- torque converter
- 700r4 to a t5?
- Anyone Know much about the 1984 olympic edition camaro?
- Painted the calipers chrome today
- what is the difference???
- Tough Decision
- Would 4th gen's SLP catback fit thirdgens?
- 86 TPI 305 problems
- What's a good setup for autocross
- fouling plugs
- wheels
- 24 lbs too much?
- Eibach Drag Launch springs?
- Need a new differential
- Hollow sway bar wall thickness
- torque converter for sale
- ***383 or LT, that is the question...***
- help , pinion angle
- GFX Question.....
- Which Differential Should I Get?
- polishing?????????
- Anyone Need an Aftermarket Waterpump for their TPI,TBI V6?
- Ram Jet 350 anyone??
- Any other cars that use the same rear end size and setup?
- here we go again...
- Indiglo Gauges for 82-89 cars??? (w/145 speedo)
- just got my 350 block!
- 383 sroker and t56 needs and wants
- Car died while driving. Need HELP!
- Rear end swap Drum to Disc--- Pain in the Ass???
- exhaust????
- Any one had this hapen?
- FlowMaster 80 Series Delta Force II catback, interested?
- omg did anybody see PHR tv
- '88 Caprice 350 info??
- spark knock
- Easiest way to put this 12 bolt into my car?
- Check out classified for lots of performance parts cheap
- opinions please!
- What should I do?
- Q: True dual Exhaust
- What the h3ll is a THM700R4?
- Hyd.roller lifters or solid flat tappet lifters
- How do I get my GTA to run faster?
- E-test 383
- '88 tpi engine
- My 1989 Camaro
- How in The heck do i Fix the sagging Headliner on my 84 TA?
- winter beaters
- 153or 168 spline flexplate
- 3rd gen wheel backspacing ???
- silly question
- What to look for in a Camaro...
- How much is my L98 Alluminum heads worth?
- is something wrong??
- 4th gen rear end swap
- Calling 5.7L TPI Guys - I need your measurements
- head light adjustment
- Where to get a Cat Convertor for my 84 Ta? New or slightly used...
- Converting my '84 to EFI: Need a fuel tank?
- Might be getting 400 on sat just had to tell someone
- LG4 350 HO Upgrade.... Is an intank fuel pump the only way???
- Need Mod info on 305 Z
- how much $$?
- 4th gen rear in a 3rd gen
- zexel-torsen differential anygood?
- holley stealth ram?
- Those who have installed carpet--Please come in.
- Losing to Civcs, need help fast
- need your advice again 383 build up
- '82 Z28 prices
- LT1/T56 swap-the best?
- Carburation Intakes
- fastest 5.0
- White Smoke - Full Details - Need Adviser =/
- Detonation sucks.
- est. HP numbers, 383
- need help in indy
- Corvette Heads
- How I ran 14.5 in a STOCK 89...
- What PROM to use?
- To Anyone Who Says Their Camaro Has No Rust!
- wheel and tire combo
- hunting idle
- Heads??
- Would you guys do this?
- can't start car
- I know this doesnt go here but....Im looking for this 3rd gen
- 2 Questions about exhaust
- Dumb would this work question (O2sencor) .
- Help, car is getting really bad gas milage
- Help me finish out my daily driver 3rd gen.....
- Front end issues, what do you think it is?
- Hey Guys. Here!
- Heres a stupid question regarding 4th gen Rearend
- tuning vortec motor
- Does my 87 Trans Am have rear disc or drums?
- Turbo Trans Am
- iroc modifications
- tires??
- Free/Cheap mods for 87 TPI (Vette)
- Motor mount dilema..........
- Bolts Busted...............
- speedo needle going wacky with SGI-5 box and t56
- Iroc Bra
- Door Lock
- LT header clearance
- Need some help with the tact
- clear tail-lights
- is that normal?
- Summit G5000 Cam for TPI
- Tack reads high.
- The right way to set valves?
- 15x5 rims
- Hesitation when cold?
- 86 and 87 Engine Compartments
- Crank Pulley
- 383 cam, bigger or smaller?
- Question for those knowledgeable in the history...
- How accurate are h/p calculators?
- Got head casting #, what do you think?
- Cody Behnke or NE people
- Scerw, Edelbrock.
- 90 GMC truck help.
- ok everyone i need ur help
- LT1 cam specs
- Puddle on the passenger side floor???
- dash problems
- looking for 12sec combos keeping the efi
- 86 LG4, a few questions for you guys...
- 305 to 350 swap- Can I keep it smog legal???
- Brake/Rear defrost problem
- Reading DTC codes
- What about this cam for a 305?
- cam
- Using a TPI (L98 maybe) to make a custom Squarebore EFI
- A GM nightmare
- 87 Trans Am Brakes, easiest ever
- Stealth Ram or LT1 intake?
- Has anyone ever used Accels cam on their TPI?
- Where does this PLUG GO?!?!?!?!
- where is the fuse for the fogs?
- T56 conversion
- 88 camaro gear ratio?
- What's involved in swapping out a 10 bolt drum rear and in a 9 bolt disc??
- Hole In My Dash???
- putting fog lights in 1991 rs
- Need a Cam!!!!!
- Will the rearend from Caprice with 9C1 police package fit my 3rd gen?
- installing miniram
- Water Pump Is it Worth the Effort?
- What tire size is equivalent to:
- Rim Trouble
- start problems
- Does BMR make subframe connectors?
- Idle's for a long time
- PBR rear disc?
- Headers or Cats
- vortec cast heads and vortec tbi manifold
- Anyone ever use GM Top Engine Cleaner on a TBI?
- A4 guys HELP!
- oil guague problems
- I've decided to take the plunge guys!
- Now a Firebird owner + questions
- Bad problems at idle......(please help)
- taking out tpi wiring
- real talk
- need help please!
- Battery very dead wtf
- Clutch Slave cylinders
- LT1 3rd Genners !!!
- 2 simple 3rd gen ?'s
- Car won't pass smog!
- Drop spindles?
- Iroc Stripes
- A.P.E. - 3rd Gen Performance
- I can't do a burnout...
- I got a new front nose but...
- What do you think I can get for my 3rd Gen?
- Im hearing noises.
- 91 RS 350... power?
- Who here has SLP loudmouth in their F body?
- need a cam too!!
- rear end help for my car
- What are the symptoms of a throw rod?
- 350? or is it a 305!?
- Borla catback for my roc?
- Posi rebuild
- Lt1 Cat Back
- race
- how much hp (stock) on a 89 formula, 305 MFI (dual cats)
- 30,000!!!
- A/c, Wtf?
- induction
- stock 2.73s to 3.42s or 3.73s
- Moving the battery to the trunk?
- Whats it worth?
- please help asap whats this worth
- gauges
- Rear end messed up
- LB9 TPS Help
- Net and Gross HP
- Australian 9 bolts
- ugrading 700r4 transmission plz look, i need opinions
- TBI to TPI and a few other Q's
- What plug wires for cars with headers?
- old lifters,new cam?????
- what rear end do i have
- Suspension Question
- engine combo
- weird problem with a surprising remedy
- new cam in 1991 305 RS
- Need a pic of a yellow camaro to paint my car
- Mod Tips
- autometer gauges
- Is it hard to change brake pads?
- tire weight??
- Transmission Temp.
- Looking at at car, what to look for? And some questions.
- how many servos are there in the 700R4 tranny?
- Metalic scraping noise.....
- 86+ Owners
- 3rd Gen Concepts
- Electrical problem or bad battery gage?
- Need Help with water pump removal
- Is this true?
- Car says choke, but still runs....
- exhaust
- problem w/eibach pro-kit
- Guages
- wheel suggestions??
- best bang for your buck...? what are the differences in the models
- INFL REST???
- Hey I haven't posted in here for quite a while...
- dropping 4k into my maro, need advice
- On my world class tranny I have a short throw hurst shifter,set the shiftstop ?
- Starter Problems
- SES codes and questions. HELP!
- horn and cigarette lighter not working..fuse?
- 3rd gen T-top cost?
- Mufflers
- Will 4th gen cat-back work on 3rd gens? B&B Triflow
- 305 power?
- 305 compression?
- Stronger 700R4, new rear, drivetrain?
- blow by
- Springs and Struts Question
- Weird vibration/noise
- dead rs
