3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48
  1. 1991 air conditioner recharge/upgrade
  2. headers
  3. is an l98 prom the same as an lb9 prom
  4. Can someone help me decide what motor to build?
  5. egr and smog nox
  6. WILL 4th GEN EXHAUST FIT 3rd ???
  7. '85 Vette with 350 TPI, I need some help!
  8. Help! removing IAC
  9. 1982-1992 F-body Turbo II Wing
  10. not a camaro, or even a chevy, but i need help
  11. Z28 won't start today - its raining...
  12. Summit TPI Cam and Lifter Kit - Any Good?
  13. Flowmaster Race muffler on 3rd gen??
  14. Exhaust question...and possibly more
  15. battery gauge sensor
  16. Cam selection for L98 with LT1 intake conversion?
  17. Need a trans. mount for a TH350, know where I can get one??
  18. Anyone running long-tubes with a single exhaust?
  19. dying camaro
  20. Ignition BEEEEEEP and dash light problems. HELP
  21. Ok guys.. T minus 2 and a half hours until I leave...
  22. What type of rearend spec does a '91 Z28 have?
  23. need help with ac compressor clutch wiring
  24. Fuel Injector Clips?
  25. How do I tell what compression I have?
  26. weird starting and idle
  27. Dual Snorkel PICS????
  28. Is there ANYWHERE to get factory floormats?
  29. 1988 9 Bolt onto a 1989 Drum 10 bolt
  30. Where to find TPI wiring harness?
  31. Setting Engine Timing Using Inductive Light Question
  32. Idle is a bit rough...New Catalytic converters
  33. My SLP headers have FINALLY arrived.....
  34. Speed Sensor question.
  35. How do I test for a bad distributor?
  36. Charging Sys problems 87 IROCZ
  37. 350 rebuild
  38. Where can you buy new wiring harnesses?
  39. AIR system
  40. Need some suggestions
  41. How To Install????
  42. maf burnoff relay
  43. car idles like ass on startup only need help
  44. How much gas can you put in?
  45. Supercharging 91 Z28?
  46. 90 RS TBI Problems
  47. 305 build up
  48. Free 1986 Trans am rear hatch near Tampa,Fl
  49. KTRE 12 bolt for 3rd gen Camaro / Firebird
  50. Cooling Problems
  51. Starts and stalls/ rough idle
  52. What's your opinion of Torsen Differentials?
  53. 2-series carrier & 3-series carrier 9 bolt
  54. Convert to serpentine belt
  55. Gta
  56. Cleaning MAF sensor
  57. Supercharger????
  58. 1990 IROC 305 TPI 5-SPD Wont Start
  59. headlights
  60. help! best course of action for multiple fuel related codes?
  61. question 1982 camaro
  62. exhaust setup
  63. which injectors?
  64. Bolting a 6-speed to a 350tpi
  65. running rich
  66. Open air element
  67. since I only post in this section
  68. Poor 90' RS got wrecked today
  69. Brodix for 1000$ or Vortec for 600$?
  70. Gas smell
  71. how much can my transmission handle?
  72. (Another) Cam Selection .452/.465 vs. .503/.510
  73. cam help
  74. my camaro is a freak of nature...
  75. 89 RS Left Front strut tower
  76. Auto Trans in an 1988 Trans Am
  77. Need info on Heads for 383
  78. High Idle, no brakes. Loss of vacuum?
  79. TRue dual side pipes
  80. LT1/LS1 Swap ups and downs....and prices
  81. Which Knock Sensor to Use
  82. Which Knock Sensor to Use
  83. air compressor!
  84. Oil leak
  85. Edelbrock Exhaust
  86. i was wondering
  87. At a standstill with fresh 383 HSR problems...I'm at your mercy
  88. Dual Snorkel...
  89. Power locks and mirrors dont work
  90. code 33 how do I test my MAF sensor?
  91. LG4 or LB9... Does It Matter?
  92. Heads weak link in TPI?
  93. 87 Iroc 5.7L 350TPI
  94. Parting..87 Iroc 350TPI..Parting
  95. Best way to reach computer on 87 Trans Am??
  96. 3rd Gen Camaro 4x4... No Sh!t
  97. Help! Can't get out my driveshaft with Nylon U-Joints!
  98. Carbed 305 in 89 RS
  99. 3 gen question
  100. Voltage drop when A/C is on
  101. best roller rockers
  102. How do I change my coolant in my L98 engine
  103. what heads for 383?
  104. 92 l98 z
  105. l98 mods
  106. got my 90 GTA YAY!!!!, got some questions
  107. Bad fan switch I assume?
  108. Question about 85-86 TPI engines
  109. What type of wheel stud do I need to buy?
  110. Engine Problem
  111. Firebird formula hood bulge decals
  112. Help me with my flywheel
  113. Intermit. starting problems
  114. Relacing 305 in 1991 RS
  115. 32V heads!
  116. flywheel problems
  117. Wierd sound...
  118. Roller Cam Help
  119. New Wheels
  120. 145+ stock?
  121. Help me clean my basement!
  122. Wiring Harness
  123. Why no oil pressure? COuld use some suggestions... PLEASE!!!
  124. What color were my emblems from the factory?
  125. Replacing fuel injectors... please help
  126. How to get out Anchor Pin bolt from rear Drums?
  127. Starting Problems
  128. who wants to play guess what fell out of my motor?
  129. Radle Problem????
  130. anyone tell me about this cam?
  131. IROC & 355 Engine Parts FS
  132. German 3rd gen bodykit
  133. 1987 IROC Test drive video!!!!!!!!!!!!
  134. IROC Steering Wheels
  135. New Exhaust set up on my 92Z28
  136. Vapor Locking My LG4
  137. is it a 305 or 350?
  138. Spacers for SS/ZR1 Rims on a 3rd gen?
  139. HELP ME!! My car idles too high!
  140. confession
  141. can someone help me out with this? compression ?
  142. exhaust
  143. 91 firebird-form tpi 305-5sp stock now tpi 350 help! problems
  144. What upgrades can i do to my suspension??
  145. 91 firebird-form tpi 305-5sp stock now tpi 350 help! problems
  146. 1987 L98 question
  147. 1987 L98 question
  148. 1987 L98 question
  149. engine running rich
  150. Looking for a part!
  151. when is it too much rust?
  152. L98 Prom
  153. 91 rs
  154. When to replace ignition module?
  155. Please Help!!!!!Car Problems
  156. strange ticking noise...???
  157. carbed 383 help
  158. Fuel line questions
  159. Does LT1 throttle body work on an L98 motor?
  160. 85 LG4 Z28/90 L98 GTA , which is faster???
  161. Car shakes and vibrates!!
  162. Cat delete...smog inspection help
  163. Air Lines
  164. Spark Plugs????
  165. fan question
  166. Gutting the cat?
  167. Accel or MSD ignition??????
  168. is this a realistic goal?
  169. Car won't start today
  170. how much nitrous on this engine?
  171. what type of speedometer sensor??
  172. V6 2.6L(89 RS) to V6 3.0L(90 RS) Engine swap
  173. For those with factory radio's
  174. fusible links
  175. high torque starter motors
  176. Going to 17" wheels Pro's/Con's
  177. starter the 350 for the first time...
  178. Anyone have knowledge of "Comp Cams Extreme Fuel Injected Cams"?
  179. 86 TPI Corvette mods..
  180. Lt1 Tb
  181. AIR Removal
  182. Car Turns Off??
  183. What will an IROC be worth in 10 years?
  184. Delay on crank
  185. victor efi and stock ecm
  186. Roots type for TPI?
  187. 350 tbi to 305 tpi ?'s
  188. Horsepower decals
  189. Cam choices for my stealthram'd 383
  190. trouble with TPI and painless
  191. Hesitation problem
  192. Duel fans question
  193. help figuring this out
  194. alittle confused...
  195. need a balancer for my 383 which one? FLUIDAMPR?
  196. v6 to v8 swap
  197. question about t.p.i
  198. Does anyone have True Dual Exhaust on thier 3rd gen?
  199. T56 swappers!
  200. How to remove Heater diverter box?
  201. Instrument cluster wiring diagrams
  202. distributor...
  203. Limited slip? or Posi???
  204. cranks but does not fire
  205. HCI recommendations for my setup.
  206. can u decode this VIN please!
  207. GTO brakes on a 3RD Gen?????
  208. trouble with tpi start
  209. .
  210. rough running
  211. Helping my friend swap a lt1 in his 91 z28
  212. a few questions about my car
  213. 6 or 7 or 8 inch balancer for 383?
  214. cc306
  215. HELP WHIT remote mount turbo system IN MY TIRD GEN
  216. 2nd-3rd gen project car
  217. Harmonic balancers effect on engine revs!!!!
  218. Corvette L98 or a 305 TPI, which do I go with?
  219. true duals?
  220. Heads cc chamber size???????
  221. Wide body kit/what do you think??
  222. stock 350 tpi 1/8 run
  223. any significant differance between long tubes and shorties?
  224. Mini ram vs. Holley stealth ram
  225. My 89 iroc has a hot starting problem?
  226. Worth Fixing?
  227. Looking to buy an 83 Z28. Questions.
  228. need manual tranny options that can handle a 383
  229. Are all air dams for 82-92 F-body the same PN?
  230. stumbles when cold, CANT FIGURE IT OUT!!!
  231. Vent Question..........
  232. 89 iroc z trans
  233. 92 305 to 350 swap
  234. VSS Code 24
  235. hatch pull down motor problems.
  236. Brake Conversion Question
  237. Metric or Standard bolt?
  238. 1984 camaro steering column?
  239. Choke Problem?
  240. please read..thanks
  241. Gaskets for a 3970010 block?
  242. 2 piece timing cover? which one?
  243. TH350 modulator line
  244. 1990 Camaro question
  245. Gak! Running to rich, no idea why
  246. Where do the rods that run down the column to the ignition switch go?
  247. exhaust/headers question
  248. Let me know if this exhaust idea will work!!!
  249. Fuel Pump
  250. one wire alternator question
