- Did my hatch motor burn out?
- ?? about wiring a 88 camaro
- L98 in a 4th gen
- need guage help
- Vin number help
- info about..
- I cant find a good cold air intake anywhere!!
- Starting problems - 89 5.0 RS Manual
- where is the map sensor?
- 91 5.0L engine upgrades?
- zf 6 speed swap
- 5 speed help no reverse
- Whats the point of a V-6 Camaro?
- Front Caliper mounting bolt
- 1990 L98 hp increase?
- brakes
- Help!!!
- Motor swap
- Help me seal the oil leaks!
- max power for stock TPI pump?
- what is this? not normal is it?
- Whats the best intake manifold??
- oil pan and pump for stroker motor?
- 5 speed help no reverse continued with video!
- OEM Leather seats?
- 1989 Iroc Z 5.7 Automatic
- March Power & Amp Series Pulley Set, 3pc alum
- Super High Idle on Start up
- juss bought a 86 z28 carb..need HELP!!!!
- RPMS high in all gears - Idle at 6000RPM?!
- Which intake and carb combo to get
- fan temp
- Dead
- dart pro1's in place of edelbrock rpm heads?
- Cylinder Heads?
- engine swap???
- Smooth Bellows
- What heads for '87 5.7TPI?
- Vortec LB9
- Do these headbolts go through waterjacket?
- FE3 preformance package
- Hatch Pull Down
- Starting Problems 91 L98
- pegged oil pressure? why?
- Thinking about getting "another" thirdgen
- weird exhaust noise
- Coolant prob
- prom chip holder
- Key'd Hotwire..where? for heated O2
- Rockers for afr 227
- t56 swap problem
- how to replace spark plugs in 92 camaro rs?
- motor mount question?
- Pedal Assembly
- Any Suspension Experts?
- blown after ~3,000 miles!?!
- Got my new crate install home
- 92 Camaro RS help
- New Rearend
- Ticking noise
- Installing U-joint
- Need OE drive shaft measurement
- Who owns this S/ced Red Camaro?
- New Motor Swap:problems! Help!
- L69 sending unit and in-tank pump help
- need a stronger rear
- rebuilt/new engine wont start
- Car overheats with a/c on.......... please help
- Starter problems
- 32 code
- 5-SPD swap on L98
- 92 camaro rs 25th anni. parts
- Need help with code
- Will a 4th gen 10 bolt...
- 1986 Iroc Z question
- running remote solenoid
- Guage mounting ideas....
- idleing high?
- Over Heating and Ticking Noise
- Whats a good rear end?
- Charging system problem??
- what cam/head package should I get
- 91 Z28 5 Speed G92
- Speedo calibration??
- Vacuum diagram?
- Transmission
- Rough Idle
- Rings or Valve seals
- Spark Plugs
- What to do.... What to do....
- chip burning
- What else can I do
- What happened to thirdgen.org
- Help Needed
- Rear License Plate Braket Problem
- Power windows sooo slow
- emissions bypassing???
- e3 diamond tech
- Rust Around Back Window
- Cable attachd to ignition switch in '85
- which spark plugs & gap for my stroker?
- Need some pics of IROCs for a Kocky Shirt....
- what is this engine?
- idle problem
- 1985 IROC z-28 "350"
- Massive Detonation!...or something?..HELP!!!!!
- valve springs help
- 1989 Iroc diferent motor need help
- TPI running rich
- backfire...help!
- Dynoed tuned 305 TBI on the GAS
- can a 305 be built like a 350?
- 84 Z28 HO Tranny Trouble
- wiring diagram for a 86 iroc
- 305 to 305 TPI
- Correcting Speedometer
- 1983 355ci small block
- Best head/cam setup
- wanna add 1.6's to my cam..whatcha think?
- Mat Sensor
- 1991 Z28 46k miles leaking antifreeze into the oil
- Descreened MAF today
- TV cable adjustment
- I have a ignition question for my IROC
- Thermostat leak and tick/clicking noise?
- questions about my 92 firebird
- spacer size for 4th gen wheels
- L98 Engine Problem/Question
- first year for a roller cam?
- whens the best time to set rockers?
- 406 SLP TPI Intake questions....
- 97 lt1 swap into thirdgen using 700r4
- Trap door fuel pump repl. in a third gen ?
- dual gate shifter in a 3rd gen?
- what's the best headers???
- Camaro wouldn't start!
- engine bogging when stepping on gas
- need some HELP lt1 in 3 gen
- Good Platform
- Saggy doorZ
- Idle Help please..
- NEED help choosing cam for tow truck
- 377 question? compression? streetable?
- carb to fuel injected....
- best sound and looks for cat-back
- Anyone use a Megasquirt fuel inj. system??
- fuel pump replacement LT-1
- L98 355 Supercharged combo ???????
- wiring a carburated LT1 in a 1983 camaro
- annoying misfire. can anyone help?
- 1985 fuel pump relay 5.0
- 305 TBI swap to 350 TPI
- What should my combo be good for?
- Car Not Cranking Over - New Battery, No Codes
- lt1 cam?
- 1982 berlinetta gas leak
- engine codes 22 & 32
- Need Help Please!
- Fuel Pressure Regulator?
- Engine Question
- holley 52mmX2 2bbl TBI throttle body ?
- New rims, what the size/dimensions?
- 305 TPI to 327 need help!
- Engine Swap 305 TPI to 327
- problems need help please
- Starter problem or Flywheel problem or what?
- 195CC AFR's vs 195CC TFS vs 113's.
- Oxygen sensor Q: How far from head??
- My 5.7 Just Barely Failed Inspection!! DAMN!!
- about to buy a RS
- 92 Rs 3.1 V6
- ESC (Electronic spark module) 305 to 383?
- Big Block Street Project
- SBC with geardrive
- Lt1 Conversion Into 87' Z-28 Wiring Help Needed!!!!
- Digital Gauges??
- supercharged 305tbi
- I need some insight with a cam for my 305
- New
- Cheap Performance Mods
- springing leaks everywhere..why?
- 350cid distributer help
- Lt1 Swap Throttle Cable Question!!!!
- Modding my 83 305 with CompCam & kit
- Newb
- Bought a 85 Z/28, need info.
- Headers?
- Blower Motor Plastic Housing Removal??
- Hood question
- Are these heads any good?
- Any 3rd gen starters interchange?
- Routed my LT1 ECM harness behind my 3rd gen dash
- drivers side gfx bracket
- Engines
- Dyno Tuner in California????
- weatherstip kits?
- Converting To 383 Need Ecm Help
- im trying to twin turbo an 86 camaro
- Mystery Eibach Springs
- weld Drag lite
- lt1 in 3rd gen
- '89 IROC will not idle
- S & W Race Cars Sub-Frame connectors?
- Fiberglass conversion
- Engine for sale 85, 305 TPI
- 87 t/a motor
- HELP My 84 Z28 WONT START!!!
- Motor mount shot?
- Cold Air for TPI
- Loud mouth fitment?
- Any Body Have An Engine Simulator??!!
- how to get correct speedo reading
- cant find this part anywhere
- long tubes and a complete dual?
- Just wondering?
- 52mm TPI throttle body
- piston trouble
- carpet install
- engine stumbles
- no acceleration?????
- tach peged
- 84 Z28 timing trouble about to set it on fire!
- Help!
- Losing oil pressure under a load
- some questions about headers
- cylinder head opinion
- I need help with getting my 1988 tpi TA to run into the 8"s in 8th mile ?
- Giving away 82-92 light saddle headliner t-top cut out
- 1992 Camaro RS 305 TBI Cheap Mods that add performance?
- Idle mysteriously at random revs over 7000rpm when braking
- posi question
- vibration help??!!
- should i buy this car?
- Cam ? for TPI
- Educate Me
- i have a 89 z28 it wont start when its cold out side
- school bus turbo?
- Hi rpm stumble
- Do factory runner bolts fit SLP runners?
- any advice??
- anybody wanna help me spend my money!!!!!
- My 383 stealth ram build
- External Fuel pump location help!!
- need advice please
- Problem when going full throttle
- accessory mounts
- Here goes Nothing,, PRAY FOR ME
- removing the oil pump shaft?
- lt1 swap ?
