- T56 in 3rd gen?
- Tach reading way too high.
- looking to buy a 383 longblock for my 86 z28
- Im making the dive
- Need help asap
- Tranny/Engine help
- 305 to 350 in 88 IROC
- Heat Shield over muffler... Do I need it?
- Did a camaro come with a 12 bolt from factory
- Distributor off a Tooth?
- Electrical Problems....
- Fuel pump voltage
- Running rough
- Ignition switch woes.
- Biggest noob ever
- Why cant my 1982 Z28 'burn rubber'? (long)
- 4th Gen Rear End Swap
- Need to know FAST, will this exhaust work??
- RPM's running 1300 HIGH
- Power Steering Pump, anyone have this happen?
- Gas mileage V6 Vs. V8??
- rebuild prices?
- RPM, what to shift at
- 89 rs 305
- Dearest third-genners, tis I.. 85_305. I have returned
- Subframe Connector pics plz
- oil pan gasket sealing?
- Cam end play?
- Idling Rough and Running Rough
- Good Deal or No?
- 3rd Geners Help me....
- Lt1 wiring help! Lt1 in 91 z28
- Hedman exhaust 68471
- Missing and Cutting out at 2000RPM
- Cam Choice for 305
- Radiator question!!!
- LT1 In 3rd Gen swap. Wiring write up.
- 350- buy retail rebuild, or do it myself??
- Stock L98 with only exhaust and 1.6rr dyno numbers ...
- problem with my 82 with tpi. help needed
- Re-Gearing the differential???
- Starting Problem 90 Iroc
- Where can I get a door roll pin?
- cam selection
- New Distributor...non HEI
- Worth?
- parts site
- Super Ram 396 Stroker
- possable injector problem
- 86 305 not starting
- Custom Exhaust Idea...Opinions? (Pic)
- radiator plug below cap
- 3rd gen wiring help
- Long Tubes
- Idle problems
- Hooker Headers Full Length..
- 2210's Header gaskets, which ones?
- LT1 Heads on an old SBC
- 1988 IROC Z28 Basic Help Needed
- 4th gen Rear End Swap...
- what's this part?
- I'm Going To Blow Up My Camaro!!
- Clogged cats?
- New Guy Here, opinions/advice wanted.
- Transmission Crossmenber???
- What size edelbrock y pipe should I use? 2.25 or 3 in? how can I mate it to
- lt1 easier swap for a 3rd gen
- Header wrap or spark plug sleeves?
- I have on my shelf R43TS R45TS NGKUR4 &rapidfire #2 which should I use?
- thirdgen.org/
- Head studs or head bolts
- 454 in a 86 f-body
- What is the fuel capacity of a third gen?
- 87 camaro Iroc/ Electronic auto tranny??
- New Best @ M11 Event!
- Kado91z clear your PM box.
- LT1 headers in a 3rd gen
- Winter storage suggestions?
- cam question
- 383/T56 Launch Picture
- Will this engine work in my Camaro?
- 4th gen Rear End Swap - E Brake Cable Needed...
- Which Clutch For my 86 IROC?
- So...I bought a painless wirirng harness.
- changing motor mounts
- AFR head and ARP head bolts?
- TPI very hard to start, very bad idle, stalling.
- Manual Steering Box needed....
- What makes starter 'slow crank' when warmed up?
- Have questions about stock or aftermarket wiring
- Anybody runnin 3" duals?
- 1992 z28 700R4 to Turbo 350 Swap.
- How do I fix the holes in my crossfire hood?
- ground on Aluminum heads?..stupid ?
- '88 IROC Z-28: Several questions
- Best street/strip clutch?
- Needing to take the whole dash apart..
- wiring help
- Putting a 3.9 V8 in a 84 Camaro can it be done? & has it been done?
- my 305 needs help!!!
- Nothing Left To Do But Cry
- Starter fusible link wire, where does it go?
- Whats up everyone?
- Choppy idle, car runs like garbage
- Exhaust Help
- WHat is the name for the exhaust valve on pass side exhaust? how can I remove it?
- True Dual exhaust
- 350 swap
- Moving Back to TX from NY
- 89 305 tpi, wount idle
- Heated O2 sensor questions
- rear end to tranny brace
- Do people stop you and ask to buy your car?
- 5 speed swap
- HELP!!! need advise on my 87 IROC
- Question about LT headers
- project or parts car!
- tpi swap help
- Got my 3rd 3rd gen today !
- How Do I Swap My 85 Ecm With A 88 Ecm
- idiling problems
- Speedo swap
- What happened to My IROC
- Engine Specs
- Problems with "new" cluster
- time for a new clutch...
- Tpi Swap Help Continued
- LT1 swap into '89RS
- Fuel Pump Bad??
- Car stopped afterfiring when I disconect the 4 wire plug that you unhook when seting
- T-Top center bracket?
- looking for some power
- removing unnecessary wiring and electronics...
- 350 Crankshaft In A 305
- TBI flow
- 87 iroc 305 tpi -to- 350
- serpentine pulley set-up for a Chevy 2 Nova
- I Need .....
- charging system
- my engine
- 153 or 168 tooth flywheel?
- Windshield Wiper not Clearing Completely
- building a 305 h.o
- slow cranking
- drivetrain value
- 82 crossfire 305--why won't fuel pump run when ignition turned "on"???
- 5 gen interior in a 3 gen camaro???
- 87 Camaro dash wiring
- Inexpensive shaft mount rocker setup?
- 91 Z starter problems!
- 91 Z starter help
- the whole story
- Carb tuning advice for higher elevations?
- alright, did a motor swap, ran into some probs
- anyone try one of those ebay 'swap harnesses'?
- new guy wants to know
- Building a v8 Small block
- Tune up
- Wondering which to choose.
- Hello, every one-
- 1992 Z28 Convertible5.7 ????
- compass in the console?
- battery drain when cranking
- CS144 alternator - what bracket ?
- How Much Is It Worth 92 Z28 Convertible Heritage Edition
- Camaro ZF? On ebay
- project hate me
- Z28 TPI engine problem
- 91 RX-7 vs 88 iroc
- Harwood 6 inch cowl hood
- sbc
- Junkyard Crawl
- What kind of cam to buy... Please help
- L98 swap into 83 grand prix
- Upper Plentnum Question
- O2 conversion
- but its JUST a 3rd gen..
- Any chips for a 91 tpi350??
- Dual Fan Set Up Question
- ECM/VSS troubles
- '82 pace worth anything?
- Why do my cooling fan wires keep frying?
- timing
- Am i missing anything?
- cam
- AS&M Runners. They have arrived.... (56k warning)
- Need Help! 91 Camaro RS with new 383 engine. No Injectors, No Fuel pump.
- What do i need to do to go to a non CC carb & dist?
- vid of the new motor!!! check it.
- throttle bodies?? whats best?
- TPI build help ..
- 2 Questions
- Harmonic balancer install
- tranny won't shift, WTF???
- Under 1000 dollar HP gains
- Question about certain cams
- 3rd Gen Exploded View Diagrams; Exist?
- Christmas Present for my Dad
- If you had $3000 to spend how would you spend it?
- wiring the TCC
- 383 stroker swap?
- having problems with 305 tpi
- taking the steering column apart.
- I have a question-
- amazing news!!!!!!!!!!!!!!!!!
- Tpi And Lobe Seperation
- Does anyone make Mudflaps for our cars?
- help!..removing bolt from block
- piston ring question
- what kind of cam???
- idle problem
- 454 suburban to irocz
- INTAKE please help
- tpi 350 what to do?
- Any idea on this
- not happy enough with fresh engine cam selection.
- free mods??
- beehive valve spring question?
- Valvespring recommendation?
- Need quick tips -- what to check on a used 3rd gen when buying?
- LS2 wire harness!
- LT1 cam??
- 88 305TBI No Start
- KYB gas-adjust to AGX? shocks/struts
- 1992 Firebird Odometer help?
- Pics of Custom Fabbed Lower Radiator Mounts
- Help!
- Tuned port injection
- tpi 350 prom resources?
- Hooker Long tube headers and mini-starters?
- Indexing front springs..where to put them?
- what makes horsepower?
- 383 Miniram questions.....
- SBC Rear Main Seal Extender?
- Donuts?
- Third Gen Issues... WTF!
- got mechanic?
- Help choosing induction for a stock bottom end.
- cust at high rpm
- Egr
- removing A/C bracket
- stealth ram for sale
- Can you get 500 rwhp from a '88 5.7 TPI?
- Major TPI Guys Look inside!! Need Help!
- Enigne cranking from boot release
- More Swap Questions
- New Third Gen Interior Plastic
- offy intake
- Long tube header choices
