3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. 87 Z28, Engine dying unable to diagnose
  2. Im bad with tire sizes can someone tell me about how big a BF a P295 50 R15 is?
  3. What do I need to do to lower the front end of my car about 1/2"?
  4. W.T.B. frame for convertible top
  5. heater hose installation
  6. Anitfreeze is dripping on to my passenger side floor.
  7. Car Seems Sluggish Lately..
  8. Anyone have detailed insructions on taking the dash apart?
  9. Cam Button and newer style blocks for roller cams
  10. No/Low Oil Pressure ?/
  11. fouled plugs AGAIN
  12. how fast am i going?
  13. Flames from under the hood!!!!!
  14. E-Tec 1/4 times(finally)
  15. injector connector seal.
  16. ZZ4 for Early 3rd Gens
  17. 3rd gen headliner to 4th gen
  18. Bodykits
  19. Interior
  20. I need to rebuild my 350 how much would it cost me?
  21. Considering 3rd gen Formula - Need help
  22. SFC desing prefrance?
  23. Fan doesn't work, why???
  24. how do i boost up my rs?
  25. thinking of getting a 3rd gen
  26. "That damn trim"
  27. Would my prom unit be causing my computerized 700-R4 to not shift when I want it to?
  28. 89 camaro rs with a 305 tbi dies at stop signs
  29. 89 camaro rs with a 305 tbi dies at stop signs
  30. engine stalling
  31. Anyone ever try to lower your car and it sits higher???
  32. On a 1986 Z28 is the AIR CLEANER the SAME on a COMPUTER controlled Carb as a REGULAR
  33. i have a question about with fbody to pick?
  34. What rear end ??
  35. Air induction ??
  36. color change
  37. HELP! Will an set-up on a 1986 TA Edelbrock headers fit an 84 TA?? help!! READ!!
  38. 1985 Z28
  39. Electrical Problem...Bad FP?!?
  40. Engine plans needed
  41. old nascar model kits bobby allison esc............
  42. My 305tbi RS keeps dieing on me
  43. Is this a factory flaw?
  44. Shift Improver Kits
  45. Coolant Temp Sensor
  46. Timing on a TPI
  47. Can you put the LT1 Stock cam into the L98 TPI?
  48. GTA Floormats?????
  49. Window Deacals??
  50. 91-92 Z28
  51. Will It Start
  52. Something has gone wrong!
  53. budget build ups... what would you do?
  54. Throttle Body Spacer/Heat Insulator TPI
  55. 90 RS ground effects - how do they come off ?
  56. fog lamps
  57. How much could i get for my car.
  58. engine swap v6 -> v8 HELP
  59. I got a small, annoying problem.
  60. Competition Engineering rool cage???
  61. 350 TPI MPG A4 & pricing read this.
  62. Do you know...
  63. What's the factory spring rate for the rear springs?
  64. Might get a 87 Camaro 305 4bbl. Need advice
  65. What Speedo Gear With 3.42's?
  66. 350 build up
  67. 3rd Gen HP Fuel Pump Systems
  68. Am I Being Anal? Catalytic Converter Question
  69. Water Coming from Knock Sensor Hole??
  70. New Engine Knocking with Timing Set at O degrees!!
  71. Convertible Firebird
  72. rough idle, stalling
  73. aluminum heads
  74. now that we've established that only vettes had aluminum heads...
  75. ball joint replacement
  76. 92 Camaro Z28
  77. Who has a big block in their 82-92 Camaro?
  78. I finally ordered my AFR195's for my SBC385
  79. TBI Injector GM5235279*RPD
  80. thinking of selling my 6speed
  81. HELP TRANNY PROBLEMS
  82. storing 1991 camaro rs for winter
  83. hello everyone...please help..im getting desperate...
  84. another question please..
  85. Ran the car after the build, numbers are hard to stomach.
  86. ZZ4 Cam in a 350 with Comp-Controlled Q-jet??
  87. anyone have datamaster?
  88. No Spark at all???
  89. How much of a difference would the K&N filter that bolts onto the TB make?
  90. HELP! ? ! ?
  91. Rear hatch problems.
  92. TPI L98 goes kaputt!!!!
  93. Mini Ram...Whats it worth?
  94. IROC pricing and suggestions
  95. TBI guys in here please
  96. 3rd gen tranny swap...
  97. filling in the wheel wells (17" or 18")?
  98. Trick Flow Heads?
  99. Just bought 88 IROC-Z, 350. Fuel pump Q:
  100. 9" Borg Warner on stock 88 IROC-Z?
  101. 86 coolant temp switch
  102. knocking noise?
  103. Starter Questions.
  104. Lighter t-tops? Plastic possibly?
  105. engine cutting off
  106. How much of a boost would a new ignition be?
  107. Please explain how running rich caused knock
  108. TPI tunnin' ?????????????????????
  109. What would cause my 88 to climb to 2K RPM?
  110. 3rd Gen's With 4th Gen Rears Look Within
  111. Serious Overheating Problem
  112. Will swapping rear-ends interfere with my speedo/tach???
  113. Buying camaro #3
  114. 1990-92 camaro recalls
  115. Roller 305 or a Flat Tappet 350??
  116. Will a LG4 electric fuel pump run a TBI motor
  117. What do you use for rust removal?
  118. Torque converter lockup
  119. What exhuast r u running???
  120. comments?what would some of this cost?
  121. 350 HO Crate!!!!!!
  122. Anyone have Eibach pro kit???
  123. horrible gas mileage
  124. 85'IROC Z28 what kind of engine, trans, rear?
  125. Just bought '86 Z...Any experts on mods?
  126. New Cables & Spark Plugs - Slow to Start
  127. How far can you run rubber fuel lines on a TBI engine?
  128. Exhaust
  129. New to this: What is a good year model?
  130. LCA/Panhard Install
  131. recomendations
  132. rear disc brake swap????
  133. Anyone know about rearends?
  134. SOMONE PUT ME IN THE 14's
  135. New here
  136. 1986 z28
  137. Panhard Bar or Trackbar?????
  138. publications and sponsorship?
  139. Check my list for T56 swap!
  140. 400 sbc buildup option
  141. tach?
  142. Project: slo3 finished pictures...
  143. Knock Sensor gone crazy. PLEASE HELP
  144. adjusting my rear koni yellows...
  145. Looking For gta wheels
  146. thinking about pissing off the wife
  147. window motor question
  148. What Cam for a Stock '92 350??
  149. Rough IDLE Question
  150. Which size headers ?
  151. Really stupid question
  152. 91 Z28 Question
  153. info on a engine swap
  154. ideas on engine mouts
  155. How Much Compression in a Stock '90's 350?
  156. Why New Spark Controller w/ZZ4 Conversion?
  157. How can I raise my HP?
  158. New Engine
  159. top speed
  160. car running hot?
  161. Such a thing as hardtops ?
  162. Idle
  163. HELP! Where to go WIRES/PLUGS for my 84 ta?? anyone?/
  164. Seat Questions
  165. I gotta get up and fix tommorow so I really need advice plz help!!!
  166. Best Prices on Gears
  167. possible cause of shifting problems?
  168. Would a Dual Fan set-up from a 97 V-6 fit my 86 IROC
  169. Idle
  170. 89 engine cleaning
  171. LS1 swap in 92 Z28
  172. T56
  173. ran a 14.4 at E-town with my 305
  174. Will LS1 rear brakes fit on my 84Z....
  175. so how do I get a BBC into a 3rd gen?
  176. Can't shift into Reverse, Help
  177. 91 z advice
  178. LT1 Stroker TT into 85 T/A
  179. Has anyone beefed up a T-5?
  180. Pulls left badly when brakes are applied...HELP
  181. runners and port job.....
  182. how expensive to make a 700r4 handle 500-600hp?
  183. hatch wont lock
  184. engine rebuild
  185. How many CC's are these Heads?
  186. My injectors are not firing
  187. Gauge Install
  188. 91 z28 305 to 350
  189. HOw can I change my Fuel Pump?
  190. Can I change to an out of tank Fuel Pump?
  191. What Casting Numbers for L98 Heads?
  192. radiator cap?does it affect runnin temp????
  193. front turn signals not blinking
  194. est. 1/4 mile times
  195. crankshaft
  196. stroker
  197. possibly putting my 406 in a convertable
  198. GM 350 HO Crate....Which cam to use????
  199. LT1 TB on a TPI???
  200. What is the Lobe Seperation on an '89 L98 Cam???
  201. Why did 3rd gens have so many motor choices?
  202. I smell gas.
  203. How much does a 87 IROC hood go for?
  204. another 3rd Gen for me:D...
  205. Someone talk some sense into me before I put a match in my gas tank.
  206. what's a good chip for a 305?
  207. piston size
  208. Any one know ther stuff on a later model ford?
  209. forged vs hypereutectic pistons
  210. power window switch
  211. bearings
  212. cam swap?
  213. What cars or trucks came with 4 bolt 350's?
  214. Driveshaft
  215. how much hp?
  216. What rear end do I have?
  217. HElP SES light
  218. water pump
  219. Need article from March '95 Hot Rod Magazine
  220. WOT shift RPM for fastchip????
  221. Header clearance?
  222. best headers
  223. camshaft
  224. Everyone who Has put a t-56 or t-5 in a 3rd gen look inside
  225. need some opinions - step in here
  226. Sanderson Headers
  227. fuel pressure regulators for TPI
  228. Bigger tb then a 58mm
  229. Not a 3rd gen but a Chevy
  230. can I swap from hydro clutch to non hydro
  231. where to find out which gears in 9bolt
  232. the right combo?
  233. T-5 To Richmond Super T10 swap. Need different drive shaft?
  234. Extra Capacity Tranny Pan, Worth It?
  235. idle problem
  236. 87 gta trans am
  237. Are after market manifolds worth it?
  238. anyone using msd billit distributor in here plz...
  239. car cuts out
  240. what transmission is behind a 82 6 cylinder??
  241. headers and exhaust for 87 camaro?
  242. 1988 GTA trans-am
  243. Need some info.....GM Crate Swap
  244. timing for 92 305 TPI
  245. witch heads to buy
  246. SDPC vortech base manifold.....
  247. Will '99 S-10 Gears work in my '87 Camaro?
  248. Super ram/mini-ram/or port match intake,plenum,runners?
  249. new 350 block 4.00 bore
  250. cast iron heads
