236. Cannot Decide On What CAM!!!
  237. 76 400 w/4sp
  238. Question about Gauge Cluster 1980 Camaro
  239. Anyone have an engine simulation program?
  240. 2 bolt vs 4 bolt
  241. its done, now I want to make it fun
  242. thoughts on engine combo
  243. camshafts
  244. 78 350
  245. 289 build up?
  246. Excellent and free tuning advice
  247. TH-400 trans performance build up. Any specs??
  248. 69 camaro 427 big block
  249. 350 Marine Block
  250. Help me build it..
