3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Comp. Eng. SFC's
  2. Can't get u-joints off driveshaft, Any suggestions?
  3. driveshaft
  4. Who's Running Glass Fenders????
  5. braking noises
  6. Help w/mods
  7. How to check VATS, clutch switch, and ignition switch???
  8. Tired of losing, need cheap speed please!!!
  9. 350 Buildup Need Some Help
  10. Help: Coolant Leak in engine!. Help!
  11. The Theory....
  12. shift problem
  13. opinion on this custom 350?
  14. coil over shocks or lower control arms
  15. is a 455 outa the question?
  16. Spark Plug Change
  17. the worth of subframe connectors??
  18. Wheres the ground wire at for MAF burn-off relay?
  19. backfiring and tach bouncing help!
  20. Side moulding on my 79
  21. mustang guy thinking about getting a camaro... convince me!
  22. 91 Camaro Z28 tranny swap
  23. Stupid Stupid Axles
  24. Squeeky Brakes
  25. vibration
  26. Will plexi t-tops from an 92 firebird fit my 86 camaro?
  27. 87 Iroc-z
  28. tranny swap
  29. rims, what are your thoughts?
  30. clearance
  31. LT4 Cam Question
  32. 405 hp possible?
  33. carb question
  34. Motion Iroc
  35. My SSBC 1 LE setup came in.
  36. Zepher or anyone who put 4th gen door panels in their 3rd gen come in.
  37. t56 transmission.. need input
  38. 305 stroker and other q's
  39. how to determine my offset?
  40. Wiring up Reverse Lights for T56 and more wiring ???
  41. heads and cam
  42. 87 Camaro stalls while idling cold
  43. Core shift? Explain plz
  44. bright lights
  45. Rear speaker access?
  46. Front Cone IROC question
  47. are lt4 springs a direct drop in on l98 heads
  48. need help on 350 buildup
  49. Where Can I Find Seat Material?
  50. Help me tune my PCM for performance
  51. 400 Sbc
  52. Whats the difference between stock or forged pistons and Hyperutectic?
  53. cooling fan relay on '92 RS?
  54. People With long tube headers in here
  55. Combinations for a 350
  56. Main cap girdles for 400 sbc
  57. 1987' speaker dimensions?
  58. Why?!?
  59. TBI->carb swap....tach problems
  60. white gauges for $20.00
  61. GM Restoration Packet
  62. Where would I run the wires from battery in the trunk?
  63. Car won't start b/c transmission.
  64. Autometer A/F guage question....
  65. Code 32 with gutted cat and cutout?
  66. elect cooling fan
  67. 91 RS what to expect?
  68. oil cooler
  69. Compression Ratio question
  70. vette brakes& probducts sport tuned suspension
  71. hooker supercomp headers
  72. Pyrometer...how's it used?
  73. Need some info on muffler choices....
  74. Very Seriously contemplating LG4 to L98(ish) swap... What do I need? Legal In CA???
  75. tranny cooler
  76. Best place to buy carpet!
  77. B&M Console Megashifter.
  78. Which Type of Camaro To buy....?
  79. Buying a chip..
  80. Car having troubles sitting in idle....
  81. tire to speedo?
  82. 342 gear rear end question
  83. Still getting code 43 after replacing ESC module
  84. Steering Wheel
  85. Water pump
  86. 4 into 1 or tri-y's?
  87. Low End vs High End
  88. Rim Question
  89. Whens everyone takin their camaros out???
  90. 87-92 camaro interior
  91. Question for "aziroc"
  92. Starting Problems
  93. intake backfire at 5,500?????
  94. starting problems
  95. Went back to the thirdgen!NO heater though....Little help?
  96. Pics Needed!!!!!! Those With Roll Cages Please Help
  97. Opinions on a mod while I have my engine out
  98. 3grand to spend...
  99. What about these mods
  100. 3.42 gear installation help plz
  101. Starting problems
  102. Will a Long tail th350 bolt up to a 83z28?
  103. How Long
  104. do 3rd gens have frames
  105. Wiper fluid wont come out!
  106. Connecting FAN to ECM
  107. What size Belt when deleting Smog Pump on 91 TPI?
  108. 700r4 compatibilty question
  109. Extra BBK Adj fuel pres reg
  110. fuel injection question?
  111. 4th gen seats
  112. cam selection for 383 Superram TPI
  113. LT1 Rear Disk Brakes on 88 Iroc
  114. gutting emisions?
  115. a while back I asked if anyone would buy a hoodscoop got pics now
  116. Vacuum Hose for Air Conditioner/Heater Selector???
  117. Does abyone make an aftermarket AC flange for headers?
  118. anyone seen or have corvette seats?
  119. what about wheel sizes?
  120. Best way to make 91 rearend into posi?
  121. Which lobe seperation has most vaccum?
  122. tpi setups mass air vs speed density
  123. Starter is Dead
  124. 5.7L 1/4 mile times
  125. Not my original rearend!!!
  126. Subframe Connectors
  127. 5 speed manual trans
  128. Electrical problem...please help!
  129. The 2004 GTO link
  130. Mag Articles on IROC Camaros
  131. proper valve lash?
  132. Car Wont Start
  133. Cold Air Intake?
  134. A/C Compressor Compatibility
  135. Bosch 4+ spark plugs
  136. Wheels, whats your favorite? opinions?
  137. LT1 Guyz in here..
  138. Just Put A 670 Cfm Tb, On A Tbi Setup And Its Running Sluggish
  139. Got my RS today........but
  140. Weatherstripping
  141. sell prices
  142. fumes
  143. Roller cam in old style block
  144. A serious Problem, Needs advice ASAP
  145. borge warner 9 bolt
  146. two questions....
  147. 305 tbi/ there's hope!
  148. Where can youC buy hip Burning Software ?
  149. Tires
  150. anyone run a CC304 in a 305?
  151. How hard is it to put in a cam?!?!?!
  152. Jet Stage 2 Chip
  153. Couple of questions
  154. EGR ?'s and Power adders
  155. k-members?
  156. Mid-Lengths?
  157. Cam
  158. Synthetic or MaxLife oil
  159. New to suspension work need help!!
  160. 4 Fuel Injectors Offline!!! Help!!
  161. radiator
  162. What's your opinion of clear euro tail lights for third gen's?
  163. 87 Iroc-z
  164. Where are a few good places to buy floor pans?
  165. Head sizes
  166. Intake
  167. How to take my Shifter nob off, its stuck
  168. 4th gen Dash in 3rd gen
  169. Turbo400
  170. Running on 6 cylinders
  171. Do we have angle plug or straight plug heads?????
  172. New engine
  173. Do you need to reprogram for a LT1 cam?
  174. Help for a friend.
  175. '72 - '78 305 block in a thirdgen?
  176. I just need to rant about stupid designs on the third gens
  177. Smog pump problems?
  178. Who has a electric exhaust cut out or dump.
  179. For those of you that have Keith Black pistons
  180. fuel pump or ignition module?
  181. Need More
  182. No Choke Carbs?
  183. What size tires
  184. are firebird and camaro fenders and 1/4 panels even remotely interchangeable?
  185. 305 TBI 1/4 mile times? mods?!
  186. 86 Iroc-Z
  187. idleing woes see also my post in wanted section
  188. Nitrous express kit or Procharger kit?
  189. Very quick question. (noob)
  190. caster/camber plates?
  191. valve covers
  192. have a look
  193. EdelbrockTPI or LT1 intake for 383...
  194. How Fast can a 3rd gen go?
  195. leak down test?
  196. Need Help With Motor Project?
  197. 4th gen rearend into 3rd-gn: Q on ride quality
  198. Anyone know where I can get a T-shirt with a 3rd Gen on it?
  199. 3rd gen suspension vs. 4th gen set up...which is better?
  200. 1991 Rs
  201. torque converters
  202. oil pressure
  203. show me your 4in cowl hoods
  204. Rear end woes.
  205. Tremec 3550
  206. motor ?
  207. Bulb replacement
  208. think i could get into the 13's??
  209. Smaller Bearings????
  210. Tires
  211. 18" wheels? likes and don't likes?
  212. who knows about tire sizes?
  213. Why is a Turbo better then a Blower?
  214. Need some opinions on this one
  215. tps sensor
  216. help help!!
  217. Chip
  218. Supercharged TPI 1/4 times
  219. Chips and Ecm and Home Prom Burning
  220. paging mrr23
  221. Best online store for 3rd generation parts.
  222. B&M Mega Shifter install????
  223. Flowmaster exhaust/ interior sound and performance?
  224. T-5 Shifter??
  225. smelling problem
  226. what are some causes for ignition modules going bad?
  227. 6 spd in 87 iroc
  228. Wonder about the condition of my current engine?
  229. Drop Spindles for 3rd generation Camaros
  230. will this work?
  231. High Performance Ignition Pieces
  232. tires, what will fit using 17" wheels
  233. More Exhaust Questions
  234. Blown Head Gasket
  235. What CAM to get for MAP 305TPI car
  236. Would Suicide/Diablo Doors be an easy/cheap idea?
  237. 350heads on305
  238. Engine won't stay started??
  239. car is whinning... HELP?
  240. Reverse Light not working Need Help
  241. Need guages
  242. confused
  243. 87 TPI heads, angled?
  244. Drop E.T
  245. Art Carr 700-R4 Trans-Brake. What do you know?
  246. Need your help!!!!
  247. Which carb would you use??
  248. More Supercharger/Turbocharger info..
  249. Questions about stock suspension layout?
  250. compression test on motor outside of car
