3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. motor pulled
  2. Dropped RPMs
  3. How to get Motor Mounts OFF!!!! AHHH!!!!
  4. Disc-brakes
  5. is a 305 a 5.0 ?
  6. Anyone using the Fastburn heads?
  7. Lt1 in 87 iroc...does it work?
  8. 383 stroker
  9. difference between a 5.0 tpi and a 5.0 tbi?
  10. Computer Problems
  11. Need Shifter Handle, Swapping Tremec TKO into Third Gen
  12. Is there an easy way to check fuel lines?
  13. tpi witha high idle
  14. wiring a toggle switch for the fan
  15. Tranny cross member
  16. Best Way to Change Valveseals
  17. How to fix wide open throttle
  18. car uses ALOT of oil
  19. std shift 5 speed
  20. need input 350tpi in 92 rs
  21. good sites? for rebuilt engines?
  22. Nitto's on my 10 bolt?
  23. what tranny is this? 4sp
  24. Weld in sub frame connectors?
  25. Question for those of you with ram air. . . .
  26. Transmission Leak
  27. bad fuel pump? and q's about it.
  28. Automatic hatchback n radio n such
  29. fuel pump relay, and getting power?
  30. For anyone whos pollished there own wheels.
  31. Kid at Christmas!!!!
  32. T56 In 1991 Rs W/ 383
  33. Opinions please... 86 IROC & 92 RS
  34. rebuild
  35. 350 Block identification
  36. 305 TPI to LT1, what parts can I reuse?
  37. Do you have to run fuel into the cabin to have a gauge?
  38. external fuel pump...
  39. Whining Fuel Pump!is That A Bad Thing?
  40. switch form electric fuel pump to mechanical
  41. best 383 stroke rebuild kit?
  42. No Z28?! To Will, and others
  43. How much engine oil?
  44. Please check this out
  45. column replacement
  46. First trip to Houston Raceway Park
  47. Pics of 350 HO Crate
  48. Thinking or dropping TPI and going to carburetion.
  49. Fabricating T-Tops to my camaro
  50. Gr0undFx
  51. Please help with my 86 Z28....
  52. Ls6.....
  53. wahoo it started!
  54. What is the best rear-end out there >?
  55. Whats a "spreadport exhaust" ?
  56. This TPI is pissing me off
  57. What's the best Torque Converter?
  58. Now What?need Help Very Very Fast.
  59. Q about fuelpressure
  60. Need Help Beating A Car!! Please HELP!
  61. 305 in a 2000 S10. Where to get motor mounts?
  62. Need help finding a dash pad
  63. Best plave to get new headlight motor?
  64. 3rd gen conversion
  65. tank Fuel lines (??)
  66. Hello from Las Vegas
  67. is this camshaft too big/small?
  68. '91 camaro conversion
  69. 87 gta trans am
  70. Is there a difference in fenders between 82-90 & 91-92?
  71. V6 to V8 Swap info
  72. Which trailing arms are best for the $$
  73. timing(chain,gears)
  74. Look at this Iroc!!
  75. For Sale? How do I figure a good asking price?
  76. 383 stroker
  77. know a good set of gears?
  78. 4th gen engine crossmember in a 3rd gen?
  79. Need pics of a tubular k member in the car.
  80. Can someone give me a pic or a 3rd gen with true dual exhaust
  81. know a good set of gears?
  82. 383 fuel pressure and timing
  83. lt1 in 3rd gen
  84. whats factory runnin temp on a 84 Z28
  85. How to wire battery in rear well.....
  86. I need help!!!
  87. torque convertor in a BB?
  88. 92 RS-Brights and Dash lights not Operating
  89. ZZ4 Cam
  90. Car wont start when hot!!! Need help!
  91. Th200-4R into a '88 T/A, need help bad!!!
  92. Power falling off at upper rpms...
  93. Tranny Idea. Anyone with a built engine in a third gen look
  94. Anyone know tricks to keep T-Tops from leaking?
  95. Very quick question please answer
  96. Trying to figure out what this connector is?
  97. dual snorkal
  98. diff?
  99. building a sbc
  100. ATTN: Those running the Heddman headers and y-pipe from Jegs...
  101. NEED HELP! 89 TBI won't run!
  102. Which clucth to go with??????????
  103. Trying to Find owner of this car!!!
  104. Third Gen tire sizes that will work ??
  105. Best place to get GM weatherstripping????
  106. Looking for a good water pump
  107. TPI gurus in here please!
  108. Whats your favorite Mods ???
  109. heater core
  110. In the search for low 6's, Any suggestions?
  111. Need help with Oil Pump Installation
  112. exhaust
  113. tanny I know it has been asked
  114. Which suspension package is better "WS6" or "Iroc" ?
  115. trannys
  116. Amber front parking lights ?
  117. How much of a differance would stock l98 heads make on my car?
  118. Shakes
  119. Help with distributer!!!!!!!
  120. Wonder Bar?????????????
  121. 3rd generation rear end
  122. fuel delivery problems
  123. Need Info
  124. Jacking up engine to remove oil pan?
  125. full body kit
  126. Which Sounds better?
  127. engine idles high
  128. Questions about my power curve...
  129. Ignition Module, limits and benefits
  130. 1988 VIN Decoding
  131. Whats the timing set for early TPI's?
  132. heater core...dun dun dun
  133. will factory roller lifters work on Accels High lift cam?
  134. WS6 Center caps
  135. hesitation problems.
  136. How bad is plug install on a V8 RS?
  137. Need help on wheel/Tire size
  138. anyone using an electric water pump
  139. mallory fuel pressure regulator
  140. Disgruntling "pop" coming from front end..... Pease help!
  141. Timing vs. MSD 6AL
  142. Body Restoration
  143. Need some Info on what this spolier is off of!
  144. Intermittent Wiper Function 90FB
  145. Roll Cage, Did you install it?
  146. My friggin luck!!!! and a question!!!!
  147. 350 Motor swap
  148. Anybody know anything about Pro-Am Firebirds??
  149. T-5 Question
  150. sub frame connectors
  151. Help!!!!!!!!
  152. '85 LG4 check engine light on
  153. BEST SOUNDING 3rd Gen
  154. What tranny is in there probably
  155. Crate vs. custom??
  156. Need some help with a leak.
  157. 3Gm 350 HO
  158. Nice Car, but the engine needs new life!
  159. Nice car, but the engine needs new life!
  160. 86 t/a 305 tpi rearend 3.27
  161. Line Lock Install, need help bad!
  162. Headlight/Tail Lights
  163. Tires
  164. Disasembling a TH700R4 with engine torque
  165. Thinking about 89 IROC-Z, have questions
  166. 1987 iroc fusebox, HELP!
  167. is 625cfm to big for a 305?
  168. New engine barely runs...
  169. When braking in a new engine
  170. Hatch Squeek, how to fix
  171. Winter Tires, what size for 16x8" rim?
  172. Update on the new motor!!!
  173. TPI Intake for the GM 350 HO
  174. need a little favor guys.
  175. Rate my new motor!
  176. Getting more mph out of my setup tomorrow...?
  177. edelbrock torque arm owners inside.......
  178. Where can I find a Parts List for 1990 ?
  179. Got car back with LT1 intake on my 305
  180. Converted to non-computer carb setup and aving trans/idle problems..
  181. Can i change my gauges?
  182. Need input on engine.
  183. best way to tell it's 350
  184. Who wants a K-Member?????
  185. Oil pressure
  186. Whoo hoo TPI problem Hasnt Resolved....
  187. 91 speedo w/TH400
  188. Check out the vid for my new motor!
  189. vortec heads on 305?
  190. HEI in my 87?
  191. Burnout Videos I finally got online
  192. FP Reg help bigtime?????
  193. installed the Transgo repgram kit, have questions
  194. Fireballlll!!
  195. Can you convert to 4 bolt mains from 2?
  196. Help!!! Suspension Q's
  197. Gears selection
  198. The on-going saga of my luck!!!!
  199. Slow Signal Lights
  200. Calling all TPI guru's
  201. Car idling awful, bad vibration etc, need help
  202. torque arm bolts
  203. t-56 in a 3rd gen
  204. theory behind my slowness....
  205. Think I fixed the ticking/please confirm my method
  206. camaro weight?
  207. how much could i get for this setup
  208. Which Engine?
  209. Anyone know of any decent 3rd gens in Mich for under $3500?
  210. Do they still make these
  211. is there anyone or any business that stretches rims
  212. Serious Tech Question For Ya'll...
  213. Check ouy MY website (Updated) no popups
  214. AFR flow numbers
  215. Electric Water Pumps, Anyone using one? streetable?
  216. Autometer Triple Guage Install
  217. Tremec T56, T5, TKO Service Manuals within
  218. PLEASE HELP! Odd..... "clicking noise" coming from pass side head area.
  219. tps voltage?
  220. Steering colounm going loose, how to fix it!!!
  221. Single plane intake under the stock hood
  222. Attn.. All 3rd Gens with Strut Tower Braces..
  223. gauges
  224. Motown crate motors
  225. What are all the differences between a 3rd gen IROC, Z28, or RS?
  226. Dumb IROC Z28 question.
  227. What can I stroke this stock block to?
  228. No power steering cooler?
  229. I want a 3rd gen What should I get
  230. Micro Fiche???
  231. running rich
  232. tranny change
  233. Taillight/Brake Light Problem...???
  234. need help with a hood
  235. my buddys 305
  236. whitch gearbox will should I buy?
  237. I hate my starter(s)
  238. Vats
  239. th200-4R into a third gen, how to, is it possible?
  240. Service Engine Soon
  241. anybody use Lt1 mass air on a tpi
  242. 3rd gen part left from parted out car
  243. Help, Headlights Don't Work!!!!!!!!
  244. starting troubles
  245. Holley Stealth Ram Intake
  246. LG4 to L98(or similar 350 TPI) SWAP!!! WHAT IS NEEDED/INVOLVED?????
  247. Shoping list for TH700R4 stuff
  248. Too Cam Or Not Too Cam
  249. Aluminum L98 Heads
  250. Melting question!!!!!
