- TPIS Mini Ram WARNING.
- TPIS Mini Ram WARNING!
- L98 w/ ZZ4 H.O cam
- Head CFM v valve lift question
- Car won't start
- Shift kits?
- new mod decision
- Edelbrock is officailly the only aftermarket company making a TPI base...
- Porting an Edelbrock TPI base (pic's inside:56k warning)
- Cam lope?
- guage cluster help after motor swap
- How to choose cam?
- turbo charger for 1988 camaro
- wheel 3rd gen -to- 4th gen???
- Fan Temp Switch to work with 180 thermostat
- L98,s Fan Cooling System Inadaquicies!
- car starts but that's it !!
- I need new tires
- car dies under accleration
- Convert to MAF Type System
- Eagle 383 rotating assembly question????
- 305 to 335 stoker is overloading help and won't start easily
- What to set timing at?
- Come on 3rd gen owners, post!
- cts or tps help
- 1991 GTA Trans Am
- How can I tell which engine is in this car?
- Need Help My 1991 5.7 Z28 Is Running Like Crap!!!
- Lack of power when accelerating
- 87 305 camaro
- Need Help - Oil Pan Replacement
- Need a little help Putting a carburated 350 in my 88 Firebird.
- 88 to 91 ground effects
- L98?s
- oil pan & timing cover ???
- 9.5 Inch Rim width on 3rd gen??
- My Cheap engine build! OPINIONS!!
- Headers???
- Having problems with my car starting
- 87 l98 and 92 l98
- Weekend Work, want input. GTA Cherry Popping.
- head gasket
- 89 iroc with code 33
- 91z stalling out
- A4 to M? in 88 camaro
- Filling my irocs bay with an LT1
- New Sponsor - Fast Toys Performance
- Drum to Disc Brakes
- cold Air intake
- 91 camaro nitrous
- Mac Catback Exhaust Blowout Sale
- Chevy 5.3L in 3rd gen. Has it been done?
- My Car is in Camaro Performers
- 700r4 vs. 383
- Aftermarket Cam With Stock L98 Heads?
- IROC facts/figures book
- rear axle
- 305 tbi to 350 carb swap
- 1985 Corvette TPI Won't Start
- 1985 Corvette TPI Starter Stays On
- what do you think of my engine?
- what needs to be done?
- Older Intake on Ceneterbolt Heads
- serp belts
- 4th gen b pillers?
- Comp Cams XFI268 Results
- Long Tube Headers etc...
- post a pic
- 91 z28 firing order
- Just got 86 iroc , light yellow in color anyone know the paint code ?
- L98 vs LT1
- What You Got? Show Me.
- Carbed Engine ??s
- Engine rebuild kits/ 305tpi
- Gears & Carrier For Car, They Fit?
- Bought crate 350, I need a timing pointer; options?
- 305 tpi on a 350
- What spark plugs do I need for this engine?
- One Month Ago Yesterday...
- Just f'ing wonderful -- POS autozone tool broke in the crank.
- 82 camaro help!
- Dashboard
- Covans Classic complete dash 3rd gen
- harmonic balancer guestion
- Will I Get More H.p From Long Tube Or My Edelbrock Smog Shortys W/ Y Pipe
- help with wiring AC delete box?
- lt1 swap questions
- Starting problem?
- need help with timing
- what I would need to swap a 400 into a 87 tpi 305 car?
- good god
- Cold Air Intake
- Exhaust Size and Engine Temps
- could this be a le1 car?
- fuel pump stoped need help
- hello my old friends, im back, trashing the fuel injection
- honest opinion on body and looks of car
- Oil Guage locked between 375-400
- regaining some luster and shine????
- Fuel pump ?
- New suspension design, new exhaust fabrication pictures
- Suggestions: Upgrading L98 Engine
- Timing Chain Replacement - Oil Pan Removal
- What will this combo produce?
- Cooling fans..
- shock time,, with slicks what do u recommend, what u runnin
- URGENT: Help to Select the RIGHT CAMSHAFT
- bored, reading up on 4th gens, cooling prob???
- 305 TPI or 350 TPI
- Can someone tell me what this code means
- Major undetaking AKA project resurrection!
- Manual fan switch
- 1987 Z28 auto
- Auto to manual tranny swap, possible?
- 91 RS. Engine trouble.
- Tachometer Help 1988 FireBird.
- Night Photos
- Complete torque listing for 350? This Chilton's sucks.
- What gives? NO #1 terminal labled on HEI distributor cap?
- Engine Hesitation after stopping - No Codes
- 305 and 350 same or different knock sensors?
- my new TPI crate engine is popping and wont idle
- Engine Hesitation after stopping - Code 44 Just Popped Up
- Engine codes?
- Starter Solenoid -- "S" or "R"?
- ALDL OBD1 Cable - Anyone use one of these??
- Just sent out an email about a camaro for sale
- lt1 manifold vrs l98
- transmition issue???
- need a lil math help here
- Digital Dash question?
- alternator issues
- Popping fuel out of carb, why?
- tpi hogh idle problem
- 1989 gauge cluster into a 1990 camaro?
- Ecm Or Icm Problem?
- Need GEN 6 DFI Tuning in New Jersey
- WTB cowl hood for bird
- 87 camaro
- Headgasket Headache
- TPI mods, complete w/MISFIRE that WON'T QUIT!!!
- got my Iroc running well kinda
- more power needed
- I'm looking at a 3rd gen...
- L98 Intake Leak
- beehive valve springs 26918 or 26120's
- Cam & Crank Timing Question
- putting together TPI for 82 Z28
- 85 camaro with fresh 383 not going into closed loop
- Anyone have a detailed motor suffix list?
- Putting in new floors
- Buildin a car...
- Engine swaps?
- Carburetors and emissions.
- need a lil help
- I'm Not Sure This is the Right Forum for this Crank Question
- Transmission problem
- Replacing a Fusible Link With a Fuse
- changing oil pan
- Need Help, running REAL ROUGH!!
- Need serious motor advice.Plz help b4 I go nuts.
- DADDY,S GIRL my camaro is such a sweetheart
- hey to everyone
- 1989 Iroc-Z
- Heater core?
- timing problems ?
- Engine idle rough. Need help.
- tpi idle adjustment suggestions
- 1988 formula ws6 m5
- 91 Z28 Ignition Module
- 305 TPI to 350 TPI. I need help
- Running Rough
- Timing
- will stock tach work with HEI?
- Changing steering gear box
- TPI MAS to MAP conversion HELP!!
- what do you think of this combo?
- top dead center...
- 383 stroker flexplate starter issue
- Power windows on 92Z......yep.....they died.
- Sbc 406
- Timing on carbed 350
- Fuel tank question
- This is a neat reference for 3rd gen cars
- Fuel injector question
- 2.8L v6, possible performance upgrades?
- Not sure what to do....
- So, I just bought a 1991 Camaro. . .
- No Front headlights
- 87 2.8 to 350
- GMMP accessory kit
- What causes puffs of smoke on decel?
- 91 Z28 Ls6
- Pic of my IROC
- What is my car worth?
- Need TPI hex bolt in Houston
- 83 Trans Am
- tbi trouble
- someone help please im so annoyed!!
- edl tb for iroc (pn) ?
- my 87 irocz28
- Where does this connector go?
- help car dies 1st -2nd shift?
- 89 Iroc no power to fp or injectors
- Power steering pulley removal?
- 3rd Gen Dual Exhaust?
- Engine rebuilt, Mild Cam, and Headers = LOSS OF TORQUE ???
- 1986 Camaro Z28, 400 Small Block Project
- Looking for 3/4 Shorty SparkPlugs?
- oil problems
- oil problems
- 3rd gen shifter options
- how important is the PCV oil baffle?
- Car is running too hot
- Antifreeze in crankcase
- Gas fumes
- 86 trying to run hot
- 3rd Gen Rear Hatch Won't Close
- there has to be a good shifter
- Rebuild My 305 or Swap for Used 350
- radiator question
- 91-92 door trim
- gas tank sump
- Which car weighs more, 91 RS or 94 Z28
- symtoms of heat soaked starter?
- Replaced intake gasket on LO3, now rough idle at start up??
- Mileage affecting decision
- A/C Clutch Swap
- Anybody using ARP Perma Loc Rocker Arm Nuts?
- Power steering pump-pulley
- twin turbo question
- Got the car Dynoed today
- Car stalls when you put it in gear!
- burnt bands?
- will LS1 LM fit with 3rd gen
- Need master cylinder fitting sizes
- Project: Grey Turd (pics inside)
- junk electronic technology!
- Looking to sell 1986 z28
- Anyone know what could cause this?
- Oil / Antifreeze Problem PLEASE HELP
- hey guys....
- no thirdgen.org right now?
- few pic`s from memorial day
- cold stall, rough runnning
- Pulley speeds
- 1987 iroc needs help
- Need help w/ vaccum hose diagram for a 85 Camaro
