3rd Gen / L98 Engine Tech
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Need Help passing Cali emissions
  2. Code 33 MAF
  3. Greatest contributer to bad mileage/power loss
  4. LS1 into 3rd Gen????
  5. How 2 Keep From Nosediving
  6. NEW Engine Installed, but Oil Pan is ruined....HELP!!!
  7. Error code question?
  8. HELP! my car won't run longer than 1 hour!
  9. LT1 in an IROC?
  10. 86 IROC 350 TPI swap
  11. Problems after Transgo install
  12. B&m console megashifter
  13. BFG Drag Radials or Nitto's
  14. Holley fuel pump.
  15. T56 bellhousing+153 flw+old block=?starter?
  16. true duals
  17. Help with Chevy Caprice
  18. help !!!!!! brakes!!!!
  19. what 2 chamber muffler produces the best power & sound?
  20. EGR removal '87 TPI 350, hex bolt stripped! Help
  21. VATS!
  22. DMH cutout
  23. What problems will I have with a 383??
  24. 5th Gen Possibility???
  25. how hard to replace front brake lines??
  26. bigger fuel tank/cell
  27. 1 more exhaust question
  28. HELP!!!!!!
  29. Cheap Wheels/Slicks
  30. Went from T5 to th350, what do I need for NHRA to pass my car
  31. What is the actual backspacing on a '84 Camaro?
  32. aluminum driveshaft
  33. Changed header gasket, still ticking
  34. A/C Delete pulley for TBI cars?
  35. Cheapest Driveshaft loop
  36. Need help with Mods on 305?
  37. Got the LT1 cam in, now what?
  38. Full lenght headers, 1 3/4
  39. Iroc parts for sale
  40. Head gasket "shim?"
  41. Freeing up horsepower
  42. 9" ford
  43. What size injectors are in a 92Z 305TPI?
  44. TPI Max HP
  45. Will Comp lifters for '87-up block work on a 400 SB? Need help fast!!!
  46. head gasket??
  47. Car shudders..need hlep
  48. Front tires rubbing!
  49. Non-emission LTs or shorties, who sells?
  50. please help with gettin this car running....
  51. Need help with a 92 Camaro (please)
  52. '90 305 IROC won't start
  53. Best Strut Tower Brace?
  54. Vapor Canister.............
  55. Motor replacement
  56. How much HP does 82-92 camaros have
  57. 5.7" rods for my 400, which to get?
  58. Fuel Pulsator...........
  59. Why does car die when.....
  60. Regulator for TPI to Carb swap
  61. Grill Replacement????
  62. Difference between 84' V6 & 92'V6
  63. Is the Kickdown Cable for TPI different then TBI?
  64. Where can I get tail light covers
  65. Running HOT!
  66. 4th gen 5 spd = 88 GTA?
  67. plug wires VS. headers
  68. 200-4Rs, do they come in 3rd gens and can they hold up
  69. Camaro Superfest!!!
  70. "High Rise spoiler for 85 Z28"
  71. Ram Air on 3rd. Gen
  72. Seat Covers/Floor Mats/ Bra
  73. gauge mounting?
  74. Question about a radiator...
  75. 4th gen Y pipe in '91 RS ?? (LT1 conv.)
  76. exshust -intake ?
  77. Window washer adjustment
  78. cooling fans, need help.
  79. TPI guys, rate your stock air induction!
  80. Looking for a nice 3rd gen to buy
  81. Need help with fans
  82. The best way to tell a 400
  83. Random Technology ram air for TPI...
  84. 15x10s on a '88 firebird
  85. LT1 HEADS ON A 305?
  86. Radiator
  87. tpi setup...
  88. strange noises
  89. HELP!! pulling intake off of a 91Z TPI, what mods can i do?
  90. the hidden joys of working on your car . . .
  91. Alternator won't charge
  92. Anybody running fastburn 385
  93. Regulators????
  94. Need another Guage....?
  95. FS: '86 Z28 only 89,xxx mi excellent condition
  96. ? about splicing into fan sensor for toggle switch
  97. Fiberglass Fenders???
  98. how much of each paint color???
  99. Better heads then Performer RPM
  100. FROM TBI TO TPI
  101. overheating IROC
  102. hooker longtubes and spark plugs?
  103. Timing on Heavily Modded 85 Camaro
  104. s+w subframes and mufflex y-pipe?
  105. 700R4 Question
  106. timing issues?
  107. LT1 Intake
  108. Hood Latch Trouble
  109. 230 CC Dart Iron heads on a 358 sbc.
  110. How much for an A/C for my car?
  111. 1988 FireBird Formula TBI 5.0 5-speed, what to mod?
  112. HELP!!!!!NEED INFO ON AXLES BY TOMORROW. PLEASE HELP!!!!!!!!!!!!!!!
  113. dash watever
  114. not staring plz help
  115. Help! what is best way to mount TPIS AFPR?
  116. oxygen sensor removal
  117. Suspension is Done
  118. 91 z28 engine swap. (like you never saw this before)
  119. Fans don't come on
  120. Emission Tubes
  121. HELP! ok air pump is off, now what to do with the 2 connectors?
  122. Cat Converters
  123. Is this a good price?
  124. L98 parts suppliers or dealers
  125. What Valve Seals?
  126. TBI Nitrous System For Sale.
  127. Any third gen guys looking for rims link inside
  128. Where to send 6AL to have it repaired....
  129. vortec heads??????????
  130. BMW bolt pattern fits on F-Bodies?
  131. Hey irocbob89.....Hows the swap going.
  132. Fiberglass Hoods
  133. Need help FAST!!! Ignition cylinder replacement
  134. how many interested in ram air hood
  135. Spedometer
  136. My Camaro
  137. anyone using an exterior pump
  138. tpi wire harnesses
  139. Upgrading to Roller Cam, what timing chain do I need plus cam button?
  140. help! TPIS afpr on a 91z 305tpi, what is best pressure?
  141. Stupid little ?
  142. runners.......
  143. air cleaners
  144. What a difference!!!
  145. LS1, LS6 swap into a 3rd gen..
  146. head gasket???
  147. 91z 5spd, is it possible to override the speed limiter?
  148. BBk afpr for sale $50
  149. Do trucks have the same style fuel pump?
  150. CAI???
  151. Help w/ tourqe convertors
  152. wheels???????????
  153. T/A motor swap
  154. MY Z IS MISSING
  155. Estimated HP and ET
  156. Cut-Off Exhaust
  157. Slow TBI
  158. Cam swap?????
  159. HELP!!! What should i set the timing at on a 91z 305tpi?????
  160. $hit! didi i set the timing properly....DOH!!!!!
  161. Clutch replacement
  162. which mod should i do 1st intake or exshust
  163. Timing Chain or ?
  164. 1/4 times
  165. What is this noise coming from timing cover...............
  166. Problem..... Damn TPI pain in the F'n A$$.
  167. idle problems.
  168. 84' L69 swap into 88' V6 bird
  169. IROC vs. Z28
  170. 3:73 gears right for me?
  171. How do I tighten the slack in my steering box?
  172. SLP Prom
  173. Speed sensor question ( 90-92 700r4 )
  174. To Much Fuel Pressure?
  175. milage when bought?
  176. 80psi on my oil pressure, help!
  177. hows this?
  178. How Low Can It Go? (Weight)
  179. jumpy fuel pressure
  180. Living with a stick at 17
  181. Brake Booster Question
  182. is it a nine bolt or ten
  183. T-5 tranny swap, igor look in here plz
  184. Are these good prices?
  185. I want an LT1 in my V6 3rd gen! What do I need ?
  186. anyone using an MSD 6AL?
  187. 2.8 to 3800
  188. 3 questions
  189. Hiya, I have a question ^_^
  190. Third Gen. Parts on Long Island
  191. Finally started to tear down the 305... some pictures
  192. 87 Iroc value
  193. Doing a non-SMOG TPI Buildup for my better half's car!!
  194. dripping from inside engine!!!!!!!!
  195. Wiring with an 83 z28
  196. i got a few questions.....
  197. motor swap on a 86 IROC any help would be great!!
  198. sound coming from tranny when downshifting to 1st...anybody?!?!
  199. Do I need a new fuel pump?
  200. Need Advice on Rear End
  201. LT1 In a 3rd. gen T/A ?
  202. TBI 305, 10:1 CR, Vortec Roller Cam.....will it work?
  203. Can you resize a rod with the piston still attached??
  204. Starter issues...please help!
  205. Is a 1986 Camaro any good?
  206. Cold Air or Runners???
  207. The worst thing I have ever seen......
  208. 5 speed L98 ?!!
  209. L98 and manual tranny
  210. I'm a dumba**
  211. Shake, rattle, and roll
  212. 96 exhaust on 84 Z28
  213. brake noise
  214. Is my Cam causing my Problem?
  215. What does this mean ??
  216. How to determine tranny?
  217. transmission leak while car is sitting 3 weeks
  218. Im going to b doing valve seals, is there anything else i should do while im at it?
  219. New Car
  220. WTF?! Why the overheating!!
  221. EGR Intake, what are the holes on the head side for?
  222. FIPK in a 3rd. gen T/A ?
  223. drive shaft????
  224. quick question about a flywheel please help fast
  225. 4 Banger Trouble Shooting help needed !!
  226. Crack and Pop at High RPM's.
  227. Was '89 the year of the Turbo 6 banger??
  228. Can someone tell me........
  229. How important is vacuum advance off carb?
  230. Dynomax Super Turbo Exhaust system
  231. Smoke from Tailpipe......PLEASE HELP??
  232. TBI Buildup!!!!
  233. Help! Where is the build sheet on an 86 Pontiac TA?
  234. injectors size? or options?
  235. Is there a Pontiac equivelant to the IROC or Z28?????
  236. WHERE TO GET CLEAN TA????
  237. Rear brake on fire
  238. HeLp...???
  239. Rocker arms
  240. Distributor Brace Bolt Size?
  241. supercharger????????
  242. how to put back door spring
  243. anyone using or used a digital 6??
  244. Whaddya guys think of this engine combo?
  245. New gears, now car runs funny?
  246. Budget TPI combo....
  247. A Big Resource Needed!!!
  248. Used engines
  249. clutch hydrualics.......
  250. Header Primaries
