3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. tuned port on a throttle body??
  2. which intake
  3. Stroker Kit? Explain to me?
  4. TPI wiring
  5. Comp. Ratio
  6. 9 bolt rear rotor and caliper questions
  7. How to jumpstart my 83 Z28 off my '99 Mirage?
  8. Help Needed!!!! Experts inside!!!!
  9. Stuped question
  10. Hom much advance does computer have???
  11. Maf options
  12. help....
  13. 305 TPI? What's your best E/T?
  14. Hatchback Motor Question...
  15. when did they start putting 350's back in Camaros
  16. Scat cranks who uses them
  17. ?s about my old 3rd gen sitting around...
  18. t-56 swap: use LT1 bellhousing? or aftermarket one?
  19. IROC 3 spoke steering wheel question....
  20. 88 Trans Am F/S
  21. 9 Bolt Posi Needed
  22. Alternatives to the 700r4 in an F-body -- Questions within...
  23. IROC-Z what should I upgrade to?
  24. GM fast burn vs Edlebrock E-tech 200
  25. RamJet on a 5.0L 305?
  26. Thinking about buying a 3rd Gen...
  27. STB....3 or 2 point?
  28. pistons rings
  29. I hate 305 bashers!!!!!!!!
  30. Th700r4
  31. rear end in 1991 RS
  32. Steering Colomn, need help with high-beam switch
  33. Y have my times not improved?
  34. Questions about Compression vs Octane Rating
  35. head ?'s
  36. Now for the 305 Question! :)
  37. A4 Stock 87' Iroc 305 Cam specs?
  38. another head ?
  39. Where is the MAP sensor?
  40. Bought new car!!!
  41. 350TPI Build, LT1, or LS1?
  42. Seat Belt Stuck
  43. Front Window Weather stripping 90 FB
  44. Sprint Springs...?
  45. Needs pics of a rollbar in a 'vert.
  46. Help! What Is Happening?
  47. Joining the F-Body crowd again! '88 IROC
  48. How much HP does a '88 350 TPI IROC have?
  49. BamaZ28, I feel Your Pain
  50. How many 3rd gens here with LT1?
  51. Where can I get fiberglass doors?
  52. Help Help Help (y Pipe)
  53. exhaust
  54. Torque converter
  55. How does one go about locating a vacuum leak?
  56. air pump question
  57. ADVISE PLEASE LOOK INSIDE all THIRD GENS!
  58. Mods
  59. Carb question
  60. Timing?
  61. on & off &on &off......
  62. electrical problem
  63. shift kit?
  64. "Actual" HP on a stock 305
  65. I need some help, buying a IROC.
  66. What is the "Barro" sensor?
  67. How can I find an LT1 engine and comp.
  68. converting 3rd to 4th gen seats and console>
  69. converting 3rd to 4th gen seats and console>
  70. Rocker arms hitting valve covers
  71. true duals
  72. Best places to buy aftermarket mods?
  73. My alternator Just died what one should I get?
  74. Porting intake base, plenum, heads
  75. 305 cam, porting, and stuff... stuff is important you know....
  76. Will 3rd gen and 4th sway bars interchange?
  77. Light under Center Vent??
  78. Who wants my T/A?
  79. slow windows
  80. Central Fl V 6 Owners Inside
  81. What size are the torquex (sp?) bits on the alternator bracket?
  82. Well my baby is away for the winter
  83. Is my tranny holding me back at the track?
  84. Was tpi an option in 91-92 rs camaros?
  85. Hypothetically......
  86. Need some QUICK help PLEASE!!
  87. At the track......
  88. How to drain coolant on 350 TPI?
  89. rear brake lines for 92 camaro?
  90. Best 3rd Gen to get?
  91. Gaskets!
  92. just bought another iroc
  93. Four wheel disc brake upgrade
  94. Overlooked 305
  95. Please help fast 1988 TBI
  96. AUTO or MANUAL
  97. quick starter solenoid question
  98. Crossfire injection on a 82' T/A????????
  99. Any one know what this is?
  100. Camaro vs Lots of different cars?
  101. Ever thrown an alternator belt ?
  102. how much lighter were the 90 and up camaros vs the older ones?
  103. Should I throw a bottle of fuel stabilizer in my Iroc for the winter ?????
  104. Another First!!
  105. LT1/LT4 in my IROC. Has this been done?
  106. 305 TPI guys.....
  107. 3rd Gen Gathering.
  108. Fuel Tank Help
  109. The last question...!!! TOP SPEED!
  110. How much torque does it take?
  111. mufflers
  112. Holly 4BBRL on an 86 305 HO
  113. One hell of an oil leak
  114. V6 T5 gear ratios
  115. need ECM # enlightenment
  116. Oil Pan Survey
  117. Steering Coloum replacment, how difficult?
  118. Where do I find 1LE products???
  119. Car won't start and more
  120. suggestions...."building" a 350 up?
  121. Fuel stabilzer, The car is already away, can I add it to my full tank and start the c
  122. Setting radio clock on '92 Camaro
  123. How much power
  124. What should I do?
  125. Whats the difference between a 92 RS and Z28?
  126. Power Mirror help.
  127. Is this a good price?
  128. Need help with lights!!!
  129. 86 TPI top end on 350 in S10
  130. Question for the cam experts...
  131. Smells like gas
  132. Test Drove Many Camaros!
  133. Where to buy a MAF for a 3rd gen?
  134. Question about nitrous oxide
  135. The I-rocZ's compared to the Z-28
  136. Crossmember bolt size?????????????/
  137. What dipstick??
  138. Saturday Tune-up, anything to watch for?
  139. 383 stroker
  140. compression difference
  141. hooker Long tube question
  142. ????'s on TV Cable
  143. Starter problems
  144. headlight switch
  145. Fuse popping problem, need help bad!
  146. LT1 cam in a 305 iroc??anygood?
  147. Bulletproof 700R4....maybe....need recommendations.
  148. Where Can I Find Adapters
  149. Getting a new speedo?
  150. Throttle stuck? help
  151. Airflow in ducts with different shaped openings
  152. Throttle stuck wide open
  153. Smooth ducting better than corrugated
  154. Question on this rearend
  155. tubular k-member
  156. help what do i need
  157. just got back from the track...
  158. questions about sfc and relocation brackets
  159. Gaskets... anyone using ROL?
  160. Oil Pressure
  161. Clutch for 84 Z28 350
  162. 87' Iroc is a *ucker to work on....
  163. Going From TPI to Holley 4bbl... Have questions....Namely Distributor
  164. Thirdgenners!! firehawk wheels forsale, check it out!
  165. Hard to shift T5 manual trans
  166. Camaro newb :p
  167. bypassing neutral safety switch
  168. a possible new purchase
  169. need new trans
  170. Will my 305 TPI run 13's N/A?
  171. First ever time slip...
  172. how much should i pay?
  173. what is a baro sensor
  174. 700r4 to 5spd
  175. ***89 IROC and dunno wut to do***
  176. heater core replacement
  177. Buying a 1992 Camaro RS v8 6.0L
  178. Subframe connector questions
  179. flexplate on a 1991 RS
  180. OIL Leak, PLEASE READ
  181. All you people that have your HEI figured out
  182. Any times/dyno numbers for supercharged/383 L98?s
  183. It's only a broken moter mount
  184. new pics with clear side markers
  185. IROC questions
  186. I Cant Figure It Out!!
  187. If I have $200 to spend...
  188. 383 Build up
  189. Help with transmissions
  190. Anyone relocate their battery to the rear trunk?
  191. cam
  192. Best guess at HP and TQ for me please
  193. Part Numbers
  194. how much would these cost me?
  195. Please do not leave me beside the road to die!(long road trip)
  196. Flat Spots On Tires
  197. Eibach
  198. Help on 1982 Berlinetta
  199. ls1 3rd gen
  200. k member
  201. Can I use my in-radiator transmission cooler as a PS cooler?
  202. Descreening MAF sensors?????
  203. Chips
  204. Are Spacers Safe?
  205. Any quality GOOD looking aftermarket GFX?
  206. 300RWHP, can the drivetrain/trans handle it?
  207. !!help!! Motor Is Missing!!
  208. Caliper Switch from 1988 to 1982
  209. Whats my 92 camaro rear housing worth?
  210. Projected cost for T56 swap?
  211. Questions about Brake Parts
  212. 89 Camaro running rough
  213. Cam swap results
  214. 83z in the snow
  215. Speedo gears : tire size
  216. TPI miss...please help
  217. Rear end questions
  218. Help With Wiring Of B&m Mega Shifter!!!!!!!!!
  219. 9 inch rearend
  220. 4spd manual to th350 swap??
  221. 4spd manual to th350 swap??
  222. How much for a bare block?
  223. New times but, E.T.-M.P.H. off, what do you guys think?
  224. Advice on a T56 swap
  225. 350 Stroked to 383, bottom end buildup suggestions welcome
  226. anyone have aftermarket brakes??
  227. Crank Height...
  228. need cam help
  229. cai
  230. 5 spd queston
  231. Anybody with 236/242 compcam???
  232. Is buying a 3rd gen worth buying to make fast?
  233. leaking t-tops
  234. Anyone using a Mini-Ram manifold??
  235. stroked??bored??stroker??
  236. Rear hatch release motor
  237. Smog pollution pump
  238. Suggestions......... ???
  239. Anyone have pics of 3rd gens with Torq Thrust II's?
  240. Where in the heck is the ECT sensor.
  241. Need help with rich problem
  242. New front end...where? How much?
  243. !!!Please help me, ignition switch hard??!!
  244. not bad for a 305?
  245. 1982 Camaro Z28----> Is This A Good Car?
  246. 1982 Z28...double hand speedometer.
  247. SB crank questions
  248. 82 Pace Car Value $$$ ???
  249. IRS in 3rd gen??
  250. 87 Z28 running too hot!!!
