- A.I.R tubes question,,
- Driver side clearance issue.
- vacuum diagram
- pain in my a$$ a.i.r tubes
- Removing The Thermostat: 305 V8
- coolant temperature sending unit
- Axles for my 84
- wiring info needed
- Has anyone fixed a code 43?
- 89 TPI water pump, long or short?
- Fans not running...
- stalling problems
- 305 tbi to 305 tpi question
- TPI timing or TPS adjustment question....
- changing tranny mount
- Stephanie's getting a makeover...help please
- Show me what you got REVISITED
- Borla exhuast and electric cutout?
- Cold air Intake for 91?
- cold air intake
- New To Muscle Cars. Need Engine Help!
- Lift limit on factory rollers.
- Cooling Fan
- Need reliable 3rd gen in Chicago area.
- tire pressure
- New Here
- Great Motor Combo?
- 1991 Z28 Camaro Owner
- Hello all!
- adjusting the tv cable
- SLP runners
- Please can you help me?
- Low Compression Issues
- 52mm t-body or something similer
- Need Help!!!!!!!!!
- I'm Back and w/ Dyno results!
- What the hell happend?? I thought I would never be in this forum
- drivers door handle 86 camaro
- temp gauge 86 z28
- 84 z28 oil pan leak
- Trying to locate strange oil leak?
- 89 Iroc running rough
- erratic idle
- What should my redline be?
- 91 Z28 Problems, running rough.
- Source for replacement parts?
- 1991 bandit II
- tranny shift points off
- digital dash
- 700R4 won't downsift but upshifts HARD into 2nd.
- Heads Too Big?
- 700R4 speedo gear?
- Looking for L98 Replacement
- 305 stroker
- Talk me out of DD'ing a low mile 3rd gen
- 1988 305 tpi slow to idle down problem
- Own a 3rd gen again. 91 RS w/ 305 looking for some help.
- camaro thats afraid of the rain?????
- My new 92 camaro
- Starter to change ? and other problems
- 91 Z28 Overheating...
- knocking when turning?
- what is my car worth? 1992 350 G92
- looking to sell 1986 z28
- Looking for the right exhuast
- Car Wont Start Or Crank
- 1LE or not?
- Decisions?
- 3rd gen with bad gas mileage.
- Exhaust issues
- steering column help
- Door hinge correction feasability ?
- Long headers
- Just bought 86 z/28, problems?
- 92 Z28
- What holds the 305 back!
- Door handle nightmare
- 92 Z stalls out
- Voltage gauge problem?
- 1982 Camaro Z28 CFI Engine Swap
- Wicked Electrical Short
- what's the best HP combo for a 350
- Vortec TPI to carb. set up ideas
- Are they temp security ignition ?
- Are they temp security to that prevent starter to go ?
- Does this Granatelli MAF for TPI adjust A/F mixture
- z
- 1984 camaro rear end
- Im new and need help
- somebody explain torque converters to me.
- An LSX 427, for my 86
- Smog Equipment & Years ?
- BBK TPI intake
- prompaq?
- paint and style
- wierd tranny problem. maybe im losing my mind
- Crate Engine Repl for L98
- Under drive pulleys
- Carb & Timing issues
- Fuel injector clip
- 305 tbi with 350 crate low on power
- Vibration over 3000 rpm
- Fuel delivery
- 383, AFR heads, HSR, BRE cam dyno'd
- 1988 Firebird fuel system help?
- drivers door problem
- 89 RS Restore & Mod
- 1987 z28
- Need 87 Z28 305 Vacuum Diagram
- Custom large tube MAF sensor for TPI
- Won't start hot
- Help Adjusting TV Cable
- Notice: Installing SLP runners. They don't work with Edelbrock intakes
- TPI or LT1 for 67 Camaro?
- Golen Engine 450 HP TPI: Streetability?
- Timing cover help..
- Lt1 intake on L98
- post pics of Lt1 Conversions
- 1985 TPI IROC issues...
- TPI or Carb?
- Value of 1986 Z28
- Finally finished carb swap
- new swap? Had an idea.....
- trans swap
- cost of a t56 swap
- an ls1 /t56 swap
- Running Hot Issues...
- cheap solution on the t-56 electric to cable speedo?
- Tpi and tbi serpentine
- Horsepower rating
- 91 rs
- what are the stock injecters for 1986 z28
- Question about engines
- 86 ta 305
- Any new best ET's this fall?
- 92 Z28 issue
- Recommendations to increase HP?
- Quick Question
- Trying something New
- 10 bolt strength->98Z28
- 87 z28
- Timing on a 92 L98 at altitude?
- Engine that hasn't been turned on in 2 years...
- 1985 Camaro Z28 5.0 TPI stalling/cuts out
- Backfires......
- Electric fan problem
- Help me ??
- 1985 camaro Z28 Finnally got codes
- Code 45 running rich
- Where to find Hooker Headers?
- 89 IROC L98 wont start cold
- octance recommended for 12:1 compression 357ci sbc
- 1994 work truck 350 TBI, STUMPED,
- Technical Auto Parts Swap Meet Part Question
- Finally, gears for 9 bolt L98 cars
- Hood Clearences with Victor Jr. intake
- 305 TPI to 383 stroker carbed
- 327 tpi
- Vss question?
- eradic idle and missing through out gears
- 85 Iroc-z engine upgrade lots of ?
- crate engine companies that build SPECIFICALLY for the TPI?
- Any interest in 3rd gen turbo kits?
- Solid roller for late model block.
- '88 TPI Intake Manifold - Bastid Year?
- 85 camaro Z-28
- what year?
- K&N Ait Filter & Air Hog Air Filter Users Anyone Hear that Oil Clogs MAF's Etc?
- alot of problems, but no answers.
- GEN 1 engine in a 4th gen?
- diverter valve for the heater core lines
- budget 406ci build
- L98 350 TPI - Fuel Pump PSI rating?
- msd box trying to find tach wire's
- 87 Iroc 305 Sputtering..on throttle
- 305 TPI Issues
- E-tec plugs
- 350 tpi swap into 91 rs
- Can Throttle Position Sensor be cleaned?
- 305 tbi to 350 tpi
- IAC Question
- Direction Needed! - Help - L98 - Teardown
- Fuel Problem
- cam/rocker question L98 mod
- L-98 code 34
- exhaust choices for a 305 tpi
- power steering pump removal
- 305 TPI to ...?
- Buying a 305
- 6-speed in 3rd gen
- tpi heads
- tpi headers
- I need chip help.
- check engine light
- 1989 iroc z with a 305 tpi
- next step
- code checking
- question?
- code 30?
- code 12 and 43
- which clutch for t56 in 2-piece main seal 350 block?
- AFR Eliminator #1040's!
- Code 54 Hard to Start in the Morning
- LT1 vs L98
- need help
- Older 350 in 91 Camaro
- Scoggin Dickey Crate Motor Springs
- Firebird power headlight motor
- code 22 and 44
- knock sensor
- Gutting air boxes?
- 88 GTA, sitting for 6 years, won't turn over
- Help! The Z caught fire on the dyno!!
- I'm Back in a 3rd Gen after 13 years!
- clutch Ques.
- 383 tpi
- 1991 Firebird Problems
- 87 IROC-Z not starting
- Extremely low oil pressure after oil change
- Goodyear F1 GSD3 vs Firestone Wide Ovals.
- Failed Smog, Please help.
- 3.42 0r 3.73 gears
- surgeing idle and stalls
- Cleaning MAF 87 Z28 Question
- 87 Iroc-Z Thermostat question
- 305 TPI 700-R4 TV/detent cable
- Cleaning MAF Question
- Building Twin Turbo 400ci SBC, Need Advice/Opinions
- have a few questions
- im changing from a 305 to a 350 will i need.....
- '89 Intake To '88 Block: Questions Arise/56K Beware
- 85 z28 newbie with questions
- aftermarket tach
- is o2 sensor needed with mechanical carb?
- Loss of power :(
- Desperate for distributor knowledge on 1985 T/A
- smog delete
- A little help, please...
- Knock Sensor Swap?
- valve guide oil leak
- What cam would you run?
- some advice please
- Leather seat option
- Code 54
- 1988 350 L98 2 Bolt Main Torque
- Getting more power out of a tbi 350
- vacume line diagram for 1987 5.7 TPI
- Considering a 91 RS
- Engine sitting for 3 years
