Classic Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12
  1. Holley carb help please!
  2. 2" headers with 4-4 1/2" collectors
  3. shifter
  4. shifter reply
  5. body blues
  6. SBC powered Foxbody Q's
  7. Drawback to large fuel line?
  8. selling my once-was project car
  9. Pictures
  10. 1970 Chevelle
  11. 305 Intake???
  12. compatable 78' & 71'
  13. head gasket
  14. blowing oil filters off?
  15. Do we have a 327???
  16. '79 Z28 Help
  17. Does anyone have......
  18. need help with conversion
  19. advice on fuel pump...
  20. Oil System and Valve Train Experts Please
  21. Bell Housing Casting Number
  22. Commander 950 problems
  23. Old Shell, New Engine
  24. B&M shift improver kit
  25. 1968 Camaro headers on 1981 Camaro?
  26. How to Tune for emissions?
  27. 83 z28 with 79 305 wont fire...
  28. Camaro engine in this Corvette?
  29. Freakin Taillights
  30. stock springs
  31. Cam for 454
  32. Storing Aluminum Heads
  33. have a newbie carb question
  34. rust in cylinders, what should I do???
  35. 15x8 Draglites w/3.5 BS in For Sale section
  36. Stall, Gears, Tires?
  37. for those that have swapped in 4l60e's
  38. 1979 trans am mod question
  39. engine out put
  40. Pontiac 301 turbo
  41. 400sbc questions..
  42. Late model pedals in a first gen?
  43. Building a New Motor.
  44. What kind of power should I expect?
  45. Could someone ID this engine for me?
  46. How much is this car worth?
  47. a Blown 540 or a N/A 598???
  48. 1970 K5 lt1 swap
  49. help with march pulleys
  50. Final decission; a Blown 502 from Scoggin-Dickey....
  51. 69 Camaro lowering questions
  52. Need Valvetrain Help. Located in Eastern Ohio.
  53. Fuelie Heads
  54. Power Steering Bracket
  55. 72 camaro stering upgrade?
  56. Holley Specs Needed
  57. 76 SBC iron head ??s
  58. heavy 74 camaro, need help
  59. Anyone ever used/heard the Comp Magnum 292 cam?
  60. Motor and body number match 75 T/A
  61. Lost horn wire
  62. How much power should this combo make
  63. What would it take for me to convert my 67 camaro
  64. Anybody restoring a 1st gen 327 Camaro coupe?
  65. Saginaw Linkages???
  66. I want to build a Z28 engine
  67. engine combo
  68. clone SS
  69. My current Project 81 Z28 Big List
  70. Mi Z-28 1981
  71. Cam selection for a 383 stroker
  72. 1973 Z28, Hedman Header installation, not even.
  73. exhaust water
  74. So my choke wasn't hooked up...
  75. Inline 6?
  76. Stroker Kit Sale
  77. help decode this motor
  78. need help- oil pan/girdle clearance
  79. Tough engine choice
  80. What size Holley on 396?
  81. Need info on 1970 T/A
  82. 1967 camaro 8 track player?
  83. 1967 RS Headlights Not Working
  84. What do you think ????
  85. A new Camaro maybe??
  86. Biggest valves on a 305?
  87. How do you jack up a 2nd gen firebird from the front ??
  88. Advice
  89. fuel cell question
  90. Not F-body Tech but still Classic Tech
  91. 68 ticking and leaking
  92. 1967 camaro questions
  93. What size diff would be on 78 Firebird Formula?
  94. 1967 Camaro RS stats
  95. Where can I find a good twin plate clutch for a Chevy 350?
  96. another cam question
  97. Got some questions about 350/383 engines.
  98. speaking of a 67 RS vert
  99. cooling system problem ideas please
  100. what temp ???
  101. 6 speed in 69 camaro
  102. 69 Camaro rear
  103. your thoughts?
  104. Best carb for a sbc400?
  105. 86 iroc-z
  106. Buick 455 Parts?
  107. Question about 350 in my camaro
  108. '67 327 to buld... need some performance input please
  109. Replacing the rear shocks??
  110. Post pics of your 1st gens, and second gens!
  111. Motor I.D. help..??
  112. secondaries flooding carb
  113. question about casting number
  114. Has anyone have this happen to them
  115. Question on Intake Manifold
  116. Problems with header install on 70RS...
  117. dz302
  118. More Trouble...
  119. Need help with infp on 400sbc heads
  120. 383 370 350 327 Which One?
  121. Any advice for this set-up to gain more power
  122. just got my new intake in for the BBC.... i want to cry
  123. kid needs help wit SB
  124. head numbers
  125. yet another kid Q
  126. easy help
  127. 700R4 in a 2nd gen
  128. 1981 turbo trans am smog pump question
  129. little fun in the driveway
  130. Want to build a BLOWN & SPRAYED 383. NEED HELP!!
  131. Torque sequence and specifications for '69 or '70 350?
  132. What are some good 1st-Gen-only message boards?
  133. Why is one headlight dim and the other bright?
  134. Guess that 383 stroker power numbers?
  135. i have a 69 and 97.... what will fit?
  136. Trying to locate a 400 oem pioneer flexplate
  137. Exhaust Backfire
  138. Small Block Shootout
  139. Power Steering?
  140. Dart Pro 1 heads & matching intake for big block Chevy
  141. Power steering pum parts?
  142. Picking up a spare block
  143. Cam Choices..
  144. oil pressure problems
  145. autometer gauge on 327 SB
  146. 350 Engine
  147. Distributor #1111500
  148. Edelbrock fuel pumps
  149. I'm confused, need help quick
  150. What's a good second gen board?
  151. 1982 Z28 street/strip
  152. no oil to the rockers?
  153. What kind of heads are these??
  154. rocker arm swap gains?
  155. cracked block. Is it fixable?
  156. SBC rods and pistons one each only
  157. 355 street/strip suggestions
  158. e/t
  159. power guess?
  160. WHAT is the ci of my motor lol???
  161. Reuse oil filter for second oil change....ok?!
  162. Scoggin Dickey or Sallee Chev.???
  163. Who has front bumper guards on 68 Camaro?
  164. What Small Block?
  165. Does anybody want some chevy parts?
  166. How to clean and Prep Block 4 paint?
  167. quick Q : power for 10's lol
  168. got a shelby alarm n i love it
  169. compression
  170. 8100 Vortec into something carbed. How?
  171. sbc cam q
  172. Help for someone who sucks at carbs (me)
  173. rebuilt 350 won't start..help
  174. anybody know
  175. ? # 67 Z28 convertable's
  176. Starter bolt problem...
  177. Need help IDing my camaro
  178. Cal-tracs for street.
  179. Low zinc in todays oils = flat tappet wear?
  180. Need 302 parts....
  181. 6.6L Trans Am needs some engine mounts
  182. 700R4 in a 2nd gen
  183. Help with my 327
  184. will 454 fit in 80 camaro?
  185. Non roller motor, can I use roller rockers or lifters?---
  186. Do I need 7/16 or 3/8 studs; 327 ; r. rockers
  187. Seatbelt on a 79 Transam
  188. what you think.
  189. 68 Camaro-- Dash lights went out!!!
  190. New heads and cam suggestion
  191. How much power?
  192. Gen1 454 BBC Short Block Weight?? need a rough estimate.
  193. 327 engin out of a 67 RS.
  194. 69' Camaro with a T-56 Question
  195. '69 Z/28: New and need advice
  196. cam selection question
  197. pipes
  198. Need Another Brain!!! Please Help
  199. has anybody ever....
  200. Will the AR 103 plugs work in my blown 327?
  201. need help please??
  202. ......
  203. Inline fuel pump with mechanical too?!---
  204. Are the 305 and 350 blocks the same?
  205. why?
  206. Gauging interest in new Bird hood
  207. Transmittion Fluid Leakage
  208. Mods for a 67 RS
  209. This thing is really going to SUCK!
  210. Chevy 400 question
  211. help camaro glass trim
  212. mech. or eletric fuel pump?
  213. Just got a 68 RS few ??s
  214. what should I tell my friend?
  215. need some pontaic help
  216. What exhaust is best?
  217. 1969 camaro 454?
  218. starter help
  219. 1969 camaro serial number
  220. Budget Project 350
  221. confusing 70 nova ss starter problem!!!please help!!!!
  222. Bent pushrod?
  223. Holley carb flooding out
  224. 454 Buildup Help
  225. Gasket Ported Stock Heads or....
  226. 500-550 HP out of a 383
  227. How to remove Cam bearing/seal?
  228. Im buying a 400 SBC, question about combo & what heads to use.
  229. 73 trans am
  230. Question for the experts
  231. Timing chain q
  232. Need some carb/ignition tuning advice.
  233. question about a 350
  234. Best place to buy heads?
  235. trans cooler install??
  236. 1979 z28 starter
  237. Cam Help!
  238. Question on my 67! What do you call.......
  239. Performer RPM Heads On A 383
  240. Pitman Arm wont come off!!! Help!!
  241. Who makes good quality rear quarter panels?
  242. I want to change my seats!
  243. got a question on pistons
  244. 454 Big Block for sale
  245. HELP new motor, runs like crap
  246. HELP!! I have no vaccumme!!
  247. Getting my engine home
  248. 455ci Big Block Question
  249. help me on my 750 holley.
  250. Decoding motor again...PLZ
